[GRASS-SVN] r48288 - grass/trunk/lib/python
svn_grass at osgeo.org
Tue Sep 13 21:00:29 EDT 2011
Author: huhabla
Date: 2011-09-13 18:00:28 -0700 (Tue, 13 Sep 2011)
New Revision: 48288
Added:
grass/trunk/lib/python/tgis_abstract_datasets.py
grass/trunk/lib/python/tgis_base.py
grass/trunk/lib/python/tgis_core.py
grass/trunk/lib/python/tgis_metadata.py
grass/trunk/lib/python/tgis_space_time_datasets.py
grass/trunk/lib/python/tgis_spatial_extent.py
grass/trunk/lib/python/tgis_temporal_extent.py
Removed:
grass/trunk/lib/python/temporal.py
grass/trunk/lib/python/Makefile
grass/trunk/lib/python/__init__.py
Split of the temporal gis python library into several files. Management functionality (create, remove, register, unregister, ...) of the temporal GIS is now functional.
Modified: grass/trunk/lib/python/Makefile
--- grass/trunk/lib/python/Makefile 2011-09-14 00:58:07 UTC (rev 48287)
+++ grass/trunk/lib/python/Makefile 2011-09-14 01:00:28 UTC (rev 48288)
@@ -8,7 +8,7 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/script
-MODULES = core db raster raster3d vector array setup task temporal
+MODULES = core db raster raster3d vector array setup task tgis_base tgis_core tgis_abstract_datasets tgis_space_time_datasets tgis_metadata tgis_spatial_extent tgis_temporal_extent
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/__init__.py
--- grass/trunk/lib/python/__init__.py 2011-09-14 00:58:07 UTC (rev 48287)
+++ grass/trunk/lib/python/__init__.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -3,4 +3,9 @@
from raster import *
from raster3d import *
from vector import *
-from temporal import *
+# Temporal GIS library functions
+from tgis_base import *
+from tgis_temporal_extent import *
+from tgis_spatial_extent import *
+from tgis_metadata import *
+from tgis_space_time_datasets import *
Deleted: grass/trunk/lib/python/temporal.py
--- grass/trunk/lib/python/temporal.py 2011-09-14 00:58:07 UTC (rev 48287)
+++ grass/trunk/lib/python/temporal.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -1,2440 +0,0 @@
-"""!@package grass.script.temporal
- at brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS related functions to be used in Python scripts.
-Usage:
- at code
-from grass.script import temporal as grass
-grass.create_temporal_database()
- at endcode
-(C) 2008-2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Soeren Gebbert
-import os
-import sqlite3
-import os
-from datetime import datetime, date, time
-import getpass
-import core
-import raster
-import vector
-import raster3d
-def get_grass_location_db_path():
- grassenv = core.gisenv()
- dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
- return os.path.join(dbpath, "grass.db")
-def get_sql_template_path():
- base = os.getenv("GISBASE")
- base_etc = os.path.join(base, "etc")
- return os.path.join(base_etc, "sql")
-def create_temporal_database():
- """This function creates the grass location database structure for raster, vector and raster3d maps
- as well as for the space-time datasets strds, str3ds and stvds"""
- database = get_grass_location_db_path()
- # Check if it already exists
- if os.path.exists(database):
- return False
- # Read all SQL scripts and templates
- map_tables_template_sql = open(os.path.join(get_sql_template_path(), "map_tables_template.sql"), 'r').read()
- raster_metadata_sql = open(os.path.join(get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
