[GRASS-SVN] r48733 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Tue Oct 11 09:52:39 EDT 2011
Author: huhabla
Date: 2011-10-11 06:52:39 -0700 (Tue, 11 Oct 2011)
New Revision: 48733
grass/trunk/lib/python/temporal/abstract_datasets.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/core.py
Use gisenv variables to select the temporal database backend at runtime.
Modified: grass/trunk/lib/python/temporal/abstract_datasets.py
--- grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-11 13:51:45 UTC (rev 48732)
+++ grass/trunk/lib/python/temporal/abstract_datasets.py 2011-10-11 13:52:39 UTC (rev 48733)
@@ -341,6 +341,7 @@
self.set_relative_time(start_time, end_time)
self.relative_time.update_all(dbif)
self.base.update(dbif)
+ dbif.connection.commit()
if connect == True:
dbif.close()
@@ -375,7 +376,10 @@
connect = True
if self.is_in_db(dbif):
+ # SELECT all needed informations from the database
+ self.select(dbif)
# First we unregister from all dependent space time datasets
self.unregister(dbif)
@@ -394,6 +398,7 @@
self.base.delete(dbif)
self.reset(None)
if connect == True:
dbif.close()
@@ -428,6 +433,8 @@
# the map has been unregistred
stds.update_from_registered_maps(dbif)
if connect == True:
dbif.close()
@@ -604,7 +611,7 @@
obj_list = []
- rows = self.get_registered_maps(where, order, dbif)
+ rows = self.get_registered_maps("id", where, order, dbif)
if rows:
for row in rows:
@@ -617,11 +624,12 @@
return obj_list
- def get_registered_maps(self, where = None, order = None, dbif=None):
+ def get_registered_maps(self, columns=None, where = None, order = None, dbif=None):
"""Return sqlite rows of all registered maps.
Each row includes all columns specified in the datatype specific view
+ @param columns: Columns to be selected as SQL compliant string
@param where: The SQL where statement to select a subset of the registered maps without "WHERE"
@param order: The SQL order statement to be used to order the objects in the list without "ORDER BY"
@param dbif: The database interface to be used
@@ -645,7 +653,10 @@
else:
map_view = self.get_new_map_instance(None).get_type() + "_view_rel_time"
- sql = "SELECT * FROM %s WHERE %s.id IN (SELECT id FROM %s)" % (map_view, map_view, self.get_map_register())
+ if columns:
+ sql = "SELECT %s FROM %s WHERE %s.id IN (SELECT id FROM %s)" % (columns, map_view, map_view, self.get_map_register())
+ else:
+ sql = "SELECT * FROM %s WHERE %s.id IN (SELECT id FROM %s)" % (map_view, map_view, self.get_map_register())
if where:
sql += " AND %s" % (where)
@@ -669,6 +680,8 @@
def delete(self, dbif=None):
"""Delete a space time dataset from the temporal database
+ This method removes the space time dataset from the temporal database and drops its map register table
# First we need to check if maps are registered in this dataset and
@@ -683,8 +696,12 @@
dbif.connect()
connect = True
+ self.select(dbif)
+ core.verbose(_("Drop map register table: %s") % (self.get_map_register()))
if self.get_map_register():
- rows = self.get_registered_maps(None, None, dbif)
+ rows = self.get_registered_maps("id", None, None, dbif)
# Unregister each registered map in the table
if rows:
for row in rows:
@@ -692,9 +709,10 @@
map = self.get_new_map_instance(row["id"])
self.unregister_map(map, dbif)
try:
- # Drop remove the map register table
+ # Drop the map register table
sql = "DROP TABLE " + self.get_map_register()
dbif.cursor.execute(sql)
except:
if connect == True:
dbif.close()
@@ -791,31 +809,18 @@
else:
except:
- try:
- # Drop stds register table
- sql = "DROP TABLE " + map_register_table
- dbif.cursor.execute(sql)
- except:
- if connect == True:
- dbif.close()
- core.error(_("Unable to drop table <%s>" % (map_register_table)))
- raise
- try:
- if dbmi.__name__ == "sqlite3":
- dbif.cursor.executescript(sql_script)
- else:
- dbif.cursor.execute(sql_script)
- except:
- dbif.close()
- core.error(_("Unable to create the space time %s dataset register table for <%s>") % (map.get_type(), map.get_id()))
- raise
+ if connect == True:
+ dbif.close()
+ core.error(_("Unable to create the space time %s dataset register table for <%s>") % \
+ (map.get_type(), map.get_id()))
+ raise
# Set the stds register table name and put it into the DB
map.set_stds_register(map_register_table)
