[GRASS-SVN] r48242 - grass/trunk/vector/v.kernel
Sun Sep 11 17:25:24 EDT 2011
Author: neteler
Date: 2011-09-11 14:25:24 -0700 (Sun, 11 Sep 2011)
New Revision: 48242
   grass/trunk/vector/v.kernel/main.c
since default is defined, required = NO
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2011-09-11 21:25:10 UTC (rev 48241)
+++ grass/trunk/vector/v.kernel/main.c	2011-09-11 21:25:24 UTC (rev 48242)
@@ -161,7 +161,7 @@
     node_opt = G_define_option();
     node_opt->key = "node";
     node_opt->type = TYPE_STRING;
-    node_opt->required = YES;
+    node_opt->required = NO;
     node_opt->description = _("Node method");
     node_opt->options = "none,split";
     node_opt->answer = "none";
@@ -172,7 +172,7 @@
     kernel_opt = G_define_option();
     kernel_opt->key = "kernel";
     kernel_opt->type = TYPE_STRING;
-    kernel_opt->required = YES;
+    kernel_opt->required = NO;
     kernel_opt->description = _("Kernel function");
     kernel_opt->options =
 	"uniform,triangular,epanechnikov,quartic,triweight,gaussian,cosine";
