[GRASS-SVN] r48948 - grass/trunk/vector/v.clean
svn_grass at osgeo.org
Wed Oct 26 05:06:05 EDT 2011
Author: martinl
Date: 2011-10-26 02:06:05 -0700 (Wed, 26 Oct 2011)
New Revision: 48948
grass/trunk/vector/v.clean/main.c
v.clean: updated for OGR write access
clean up (opt, flag)
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2011-10-26 09:05:20 UTC (rev 48947)
+++ grass/trunk/vector/v.clean/main.c 2011-10-26 09:06:05 UTC (rev 48948)
@@ -7,7 +7,7 @@
* * PURPOSE: Clean vector features
- * * COPYRIGHT: (C) 2001-2009 by the GRASS Development Team
+ * * COPYRIGHT: (C) 2001-2009, 2011 by the GRASS Development Team
* * This program is free software under the
* * GNU General Public License (>=v2).
@@ -28,14 +28,17 @@
int main(int argc, char *argv[])
struct Map_info In, Out, Err, *pErr;
- int i, otype, with_z;
+ int i, otype, with_z, native;
struct GModule *module;
- struct Option *in_opt, *field_opt, *out_opt, *type_opt, *tool_opt, *thresh_opt,
- *err_opt;
- struct Flag *no_build_flag, *combine_flag;
+ struct {
+ struct Option *in, *field, *out, *type, *tool, *thresh,
+ *err;
+ } opt;
+ struct {
+ struct Flag *no_build, *combine;
+ } flag;
int *tools, ntools, atools;
double *threshs;
- int level;
int count;
double size;
char *desc;
@@ -47,29 +50,31 @@
G_add_keyword(_("topology"));
module->description = _("Toolset for cleaning topology of vector map.");
- in_opt = G_define_standard_option(G_OPT_V_INPUT);
- field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
- field_opt->answer = "-1";
- field_opt->guisection = _("Selection");
- type_opt = G_define_standard_option(G_OPT_V3_TYPE);
- type_opt->guisection = _("Selection");
+ opt.in = G_define_standard_option(G_OPT_V_INPUT);
- out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt.field = G_define_standard_option(G_OPT_V_FIELD_ALL);
+ opt.field->answer = "-1";
+ opt.field->guisection = _("Selection");
- err_opt = G_define_standard_option(G_OPT_V_OUTPUT);
- err_opt->key = "error";
- err_opt->description = _("Name of output map where errors are written");
- err_opt->required = NO;
+ opt.type = G_define_standard_option(G_OPT_V3_TYPE);
+ opt.type->guisection = _("Selection");
- tool_opt = G_define_option();
- tool_opt->key = "tool";
- tool_opt->type = TYPE_STRING;
- tool_opt->required = YES;
- tool_opt->multiple = YES;
- tool_opt->options =
+ opt.out = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt.err = G_define_standard_option(G_OPT_V_OUTPUT);
+ opt.err->key = "error";
+ opt.err->description = _("Name of output map where errors are written");
+ opt.err->required = NO;
+ opt.tool = G_define_option();
+ opt.tool->key = "tool";
+ opt.tool->type = TYPE_STRING;
+ opt.tool->required = YES;
+ opt.tool->multiple = YES;
+ opt.tool->options =
"break,snap,rmdangle,chdangle,rmbridge,chbridge,rmdupl,rmdac,bpol,prune,"
"rmarea,rmline,rmsa";
- tool_opt->description = _("Cleaning tool");
+ opt.tool->description = _("Cleaning tool");
desc = NULL;
G_asprintf(&desc,
"break;%s;"
@@ -104,35 +109,35 @@
_("remove small areas, the longest boundary with adjacent area is removed"),
_("remove all lines or boundaries of zero length, threshold is ignored"),
_("remove small angles between lines at nodes"));
- tool_opt->descriptions = desc;
+ opt.tool->descriptions = desc;
- thresh_opt = G_define_option();
- thresh_opt->key = "thresh";
- thresh_opt->type = TYPE_DOUBLE;
- thresh_opt->required = NO;
