[GRASS-SVN] r48757 - in grass/trunk: gui/wxpython/gui_modules
lib/python
svn_grass at osgeo.org
Wed Oct 12 07:59:40 EDT 2011
Author: martinl
Date: 2011-10-12 04:59:40 -0700 (Wed, 12 Oct 2011)
New Revision: 48757
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/lib/python/core.py
pythonlib: r48755 - follow naming convetion
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-10-12 11:52:02 UTC (rev 48756)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-10-12 11:59:40 UTC (rev 48757)
@@ -329,7 +329,7 @@
# list of mapsets in current location
if mapsets is None:
- mapsets = grass.mapsets(searchPath = True)
+ mapsets = grass.mapsets(search_path = True)
# current mapset first
if curr_mapset in mapsets and mapsets[0] != curr_mapset:
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2011-10-12 11:52:02 UTC (rev 48756)
+++ grass/trunk/lib/python/core.py 2011-10-12 11:59:40 UTC (rev 48757)
@@ -629,7 +629,7 @@
mapset_re = re.compile("<(.*)>")
result = {}
if check_search_path:
- for mapset in mapsets(searchPath = True):
+ for mapset in mapsets(search_path = True):
result[mapset] = []
mapset = None
@@ -712,7 +712,7 @@
result = {}
result[mapset] = []
mapset = None
@@ -875,14 +875,14 @@
# interface to g.mapsets
-def mapsets(searchPath = False):
+def mapsets(search_path = False):
"""!List available mapsets
@param searchPatch True to list mapsets only in search path
@return list of mapsets
- if searchPath:
+ if search_path:
flags = 'p'
else:
flags = 'l'
