[GRASS-SVN] r48732 - in grass/trunk/temporal: . t.info tr.aggregate tr.extract tr.list tr.series
Tue Oct 11 09:51:45 EDT 2011
Author: huhabla
Date: 2011-10-11 06:51:45 -0700 (Tue, 11 Oct 2011)
New Revision: 48732
Added:
   grass/trunk/temporal/tr.list/
   grass/trunk/temporal/tr.list/Makefile
   grass/trunk/temporal/tr.list/test.tr.list.sh
   grass/trunk/temporal/tr.list/tr.list.html
   grass/trunk/temporal/tr.list/tr.list.py
   grass/trunk/temporal/Makefile
   grass/trunk/temporal/t.info/t.info.py
   grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh
   grass/trunk/temporal/tr.aggregate/tr.aggregate.py
   grass/trunk/temporal/tr.extract/tr.extract.py
   grass/trunk/temporal/tr.series/tr.series.py
New strds list module. Minor fixes in several temporal modules.
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/Makefile	2011-10-11 13:51:45 UTC (rev 48732)
@@ -9,6 +9,7 @@
 	t.time.rel \
 	tr.aggregate \
 	tr.register \
+	tr.list \
 	tr.series \
 	tr.extract \
 	tr3.register \
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/t.info/t.info.py	2011-10-11 13:51:45 UTC (rev 48732)
@@ -24,7 +24,7 @@
 #% key: dataset
 #% type: string
 #% description: Name of an existing space time or map dataset
-#% required: yes
+#% required: no
 #% multiple: no
 #%end
@@ -47,6 +47,12 @@
 #% description: Print temporal relation matrix for space time datasets
 #%end
+#%flag
+#% key: s
+#% description: Print information about the temporal DBMI interface and exit
+#%end
 import grass.script as grass
 import grass.temporal as tgis
@@ -59,12 +65,25 @@
     type = options["type"]
     shellstyle = flags['g']
     tmatrix = flags['t']
+    system = flags['s']
-  # Make sure the temporal database exists
+    # Make sure the temporal database exists
     tgis.create_temporal_database()
     #Get the current mapset to create the id of the space time dataset
+    if system:
+        #      0123456789012345678901234567890
+        print " +------------------- Temporal DBMI backend information ----------------------+"
+        print " | DBMI Python interface:...... " + str(tgis.dbmi.__name__)
+        print " | DBMI init string:........... " + str(tgis.get_temporal_dbmi_init_string())
+        print " | SQL template path:.......... " + str(tgis.get_sql_template_path())
+        print " +----------------------------------------------------------------------------+"
+        return
+    if not system and not name:
+        grass.fatal(_("Please specify %s=") % ("name"))
     if name.find("@") >= 0:
         id = name
     else:
Modified: grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh
--- grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/tr.aggregate/test.tr.aggregate.sh	2011-10-11 13:51:45 UTC (rev 48732)
@@ -15,7 +15,7 @@
 r.mapcalc --o expr="prec_6 = rand(0, 650)"
 t.create --o type=strds temporaltype=absolute dataset=precip_abs1 gran="3 months" title="A test" descr="A test"
-tr.register -i dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+tr.register --v -i dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
 # The first @test
 # We create the space time raster datasets and register the raster maps with absolute time interval
Modified: grass/trunk/temporal/tr.aggregate/tr.aggregate.py
--- grass/trunk/temporal/tr.aggregate/tr.aggregate.py	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/tr.aggregate/tr.aggregate.py	2011-10-11 13:51:45 UTC (rev 48732)
@@ -82,7 +82,7 @@
     print where
-    rows = sp.get_registered_maps(where, "start_time", dbif)
+    rows = sp.get_registered_maps("id", where, "start_time", dbif)
     if not rows:
         return None
@@ -107,7 +107,10 @@
+    # We need a database interface
+    dbif = tgis.sql_database_interface()
+    dbif.connect()
     mapset =  grass.gisenv()["MAPSET"]
     if input.find("@") >= 0:
@@ -118,11 +121,9 @@
     sp = tgis.space_time_raster_dataset(id)
     if sp.is_in_db() == False:
+        dbif.close()
         grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
-    dbif = tgis.sql_database_interface()
-    dbif.connect()
     sp.select(dbif)
     if output.find("@") >= 0:
@@ -132,20 +133,22 @@
     # The new space time raster dataset
     new_sp = tgis.space_time_raster_dataset(out_id)
-    if new_sp.is_in_db():
+    if new_sp.is_in_db(dbif):
         if grass.overwrite() == True:
             new_sp.delete(dbif)
         else:
+            dbif.close()
             grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
     granularity, temporal_type, semantic_type, title, description = sp.get_initial_values()
     new_sp.set_initial_values(gran, temporal_type, semantic_type, title, description)
     new_sp.insert(dbif)
+    rows = sp.get_registered_maps("id,start_time", where, "start_time", dbif)
     if not rows:
+            dbif.close()
             grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
     # Modify the start time to fit the granularity
@@ -222,8 +225,8 @@
             new_sp.register_map(new_map, dbif)
-        # Update the spatio-temporal extent and the raster metadata table entries
-        new_sp.update_from_registered_maps(dbif)