- raster3d_metadata_sql = open(os.path.join(get_sql_template_path(), "raster3d_metadata_table.sql"), 'r').read()
- vector_metadata_sql = open(os.path.join(get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
- stds_tables_template_sql = open(os.path.join(get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
- strds_metadata_sql = open(os.path.join(get_sql_template_path(), "strds_metadata_table.sql"), 'r').read()
- str3ds_metadata_sql = open(os.path.join(get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
- stvds_metadata_sql = open(os.path.join(get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
- # Create the raster, raster3d and vector tables
- raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
- vector_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "vector")
- raster3d_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster3d")
- # Create the space-time raster, raster3d and vector dataset tables
- strds_tables_sql = stds_tables_template_sql.replace("STDS", "strds")
- stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
- str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
- # Check for completion
- sqlite3.complete_statement(raster_tables_sql)
- sqlite3.complete_statement(vector_tables_sql)
- sqlite3.complete_statement(raster3d_tables_sql)
- sqlite3.complete_statement(raster_metadata_sql)
- sqlite3.complete_statement(vector_metadata_sql)
- sqlite3.complete_statement(raster3d_metadata_sql)
- sqlite3.complete_statement(strds_tables_sql)
- sqlite3.complete_statement(stvds_tables_sql)
- sqlite3.complete_statement(str3ds_tables_sql)
- sqlite3.complete_statement(strds_metadata_sql)
- sqlite3.complete_statement(stvds_metadata_sql)
- sqlite3.complete_statement(str3ds_metadata_sql)
- # Connect to database
- connection = sqlite3.connect(database)
- cursor = connection.cursor()
- # Execute the SQL statements
- # Create the global tables for the native grass datatypes
- cursor.executescript(raster_tables_sql)
- cursor.executescript(raster_metadata_sql)
- cursor.executescript(vector_tables_sql)
- cursor.executescript(vector_metadata_sql)
- cursor.executescript(raster3d_tables_sql)
- cursor.executescript(raster3d_metadata_sql)
- # Create the tables for the new space-time datatypes
- cursor.executescript(strds_tables_sql)
- cursor.executescript(strds_metadata_sql)
- cursor.executescript(stvds_tables_sql)
- cursor.executescript(stvds_metadata_sql)
- cursor.executescript(str3ds_tables_sql)
- cursor.executescript(str3ds_metadata_sql)
- connection.commit()
- cursor.close()
-class dict_sql_serializer():
- def __init__(self):
- self.D = {}
- def serialize(self, type, table, where=None):
- """Convert the internal dictionary into a string of semicolon separated SQL statements
- The keys are the colum names and the values are the row entries
- @type must be SELECT. INSERT, UPDATE
- @table The name of the table to select, insert or update
- @where The optinal where statment
- @return the sql string
- sql = ""
- args = []
- # Create ordered select statement
- if type == "SELECT":
- sql += 'SELECT '
- count = 0
- for key in self.D.keys():
- if count == 0:
- sql += ' %s ' % key
- else:
- sql += ' , %s ' % key
- count += 1
- sql += ' FROM ' + table + ' '
- if where:
- sql += where
- # Create insert statement
- if type =="INSERT":
- count = 0
- sql += 'INSERT INTO ' + table + ' ('
- if count == 0:
- else:
- sql += ' ,%s ' % key
- count += 1
- count = 0
- sql += ') VALUES ('
- if count == 0:
- sql += '?'
- else:
- sql += ',?'
