[GRASS-SVN] r48970 - in grass/trunk/temporal: . t.time.rel
t.topology tr.list tr.out.vtk tr3.list tv.list
svn_grass at osgeo.org
Thu Oct 27 12:47:34 EDT 2011
Author: huhabla
Date: 2011-10-27 09:47:34 -0700 (Thu, 27 Oct 2011)
New Revision: 48970
Added:
grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
grass/trunk/temporal/tr.out.vtk/
grass/trunk/temporal/tr.out.vtk/Makefile
grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh
grass/trunk/temporal/tr.out.vtk/tr.out.vtk.html
grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py
Removed:
grass/trunk/temporal/t.topology/test.t.topology.sh
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/tr.list/test.tr.list.sh
grass/trunk/temporal/tr.list/tr.list.py
grass/trunk/temporal/tr3.list/tr3.list.py
grass/trunk/temporal/tv.list/tv.list.py
New VTK time series export modules. New option for tr.list: sample space
time datasets with granularity. Bug fixing and tests.
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/Makefile 2011-10-27 16:47:34 UTC (rev 48970)
@@ -17,6 +17,7 @@
tr3.list \
tr.series \
tr.export \
+ tr.out.vtk \
tr.import \
tr.extract \
tr3.register \
Modified: grass/trunk/temporal/t.time.rel/test.t.time.rel.sh
--- grass/trunk/temporal/t.time.rel/test.t.time.rel.sh 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/t.time.rel/test.t.time.rel.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -28,9 +28,13 @@
# Check if the space time inputs are updated correctly
t.time.rel --v input=prec_1,prec_2,prec_3 start=0 increment=1000
t.info type=strds input=precip_rel1
+t.topology type=strds input=precip_rel1
+t.topology -m type=strds input=precip_rel1
t.time.rel --v -i input=prec_1,prec_2,prec_3 start=0 increment=1000 -i
t.time.rel --v input=prec_4,prec_5 start=5000 end=6000
t.info type=rast input=prec_4
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/t.topology/t.topology.py 2011-10-27 16:47:34 UTC (rev 48970)
@@ -41,30 +41,10 @@
#%end
#%flag
-#% key: c
-#% description: Check temporal topology
-#%end
-#%flag
-#% key: g
-#% description: Compute granularity
-#%end
-#%flag
-#% key: t
+#% key: m
#% description: Print temporal relation matrix and exit
#%end
-#%flag
-#% key: r
-#% description: Print temporal relation count
-#%end
-#%flag
-#% key: m
-#% description: Print temporal map type count
-#%end
import grass.script as grass
import grass.temporal as tgis
@@ -76,11 +56,7 @@
name = options["input"]
type = options["type"]
where = options["where"]
- tmatrix = flags['t']
- relation = flags['r']
- map_types = flags['m']
- check_topo = flags['c']
- comp_gran = flags['g']
+ tmatrix = flags['m']
# Make sure the temporal database exists
tgis.create_temporal_database()
@@ -103,37 +79,80 @@
# Get ordered map list
maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=None)
- if check_topo:
- check = sp.check_temporal_topology(maps)
- if check:
- print "Temporal topology is valid"
- else:
- print "Temporal topology is invalid"
if tmatrix:
matrix = sp.print_temporal_relation_matrix(maps)
+ return
- if relation:
- dict = sp.count_temporal_relations(maps)
+ sp.base.print_info()
- for key in dict.keys():
- print key, dict[key]
+ # 0123456789012345678901234567890
