[GRASS-SVN] r48969 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Oct 27 12:46:27 EDT 2011
Author: huhabla
Date: 2011-10-27 09:46:27 -0700 (Thu, 27 Oct 2011)
New Revision: 48969
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/lib/python/temporal/temporal_extent.py
Bug fixing. New method to sample a spcae time dataset by granularity.
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2011-10-27 16:32:10 UTC (rev 48968)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2011-10-27 16:46:27 UTC (rev 48969)
@@ -104,7 +104,7 @@
@param end_time: A double value in days
- if start_time and end_time:
+ if start_time != None and end_time != None:
if abs(float(start_time)) > abs(float(end_time)):
core.fatal(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
else:
@@ -161,8 +161,8 @@
else:
start, end = self.get_relative_time()
- if start:
- if end:
+ if start != None:
+ if end != None:
if start >= end:
core.error(_("Map <%s> has incorrect time interval, start time is greater than end time") % (self.get_id()))
return False
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-10-27 16:32:10 UTC (rev 48968)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-10-27 16:46:27 UTC (rev 48969)
@@ -223,9 +223,9 @@
if maps[i].is_time_relative():
start, end = maps[i].get_relative_time()
- if start and end:
+ if start != None and end != None:
time_interval += 1
- elif start and not end:
+ elif start != None and end == None:
time_point += 1
else:
time_invalid += 1
@@ -345,6 +345,78 @@
return True
+ def get_registered_maps_as_objects_by_granularity(self, gran=None, dbif=None):
+ """Return all registered maps as ordered (by start_time) object list with
+ "gap" map objects (id==None) for temporal topological operations using the
+ granularity of the space time dataset as increment
+ A valid temporal topology (no overlapping or inclusion allowed) is needed to get correct results.
+ The dataset must have "interval" as temporal map type, so all maps have valid interval time.
+ Gaps between maps are identified as unregistered maps with id==None.
+ The objects are initialized with the id and the temporal extent (temporal type, start time, end time).
+ In case more map informations are needed, use the select() method for each listed object.
+ @param gran: The granularity to be used
+ @param dbif: The database interface to be used
+ In case nothing found None is returned
+ connect = False
+ if dbif == None:
+ dbif = sql_database_interface()
+ dbif.connect()
+ connect = True
+ obj_list = []
+ if self.get_map_time() != "interval":
+ core.error(_("The temporal map type must be interval"))
+ #TODO: Check for valid topology too?
+ return None
+ if gran == None:
+ gran = self.get_granularity()
+ start, end = self.get_valid_time()
+ while start < end:
+ if self.is_time_absolute():
+ next = increment_datetime_by_string(start, gran)
+ else:
+ next = start + gran
+ where = "(start_time <= '%s' and end_time >= '%s')" % (start, next)
+ rows = self.get_registered_maps("id", where, "start_time", dbif)
+ if rows:
+ if len(rows) > 1:
+ core.error(_("More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."))
+ # Take the first map
+ map = self.get_new_map_instance(rows[0]["id"])
+ else:
+ # In case of a gap, create a dummy map with identifier None
+ map = self.get_new_map_instance(None)
+ map.set_absolute_time(start, next)
+ elif self.is_time_relative():
+ map.set_relative_time(start, next)
+ obj_list.append(copy.copy(map))
+ start = next
+ if connect == True:
+ dbif.close()
+ return obj_list
def get_registered_maps_as_objects_with_gaps(self, where=None, dbif=None):
@@ -881,12 +953,15 @@
if dbmi.__name__ == "sqlite3":
tstring = row[0]
# Convert the unicode string into the datetime format
- if tstring.find(":") > 0:
- time_format = "%Y-%m-%d %H:%M:%S"
- else:
- time_format = "%Y-%m-%d"
+ if tstring.find(":") > 0:
+ time_format = "%Y-%m-%d %H:%M:%S"
+ else:
+ time_format = "%Y-%m-%d"
- max_start_time = datetime.strptime(tstring, time_format)
+ max_start_time = datetime.strptime(tstring, time_format)
+ else:
+ max_start_time = row[0]
else:
@@ -939,7 +1014,7 @@
gran = compute_absolute_time_granularity(maps)
- gran = compute_absolute_time_granularity(maps)
+ gran = compute_relative_time_granularity(maps)
else:
gran = None
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-27 16:32:10 UTC (rev 48968)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-10-27 16:46:27 UTC (rev 48969)
@@ -28,7 +28,6 @@
def register_maps_in_space_time_dataset(type, name, maps=None, file=None, start=None, end=None, increment=None, dbif = None, interval=False, fs="|"):
"""Use this method to register maps in space time datasets. This function is generic and
- can handle raster, vector and raster3d maps as well as there space time datasets.
Additionally a start time string and an increment string can be specified
to assign a time interval automatically to the maps.
@@ -407,7 +406,7 @@
else:
mapid = entry
- sp = dataset_factory(type, id)
+ map = dataset_factory(type, mapid)
# Use the time data from file
if start_time_in_file:
@@ -557,6 +556,7 @@
* "comma": Print the map ids (name at mapset) as comma separated string
* "delta": Print the map ids (name at mapset) with start time, end time, relative length of intervals and the relative distance to the begin
* "deltagaps": Same as "delta" with addtitionakl listing of gaps. Gaps can be simply identified as the id is "None"
+ * "gran": List map using the granularity of the space time dataset, columns are identical to deltagaps
@param header: Set True to print column names
mapset = core.gisenv()["MAPSET"]
@@ -577,12 +577,14 @@
separator = "\t"
# This method expects a list of objects for gap detection
- if method == "delta" or method == "deltagaps":
+ if method == "delta" or method == "deltagaps" or method == "gran":
columns = "id,start_time,end_time"
if method == "deltagaps":
maps = sp.get_registered_maps_as_objects_with_gaps(where, None)
- else:
+ elif method == "delta":
maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+ elif method == "gran":
+ maps = sp.get_registered_maps_as_objects_by_granularity(None)
if header:
string = ""
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2011-10-27 16:32:10 UTC (rev 48968)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2011-10-27 16:46:27 UTC (rev 48969)
@@ -288,8 +288,6 @@
return "started"
if self.finished(map):
return "finished"
- if self.equivalent(map):
- return "equivalent"
if self.follows(map):
return "follows"
if self.precedes(map):