- count += 1
- args.append(self.D[key])
- sql += ') '
- if where:
- sql += where
- # Create update statement
- if type =="UPDATE":
- count = 0
- sql += 'UPDATE ' + table + ' SET '
- # Update only entries which are not None
- if self.D[key] != None:
- if count == 0:
- sql += ' %s = ? ' % key
- else:
- sql += ' ,%s = ? ' % key
- count += 1
- if where:
- sql += where
- return sql, tuple(args)
- def deserialize(self, row):
- """Convert the content of the sqlite row into the internal dictionary"""
- self.D = {}
- for key in row.keys():
- self.D[key] = row[key]
- def clear(self):
- """Remove all the content of this class"""
- self.D = {}
- def print_self(self):
- print self.D
- def test(self):
- t = dict_sql_serializer()
- t.D["id"] = "soil at PERMANENT"
- t.D["name"] = "soil"
- t.D["mapset"] = "PERMANENT"
- t.D["creator"] = "soeren"
- t.D["creation_time"] = datetime.now()
- t.D["modification_time"] = datetime.now()
- t.D["revision"] = 1
- sql, values = t.serialize(type="SELECT", table="raster_base")
- print sql, '\n', values
- sql, values = t.serialize(type="INSERT", table="raster_base")
- sql, values = t.serialize(type="UPDATE", table="raster_base")
-class sql_database_interface(dict_sql_serializer):
- """This is the sql database interface to sqlite3"""
- def __init__(self, table=None, ident=None, database=None):
- dict_sql_serializer.__init__(self)
- self.table = table # Name of the table, set in the subclass
- if database == None:
- self.database = get_grass_location_db_path()
- else:
- self.database = database
- self.ident = ident
- def get_table_name(self):
- return self.table
- def connect(self):
- self.connection = sqlite3.connect(self.database, detect_types=sqlite3.PARSE_DECLTYPES|sqlite3.PARSE_COLNAMES)
- self.connection.row_factory = sqlite3.Row
- self.cursor = self.connection.cursor()
- def close(self):
- self.connection.commit()
- self.cursor.close()
- def get_delete_statement(self):
- return "DELETE FROM " + self.table + " WHERE id = \"" + str(self.ident) + "\""
- def delete(self):
- self.connect()
- sql = self.get_delete_statement()
- #print sql
- self.cursor.execute(sql)
- self.close()
- def get_is_in_db_statement(self):
- return "SELECT id FROM " + self.table + " WHERE id = \"" + str(self.ident) + "\""
- def is_in_db(self):
- self.connect()
- sql = self.get_is_in_db_statement()
- #print sql
- row = self.cursor.fetchone()
- self.close()
- # Nothing found
- if row == None:
- return False
- return True
- def get_select_statement(self):
- return self.serialize("SELECT", self.table, "WHERE id = \"" + str(self.ident) + "\"")
- def select(self):
- self.connect()
- sql, args = self.get_select_statement()
- #print sql
- #print args
- if len(args) == 0:
- else:
- self.cursor.execute(sql, args)
- # Nothing found
- if row == None:
- return False
- if len(row) > 0:
- self.deserialize(row)
- else:
- raise IOError
- self.close()
- return True
- def get_insert_statement(self):
- return self.serialize("INSERT", self.table)
- def insert(self):
- self.connect()
- sql, args = self.get_insert_statement()
- #print sql
- #print args
- self.close()
- def get_update_statement(self):
- return self.serialize("UPDATE", self.table, "WHERE id = \"" + str(self.ident) + "\"")
- def update(self):
- if self.ident == None:
- raise IOError("Missing identifer");
- sql, args = self.get_update_statement()
- #print sql
- #print args
- self.connect()
- self.close()
-class dataset_identifer(sql_database_interface):
- """This is the base class for all maps and spacetime datasets storing basic information"""
- def __init__(self, table=None, ident=None, name=None, mapset=None, creator=None, ctime=None,\
- mtime=None, ttype=None, revision=1):
- sql_database_interface.__init__(self, table, ident)
- self.set_id(ident)
- self.set_name(name)
- self.set_mapset(mapset)
- self.set_creator(creator)
- self.set_ctime(ctime)
- self.set_mtime(mtime)
- self.set_ttype(ttype)
- self.set_revision(revision)
- def set_id(self, ident):
- """Convenient method to set the unique identifier (primary key)"""
- self.D["id"] = ident
- def set_name(self, name):
- """Set the name of the map"""
- self.D["name"] = name
