[GRASS-SVN] r48243 -
grass/branches/develbranch_6/scripts/g.extension
svn_grass at osgeo.org
Mon Sep 12 02:20:27 EDT 2011
Author: hamish
Date: 2011-09-11 23:20:27 -0700 (Sun, 11 Sep 2011)
New Revision: 48243
grass/branches/develbranch_6/scripts/g.extension/g.extension
whitespace/line wrap
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension 2011-09-11 21:25:24 UTC (rev 48242)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension 2011-09-12 06:20:27 UTC (rev 48243)
@@ -6,7 +6,7 @@
# AUTHOR(S): Markus Neteler
# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
# local GRASS installation
-# COPYRIGHT: (C) 2009-2010 by the Markus Neteler, GRASS Development Team
+# COPYRIGHT: (C) 2009-2011 by Markus Neteler, and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -14,13 +14,11 @@
#%Module
#% label: Tool to maintain GRASS extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
#% keywords: general, extensions
#%End
#%option
#% key: extension
#% type: string
@@ -282,7 +280,13 @@
cd "$TMPDIR/$MODULE"
g.message message="Compiling <$MODULE>..."
-make MODULE_TOPDIR="$GISBASE" ARCH_INC="-I$GISBASE/include -I${MYINST_DIR}/include -I$TMPDIR/dist/include" ARCH_LIBPATH="-L$GISBASE/lib -L${MYINST_DIR}/lib -L$TMPDIR/dist/lib" ARCH_LIBDIR="$GISBASE/lib" ARCH_DISTDIR="$TMPDIR/dist"
+make MODULE_TOPDIR="$GISBASE" \
+ ARCH_INC="-I$GISBASE/include -I${MYINST_DIR}/include -I$TMPDIR/dist/include" \
+ ARCH_LIBPATH="-L$GISBASE/lib -L${MYINST_DIR}/lib -L$TMPDIR/dist/lib" \
+ ARCH_LIBDIR="$GISBASE/lib" \
+ ARCH_DISTDIR="$TMPDIR/dist"
if [ $? -ne 0 ] ; then
g.message -e message="Compilation failed, sorry. Please check above error messages."
cleanup
@@ -322,16 +326,23 @@
fi
if [ $GIS_FLAG_U -eq 1 ] ; then
g.message "You may need to enter your password to install $MODULE:"
- sudo make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install
+ sudo make MODULE_TOPDIR="$GISBASE" \
+ ARCH_DISTDIR="$TMPDIR/dist" \
+ INST_DIR="$MYINST_DIR" install
else
g.message "You need to enter the root password to install $MODULE:"
su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
fi
else
if test -f "$MYINST_DIR/$PROGTYPE/$MODULE" ; then
rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
fi
- make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install
+ make MODULE_TOPDIR="$GISBASE" \
fi