+    # Update the spatio-temporal extent and the raster metadata table entries
+    new_sp.update_from_registered_maps(dbif)
     dbif.close()
Modified: grass/trunk/temporal/tr.extract/tr.extract.py
--- grass/trunk/temporal/tr.extract/tr.extract.py	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/tr.extract/tr.extract.py	2011-10-11 13:51:45 UTC (rev 48732)
@@ -117,7 +117,7 @@
     new_sp.set_initial_values(granularity, temporal_type, semantic_type, title, description)
     new_sp.insert(dbif)
     if rows:
 	num_rows = len(rows)
Added: grass/trunk/temporal/tr.list/Makefile
--- grass/trunk/temporal/tr.list/Makefile	                        (rev 0)
+++ grass/trunk/temporal/tr.list/Makefile	2011-10-11 13:51:45 UTC (rev 48732)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = tr.list
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/tr.list/test.tr.list.sh
--- grass/trunk/temporal/tr.list/test.tr.list.sh	                        (rev 0)
+++ grass/trunk/temporal/tr.list/test.tr.list.sh	2011-10-11 13:51:45 UTC (rev 48732)
@@ -0,0 +1,25 @@
+# This is a test to list raster maps of a space time raster dataset
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create a space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute dataset=precip_abs1 gran="1 senconds" title="A test" descr="A test"
+tr.register -i dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="2 months"
+t.info type=strds dataset=precip_abs1
+# The first @test
+tr.list -c input=precip_abs1
+t.remove type=strds dataset=precip_abs1
+t.remove type=raster dataset=prec_1,prec_2,prec_3
+t.remove type=raster dataset=prec_4,prec_5,prec_6
Added: grass/trunk/temporal/tr.list/tr.list.html
Added: grass/trunk/temporal/tr.list/tr.list.py
--- grass/trunk/temporal/tr.list/tr.list.py	                        (rev 0)
+++ grass/trunk/temporal/tr.list/tr.list.py	2011-10-11 13:51:45 UTC (rev 48732)
@@ -0,0 +1,142 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	tr.list
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	List registered maps of a spae time raster dataset
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: List registered maps of a spae time raster dataset
+#% keywords: dataset
+#% keywords: spacetime
+#% keywords: raster
+#% keywords: list
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of a space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: sort
+#% type: string
+#% description: Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets
+#% required: no
+#% multiple: yes
+#% options: id, name, creator, mapset, temporal_type, creation_time, start_time, end_time, north, south, west, east, nsres, ewres, cols, rows, number_of_cells, min, max
+#% answer: start_time
+#%end
+#%option
+#% key: columns
+#% type: string
+#% description: Which columns should be printed to stdout. Columns number_of_maps and granularity only available fpr space time datasets
+#% required: no
+#% multiple: yes
+#% answer: name,mapset,start_time,end_time
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: A where statement for selected listing e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: The field separator character between the columns, default is tabular "\t"
+#% required: no
+#%end
+#%flag
+#% key: c
+#% description: Print the column names as first row
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+    # Get the options
+    input = options["input"]
+    columns = options["columns"]
+    sort = options["sort"]
+    where = options["where"]
+    separator = options["fs"]
+    colhead = flags['c']
+    tgis.create_temporal_database()
+    mapset =  grass.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = tgis.space_time_raster_dataset(id)
+    if sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+    sp.select()
+    rows = sp.get_registered_maps(columns, where, sort, None)
+    # Print the query result to stout
+    if rows:
+        if separator == None or separator == "":
+            separator = "\t"
+        # Print the column names if requested
+        if colhead == True:
+            output = ""
+            count = 0
+            collist = columns.split(",")
+            for key in collist:
+                if count > 0:
+                    output += separator + str(key)
+                else:
+                    output += str(key)
+                count += 1
+            print output
+        for row in rows:
+            output = ""
+            count = 0
+            for col in row:
+                if count > 0:
+                    output += separator + str(col)
+                else:
+                    output += str(col)
+                count += 1
+            print output
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/temporal/tr.list/tr.list.py
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py	2011-10-11 13:26:10 UTC (rev 48731)
+++ grass/trunk/temporal/tr.series/tr.series.py	2011-10-11 13:51:45 UTC (rev 48732)
@@ -91,7 +91,7 @@
     sp.select()
-    rows = sp.get_registered_maps(where, sort, None)
+    rows = sp.get_registered_maps("id", where, sort, None)
     if rows:
         # Create the r.series input file