map.metadata.update(dbif)
- core.verbose(_("Created register table <%s> for %s map <%s>") % (map_register_table, map.get_type(), map.get_id()))
+ core.verbose(_("Created register table <%s> for %s map <%s>") % \
+ (map_register_table, map.get_type(), map.get_id()))
# We need to create the table and register it
if stds_register_table == None:
@@ -839,49 +844,20 @@
else:
except:
- try:
- # Drop map register table
- sql = "DROP TABLE " + stds_register_table
- print sql
- except:
- dbif.close()
- core.error(_("Unable to drop table <%s>" % (stds_register_table)))
- raise
- try:
- else:
- except:
- dbif.close()
- raise
+ dbif.close()
+ raise
- # Trigger have been disabled due to peformance issues while registration
- ## We need raster specific trigger
- #sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
- #sql = sql.replace("GRASS_MAP", map.get_type())
- #sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
- #sql = sql.replace("SPACETIME_ID", self.base.get_id())
- #sql = sql.replace("STDS", self.get_type())
- #sql_script = ""
- #sql_script += "BEGIN TRANSACTION;\n"
- #sql_script += sql
- #sql_script += "\n"
- #sql_script += "END TRANSACTION;"
- #dbif.cursor.executescript(sql_script)
# Set the map register table name and put it into the DB
self.set_map_register(stds_register_table)
self.metadata.update(dbif)
- core.verbose(_("Created register table <%s> for space time %s dataset <%s>") % (stds_register_table, map.get_type(), self.get_id()))
+ core.verbose(_("Created register table <%s> for space time %s dataset <%s>") % \
+ (stds_register_table, map.get_type(), self.get_id()))
# Register the stds in the map stds register table
# Check if the entry is already there
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2011-10-11 13:51:45 UTC (rev 48732)
+++ grass/trunk/lib/python/temporal/base.py 2011-10-11 13:52:39 UTC (rev 48733)
@@ -199,7 +199,7 @@
self.table = table # Name of the table, set in the subclass
if database == None:
- self.database = get_grass_location_db_path()
+ self.database = get_temporal_dbmi_init_string()
else:
self.database = database
self.ident = ident
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2011-10-11 13:51:45 UTC (rev 48732)
+++ grass/trunk/lib/python/temporal/core.py 2011-10-11 13:52:39 UTC (rev 48733)
@@ -24,21 +24,47 @@
import copy
from datetime import datetime, date, time, timedelta
import grass.script.core as core
-# The import should be decided by grass environmental variables
-import sqlite3 as dbmi
-#import psycopg2 as dbmi
-# Needed for dictionary like cursors
-#import psycopg2.extras
-def get_grass_location_db_path():
+def get_temporal_dbmi_default_path(grassenv):
+ dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
+ dbpath = os.path.join(dbpath, "PERMANENT")
+ return os.path.join(dbpath, "grass.db")
+# The chosen DBMI backend can be defined on runtime
+# Check the grass environment before import
+grassenv = core.gisenv()
+if grassenv.has_key("TDBMI"):
+ if grassenv["TDBMI"] == "sqlite3":
+ import sqlite3 as dbmi
+ elif grassenv["TDBMI"] == "psycopg2":
+ import psycopg2 as dbmi
+ # Needed for dictionary like cursors
+ import psycopg2.extras
+ else:
+ core.fatal(_("Unable to initialize the temporal DBMI interface: %s. \nPlease set g.gisenv set=\"TDBMI=sqlite3\" or g.gisenv set=\"TDBMI=psycopg2\"") % grassenv["TDBMI"])
+else:
+ # Use the default sqlite variable
+ core.run_command("g.gisenv", set="TDBMI=sqlite3")
+ core.run_command("g.gisenv", set="TDBMI_INIT=%s" % get_temporal_dbmi_default_path(grassenv))
+def get_temporal_dbmi_init_string():
+ grassenv = core.gisenv()
- grassenv = core.gisenv()
- dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
- return os.path.join(dbpath, "grass.db")
+ if grassenv.has_key("TDBMI_INIT"):
+ return grassenv["TDBMI_INIT"]
+ else:
+ return get_temporal_dbmi_default_path(grassenv)
elif dbmi.__name__ == "psycopg2":
- return "dbname=grass_test user=soeren password=abcdefgh"
+ else:
+ return "dbname=grass_test user=soeren password=abcdefgh"
@@ -56,7 +82,7 @@
This functions must be called befor any spatio-temporal processing is started
- database = get_grass_location_db_path()
+ database = get_temporal_dbmi_init_string()
db_exists = False
