[GRASS-SVN] r48756 - in grass/branches/develbranch_6: gui/wxpython/gui_modules lib/python
Wed Oct 12 07:52:02 EDT 2011
Author: martinl
Date: 2011-10-12 04:52:02 -0700 (Wed, 12 Oct 2011)
New Revision: 48756
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/lib/python/core.py
   grass/branches/develbranch_6/lib/python/db.py
pythonlib: improve mapsets() interface
	   (merge r48755 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2011-10-12 11:50:21 UTC (rev 48755)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2011-10-12 11:52:02 UTC (rev 48756)
@@ -327,7 +327,7 @@
         # list of mapsets in current location
         if mapsets is None:
-            mapsets = grass.mapsets()
+            mapsets = grass.mapsets(searchPath = True)
         # current mapset first
         if curr_mapset in mapsets and mapsets[0] != curr_mapset:
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py	2011-10-12 11:50:21 UTC (rev 48755)
+++ grass/branches/develbranch_6/lib/python/core.py	2011-10-12 11:52:02 UTC (rev 48756)
@@ -620,7 +620,7 @@
     mapset_re = re.compile("<(.*)>")
     result = {}
     if check_search_path:
-        for mapset in mapsets(accessible = True):
+        for mapset in mapsets(searchPath = True):
             result[mapset] = []
     mapset = None
@@ -703,7 +703,7 @@
     result = {}
             result[mapset] = []
     mapset = None
@@ -866,14 +866,14 @@
 # interface to g.mapsets
-def mapsets(accessible = True):
-    """!List accessible mapsets (mapsets in search path)
+def mapsets(searchPath = False):
+    """!List available mapsets
-    @param accessible False to list all mapsets in the location
+    @param searchPatch True to list mapsets only in search path
     @return list of mapsets
-    if accessible:
+    if searchPath:
         flags = 'p'
     else:
         flags = 'l'
@@ -883,7 +883,7 @@
                            quiet = True)
     if not mapsets:
         fatal(_("Unable to list mapsets"))
     return mapsets.splitlines()
 # interface to `g.proj -c`
Modified: grass/branches/develbranch_6/lib/python/db.py
--- grass/branches/develbranch_6/lib/python/db.py	2011-10-12 11:50:21 UTC (rev 48755)
+++ grass/branches/develbranch_6/lib/python/db.py	2011-10-12 11:52:02 UTC (rev 48756)
@@ -112,7 +112,7 @@
         fatal(_("Fetching data from table <%s> failed") % table)
     ofile = open(fname)
-    result = ofile.readlines()
+    result = map(lambda x: x.rstrip(os.linesep), ofile.readlines())
     ofile.close()
     try_remove(fname)
