[GRASS-SVN] r48287 - grass/trunk/lib/temporal
svn_grass at osgeo.org
Tue Sep 13 20:58:07 EDT 2011
Author: huhabla
Date: 2011-09-13 17:58:07 -0700 (Tue, 13 Sep 2011)
New Revision: 48287
Added:
grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql
grass/trunk/lib/temporal/map_stds_register_table_template.sql
grass/trunk/lib/temporal/str3ds_metadata_table.sql
grass/trunk/lib/temporal/strds_metadata_table.sql
grass/trunk/lib/temporal/stvds_metadata_table.sql
grass/trunk/lib/temporal/test.temporal.py
Minor SQL fixes and improved table name handling.
Modified: grass/trunk/lib/temporal/map_stds_register_table_template.sql
--- grass/trunk/lib/temporal/map_stds_register_table_template.sql 2011-09-13 22:22:28 UTC (rev 48286)
+++ grass/trunk/lib/temporal/map_stds_register_table_template.sql 2011-09-14 00:58:07 UTC (rev 48287)
@@ -3,32 +3,32 @@
-- which the GRASS_MAP map is registered
-- This table is map specific and created for each GRASS_MAP map which is registered
--- in a STDS. MAP_NAME is a placeholder for the dataset name.
+-- in a STDS. TABLE_NAME is a placeholder for the dataset name.
-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
PRAGMA foreign_keys = ON;
--- MAP_NAME is a placeholder for specific map name (SQL compliant): name_mapset
+-- TABLE_NAME is a placeholder for specific map name (SQL compliant): name_mapset
-- MAP_ID is a placeholder for specific map id: name at mapset
-- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
-- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
-- This table stores the names of the space-time datasets in which this map is registered
-CREATE TABLE MAP_NAME_STDS_register (
+CREATE TABLE TABLE_NAME_STDS_register (
id VARCHAR NOT NULL, -- This column is a primary foreign key storing the STDS names
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES STDS_base (id) ON DELETE CASCADE
-CREATE TRIGGER MAP_NAME_STDS_register_insert AFTER INSERT ON MAP_NAME_STDS_register
+CREATE TRIGGER TABLE_NAME_STDS_register_insert AFTER INSERT ON TABLE_NAME_STDS_register
BEGIN
UPDATE GRASS_MAP_base SET modification_time = datetime("NOW") WHERE GRASS_MAP_base.id = "MAP_ID";
UPDATE GRASS_MAP_base SET revision = (revision + 1) WHERE GRASS_MAP_base.id = "MAP_ID";
END;
-CREATE TRIGGER MAP_NAME_STDS_register_delete AFTER DELETE ON MAP_NAME_STDS_register
+CREATE TRIGGER TABLE_NAME_STDS_register_delete AFTER DELETE ON TABLE_NAME_STDS_register
BEGIN
Added: grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql (rev 0)
+++ grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql 2011-09-14 00:58:07 UTC (rev 48287)
@@ -0,0 +1,6 @@
+-- This SQL script is for now a placeholder, till the vector metadata
+-- concept is clear
+-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
\ No newline at end of file
Modified: grass/trunk/lib/temporal/str3ds_metadata_table.sql
--- grass/trunk/lib/temporal/str3ds_metadata_table.sql 2011-09-13 22:22:28 UTC (rev 48286)
+++ grass/trunk/lib/temporal/str3ds_metadata_table.sql 2011-09-14 00:58:07 UTC (rev 48287)
@@ -29,7 +29,7 @@
-- Create the views to access all cols for absolute or relative time
CREATE VIEW str3ds_view_abs_time AS SELECT
- A1.id, A1.temporal_type,
+ A1.id, A1.name, A1.mapset, A1.temporal_type,
A1.creator, A1.semantic_type,
A1.creation_time, A1.modification_time,
A1.revision, A2.start_time,
@@ -48,7 +48,7 @@
A1.id = A3.id AND A1.id = A4.id;
CREATE VIEW str3ds_view_rel_time AS SELECT
A1.revision,
Modified: grass/trunk/lib/temporal/strds_metadata_table.sql
--- grass/trunk/lib/temporal/strds_metadata_table.sql 2011-09-13 22:22:28 UTC (rev 48286)
+++ grass/trunk/lib/temporal/strds_metadata_table.sql 2011-09-14 00:58:07 UTC (rev 48287)
@@ -27,7 +27,7 @@
CREATE VIEW strds_view_abs_time AS SELECT
@@ -45,7 +45,7 @@
CREATE VIEW strds_view_rel_time AS SELECT
A1.revision,
Modified: grass/trunk/lib/temporal/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/stvds_metadata_table.sql 2011-09-13 22:22:28 UTC (rev 48286)
+++ grass/trunk/lib/temporal/stvds_metadata_table.sql 2011-09-14 00:58:07 UTC (rev 48287)