+ print " +-------------------- Temporal topology -------------------------------------+"
+ if where:
+ print " | Is subset of dataset: ...... True"
+ else:
+ print " | Is subset of dataset: ...... False"
- if map_types:
- dict = sp.count_temporal_types(maps)
+ check = sp.check_temporal_topology(maps)
+ if check:
+ print " | Temporal topology is: ...... valid"
+ else:
+ print " | Temporal topology is: ...... invalid"
- if dict["invalid"] == 0:
- print "Gaps", sp.count_gaps(maps)
- else:
- print "Gaps", None
+ dict = sp.count_temporal_types(maps)
+ for key in dict.keys():
+ if key == "interval":
+ print " | Number of intervals: ....... %s" % (dict[key])
+ if key == "point":
+ print " | Number of points: .......... %s" % (dict[key])
+ if key == "invalid":
+ print " | Invalid time stamps: ....... %s" % (dict[key])
- if comp_gran:
+ print " | Number of gaps: ............ %i" % sp.count_gaps(maps)
+ if sp.is_time_absolute():
gran = tgis.compute_absolute_time_granularity(maps)
- print "Granularity", gran
+ else:
+ gran = tgis.compute_relative_time_granularity(maps)
+ print " | Granularity: ............... %s" % str(gran)
+ print " +-------------------- Topological relations ---------------------------------+"
+ dict = sp.count_temporal_relations(maps)
+ if key == "equivalent":
+ print " | Equivalent: ................ %s" % (dict[key])
+ if key == "during":
+ print " | During: .................... %s" % (dict[key])
+ if key == "contains":
+ print " | Contains: .................. %s" % (dict[key])
+ if key == "overlaps":
+ print " | Overlaps: .................. %s" % (dict[key])
+ if key == "overlapped":
+ print " | Overlapped: ................ %s" % (dict[key])
+ if key == "after":
+ print " | After: ..................... %s" % (dict[key])
+ if key == "before":
+ print " | Before: .................... %s" % (dict[key])
+ if key == "starts":
+ print " | Starts: .................... %s" % (dict[key])
+ if key == "finishes":
+ print " | Finishes: .................. %s" % (dict[key])
+ if key == "started":
+ print " | Started: ................... %s" % (dict[key])
+ if key == "finished":
+ print " | Finished: .................. %s" % (dict[key])
+ if key == "follows":
+ print " | Follows: ................... %s" % (dict[key])
+ if key == "precedes":
+ print " | Precedes: .................. %s" % (dict[key])
+ print " +----------------------------------------------------------------------------+"
if __name__ == "__main__":
options, flags = grass.parser()
main()
Copied: grass/trunk/temporal/t.topology/test.t.topology.abstime.sh (from rev 48883, grass/trunk/temporal/t.topology/test.t.topology.sh)
--- grass/trunk/temporal/t.topology/test.t.topology.abstime.sh (rev 0)
+++ grass/trunk/temporal/t.topology/test.t.topology.abstime.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -0,0 +1,102 @@
+# This is a test to register and unregister raster maps in
+# space time raster input.
+# The raster maps will be registered in different space time raster
+# inputs
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+n1=`g.tempfile pid=1 -d`
+n2=`g.tempfile pid=2 -d`
+n3=`g.tempfile pid=3 -d`
+n4=`g.tempfile pid=4 -d`
+n5=`g.tempfile pid=5 -d`
+cat > $n1 << EOF
+prec_1
+prec_2
+prec_3
+prec_4
+prec_5
+prec_6
+EOF
+cat > $n2 << EOF