- def set_mapset(self, mapset):
- """Set the mapset of the map"""
- self.D["mapset"] = mapset
- def set_creator(self, creator):
- """Set the creator of the map"""
- self.D["creator"] = creator
- def set_ctime(self, ctime=None):
- """Set the creation time of the map, if nothing set the current time is used"""
- if ctime == None:
- self.D["creation_time"] = datetime.now()
- else:
- self.D["creation_time"] = ctime
- def set_mtime(self, mtime=None):
- """Set the modification time of the map, if nothing set the current time is used"""
- if mtime == None:
- self.D["modification_time"] = datetime.now()
- else:
- self.D["modification_time"] = mtime
- def set_ttype(self, ttype):
- """Set the temporal type of the map: absolute or relative, if nothing set absolute time will assumed"""
- if ttype == None or (ttype != "absolute" and ttype != "relative"):
- self.D["temporal_type"] = "absolute"
- else:
- self.D["temporal_type"] = ttype
- def set_revision(self, revision=1):
- """Set the revision of the map: if nothing set revision 1 will assumed"""
- self.D["revision"] = revision
- def get_id(self):
- """Convenient method to get the unique identifier (primary key)
- @return None if not found
- if self.D.has_key("id"):
- return self.D["id"]
- else:
- return None
- def get_name(self):
- """Get the name of the map
- @return None if not found"""
- if self.D.has_key("name"):
- return self.D["name"]
- else:
- return None
- def get_mapset(self):
- """Get the mapset of the map
- if self.D.has_key("mapset"):
- return self.D["mapset"]
- else:
- return None
- def get_creator(self):
- """Get the creator of the map
- if self.D.has_key("creator"):
- return self.D["creator"]
- else:
- return None
- def get_ctime(self):
- """Get the creation time of the map, datatype is datetime
- if self.D.has_key("creation_time"):
- return self.D["creation_time"]
- else:
- return None
- def get_mtime(self):
- """Get the modification time of the map, datatype is datetime
- if self.D.has_key("modification_time"):
- return self.D["modification_time"]
- else:
- return None
- def get_ttype(self):
- """Get the temporal type of the map
- if self.D.has_key("temporal_type"):
- return self.D["temporal_type"]
- else:
- return None
- def get_revision(self):
- """Get the revision of the map
- if self.D.has_key("revision"):
- return self.D["revision"]
- else:
- return None
-class raster_base(dataset_identifer):
- def __init__(self, ident=None, name=None, mapset=None, creator=None, creation_time=None,\
- modification_time=None, temporal_type=None, revision=1):
- dataset_identifer.__init__(self, "raster_base", ident, name, mapset, creator, creation_time,\
- modification_time, temporal_type, revision)
-class raster3d_base(dataset_identifer):
- dataset_identifer.__init__(self, "raster3d_base", ident, name, mapset, creator, creation_time,\
-class vector_base(dataset_identifer):
- dataset_identifer.__init__(self, "vector_base", ident, name, mapset, creator, creation_time,\
-class stds_base(dataset_identifer):
- def __init__(self, table=None, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
- dataset_identifer.__init__(self, table, ident, name, mapset, creator, creation_time,\
- self.set_semantic_type(semantic_type)
- def set_semantic_type(self, semantic_type):
- """Set the sematnic type of the space time dataset"""
- self.D["semantic_type"] = semantic_type
- def get_semantic_type(self):
- """Get the semantic_type of the space time dataset
- if self.D.has_key("semantic_type"):
- return self.D["semantic_type"]
- else:
- return None
-class strds_base(stds_base):
- def __init__(self, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
- stds_base.__init__(self, "strds_base", ident, name, mapset, semantic_type, creator, creation_time,\
-class str3ds_base(stds_base):
- stds_base.__init__(self, "str3ds_base", ident, name, mapset, semantic_type, creator, creation_time,\
-class stvds_base(stds_base):
- stds_base.__init__(self, "stvds_base", ident, name, mapset, semantic_type, creator, creation_time,\
-class absolute_temporal_extent(sql_database_interface):
- """This is the absolute time base class for all maps and spacetime datasets"""