@@ -61,7 +61,7 @@
BEGIN
DELETE FROM stvds_absolute_time WHERE id = old.id;
DELETE FROM stvds_relative_time WHERE id = old.id;
- DELETE FROM stvds_spatial_exntent WHERE id = old.id;
+ DELETE FROM stvds_spatial_extent WHERE id = old.id;
DELETE FROM stvds_metadata WHERE id = old.id;
END;
Modified: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py 2011-09-13 22:22:28 UTC (rev 48286)
+++ grass/trunk/lib/temporal/test.temporal.py 2011-09-14 00:58:07 UTC (rev 48287)
@@ -1,7 +1,12 @@
import os
-from grass.script.temporal import *
+from grass.script.tgis_core import *
+from grass.script.tgis_base import *
+from grass.script.tgis_temporal_extent import *
+from grass.script.tgis_spatial_extent import *
+from grass.script.tgis_metadata import *
+from grass.script.tgis_map_datasets import *
+from grass.script.tgis_space_time_datasets import *
import grass.script as grass
def test_dict_sql_serializer():
@@ -629,7 +634,7 @@
# Reread the data from the db
strds.select()
# Print self info
- strds.print_self()
+ #strds.print_self()
# Create a test maps
for i in range(11):
@@ -666,11 +671,13 @@
# Register the map in the space time raster dataset
strds.register_map(rds)
# Print self info
- rds.print_self()
+ #rds.print_self()
strds.select()
# Print self info
strds.print_self()
+ # Delete the dataset
+ strds.delete()
def test_str3ds_dataset():
@@ -693,7 +700,7 @@
str3ds.select()
# Print self info
- str3ds.print_self()
+ #str3ds.print_self()
for i in range(11):
@@ -730,25 +737,96 @@
str3ds.register_map(r3ds)
# Print self info
- r3ds.print_self()
+ #r3ds.print_self()
str3ds.select()
# Print self info
str3ds.print_self()
+ str3ds.delete()
-#test_dict_sql_serializer()
+def test_stvds_dataset():
+ name = "stvds_test_1"
+ mapset = grass.gisenv()["MAPSET"]
+ print "Create a stvds object"
+ # We need to specify the name and the mapset as identifier
+ stvds = space_time_vector_dataset(ident = name + "@" + mapset)
+ # Check if in db
+ print "Is stvds in db: ", stvds.is_in_db()
+ # Create a new entry if not in db
+ if stvds.is_in_db() == False:
+ stvds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
+ semantic_type="event", title="This is a test space time vector dataset", description="A space time vector dataset for testing")
+ stvds.insert()
+ # Reread the data from the db
+ stvds.select()
+ # Print self info
+ #stvds.print_self()
+ # Create a test maps
+ for i in range(11):
+ name = "test" + str(i)
+ ident = name + "@" + mapset
+ i = i + 1
+ grass.run_command("v.random", output=name, n=100, zmin=0, zmax=100, column="height" ,flags="z" , overwrite = True)
+ print "Create a vector object"
+ vds = vector_dataset(ident)
+ # Load data from the raster map in the mapset
+ vds.load()
+ print "Is vector in db: ", vds.is_in_db()
+ if vds.is_in_db():
+ vds.select()
+ vds.print_self()
+ # Remove the entry if it is in the db
+ vds.delete()
+ vds.reset(ident)
+ vds.load()
+ # Set the absolute valid time
+ vds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
+ end_time= datetime(year=2000, month=i + 1, day=1))
+ # Insert the map data into the SQL database
+ vds.insert()
+ # Register the map in the space time raster dataset
+ stvds.register_map(vds)
+ # Print self info
+ #vds.print_self()
+ stvds.select()
+ # Print self info
+ stvds.print_self()
+ stvds.delete()
+test_dict_sql_serializer()
create_temporal_database()
-#test_dataset_identifer()
-#test_absolute_timestamp()
-#test_relative_timestamp()
-#test_spatial_extent()
-#test_map_metadata()
-#test_base_absolute_time_extent_metadata()
-#test_absolut_time_temporal_relations()
-#test_raster_dataset()
-#test_raster3d_dataset()
-#test_vector_dataset()
+test_dataset_identifer()
+test_absolute_timestamp()
+test_relative_timestamp()
+test_spatial_extent()
+test_map_metadata()
+test_base_absolute_time_extent_metadata()
+test_absolut_time_temporal_relations()
-#test_strds_dataset()
-test_str3ds_dataset()
+test_raster_dataset()
+test_raster3d_dataset()
+test_vector_dataset()
+test_strds_dataset()
+test_str3ds_dataset()
+test_stvds_dataset()