+prec_1|2001-01-01
+prec_2|2001-02-01
+prec_3|2001-03-01
+prec_4|2001-04-01
+prec_5|2001-05-01
+prec_6|2001-06-01
+EOF
+cat > $n3 << EOF
+prec_1|2001-01-01|2001-04-01
+prec_2|2001-05-01|2001-07-01
+prec_3|2001-08-01|2001-10-01
+prec_4|2001-11-01|2002-01-01
+prec_5|2002-02-01|2002-04-01
+prec_6|2002-05-01|2002-07-01
+EOF
+cat > $n4 << EOF
+prec_1|2001-01-01|2001-07-01
+prec_2|2001-02-01|2001-04-01
+prec_3|2001-03-01|2001-04-01
+prec_4|2001-04-01|2001-06-01
+prec_5|2001-05-01|2001-06-01
+prec_6|2001-06-01|2001-07-01
+EOF
+cat > $n5 << EOF
+prec_1|2001-01-01|2001-03-11
+prec_3|2001-03-01|2001-06-02
+prec_4|2001-04-01|2001-04-01
+prec_5|2001-05-01|2001-05-01
+EOF
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.create --o type=strds temporaltype=absolute output=precip_abs title="A test with input files" descr="A test with input files"
+tr.register -i input=precip_abs file=$n1 start="2001-01-01" increment="1 months"
+cat $n1
+t.topology input=precip_abs
+t.topology -m input=precip_abs
+tr.register -i input=precip_abs file=$n2 start=file
+cat $n2
+tr.register -i input=precip_abs file=$n3 start=file end=file
+cat $n3
+tr.register -i input=precip_abs file=$n4 start=file end=file
+cat $n4
+tr.register -i input=precip_abs file=$n5 start=file end=file
+cat $n5
+t.remove type=strds input=precip_abs
+t.remove type=rast file=$n1
Added: grass/trunk/temporal/t.topology/test.t.topology.reltime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.reltime.sh (rev 0)
+++ grass/trunk/temporal/t.topology/test.t.topology.reltime.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -0,0 +1,102 @@
+# inputs
+# with relative and relolute time
+cat > $n1 << EOF
+prec_1
+prec_2
+prec_3
+prec_4
+prec_5
+prec_6
+EOF
+cat > $n2 << EOF
+prec_1|1
+prec_2|2
+prec_3|3
+prec_4|4
+prec_5|5
+prec_6|6
+EOF
+cat > $n3 << EOF
+prec_1|1|4
+prec_2|5|7
+prec_3|8|10
+prec_4|11|12
+prec_5|13|14
+prec_6|15|25
+EOF
+cat > $n4 << EOF
+prec_1|2001|2007
+prec_2|2002|2004
+prec_3|2003|2004
+prec_4|2004|2006
+prec_5|2005|2006
+prec_6|2006|2007
+EOF
+cat > $n5 << EOF
+prec_1|2001|2003
+prec_2|2002|2004
+prec_3|2003|2006
+prec_4|2004|2004
+prec_5|2005|2005
+prec_6|2006|2007
+EOF
+# The first @test
+# We create the space time raster inputs and register the raster maps with relolute time interval
+t.create --o type=strds temporaltype=relative output=precip_rel title="A test with input files" descr="A test with input files"
+tr.register -i --v input=precip_rel file=$n1 start=0 increment=1
+cat $n1
+t.topology input=precip_rel
+t.topology -m input=precip_rel
+tr.register -i input=precip_rel file=$n2 start=file
+cat $n2
+tr.register -i input=precip_rel file=$n3 start=file end=file
+cat $n3
+tr.register -i input=precip_rel file=$n4 start=file end=file
+cat $n4
+tr.register -i input=precip_rel file=$n5 start=file end=file
+cat $n5
+t.remove type=strds input=precip_rel
Deleted: grass/trunk/temporal/t.topology/test.t.topology.sh
--- grass/trunk/temporal/t.topology/test.t.topology.sh 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/t.topology/test.t.topology.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -1,102 +0,0 @@
-# This is a test to register and unregister raster maps in
-# space time raster input.
