[GRASS-SVN] r48765 - in grass/trunk/gui/wxpython: . gui_modules
    svn_grass at osgeo.org
    Wed Oct 12 12:36:36 EDT 2011
Author: annakrat
Date: 2011-10-12 09:36:36 -0700 (Wed, 12 Oct 2011)
New Revision: 48765
   grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
   grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
   grass/trunk/gui/wxpython/gui_modules/layertree.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: toolbar access methods added (co-author V. Petras)
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmanager.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -1787,7 +1787,7 @@
     def UpdateActive(self, win):
         # optionally disable tool zoomback tool
-        self.toolbars['gcpdisp'].Enable('zoomback', enable = (len(self.MapWindow.zoomhistory) > 1))
+        self.GetMapToolbar().Enable('zoomback', enable = (len(self.MapWindow.zoomhistory) > 1))
         if self.activemap.GetSelection() != (win == self.TgtMapWindow):
             self.activemap.SetSelection(win == self.TgtMapWindow)
@@ -1883,7 +1883,7 @@
     def OnDispResize(self, event):
         """!GCP Map Display resized, adjust Map Windows
-        if self.toolbars['gcpdisp']:
+        if self.GetMapToolbar():
             srcwidth, srcheight = self.SrcMapWindow.GetSize()
             tgtwidth, tgtheight = self.TgtMapWindow.GetSize()
             srcwidth = (srcwidth + tgtwidth) / 2
@@ -2758,7 +2758,7 @@
                     self.parent.show_target = True
                     self.parent._mgr.GetPane("target").Show()
                     self.parent._mgr.Update()
-                    self.parent.toolbars['gcpdisp'].Enable('zoommenu', enable = True)
+                    self.parent.GetMapToolbar().Enable('zoommenu', enable = True)
                     self.parent.activemap.Enable()
                     self.parent.TgtMapWindow.ZoomToMap(layers = self.parent.TgtMap.GetListOfLayers())
             else: # tgt_map == ''
@@ -2768,7 +2768,7 @@
                     self.parent.activemap.SetSelection(0)
                     self.parent.activemap.Enable(False)
-                    self.parent.toolbars['gcpdisp'].Enable('zoommenu', enable = False)
+                    self.parent.GetMapToolbar().Enable('zoommenu', enable = False)
         self.parent.UpdateColours(srcrender, srcrenderVector, tgtrender, tgtrenderVector)
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -95,12 +95,6 @@
         # Add toolbars
-        self.toolbars = { 'map' : None,
-                          'vdigit' : None,
-                          'gcpdisp' : None,
-                          'gcpman' : None,
-                          'nviz' : None }
         for toolb in toolbars:
             self.AddToolbar(toolb)
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -228,7 +228,7 @@
         idle time instead of multiple times during layer changing.
         if self.rerender:
-            if self.mapdisplay.toolbars['vdigit']:
+            if self.mapdisplay.GetToolbar('vdigit'):
                 vector = True
             else:
                 vector = False
@@ -335,7 +335,7 @@
             layer = self.GetPyData(self.layer_selected)[0]['maplayer']
             # enable editing only for vector map layers available in the current mapset
-            digitToolbar = self.mapdisplay.toolbars['vdigit']
+            digitToolbar = self.mapdisplay.GetToolbar('vdigit')
             if digitToolbar:
                 # background vector map
                 self.popupMenu.Append(self.popupID['bgmap'],
@@ -605,7 +605,7 @@
             dlg.Destroy()
             return
-        if not self.mapdisplay.toolbars['vdigit']: # enable tool
+        if not self.mapdisplay.GetToolbar('vdigit'): # enable tool
             self.mapdisplay.AddToolbar('vdigit')
         else: # tool already enabled
             pass
@@ -669,8 +669,8 @@
                              self._getLayerName(self.layer_selected))
             # vector layer currently edited
-            if self.mapdisplay.toolbars['vdigit'] and \
-                    self.mapdisplay.toolbars['vdigit'].GetLayer() == maplayer:
+            if self.mapdisplay.GetToolbar('vdigit') and \
+                    self.mapdisplay.GetToolbar('vdigit').GetLayer() == maplayer:
                 alpha = int(new_opacity * 255)
                 self.mapdisplay.GetWindow().digit.GetDisplay().UpdateSettings(alpha = alpha)
@@ -1084,7 +1084,7 @@
         self.rerender = True
         self.reorder = True
             self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers (updateTool = True)
         # update progress bar range (mapwindow statusbar)
@@ -1115,7 +1115,7 @@
         item    = event.GetItem()
         checked = item.IsChecked()
         if self.first == False:
             # change active parameter for item in layers list in render.Map
             if self.GetPyData(item)[0]['type'] == 'group':
@@ -1202,7 +1202,7 @@
             event.Veto()
             return
         if digitToolbar:
             mapLayer = self.GetPyData(layer)[0]['maplayer']
             bgmap = UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
@@ -1566,8 +1566,8 @@
         self.GetPyData(item)[0]['maplayer'] = maplayer
         # if digitization tool enabled -> update list of available vector map layers
-            self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers(updateTool = True)
+            self.mapdisplay.GetToolbar('vdigit').UpdateListOfLayers(updateTool = True)
         # redraw map if auto-rendering is enabled
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -116,6 +116,9 @@
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+        # toolbars
+        self.toolbars = {}
         # Fancy gui
@@ -251,6 +254,13 @@
        """!Returns toolbar with zooming tools"""
        raise NotImplementedError()
