[GRASS-SVN] r48763 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Oct 12 10:31:18 EDT 2011
Author: annakrat
Date: 2011-10-12 07:31:17 -0700 (Wed, 12 Oct 2011)
New Revision: 48763
grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
wxGUI: moving code to MapFrameBase (co-author V. Petras)
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-12 14:07:31 UTC (rev 48762)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-12 14:31:17 UTC (rev 48763)
@@ -86,9 +86,12 @@
MapFrameBase.__init__(self, parent = parent, title = title, toolbars = toolbars,
- tree = tree, notebook = notebook, lmgr = lmgr, page = page,
Map = Map, auimgr = auimgr, name = name, **kwargs)
+ self._layerManager = lmgr # Layer Manager object
+ self.tree = tree # Layer Manager layer tree object
+ self.page = page # Notebook page holding the layer tree
+ self.layerbook = notebook # Layer Manager layer tree notebook
# Add toolbars
@@ -158,7 +161,8 @@
# initialize region values
- self.__InitDisplay()
+ self._initMap(map = self.SrcMap)
+ self._initMap(map = self.TgtMap)
# Bind various events
@@ -284,22 +288,6 @@
self._mgr.Update()
- def __InitDisplay(self):
- Initialize map display, set dimensions and map region
- self.width, self.height = self.GetClientSize()
- Debug.msg(2, "MapFrame.__InitDisplay():")
- self.grwiz.SwitchEnv('source')
- self.SrcMap.ChangeMapSize(self.GetClientSize())
- self.SrcMap.region = self.SrcMap.GetRegion() # g.region -upgc
- self.grwiz.SwitchEnv('target')
- self.TgtMap.ChangeMapSize(self.GetClientSize())
- self.TgtMap.region = self.TgtMap.GetRegion() # g.region -upgc
- # self.SrcMap.SetRegion() # adjust region to match display window
- # self.TgtMap.SetRegion() # adjust region to match display window
def OnUpdateProgress(self, event):
Update progress bar info
@@ -696,4 +684,8 @@
def GetShowTarget(self):
return self.show_target
+ def GetMapToolbar(self):
+ """!Returns toolbar with zooming tools"""
+ return self.toolbars['gcpdisp']
# end of class MapFrame
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-12 14:07:31 UTC (rev 48762)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-12 14:31:17 UTC (rev 48763)
@@ -82,26 +82,17 @@
def __init__(self, parent = None, id = wx.ID_ANY, title = None,
style = wx.DEFAULT_FRAME_STYLE, toolbars = None,
- tree = None, notebook = None, lmgr = None, page = None,
Map = None, auimgr = None, name = None, **kwargs):
@param toolbars array of activated toolbars, e.g. ['map', 'digit']
- @param tree reference to layer tree
- @param notebook control book ID in Layer Manager
- @param lmgr Layer Manager
- @param page notebook page with layer tree
@param Map instance of render.Map
@param auimgs AUI manager
@param name frame name
@param kwargs wx.Frame attributes
- self._layerManager = lmgr # Layer Manager object
self.Map = Map # instance of render.Map
- self.tree = tree # Layer Manager layer tree object
- self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # Layer Manager layer tree notebook
self.parent = parent
wx.Frame.__init__(self, parent, id, title, style = style, name = name, **kwargs)
@@ -129,7 +120,21 @@
# Fancy gui
self._mgr = wx.aui.AuiManager(self)
+ def _initMap(self, map):
+ """!Initialize map display, set dimensions and map region
+ if not grass.find_program('g.region', ['--help']):
+ sys.exit(_("GRASS module '%s' not found. Unable to start map "
+ "display window.") % 'g.region')
+ self.width, self.height = self.GetClientSize()
+ Debug.msg(2, "MapFrame._initMap():")
+ map.ChangeMapSize(self.GetClientSize())
+ map.region = map.GetRegion() # g.region -upgc
+ # self.Map.SetRegion() # adjust region to match display window
def SetProperty(self, name, value):
"""!Sets property"""
self.statusbarManager.SetProperty(name, value)
@@ -225,7 +230,7 @@
Progress bar can be used by other classes.
return self.statusbarManager.GetProgressBar()
def GetRender(self):
"""!Returns current instance of render.Map()
@@ -241,32 +246,40 @@
def GetWindow(self):
"""!Get map window"""
return self.MapWindow
+ raise NotImplementedError()
def StatusbarUpdate(self):
"""!Update statusbar content"""
self.statusbarManager.Update()
def IsAutoRendered(self):
"""!Check if auto-rendering is enabled"""
return self.GetProperty('render')
def CoordinatesChanged(self):
"""!Shows current coordinates on statusbar.
Used in BufferedWindow to report change of map coordinates (under mouse cursor).
self.statusbarManager.ShowItem('coordinates')
def StatusbarReposition(self):
"""!Reposition items in statusbar"""
self.statusbarManager.Reposition()
def StatusbarEnableLongHelp(self, enable = True):
"""!Enable/disable toolbars long help"""
for toolbar in self.toolbars.itervalues():
if toolbar:
toolbar.EnableLongHelp(enable)
+ def IsStandalone(self):
+ """!Check if Map display is standalone"""
+ raise NotImplementedError("IsStandalone")
class MapFrame(MapFrameBase):
"""!Main frame for map display window. Drawing takes place in
child double buffered drawing window.
@@ -288,9 +301,12 @@
# Add toolbars
@@ -354,7 +370,7 @@
- self._initDisplay()
+ self._initMap(map = self.Map)
@@ -632,21 +648,7 @@
if self._mgr.GetPane(name).IsOk():
return self._mgr.GetPane(name).IsShown()
return False
- def _initDisplay(self):
- """!Initialize map display, set dimensions and map region
- if not grass.find_program('g.region', ['--help']):
- sys.exit(_("GRASS module '%s' not found. Unable to start map "
- "display window.") % 'g.region')
- Debug.msg(2, "MapFrame._initDisplay():")
- self.Map.ChangeMapSize(self.GetClientSize())
- self.Map.region = self.Map.GetRegion() # g.region -upgc
- # self.Map.SetRegion() # adjust region to match display window
"""!Update progress bar info
@@ -670,7 +672,6 @@
if pgnum > -1:
self.layerbook.SetSelection(pgnum)
self._layerManager.curr_page = self.layerbook.GetCurrentPage()
- self.layerbook
event.Skip()
@@ -1684,6 +1685,10 @@
return self._layerManager
+ return self.toolbars['map']
class MapApp(wx.App):
def OnInit(self):
wx.InitAllImageHandlers()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-12 14:07:31 UTC (rev 48762)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-12 14:31:17 UTC (rev 48763)
@@ -834,7 +834,7 @@
if not self.parent.IsStandalone() and \
self.parent.GetLayerManager().gcpmanagement:
# -> georectifier (redraw GCPs)
- if self.parent.toolbars['gcpdisp']:
+ if self.parent.GetMapToolbar():
if self == self.parent.TgtMapWindow:
coordtype = 'target'
else:
@@ -1705,12 +1705,7 @@
else:
enable = False
- if self.parent.GetName() == 'MapWindow':
- toolbar = self.parent.toolbars['map']
- elif self.parent.GetName() == 'GRMapWindow':
- toolbar = self.parent.toolbars['georect']
- elif self.parent.GetName() == 'GCPMapWindow':
- toolbar = self.parent.toolbars['gcpdisp']
+ toolbar = self.parent.GetMapToolbar()
toolbar.Enable('zoomback', enable)