-# The raster maps will be registered in different space time raster
-# inputs
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
-n1=`g.tempfile pid=1 -d`
-n2=`g.tempfile pid=2 -d`
-n3=`g.tempfile pid=3 -d`
-n4=`g.tempfile pid=4 -d`
-n5=`g.tempfile pid=5 -d`
-cat > $n1 << EOF
-prec_1
-prec_2
-prec_3
-prec_4
-prec_5
-prec_6
-EOF
-cat > $n2 << EOF
-prec_1|2001-01-01
-prec_2|2001-02-01
-prec_3|2001-03-01
-prec_4|2001-04-01
-prec_5|2001-05-01
-prec_6|2001-06-01
-EOF
-cat > $n3 << EOF
-prec_1|2001-01-01|2001-04-01
-prec_2|2001-05-01|2001-07-01
-prec_3|2001-08-01|2001-10-01
-prec_4|2001-11-01|2002-01-01
-prec_5|2002-02-01|2002-04-01
-prec_6|2002-05-01|2002-07-01
-EOF
-cat > $n4 << EOF
-prec_1|2001-01-01|2001-07-01
-prec_2|2001-02-01|2001-04-01
-prec_3|2001-03-01|2001-04-01
-prec_4|2001-04-01|2001-06-01
-prec_5|2001-05-01|2001-06-01
-prec_6|2001-06-01|2001-07-01
-EOF
-cat > $n5 << EOF
-prec_1|2001-01-01|2001-03-11
-prec_3|2001-03-01|2001-06-02
-prec_4|2001-04-01|2001-04-01
-prec_5|2001-05-01|2001-05-01
-EOF
-# The first @test
-# We create the space time raster inputs and register the raster maps with absolute time interval
-t.create --o type=strds temporaltype=absolute output=precip_abs title="A test with input files" descr="A test with input files"
-tr.register -i input=precip_abs file=$n1 start="2001-01-01" increment="1 months"
-t.info type=strds input=precip_abs
-cat $n1
-t.topology -gctmr input=precip_abs
-tr.register -i input=precip_abs file=$n2 start=file
-cat $n2
-tr.register -i input=precip_abs file=$n3 start=file end=file
-cat $n3
-tr.register -i input=precip_abs file=$n4 start=file end=file
-cat $n4
-tr.register -i input=precip_abs file=$n5 start=file end=file
-cat $n5
-t.remove type=strds input=precip_abs
-t.remove type=rast file=$n1
Modified: grass/trunk/temporal/tr.list/test.tr.list.sh
--- grass/trunk/temporal/tr.list/test.tr.list.sh 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/tr.list/test.tr.list.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -64,19 +64,29 @@
EOF
+t.create --o type=strds temporaltype=absolute output=precip_abs0 title="A test with input files" descr="A test with input files"
t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test with input files" descr="A test with input files"
t.create --o type=strds temporaltype=absolute output=precip_abs3 title="A test with input files" descr="A test with input files"
t.create --o type=strds temporaltype=absolute output=precip_abs4 title="A test with input files" descr="A test with input files"
t.create --o type=strds temporaltype=absolute output=precip_abs5 title="A test with input files" descr="A test with input files"
-# The first @test
+# The @test
+tr.register -i input=precip_abs0 file=$n1 start="2001-01-01" increment="1 months"
+tr.list fs=" | " method=comma input=precip_abs0
+tr.list -h input=precip_abs1
+tr.list -h fs=" | " method=cols input=precip_abs0
+tr.list -h fs=" | " method=delta input=precip_abs0
+tr.list -h fs=" | " method=deltagaps input=precip_abs0
+tr.list -h fs=" | " method=gran input=precip_abs0
tr.register input=precip_abs1 file=$n1 start="2001-01-01" increment="1 months"
tr.list fs=" | " method=comma input=precip_abs1
tr.list -h fs=" | " method=cols input=precip_abs1
tr.list -h fs=" | " method=delta input=precip_abs1
tr.list -h fs=" | " method=deltagaps input=precip_abs1
+tr.list -h fs=" | " method=gran input=precip_abs1
tr.register -i input=precip_abs2 file=$n2 start=file
tr.list fs=" | " method=comma input=precip_abs2
@@ -84,16 +94,19 @@
tr.list -h fs=" | " method=cols input=precip_abs2
tr.list -h fs=" | " method=delta input=precip_abs2
tr.list -h fs=" | " method=deltagaps input=precip_abs2
+tr.list -h fs=" | " method=gran input=precip_abs2
tr.register -i input=precip_abs3 file=$n3 start=file end=file
tr.list fs=" | " method=comma input=precip_abs3