- thresh_opt->multiple = YES;
- thresh_opt->label = _("Threshold in map units, one value for each tool");
- thresh_opt->description = _("Default: 0.0[,0.0,...])");
+ opt.thresh = G_define_option();
+ opt.thresh->key = "thresh";
+ opt.thresh->type = TYPE_DOUBLE;
+ opt.thresh->required = NO;
+ opt.thresh->multiple = YES;
+ opt.thresh->label = _("Threshold in map units, one value for each tool");
+ opt.thresh->description = _("Default: 0.0[,0.0,...])");
- no_build_flag = G_define_flag();
- no_build_flag->key = 'b';
- no_build_flag->description =
+ flag.no_build = G_define_flag();
+ flag.no_build->key = 'b';
+ flag.no_build->description =
_("Don't build topology for the output vector");
- combine_flag = G_define_flag();
- combine_flag->key = 'c';
- combine_flag->description =
+ flag.combine = G_define_flag();
+ flag.combine->key = 'c';
+ flag.combine->description =
_("Combine tools with recommended follow-up tools.");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- otype = Vect_option_to_types(type_opt);
+ otype = Vect_option_to_types(opt.type);
- Vect_check_input_output_name(in_opt->answer, out_opt->answer,
+ Vect_check_input_output_name(opt.in->answer, opt.out->answer,
GV_FATAL_EXIT);
- if (err_opt->answer) {
- Vect_check_input_output_name(in_opt->answer, err_opt->answer,
+ if (opt.err->answer) {
+ Vect_check_input_output_name(opt.in->answer, opt.err->answer,
GV_FATAL_EXIT);
@@ -142,40 +147,40 @@
/* Read tools */
ntools = 0;
i = 0;
- if (strlen(tool_opt->answer) < 1)
+ if (strlen(opt.tool->answer) < 1)
G_fatal_error(_("You must select at least one tool"));
- while (tool_opt->answers[i]) {
+ while (opt.tool->answers[i]) {
if (i + 1 >= atools) {
atools += 20;
G_realloc(tools, atools * sizeof(int));
- G_debug(1, "tool : %s", tool_opt->answers[i]);
- if (strcmp(tool_opt->answers[i], "break") == 0)
+ G_debug(1, "tool : %s", opt.tool->answers[i]);
+ if (strcmp(opt.tool->answers[i], "break") == 0)
tools[ntools] = TOOL_BREAK;
- else if (strcmp(tool_opt->answers[i], "rmdupl") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmdupl") == 0)
tools[ntools] = TOOL_RMDUPL;
- else if (strcmp(tool_opt->answers[i], "rmdangle") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmdangle") == 0)
tools[ntools] = TOOL_RMDANGLE;
- else if (strcmp(tool_opt->answers[i], "chdangle") == 0)
+ else if (strcmp(opt.tool->answers[i], "chdangle") == 0)
tools[ntools] = TOOL_CHDANGLE;
- else if (strcmp(tool_opt->answers[i], "rmbridge") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmbridge") == 0)
tools[ntools] = TOOL_RMBRIDGE;
- else if (strcmp(tool_opt->answers[i], "chbridge") == 0)
+ else if (strcmp(opt.tool->answers[i], "chbridge") == 0)
tools[ntools] = TOOL_CHBRIDGE;
- else if (strcmp(tool_opt->answers[i], "snap") == 0)
+ else if (strcmp(opt.tool->answers[i], "snap") == 0)
tools[ntools] = TOOL_SNAP;
- else if (strcmp(tool_opt->answers[i], "rmdac") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmdac") == 0)
tools[ntools] = TOOL_RMDAC;
- else if (strcmp(tool_opt->answers[i], "bpol") == 0)
+ else if (strcmp(opt.tool->answers[i], "bpol") == 0)
tools[ntools] = TOOL_BPOL;
- else if (strcmp(tool_opt->answers[i], "prune") == 0)
+ else if (strcmp(opt.tool->answers[i], "prune") == 0)
tools[ntools] = TOOL_PRUNE;
- else if (strcmp(tool_opt->answers[i], "rmarea") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmarea") == 0)
