[GRASS-SVN] r48240 - grass/trunk/raster/r.univar
    svn_grass at osgeo.org
    Sun Sep 11 17:25:05 EDT 2011
Author: hamish
Date: 2011-09-11 14:25:05 -0700 (Sun, 11 Sep 2011)
New Revision: 48240
   grass/trunk/raster/r.univar/globals.h
   grass/trunk/raster/r.univar/stats.c
allow n to be really big
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h	2011-09-11 21:24:59 UTC (rev 48239)
+++ grass/trunk/raster/r.univar/globals.h	2011-09-11 21:25:05 UTC (rev 48240)
@@ -34,14 +34,14 @@
     unsigned int n_perc;
     double *perc;
     double sum_abs;
-    int n;
-    int size;
+    unsigned long n;
+    unsigned long size;
     DCELL *dcell_array;
     FCELL *fcell_array;
     CELL *cell_array;
     int map_type;
     void *nextp;
-    int n_alloc;
+    off_t n_alloc;
     int first;
 } univar_stat;
Modified: grass/trunk/raster/r.univar/stats.c
--- grass/trunk/raster/r.univar/stats.c	2011-09-11 21:24:59 UTC (rev 48239)
+++ grass/trunk/raster/r.univar/stats.c	2011-09-11 21:25:05 UTC (rev 48240)
@@ -141,15 +141,15 @@
 	if (!param.shell_style->answer) {
-	    fprintf(stdout, "total null and non-null cells: %d\n", stats[z].size);
-	    fprintf(stdout, "total null cells: %d\n\n", stats[z].size - stats[z].n);
+	    fprintf(stdout, "total null and non-null cells: %lu\n", stats[z].size);
+	    fprintf(stdout, "total null cells: %lu\n\n", stats[z].size - stats[z].n);
 	    fprintf(stdout, "Of the non-null cells:\n----------------------\n");
 	if (param.shell_style->answer) {
-	    fprintf(stdout, "n=%d\n", stats[z].n);
-	    fprintf(stdout, "null_cells=%d\n", stats[z].size - stats[z].n);
-	    fprintf(stdout, "cells=%d\n", stats->size);
+	    fprintf(stdout, "n=%lu\n", stats[z].n);
+	    fprintf(stdout, "null_cells=%lu\n", stats[z].size - stats[z].n);
+	    fprintf(stdout, "cells=%lu\n", stats->size);
 	    fprintf(stdout, "min=%.15g\n", stats[z].min);
 	    fprintf(stdout, "max=%.15g\n", stats[z].max);
 	    fprintf(stdout, "range=%.15g\n", stats[z].max - stats[z].min);
@@ -161,7 +161,7 @@
 	    fprintf(stdout, "sum=%s\n", sum_str);
 	else {
-	    fprintf(stdout, "n: %d\n", stats[z].n);
+	    fprintf(stdout, "n: %lu\n", stats[z].n);
 	    fprintf(stdout, "minimum: %g\n", stats[z].min);
 	    fprintf(stdout, "maximum: %g\n", stats[z].max);
 	    fprintf(stdout, "range: %g\n", stats[z].max - stats[z].min);
@@ -377,9 +377,9 @@
 	/* non-null cells cells */
-	fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
+	fprintf(stdout, "%lu%s", stats[z].n, zone_info.sep);
 	/* null cells */
-	fprintf(stdout, "%d%s", stats[z].size - stats[z].n, zone_info.sep);
+	fprintf(stdout, "%lu%s", stats[z].size - stats[z].n, zone_info.sep);
 	/* min */
 	fprintf(stdout, "%.15g%s", stats[z].min, zone_info.sep);
 	/* max */