tr.list -h fs=" | " method=delta input=precip_abs3
tr.list -h fs=" | " method=deltagaps input=precip_abs3
+tr.list -h fs=" | " method=gran input=precip_abs3
tr.register -i input=precip_abs4 file=$n4 start=file end=file
tr.list fs=" | " method=comma input=precip_abs4
tr.list -h fs=" | " method=delta input=precip_abs4
tr.list -h fs=" | " method=deltagaps input=precip_abs4
+tr.list -h fs=" | " method=gran input=precip_abs4
tr.register -i input=precip_abs5 file=$n5 start=file end=file
tr.list fs=" | " method=comma input=precip_abs5
@@ -101,6 +114,7 @@
tr.list -h fs=" | " method=cols input=precip_abs5
tr.list -h fs=" | " method=delta input=precip_abs5
tr.list -h fs=" | " method=deltagaps input=precip_abs5
+tr.list -h fs=" | " method=gran input=precip_abs5
t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5
+t.remove type=strds input=precip_abs0,precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5
Modified: grass/trunk/temporal/tr.list/tr.list.py
--- grass/trunk/temporal/tr.list/tr.list.py 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/tr.list/tr.list.py 2011-10-27 16:47:34 UTC (rev 48970)
@@ -61,10 +61,10 @@
#%option
#% key: method
#% type: string
-#% description: Which method should be used fot data listing
+#% description: Which method should be used for data listing
#% required: no
#% multiple: no
-#% options: cols,comma,delta,deltagaps
+#% options: cols,comma,delta,deltagaps,gran
#% answer: cols
#%end
Added: grass/trunk/temporal/tr.out.vtk/Makefile
--- grass/trunk/temporal/tr.out.vtk/Makefile (rev 0)
+++ grass/trunk/temporal/tr.out.vtk/Makefile 2011-10-27 16:47:34 UTC (rev 48970)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = tr.out.vtk
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh
--- grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh (rev 0)
+++ grass/trunk/temporal/tr.out.vtk/test.tr.out.vtk.sh 2011-10-27 16:47:34 UTC (rev 48970)
@@ -0,0 +1,53 @@
+# This is a test to export space time raster datasets as VTK time series data
+# raster with r.mapcalc and create a space time raster datasets
+g.region s=0 n=80 w=0 e=120 res=0.5 -p
+r.mapcalc --o expr="elevation = sin(row() + col()) * 10"
+cat > $n1 << EOF
+prec_1|2001-01-01|2001-02-01
+prec_2|2001-02-01|2001-03-01
+prec_4|2001-05-01|2001-06-01
+prec_5|2001-07-01|2001-08-01
+prec_6|2001-08-01|2001-09-01
+EOF
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
+t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test with input files" descr="A test with input files"
+t.create --o type=strds temporaltype=absolute output=precip_abs3 title="A test with input files" descr="A test with input files"
+# The first @test
+mkdir /tmp/test1
+tr.register -i input=precip_abs1 file=$n1 start=file end=file
+tr.out.vtk input=precip_abs1 expdir=/tmp/test1
+ls -al /tmp/test1
+mkdir /tmp/test2
+tr.register -i input=precip_abs2 file=$n1
+tr.out.vtk input=precip_abs2 expdir=/tmp/test2 elevation=elevation
+ls -al /tmp/test2
+mkdir /tmp/test3
+tr.register -i input=precip_abs3 file=$n1
+tr.out.vtk -g input=precip_abs3 expdir=/tmp/test3 elevation=elevation
+ls -al /tmp/test3
+rm -rf /tmp/test1
+rm -rf /tmp/test2
+rm -rf /tmp/test3
+t.remove type=rast input=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3
Added: grass/trunk/temporal/tr.out.vtk/tr.out.vtk.html
Added: grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py
--- grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py (rev 0)
+++ grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py 2011-10-27 16:47:34 UTC (rev 48970)
@@ -0,0 +1,169 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: tr.out.vtk
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Export space time raster dataset as VTK time series
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Export space time raster dataset as VTK time series