tools[ntools] = TOOL_RMAREA;
- else if (strcmp(tool_opt->answers[i], "rmsa") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmsa") == 0)
tools[ntools] = TOOL_RMSA;
- else if (strcmp(tool_opt->answers[i], "rmline") == 0)
+ else if (strcmp(opt.tool->answers[i], "rmline") == 0)
tools[ntools] = TOOL_RMLINE;
else
G_fatal_error(_("Tool doesn't exist"));
@@ -191,9 +196,9 @@
for (i = 0; i < ntools; i++)
threshs[i] = 0.0;
i = 0;
- while (thresh_opt->answers && thresh_opt->answers[i]) {
- threshs[i] = atof(thresh_opt->answers[i]);
- G_debug(1, "thresh : %s -> %f ", tool_opt->answers[i], threshs[i]);
+ while (opt.thresh->answers && opt.thresh->answers[i]) {
+ threshs[i] = atof(opt.thresh->answers[i]);
+ G_debug(1, "thresh : %s -> %f ", opt.tool->answers[i], threshs[i]);
if (threshs[i] != 0 && tools[i] != TOOL_SNAP &&
tools[i] != TOOL_RMDANGLE && tools[i] != TOOL_CHDANGLE &&
@@ -265,20 +270,20 @@
* virtual centroids (shapefile/OGR) and level 1 is better if input is too big
* and build in previous module (like v.in.ogr or other call to v.clean) would take
* a long time */
- level = Vect_open_old2(&In, in_opt->answer, "", field_opt->answer);
+ Vect_open_old2(&In, opt.in->answer, "", opt.field->answer);
with_z = Vect_is_3d(&In);
Vect_set_fatal_error(GV_FATAL_PRINT);
- if (0 > Vect_open_new(&Out, out_opt->answer, with_z)) {
+ if (0 > Vect_open_new(&Out, opt.out->answer, with_z)) {
Vect_close(&In);
exit(EXIT_FAILURE);
Vect_set_open_level(2);
- if (0 > Vect_open_new(&Err, err_opt->answer, with_z)) {
+ if (0 > Vect_open_new(&Err, opt.err->answer, with_z)) {
Vect_close(&In);
Vect_close(&Out);
exit(EXIT_FAILURE);
@@ -295,11 +300,21 @@
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
+ native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
+ if (!native) {
+ /* Copy attributes (OGR format) */
+ Vect_copy_map_dblinks(&In, &Out, TRUE);
/* This works for both level 1 and 2 */
- Vect_copy_map_lines_field(&In, Vect_get_field_number(&In, field_opt->answer), &Out);
- if (Vect_copy_tables(&In, &Out, 0))
- G_warning(_("Failed to copy attribute table to output map"));
+ Vect_copy_map_lines_field(&In, Vect_get_field_number(&In, opt.field->answer), &Out);
+ if (native) {
+ /* Copy attribute tables (native format only) */
+ if (Vect_copy_tables(&In, &Out, 0))
+ G_warning(_("Failed to copy attribute table to output vector map"));
Vect_set_release_support(&In);
Vect_close(&In);
@@ -334,7 +349,7 @@
case TOOL_BREAK:
G_message(_("Tool: Break lines at intersections"));
Vect_break_lines(&Out, otype, pErr);
- if (combine_flag->answer) {
+ if (flag.combine->answer) {
G_message(_("Tool: Remove duplicates"));
Vect_remove_duplicates(&Out, otype, pErr);
@@ -366,7 +381,7 @@
case TOOL_SNAP:
G_message(_("Tool: Snap line to vertex in threshold"));
Vect_snap_lines(&Out, otype, threshs[i], pErr);
int nmod;
do {
@@ -383,7 +398,7 @@
case TOOL_BPOL:
G_message(_("Tool: Break polygons"));
Vect_break_polygons(&Out, otype, pErr);
@@ -399,7 +414,7 @@
break;
case TOOL_RMSA:
G_message(_("Tool: Remove small angles at nodes"));
- if (!combine_flag->answer) {
+ if (!flag.combine->answer) {
count =
Vect_clean_small_angles_at_nodes(&Out, otype, pErr);
@@ -426,7 +441,7 @@
G_message(SEP);
- if (!no_build_flag->answer) {
+ if (!flag.no_build->answer) {
G_important_message(_("Rebuilding topology for output vector map..."));
Vect_build_partial(&Out, GV_BUILD_NONE);
Vect_build(&Out);