- def __init__(self, table=None, ident=None, start_time=None, end_time=None, timezone=None):
- self.set_start_time(start_time)
- self.set_end_time(end_time)
- self.set_timezone(timezone)
- def starts(self, map):
- """Return True if this absolute time object starts at the start of the provided absolute time object and finishes within it
- A |-----|
- B |---------|
- if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] < map.D["end_time"]:
- return True
- else:
- return False
- def started(self, map):
- """Return True if this absolute time object is started at the start of the provided absolute time object
- A |---------|
- B |-----|
- if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] > map.D["end_time"]:
- return True
- else:
- return False
- def finishes(self, map):
- """Return True if this absolute time object finishes at the end and within of the provided absolute time object
- A |-----|
- B |---------|
- if self.D["end_time"] == map.D["end_time"] and self.D["start_time"] > map.D["start_time"] :
- return True
- else:
- return False
- def finished(self, map):
- """Return True if this absolute time object finished at the end of the provided absolute time object
- A |---------|
- B |-----|
- if self.D["end_time"] == map.D["end_time"] and self.D["start_time"] < map.D["start_time"] :
- return True
- else:
- return False
- def after(self, map):
- """Return True if this absolute time object is temporal located after the provided absolute time object
- A |---------|
- B |---------|
- if self.D["start_time"] > map.D["end_time"]:
- return True
- else:
- return False
- def before(self, map):
- """Return True if this absolute time object is temporal located bevor the provided absolute time object
- A |---------|
- B |---------|
- if self.D["end_time"] < map.D["start_time"]:
- return True
- else:
- return False
- def adjacent(self, map):
- """Return True if this absolute time object is a meeting neighbour the provided absolute time object
- A |---------|
- B |---------|
- A |---------|
- B |---------|
- if (self.D["start_time"] == map.D["end_time"]) or (self.D["end_time"] == map.D["start_time"]):
- return True
- else:
- return False
- def follows(self, map):
- """Return True if this absolute time object is temporal follows the provided absolute time object
- A |---------|
- B |---------|
- if self.D["start_time"] == map.D["end_time"]:
- return True
- else:
- return False
- def precedes(self, map):
- """Return True if this absolute time object is temporal precedes the provided absolute time object
- A |---------|
- B |---------|
- if self.D["end_time"] == map.D["start_time"]:
- return True
- else:
- return False
- def during(self, map):
- """Return True if this absolute time object is temporal located during the provided absolute time object
- A |-------|
- B |---------|
- if self.D["start_time"] > map.D["start_time"] and self.D["end_time"] < map.D["end_time"]:
- return True
- else:
- return False
- def contains(self, map):
- A |---------|
- B |-------|
- if self.D["start_time"] < map.D["start_time"] and self.D["end_time"] > map.D["end_time"]:
- return True
- else:
- return False
- def equivalent(self, map):
- """Return True if this absolute time object is temporal located equivalent the provided absolute time object
- A |---------|
- B |---------|
- if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] == map.D["end_time"]:
- return True
- else:
- return False
- def overlaps(self, map):
- """Return True if this absolute time object is temporal overlaps the provided absolute time object
- A |---------|
- B |---------|
- if self.D["start_time"] < map.D["start_time"] and self.D["end_time"] < map.D["end_time"] and\
- self.D["end_time"] > map.D["start_time"]:
- return True
- else:
- return False
- def overlapped(self, map):
- """Return True if this absolute time object is temporal overlaped by the provided absolute time object
- A |---------|
- B |---------|
- if self.D["start_time"] > map.D["start_time"] and self.D["end_time"] > map.D["end_time"] and\
- self.D["start_time"] < map.D["end_time"]:
- return True
- else:
- return False
- def temporal_relation(self, map):
