[GRASS-SVN] r48764 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Wed Oct 12 10:57:57 EDT 2011
Author: annakrat
Date: 2011-10-12 07:57:57 -0700 (Wed, 12 Oct 2011)
New Revision: 48764
grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI: remove unused code of old georectifier (co-author V. Petras)
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -97,7 +97,6 @@
self.toolbars = { 'map' : None,
'vdigit' : None,
- 'georect' : None,
'gcpdisp' : None,
'gcpman' : None,
'nviz' : None }
@@ -245,7 +244,6 @@
- 'vdigit' - vector digitizer
- 'gcpdisp' - GCP Manager, Display
- 'gcpman' - GCP Manager, points management
- - 'georect' - georectifier
- 'nviz' - 3D view mode
# default toolbar
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -312,7 +312,6 @@
'vdigit' : None,
- 'georect' : None,
'gcpdisp' : None,
'gcpman' : None,
'nviz' : None }
@@ -586,7 +585,6 @@
- 'map' - basic map toolbar
- 'gcpdisp' - GCP Manager Display
# default toolbar
if name == "map":
@@ -605,19 +603,6 @@
elif name == "vdigit":
self._addToolbarVDigit()
- # georectifier
- elif name == "georect":
- self.toolbars['georect'] = toolbars.GRToolbar(self, self.Map)
- self._mgr.AddPane(self.toolbars['georect'],
- wx.aui.AuiPaneInfo().
- Name("georecttoolbar").Caption(_("Georectification Toolbar")).
- ToolbarPane().Top().
- LeftDockable(False).RightDockable(False).
- BottomDockable(False).TopDockable(True).
- CloseButton(False).Layer(2).
- BestSize((self.toolbars['georect'].GetBestSize())))
self._mgr.Update()
def RemoveToolbar (self, name):
@@ -658,20 +643,13 @@
def OnFocus(self, event):
"""!Change choicebook page to match display.
- Or set display for georectifying
- if self._layerManager and \
- self._layerManager.georectifying:
- # in georectifying session; display used to get geographic
- # coordinates for GCPs
- self.OnPointer(event)
- else:
- # change bookcontrol page to page associated with display
- if self.page:
- pgnum = self.layerbook.GetPageIndex(self.page)
- if pgnum > -1:
- self.layerbook.SetSelection(pgnum)
- self._layerManager.curr_page = self.layerbook.GetCurrentPage()
+ # change bookcontrol page to page associated with display
+ if self.page:
+ pgnum = self.layerbook.GetPageIndex(self.page)
+ if pgnum > -1:
+ self.layerbook.SetSelection(pgnum)
+ self._layerManager.curr_page = self.layerbook.GetCurrentPage()
event.Skip()
@@ -733,9 +711,6 @@
else: # moveLine, deleteLine
self.MapWindow.mouse['box'] = 'box'
- elif self._layerManager and self._layerManager.georectifying:
- self.MapWindow.SetCursor(self.cursors["cross"])
else:
self.MapWindow.SetCursor(self.cursors["default"])
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -821,15 +821,6 @@
if len(self.polycoords) > 0:
self.DrawLines(self.pdcTmp)
- if not self.parent.IsStandalone() and \
- self.parent.GetLayerManager().georectifying:
- # -> georectifier (redraw GCPs)
- if self.parent.toolbars['georect']:
- coordtype = 'gcpcoord'
- else:
- coordtype = 'mapcoord'
- self.parent.GetLayerManager().georectifying.DrawGCP(coordtype)
self.parent.GetLayerManager().gcpmanagement:
@@ -1336,20 +1327,7 @@
self.parent.GetLayerManager().gcpmanagement.SetGCPData(coordtype, coord, self, confirm = True)
self.UpdateMap(render = False, renderVector = False)
- elif self.mouse["use"] == "pointer" and \
- not self.parent.IsStandalone() and \
- # -> georectifying
- coord = self.Pixel2Cell(self.mouse['end'])
- else:
- self.parent.GetLayerManager().georectifying.SetGCPData(coordtype, coord, self)
- self.UpdateMap(render = False, renderVector = False)
hasattr(self, "digit"):
self._onLeftUp(event)
@@ -1660,13 +1638,7 @@
# disable tool if stack is empty
if len(self.zoomhistory) < 2: # disable tool
- if self.parent.GetName() == 'MapWindow':
- toolbar = self.parent.toolbars['map']
- elif self.parent.GetName() == 'GRMapWindow':
- toolbar = self.parent.toolbars['georect']
- elif self.parent.GetName() == 'GCPMapWindow':
- toolbar = self.parent.toolbars['gcpdisp']
+ toolbar = self.parent.GetMapToolbar()
toolbar.Enable('zoomback', enable = False)
# zoom to selected region
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -521,12 +521,6 @@
'width' : 2,
- 'georect' : {
- 'symbol' : {
- 'color' : (0, 0, 255, 255),
- 'width' : 2,
'nviz' : {
'view' : {
'persp' : {
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -438,8 +438,8 @@
# add tool to toggle active map window
self.togglemapid = wx.NewId()
self.togglemap = wx.Choice(parent = self, id = self.togglemapid,
- choices = [_('source'), _('target')],
- style = wx.CB_READONLY)
+ choices = [_('source'), _('target')],
+ style = wx.CB_READONLY)
self.InsertControl(10, self.togglemap)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-10-12 14:57:57 UTC (rev 48764)
@@ -112,7 +112,6 @@
self.curr_pagenum = None # currently selected page number for layer tree notebook
self.workspaceFile = workspace # workspace file
self.workspaceChanged = False # track changes in workspace
- self.georectifying = None # reference to GCP class or None
self.gcpmanagement = None # reference to GCP class or None
# list of open dialogs
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2011-10-12 14:31:17 UTC (rev 48763)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2011-10-12 14:57:57 UTC (rev 48764)
@@ -160,6 +160,7 @@
- gui_modules::mapdisp_command::Command
- gui_modules/mapdisp.py
+ - gui_modules::mapdisp::MapFrameBase
- gui_modules::mapdisp::MapApp
@@ -178,14 +179,19 @@
- gui_modules::toolbars::MapToolbar
- gui_modules::toolbars::GCPManToolbar
- gui_modules::toolbars::GCPDisplayToolbar
- - gui_modules::toolbars::GRToolbar
- - gui_modules::toolbars::GCPToolbar
- gui_modules::toolbars::VDigitToolbar
- gui_modules::toolbars::ProfileToolbar
- - gui_modules::toolbars::NvizToolbar
+ - gui_modules::toolbars::LMNvizToolbar
- gui_modules::toolbars::ModelToolbar
- gui_modules::toolbars::HistogramToolbar
- - gui_modules::toolbars::LayerManagerToolbar
+ - gui_modules::toolbars::Histogram2Toolbar
+ - gui_modules::toolbars::ScatterplotToolbar
+ - gui_modules::toolbars::LMWorkspaceToolbar
+ - gui_modules::toolbars::LMDataToolbar
+ - gui_modules::toolbars::LMToolsToolbar
+ - gui_modules::toolbars::LMMiscToolbar
+ - gui_modules::toolbars::LMVectorToolbar
+ - gui_modules::toolbars::PsMapToolbar
\subsection wscreen Welcome screen
