[GRASS-SVN] r48239 -
grass/branches/releasebranch_6_4/vector/v.kernel
svn_grass at osgeo.org
Sun Sep 11 17:24:59 EDT 2011
Author: neteler
Date: 2011-09-11 14:24:59 -0700 (Sun, 11 Sep 2011)
New Revision: 48239
grass/branches/releasebranch_6_4/vector/v.kernel/main.c
since default is defined, required = NO
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/main.c
--- grass/branches/releasebranch_6_4/vector/v.kernel/main.c 2011-09-11 20:58:44 UTC (rev 48238)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/main.c 2011-09-11 21:24:59 UTC (rev 48239)
@@ -159,7 +159,7 @@
node_opt = G_define_option();
node_opt->key = "node";
node_opt->type = TYPE_STRING;
- node_opt->required = YES;
+ node_opt->required = NO;
node_opt->description = _("Node method");
node_opt->options = "none,split";
node_opt->answer = "none";
@@ -170,7 +170,7 @@
kernel_opt = G_define_option();
kernel_opt->key = "kernel";
kernel_opt->type = TYPE_STRING;
- kernel_opt->required = YES;
+ kernel_opt->required = NO;
kernel_opt->description = _("Kernel function");
kernel_opt->options =
"uniform,triangular,epanechnikov,quartic,triweight,gaussian,cosine";