+#% keywords: dataset
+#% keywords: spacetime
+#% keywords: raster
+#% keywords: export
+#% keywords: VTK
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of a space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: expdir
+#% type: string
+#% description: Path to the export directory
+#% required: yes
+#% multiple: no
+#%end
+#%option G_OPT_R_INPUT
+#% key: elevation
+#% type: string
+#% description: Elevation raster map
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: A where statement for selected listing e.g: (start_time < '2001-01-01' and end_time > '2001-01-01')
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: null
+#% type: double
+#% description: Value to represent no data cell
+#% required: no
+#% multiple: no
+#% answer: -10.0
+#%end
+#%flag
+#% key: p
+#% description: Create VTK point data instead of VTK cell data (if no elevation map is given)
+#%end
+#%flag
+#% key: c
+#% description: Correct the coordinates to fit the VTK-OpenGL precision
+#%end
+#%flag
+#% key: g
+#% description: Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored
+#%end
+import os
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ input = options["input"]
+ elevation = options["elevation"]
+ expdir = options["expdir"]
+ where = options["where"]
+ null = options["null"]
+ use_pdata = flags["p"]
+ coorcorr = flags["c"]
+ use_granularity = flags["g"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ if not os.path.exists(expdir):
+ grass.fatal(_("Export directory <%s> not found.") % expdir)
+ os.chdir(expdir)
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = tgis.space_time_raster_dataset(id)
+ if sp.is_in_db() == False:
+ grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+ sp.select()
+ if use_granularity:
+ maps = sp.get_registered_maps_as_objects_by_granularity()
+ # Create a NULL map in case of granularity support
+ null_map = "temporary_null_map_%i" % os.getpid()
+ grass.mapcalc("%s = null()" % (null_map))
+ else:
+ maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+ # To have scalar values with the same name, we need to copy the raster maps using a single name
+ map_name = "%s_%i" % (sp.base.get_name(), os.getpid())
+ count = 0
+ if maps:
+ for map in maps:
+ id = map.get_id()
+ # None ids will be replaced by NULL maps
+ if id == None:
+ id = null_map
+ grass.run_command("g.copy", rast="%s,%s" % (id, map_name), overwrite=True)
+ out_name = "%6.6i_%s.vtk" % (count, sp.base.get_name())
+ mflags=""
+ if use_pdata:
+ mflags += "p"
+ if coorcorr:
+ mflags += "c"
+ # Export the raster map with r.out.vtk
+ if elevation:
+ ret = grass.run_command("r.out.vtk", flags=mflags, null=null, input=map_name, elevation=elevation, output=out_name, overwrite=grass.overwrite())
+ else:
+ ret = grass.run_command("r.out.vtk", flags=mflags, null=null, input=map_name, output=out_name, overwrite=grass.overwrite())
+ if ret != 0:
+ grass.fatal(_("Unable to export raster map <%s>" % name))
+ count += 1
+ grass.run_command("g.remove", rast=null_map)
+ grass.run_command("g.remove", rast=map_name)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/tr.out.vtk/tr.out.vtk.py
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/temporal/tr3.list/tr3.list.py
--- grass/trunk/temporal/tr3.list/tr3.list.py 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/tr3.list/tr3.list.py 2011-10-27 16:47:34 UTC (rev 48970)
@@ -61,10 +61,10 @@
#%option
#% key: method
#% type: string
#% required: no
#% multiple: no
#% answer: cols
#%end
Modified: grass/trunk/temporal/tv.list/tv.list.py
--- grass/trunk/temporal/tv.list/tv.list.py 2011-10-27 16:46:27 UTC (rev 48969)
+++ grass/trunk/temporal/tv.list/tv.list.py 2011-10-27 16:47:34 UTC (rev 48970)
@@ -61,10 +61,10 @@
#%option
#% key: method
#% type: string
#% required: no
#% multiple: no
#% answer: cols
#%end
