[GRASS-SVN] r48929 - in grass/trunk: gui/wxpython/gui_modules
scripts/g.extension
svn_grass at osgeo.org
Tue Oct 25 08:02:28 EDT 2011
Author: lucadelu
Date: 2011-10-25 05:02:28 -0700 (Tue, 25 Oct 2011)
New Revision: 48929
grass/trunk/gui/wxpython/gui_modules/ghelp.py
grass/trunk/scripts/g.extension/g.extension.py
fix problem in removing modules with more command like r.modis
Modified: grass/trunk/gui/wxpython/gui_modules/ghelp.py
--- grass/trunk/gui/wxpython/gui_modules/ghelp.py 2011-10-24 00:08:28 UTC (rev 48928)
+++ grass/trunk/gui/wxpython/gui_modules/ghelp.py 2011-10-25 12:02:28 UTC (rev 48929)
@@ -827,7 +827,7 @@
desc = f.get('description', '')
if not name and not desc:
continue
- if name in ('l', 'f', 'g', 'quiet', 'verbose'):
+ if name in ('l', 'c', 'g', 'quiet', 'verbose'):
continue
self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label = desc)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-10-24 00:08:28 UTC (rev 48928)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-10-25 12:02:28 UTC (rev 48929)
@@ -64,8 +64,8 @@
#% suppress_required: yes
#%end
#%flag
-#% key: f
-#% description: List available modules in the GRASS Addons SVN repository including modules description
+#% key: c
+#% description: List available modules in the GRASS Addons SVN repository including complete module description
#% guisection: Print
#%end
@@ -87,12 +87,17 @@
#% key: i
#% description: Don't install new extension, just compile it
#%end
+#%flag
+#% key: f
+#% description: Force removal (required for actual deletion of files)
+#%end
import os
import sys
import re
import atexit
import shutil
+import glob
import urllib
@@ -192,7 +197,7 @@
return mlist
def print_module_desc(name, url):
- if not flags['f'] and not flags['g']:
+ if not flags['c'] and not flags['g']:
print name
return
@@ -415,19 +420,36 @@
grass.warning(_('This add-on module will not function until you set the '
'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
-def remove_extension():
- # is module available?
- bin_dir = os.path.join(options['prefix'], 'bin', options['extension'])
- scr_dir = os.path.join(options['prefix'], 'scripts', options['extension'])
- if not os.path.exists(bin_dir) and not os.path.exists(scr_dir):
- grass.fatal(_("Module <%s> not found") % options['extension'])
- for f in [bin_dir, scr_dir,
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
- os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
- grass.try_remove(f)
- grass.message(_("Module <%s> successfully uninstalled") % options['extension'])
+def remove_extension(flags):
+ #is module available?
+ bin_dir = os.path.join(options['prefix'], 'bin')
+ scr_dir = os.path.join(options['prefix'], 'scripts')
+ #add glob because if install a module with several submodule like r.modis
+ #or r.pi.* or r.stream.* it was not possible to remove all the module
+ #but the user has to remove the single command
+ if glob.glob1(bin_dir,options['extension'] + "*"):
+ modules = glob.glob1(bin_dir,options['extension'] + "*")
+ elif glob.glob1(scr_dir,options['extension'] + "*"):
+ modules = glob.glob1(scr_dir,options['extension'] + "*")
+ else:
+ grass.fatal(_("No module <%s> found") % options['extension'])
+ #the user want really remove the scripts
+ if flags['f']:
+ #for each module remove script and documentation files
+ for mod in modules:
+ for f in [os.path.join(bin_dir, mod), os.path.join(scr_dir, mod),
+ os.path.join(options['prefix'], 'docs', 'html', mod + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', mod + '.1')]:
+ grass.try_remove(f)
+ #add etc for the internal library of a module
+ grass.try_rmdir(os.path.join(options['prefix'], 'etc', options['extension']))
+ grass.message(_("Module <%s> successfully uninstalled") % options['extension'])
+ #print modules that you are going to remove with -f option
+ else:
+ grass.message(mod)
+ grass.message(_("You must use the force flag (-%s) to actually remove them. Exiting") % "f")
def create_dir(path):
if os.path.isdir(path):
@@ -468,7 +490,7 @@
check()
# list available modules
- if flags['l'] or flags['f'] or flags['g']:
+ if flags['l'] or flags['c'] or flags['g']:
list_available_modules()
return 0
else:
@@ -506,7 +528,7 @@
if options['operation'] == 'add':
install_extension()
else: # remove
- remove_extension()
+ remove_extension(flags)
return 0
