[GRASS-SVN] r48949 - grass/trunk/vector/v.extract
svn_grass at osgeo.org
Wed Oct 26 05:14:58 EDT 2011
Author: martinl
Date: 2011-10-26 02:14:58 -0700 (Wed, 26 Oct 2011)
New Revision: 48949
grass/trunk/vector/v.extract/extract.c
grass/trunk/vector/v.extract/main.c
v.extract: use Vect_copy_map_dblinks()
Modified: grass/trunk/vector/v.extract/extract.c
--- grass/trunk/vector/v.extract/extract.c 2011-10-26 09:06:05 UTC (rev 48948)
+++ grass/trunk/vector/v.extract/extract.c 2011-10-26 09:14:58 UTC (rev 48949)
@@ -194,7 +194,7 @@
struct Map_info *Out, int new, int select_type, int dissolve,
int field, int type_only, int reverse)
- int line, nlines, is_ogr;
+ int line, nlines, native;
struct line_pnts *Points;
struct line_cats *Line_Cats_Old, *CCats;
@@ -220,10 +220,10 @@
qsort(cats_array, ncats_array, sizeof(int), cmp);
/* writting OGR layers directly */
- is_ogr = Vect_maptype(Out) == GV_FORMAT_OGR_DIRECT;
- if (is_ogr && Vect_level(In) < 2)
+ native = Vect_maptype(Out) == GV_FORMAT_NATIVE;
+ if (!native && Vect_level(In) < 2)
G_warning(_("Topology level required for extracting areas "
- "for OGR layers"));
+ "for OGR layers. Areas will be not processed."));
/* Cycle through all lines */
nlines = Vect_get_num_lines(In);
@@ -243,7 +243,7 @@
type = Vect_read_line(In, Points, Line_Cats_Old, line);
G_debug(3, "type = %d ncats = %d", type, Line_Cats_Old->n_cats);
- if (is_ogr && type == GV_BOUNDARY)
+ if (!native && type == GV_BOUNDARY)
/* OGR layers writes areas as polygons */
continue;
@@ -388,7 +388,7 @@
if (write) {
extract_cats(Line_Cats_Old, type_only, field, new, reverse);
- if (is_ogr && type == GV_CENTROID && area > 0)
+ if (!native && type == GV_CENTROID && area > 0)
extract_area(In, Out, area, Points, Line_Cats_Old, field);
else
Vect_write_line(Out, type, Points, Line_Cats_Old);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2011-10-26 09:06:05 UTC (rev 48948)
+++ grass/trunk/vector/v.extract/main.c 2011-10-26 09:14:58 UTC (rev 48949)
@@ -43,7 +43,7 @@
int main(int argc, char **argv)
- int i, new_cat, type, ncats, *cats, c, is_ogr;
+ int i, new_cat, type, ncats, *cats, c, native;
int field, dissolve, x, y, type_only;
char buffr[1024], text[80];
char *input, *output;
@@ -349,16 +349,10 @@
G_message(_("Extracting features..."));
- is_ogr = Vect_maptype(&Out) == GV_FORMAT_OGR_DIRECT;
- if (!flag.t->answer && is_ogr) {
+ native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
+ if (!flag.t->answer && !native) {
/* Copy attributes for OGR output */
- if (!Fi)
- Fi = Vect_get_field(&In, field);
- if (!Fi)
- G_fatal_error(_("Database connection not defined for layer <%s>"),
- opt.field->answer);
- Vect_map_add_dblink(&Out, Fi->number, Fi->name, Fi->table, Fi->key,
- Fi->database, Fi->driver);
+ Vect_copy_map_dblinks(&In, &Out, TRUE);
extract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve, field,
@@ -367,7 +361,7 @@
Vect_build(&Out);
/* Copy tables */
- if (!flag.t->answer && !is_ogr) {
+ if (!flag.t->answer && native) {
copy_tabs(&In, field, new_cat, &Out);