+    def GetToolbar(self, name):
+        """!Returns toolbar if exists else None"""
+        if name in self.toolbars:
+            return self.toolbars[name]
+        return None
     def StatusbarUpdate(self):
         """!Update statusbar content"""
         self.statusbarManager.Update()
@@ -273,12 +283,16 @@
     def StatusbarEnableLongHelp(self, enable = True):
         """!Enable/disable toolbars long help"""
         for toolbar in self.toolbars.itervalues():
-            if toolbar:
-                toolbar.EnableLongHelp(enable)
+            toolbar.EnableLongHelp(enable)
     def IsStandalone(self):
         """!Check if Map display is standalone"""
         raise NotImplementedError("IsStandalone")
+    def OnRender(self, event):
+        """!Re-render map composition (each map layer)
+        raise NotImplementedError("OnRender")
 class MapFrame(MapFrameBase):
     """!Main frame for map display window. Drawing takes place in
@@ -310,12 +324,6 @@
         # Add toolbars
-                          'vdigit' : None,
-                          'gcpdisp' : None,
-                          'gcpman' : None,
-                          'nviz' : None }
@@ -616,7 +624,7 @@
         self._mgr.DetachPane(self.toolbars[name])
         self.toolbars[name].Destroy()
-        self.toolbars[name] = None
+        self.toolbars.pop(name)
         if name == 'vdigit':
             self._mgr.GetPane('vdigit').Hide()
@@ -673,7 +681,7 @@
             self.MapWindow.ClearLines()
         # deselect features in vdigit
-        if self.toolbars['vdigit']:
+        if self.GetToolbar('vdigit'):
             self.MapWindow.digit.GetDisplay().SetSelected([])
             self.MapWindow.UpdateMap(render = True, renderVector = True)
         else:
@@ -685,7 +693,7 @@
     def OnPointer(self, event):
         """!Pointer button clicked
-        if self.toolbars['map']:
             if event:
                 self.toolbars['map'].OnTool(event)
             self.toolbars['map'].action['desc'] = ''
@@ -694,7 +702,7 @@
         self.MapWindow.mouse['box'] = "point"
         # change the cursor
             # digitization tool activated
             self.MapWindow.SetCursor(self.cursors["cross"])
@@ -718,7 +726,7 @@
         """!Zoom in the map.
         Set mouse cursor, zoombox attributes, and zoom direction
@@ -734,7 +742,7 @@
         """!Zoom out the map.
@@ -754,7 +762,7 @@
     def OnPan(self, event):
         """!Panning, set mouse to drag
@@ -768,7 +776,7 @@
     def OnRotate(self, event):
         """!Rotate 3D view
@@ -878,7 +886,7 @@
         self.Map.Clean()
         # close edited map and 3D tools properly
             maplayer = self.toolbars['vdigit'].GetLayer()
             if maplayer:
                 self.toolbars['vdigit'].OnExit()
@@ -1088,7 +1096,7 @@
     def OnQuery(self, event):
         """!Query tools menu"""
             action = self.toolbars['map'].GetAction()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -40,7 +40,7 @@
                                 style, **kwargs)
         self.pdcVector = wx.PseudoDC()
-        self.toolbar   = self.parent.toolbars['vdigit']
+        self.toolbar   = self.parent.GetToolbar('vdigit')
         self.digit     = None # wxvdigit.IVDigit
         self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -1318,7 +1318,7 @@
                 not self.parent.IsStandalone() and \
                 self.parent.GetLayerManager().gcpmanagement:
             # -> GCP manager
-            if self.parent.toolbars['gcpdisp']:
+            if self.parent.GetToolbar('gcpdisp'):
                 coord = self.Pixel2Cell(self.mouse['end'])
                 if self.parent.MapWindow == self.parent.SrcMapWindow:
                     coordtype = 'source'
@@ -1444,7 +1444,7 @@
         if not self.parent.IsStandalone() and \
                 if not self.parent.MapWindow == self:
                     self.parent.MapWindow = self
                     self.parent.Map = self.Map
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -657,7 +657,7 @@
         # disable tool if stack is empty
         if len(self.viewhistory) < 2: # disable tool
-            toolbar = self.parent.toolbars['map']
+            toolbar = self.parent.GetMapToolbar()
             toolbar.Enable('zoomback', enable = False)
         # set view and update nviz view page
@@ -697,7 +697,7 @@
         else:
             enable = False
         toolbar.Enable('zoomback', enable)
         return removed
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -124,7 +124,7 @@
             return
         if hasattr(self.parent, 'toolbars'):
-            if self.parent.toolbars['vdigit']:
+            if self.parent.GetToolbar('vdigit'):
                 # update vdigit toolbar (unselect currently selected tool)
                 id = self.parent.toolbars['vdigit'].GetAction(type = 'id')
                 self.parent.toolbars['vdigit'].ToggleTool(id, False)
@@ -374,13 +374,13 @@
             self.parent.AddNviz()
         elif tool == self.toolId['vdigit'] and \
-                not self.parent.toolbars['vdigit']:
+                not self.parent.GetToolbar('vdigit'):
             self.ExitToolbars()
             self.parent.AddToolbar("vdigit")
             self.parent.MapWindow.SetFocus()
     def ExitToolbars(self):
             self.parent.toolbars['vdigit'].OnExit()
         if self.parent.GetLayerManager().IsPaneShown('toolbarNviz'):
             self.parent.RemoveNviz()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-10-12 14:57:57 UTC (rev 48764)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-10-12 16:36:36 UTC (rev 48765)
@@ -500,6 +500,13 @@
         """!Get widget for command output"""
         return self.goutput
+        return None
     def GetMenuCmd(self, event):
         """!Get GRASS command from menu item
