[GRASS-SVN] r48930 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Oct 25 08:47:12 EDT 2011
Author: martinl
Date: 2011-10-25 05:47:12 -0700 (Tue, 25 Oct 2011)
New Revision: 48930
grass/trunk/gui/wxpython/gui_modules/gmodeler.py
wxGUI/modeler: merge SetValid() with SetParameterized()
Modified: grass/trunk/gui/wxpython/gui_modules/gmodeler.py
--- grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-10-25 12:02:28 UTC (rev 48929)
+++ grass/trunk/gui/wxpython/gui_modules/gmodeler.py 2011-10-25 12:47:12 UTC (rev 48930)
@@ -290,23 +290,7 @@
self.AddItem(actionItem)
- task = actionItem.GetTask()
- parameterized = False
- valid = True
- for f in task.get_options()['flags']:
- if f.get('parameterized', False):
- parameterized = True
- break
- for p in task.get_options()['params']:
- if p.get('required', 'no') != 'no' and \
- p.get('value', '') == '' and \
- p.get('default', '') == '':
- valid = False
- if p.get('parameterized', False):
- actionItem.SetValid(valid)
- actionItem.SetParameterized(parameterized)
+ actionItem.SetValid(actionItem.GetTask().get_options())
actionItem.GetLog() # substitute variables (-> valid/invalid)
# load data & relations
@@ -1283,7 +1267,7 @@
# show properties dialog
win = action.GetPropDialog()
if not win:
- if len(action.GetLog(string = False)) > 1:
+ if action.IsValid():
self.GetOptData(dcmd = action.GetLog(string = False), layer = action,
params = action.GetParams(), propwin = None)
else:
@@ -1389,28 +1373,8 @@
self.AddLine(rel)
data.Update()
- # valid ?
- valid = True
- for p in params['params']:
- if p.get('required', False) and \
- valid = False
- break
- layer.SetValid(valid)
- # parameterized ?
- for f in params['flags']:
- break
- if not parameterized:
- break
- layer.SetParameterized(parameterized)
+ # valid / parameterized ?
+ layer.SetValid(params)
self.canvas.Refresh()
@@ -1502,15 +1466,7 @@
# final updates
for action in self.model.GetItems(objType = ModelAction):
- valid = True
- params = action.GetParams()
- valid = False
- break
- action.SetValid(valid)
+ action.SetValid(action.GetParams())
action.Update()
self.canvas.Refresh(True)
@@ -1790,7 +1746,10 @@
self._setPen()
self._setBrush()
self.SetId(id)
+ if self.task:
+ self.SetValid(self.task.get_options())
def _setBrush(self, running = False):
"""!Set brush"""
if running:
@@ -1919,17 +1878,35 @@
self.task.set_param(p['name'],
p.get('value', ''))
- def SetValid(self, isvalid):
- """!Set instance to be valid/invalid"""
- self.isValid = isvalid
- self._setBrush()
+ def SetValid(self, options):
+ """!Set validity for action
- def SetParameterized(self, isparameterized):
- """!Set action parameterized"""
- self.isParameterized = isparameterized
- if self.parent.GetCanvas():
+ @param options dictionary with flags and params (gtask)
+ self.isValid = True
+ self.isParameterized = False
+ for f in options['flags']:
+ if f.get('parameterized', False):
+ self.IsParameterized = True
+ break
+ for p in options['params']:
+ if self.isValid and p.get('required', False) and \
+ p.get('value', '') == '' and \
+ p.get('default', '') == '':
+ self.isValid = False
+ if not self.isParameterized and p.get('parameterized', False):
+ self.isParameterized = True
+ if self.parent.GetCanvas():
+ self._setBrush()
self._setPen()
+ def IsValid(self):
+ """!Check validity (all required parameters set)"""
+ return self.isValid
def IsParameterized(self):
"""!Check if action is parameterized"""
return self.isParameterized
@@ -1956,7 +1933,7 @@
self._setBrush()
self._setPen()
ogl.RectangleShape.OnDraw(self, dc)
class ModelData(ModelObject, ogl.EllipseShape):
def __init__(self, parent, x, y, value = '', prompt = '', width = None, height = None):
"""Data item class
