[GRASS-SVN] r48758 - in grass/branches/develbranch_6:
gui/wxpython/gui_modules lib/python
svn_grass at osgeo.org
Wed Oct 12 08:01:50 EDT 2011
Author: martinl
Date: 2011-10-12 05:01:49 -0700 (Wed, 12 Oct 2011)
New Revision: 48758
grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
grass/branches/develbranch_6/lib/python/core.py
pythonlib: r48755 - follow naming convetion
(merge r48757 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-10-12 11:59:40 UTC (rev 48757)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py 2011-10-12 12:01:49 UTC (rev 48758)
@@ -327,7 +327,7 @@
# list of mapsets in current location
if mapsets is None:
- mapsets = grass.mapsets(searchPath = True)
+ mapsets = grass.mapsets(search_path = True)
# current mapset first
if curr_mapset in mapsets and mapsets[0] != curr_mapset:
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2011-10-12 11:59:40 UTC (rev 48757)
+++ grass/branches/develbranch_6/lib/python/core.py 2011-10-12 12:01:49 UTC (rev 48758)
@@ -620,7 +620,7 @@
mapset_re = re.compile("<(.*)>")
result = {}
if check_search_path:
- for mapset in mapsets(searchPath = True):
+ for mapset in mapsets(search_path = True):
result[mapset] = []
mapset = None
@@ -703,7 +703,7 @@
result = {}
result[mapset] = []
mapset = None
@@ -866,14 +866,14 @@
# interface to g.mapsets
-def mapsets(searchPath = False):
+def mapsets(search_path = False):
"""!List available mapsets
@param searchPatch True to list mapsets only in search path
@return list of mapsets
- if searchPath:
+ if search_path:
flags = 'p'
else:
flags = 'l'