- """Returns the temporal relation between absolute time temporal objects
- Temporal relationsships are implemented after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
- if self.equivalent(map):
- return "equivalent"
- if self.during(map):
- return "during"
- if self.contains(map):
- return "contains"
- if self.overlaps(map):
- return "overlaps"
- if self.overlapped(map):
- return "overlapped"
- if self.after(map):
- return "after"
- if self.before(map):
- return "before"
- if self.starts(map):
- return "starts"
- if self.finishes(map):
- return "finishes"
- if self.started(map):
- return "started"
- if self.finished(map):
- return "finished"
- if self.follows(map):
- return "follows"
- if self.precedes(map):
- return "precedes"
- return None
- def set_start_time(self, start_time):
- """Set the valid start time of the map, this should be of type datetime"""
- self.D["start_time"] = start_time
- def set_end_time(self, end_time):
- """Set the valid end time of the map, this should be of type datetime"""
- self.D["end_time"] = end_time
- def set_timezone(self, timezone):
- """Set the timezone of the map, integer from 1 - 24"""
- self.D["timezone"] = timezone
- def get_id(self):
- else:
- return None
- def get_start_time(self):
- """Get the valid start time of the map
- if self.D.has_key("start_time"):
- return self.D["start_time"]
- else:
- return None
- def get_end_time(self):
- """Get the valid end time of the map
- if self.D.has_key("end_time"):
- return self.D["end_time"]
- else:
- return None
- def get_timezone(self):
- """Get the timezone of the map
- if self.D.has_key("timezone"):
- return self.D["timezone"]
- else:
- return None
-class raster_absolute_time(absolute_temporal_extent):
- def __init__(self, ident=None, start_time=None, end_time=None, timezone=None):
- absolute_temporal_extent.__init__(self, "raster_absolute_time", ident, start_time, end_time, timezone)
-class raster3d_absolute_time(absolute_temporal_extent):
- absolute_temporal_extent.__init__(self, "raster3d_absolute_time", ident, start_time, end_time, timezone)
-class vector_absolute_time(absolute_temporal_extent):
- absolute_temporal_extent.__init__(self, "vector_absolute_time", ident, start_time, end_time, timezone)
-class stds_absolute_time(absolute_temporal_extent):
- def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
- absolute_temporal_extent.__init__(self, table, ident, start_time, end_time, timezone)
- self.set_granularity(granularity)
- def set_granularity(self, granularity):
- """Set the granularity of the space time dataset"""
- self.D["granularity"] = granularity
- def get_granularity(self):
- """Get the granularity of the space time dataset
- if self.D.has_key("granularity"):
- return self.D["granularity"]
- else:
- return None
-class strds_absolute_time(stds_absolute_time):
- def __init__(self, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
- stds_absolute_time.__init__(self, "strds_absolute_time", ident, start_time, end_time, granularity, timezone)
-class str3ds_absolute_time(stds_absolute_time):
- stds_absolute_time.__init__(self, "str3ds_absolute_time", ident, start_time, end_time, granularity, timezone)
-class stvds_absolute_time(stds_absolute_time):
- stds_absolute_time.__init__(self, "stvds_absolute_time", ident, start_time, end_time, granularity, timezone)
-class relative_temporal_extent(sql_database_interface):
- """This is the relative time base class for all maps and spacetime datasets"""
- def __init__(self, table=None, ident=None, interval=None):
- self.set_interval(interval)
- """Return True if this relative time object is temporal located after the provided relative time object
- A |
- B |
- if self.D["interval"] > map.D["interval"]:
- return True
- else:
- return False
- """Return True if this relative time object is temporal located bevor the provided relative time object
- A |
- B |
- if self.D["interval"] < map.D["interval"]:
- return True
- else:
- return False
- """Return True if this relative time object is equivalent to the provided relative time object
- A |
- B |
- if self.D["interval"] == map.D["interval"]:
- return True
- else:
- return False
