[GRASS-SVN] r48755 - in grass/trunk: gui/wxpython/gui_modules lib/python
Wed Oct 12 07:50:21 EDT 2011
Author: martinl
Date: 2011-10-12 04:50:21 -0700 (Wed, 12 Oct 2011)
New Revision: 48755
   grass/trunk/gui/wxpython/gui_modules/gselect.py
   grass/trunk/lib/python/core.py
   grass/trunk/lib/python/db.py
pythonlib: improve mapsets() interface
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-10-12 11:20:55 UTC (rev 48754)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py	2011-10-12 11:50:21 UTC (rev 48755)
@@ -329,7 +329,7 @@
         # list of mapsets in current location
         if mapsets is None:
-            mapsets = grass.mapsets()
+            mapsets = grass.mapsets(searchPath = True)
         # current mapset first
         if curr_mapset in mapsets and mapsets[0] != curr_mapset:
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py	2011-10-12 11:20:55 UTC (rev 48754)
+++ grass/trunk/lib/python/core.py	2011-10-12 11:50:21 UTC (rev 48755)
@@ -629,7 +629,7 @@
     mapset_re = re.compile("<(.*)>")
     result = {}
     if check_search_path:
-        for mapset in mapsets(accessible = True):
+        for mapset in mapsets(searchPath = True):
             result[mapset] = []
     mapset = None
@@ -712,7 +712,7 @@
     result = {}
             result[mapset] = []
     mapset = None
@@ -875,14 +875,14 @@
 # interface to g.mapsets
-def mapsets(accessible = True):
-    """!List accessible mapsets (mapsets in search path)
+def mapsets(searchPath = False):
+    """!List available mapsets
-    @param accessible False to list all mapsets in the location
+    @param searchPatch True to list mapsets only in search path
     @return list of mapsets
-    if accessible:
+    if searchPath:
         flags = 'p'
     else:
         flags = 'l'
@@ -892,7 +892,7 @@
                            quiet = True)
     if not mapsets:
         fatal(_("Unable to list mapsets"))
     return mapsets.splitlines()
 # interface to `g.proj -c`
Modified: grass/trunk/lib/python/db.py
--- grass/trunk/lib/python/db.py	2011-10-12 11:20:55 UTC (rev 48754)
+++ grass/trunk/lib/python/db.py	2011-10-12 11:50:21 UTC (rev 48755)
@@ -122,7 +122,7 @@
         fatal(_("Fetching data from table <%s> failed") % table)
     ofile = open(fname)
-    result = ofile.readlines()
+    result = map(lambda x: x.rstrip(os.linesep), ofile.readlines())
     ofile.close()
     try_remove(fname)