- """Returns the temporal relation between relative time temporal objects
- return "after"
- return "before"
- return None
- def set_interval(self, interval):
- """Set the valid interval time of the map, this should be of type datetime"""
- self.D["interval"] = interval
- def get_id(self):
- else:
- return None
- def get_interval(self):
- """Get the valid interval time of the map
- if self.D.has_key("interval"):
- return self.D["interval"]
- else:
- return None
-class raster_relative_time(relative_temporal_extent):
- def __init__(self, ident=None, interval=None):
- relative_temporal_extent.__init__(self, "raster_relative_time", ident, interval)
-class raster3d_relative_time(relative_temporal_extent):
- relative_temporal_extent.__init__(self, "raster3d_relative_time", ident, interval)
-class vector_relative_time(relative_temporal_extent):
- relative_temporal_extent.__init__(self, "vector_relative_time", ident, interval)
-class stds_relative_time(relative_temporal_extent):
- def __init__(self, table=None, ident=None, interval=None, granularity=None):
- relative_temporal_extent.__init__(self, table, ident, interval)
- else:
- return None
-class strds_relative_time(stds_relative_time):
- def __init__(self, ident=None, interval=None, granularity=None):
- stds_relative_time.__init__(self, "strds_relative_time", ident, interval, granularity)
-class str3ds_relative_time(stds_relative_time):
- stds_relative_time.__init__(self, "str3ds_relative_time", ident, interval, granularity)
-class stvds_relative_time(stds_relative_time):
- stds_relative_time.__init__(self, "stvds_relative_time", ident, interval, granularity)
-class spatial_extent(sql_database_interface):
- """This is the spatial extent base class for all maps and spacetime datasets"""
- def __init__(self, table=None, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None, proj="XY"):
- self.set_spatial_extent(north, south, east, west, top, bottom)
- self.set_projection(proj)
- def overlap_2d(self, extent):
- """Return True if the 2d extents overlap. Code is lend from wind_overlap.c in lib/gis"""
- if self.get_projection() != extent.get_projection():
- core.error("Projections are different. Unable to compute overlap_2d for spatial extents")
- N = extent.get_north()
- S = extent.get_south()
- E = extent.get_east()
- W = extent.get_west()
- if(self.get_north() <= S):
- return False
- if(self.get_south() >= N):
- return False
- # Adjust the east and west in case of LL projection
- if self.get_proj() == "LL":
- while E < self.get_west():
- E += 360.0
- W += 360.0
- while W > self.get_east():
- E -= 360.0
- W -= 360.0
- if self.get_east() <= W:
- return False
- if self.get_west() >= E:
- return False
- return True
- def overlap(self, extent):
- """Return True if the extents overlap."""
- if self.overlap_2d(extent) == False:
- return False
- T = extent.get_top()
- B = extent.get_bottom()
- if self.get_top() <= B:
- return False
- if self.get_bottom() >= T:
- return False
- return True
- def set_spatial_extent(self, north, south, east, west, top, bottom):
- """Set the spatial extent"""
- self.set_north(north)
- self.set_south(south)
- self.set_east(east)
- self.set_west(west)
- self.set_top(top)
- self.set_bottom(bottom)
- def set_projection(self, proj):
- """Set the projection of the spatial extent it should be XY or LL.
- As default the projection is XY
- if proj == None or (proj != "XY" and proj != "LL"):
- self.D["proj"] = "XY"
- else:
- self.D["proj"] = proj
- def set_spatial_extent_2d(self, north, south, east, west):
- self.set_top(0)
- self.set_bottom(0)
- def set_north(self, north):
- """Set the northern edge of the map"""
- self.D["north"] = north
- def set_south(self, sourth):
- """Set the sourthern edge of the map"""
- self.D["south"] = sourth
- def set_west(self, west):
- """Set the western edge of the map"""
- self.D["west"] = west
- def set_east(self, east):
- """Set the eastern edge of the map"""
- self.D["east"] = east
- def set_top(self, top):
- """Set the top edge of the map"""
- self.D["top"] = top
- def set_bottom(self, bottom):
- """Set the bottom edge of the map"""
- self.D["bottom"] = bottom
- def get_id(self):
- else:
- return None
- def get_projection(self):
- """Get the projection of the spatial extent"""
- return self.D["proj"]
- def get_volume(self):
- """Compute the volume of the extent, in case z is zero (top == bottom or top - bottom = 1) the area is returned"""
- if self.get_projection() == "LL":
- core.error("Volume computation is not supported for LL projections")
- area = self.get_area()
- bbox = self.get_spatial_extent()
- z = abs(bbox[4] - bbox[5])
- if z == 0:
- z = 1.0
- return area*z
- def get_area(self):
- """Compute the area of the extent, extent in z direction is ignored"""
- core.error("Area computation is not supported for LL projections")
- y = abs(bbox[0] - bbox[1])
- x = abs(bbox[2] - bbox[3])
- return x*y
- def get_spatial_extent(self):
- """Return a tuple (north, south, east, west, top, bottom) of the spatial extent"""
- return (self.get_north(), self.get_south, self.get_east(), self.get_west(), \
- self.get_top(), self.get_bottom())
- def get_spatial_extent_2d(self):
- """Return a tuple (north, south, east, west,) of the 2d spatial extent"""
- return (self.get_north(), self.get_south, self.get_east(), self.get_west())
- def get_north(self):
- """Get the northern edge of the map
- if self.D.has_key("north"):
- return self.D["north"]
- else:
- return None
- def get_south(self):
- """Get the southern edge of the map
- if self.D.has_key("south"):
- return self.D["south"]
- else:
- return None
- def get_east(self):
- """Get the eastern edge of the map
- if self.D.has_key("east"):
- return self.D["east"]
- else:
- return None
- def get_west(self):
- """Get the western edge of the map
- if self.D.has_key("west"):
- return self.D["west"]
- else:
- return None
- def get_top(self):
- """Get the top edge of the map
- if self.D.has_key("top"):
- return self.D["top"]
- else:
- return None
- def get_bottom(self):
- """Get the bottom edge of the map
- if self.D.has_key("bottom"):
- return self.D["bottom"]
- else:
- return None
-class raster_spatial_extent(spatial_extent):
- def __init__(self, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
- spatial_extent.__init__(self, "raster_spatial_extent", ident, north, south, east, west, top, bottom)
-class raster3d_spatial_extent(spatial_extent):
- spatial_extent.__init__(self, "raster3d_spatial_extent", ident, north, south, east, west, top, bottom)
-class vector_spatial_extent(spatial_extent):
- spatial_extent.__init__(self, "vector_spatial_extent", ident, north, south, east, west, top, bottom)
-class strds_spatial_extent(spatial_extent):
- spatial_extent.__init__(self, "strds_spatial_extent", ident, north, south, east, west, top, bottom)
-class str3ds_spatial_extent(spatial_extent):
- spatial_extent.__init__(self, "str3ds_spatial_extent", ident, north, south, east, west, top, bottom)
-class stvds_spatial_extent(spatial_extent):
- spatial_extent.__init__(self, "stvds_spatial_extent", ident, north, south, east, west, top, bottom)
-class raster_metadata_base(sql_database_interface):
- """This is the raster metadata base class for raster and raster3d maps"""
- def __init__(self, table=None, ident=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
- self.set_datatype(datatype)
- self.set_cols(cols)
- self.set_rows(rows)
- self.set_number_of_cells(number_of_cells)
- self.set_nsres(nsres)
- self.set_ewres(ewres)
- self.set_min(min)
- self.set_max(max)
- def set_datatype(self, datatype):
- """Set the datatype"""
- self.D["datatype"] = datatype
- def set_cols(self, cols):
- """Set the number of cols"""
- self.D["cols"] = cols
- def set_rows(self, rows):
- """Set the number of rows"""
- self.D["rows"] = rows
- def set_number_of_cells(self, number_of_cells):
- """Set the number of cells"""
- self.D["number_of_cells"] = number_of_cells
- def set_nsres(self, nsres):
- """Set the north-south resolution"""
- self.D["nsres"] = nsres
- def set_ewres(self, ewres):
- """Set the east-west resolution"""
- self.D["ewres"] = ewres
- def set_min(self, min):
- """Set the minimum raster value"""
- self.D["min"] = min
- def set_max(self, max):
- """Set the maximum raster value"""
- self.D["max"] = max
- def get_id(self):
- else:
- return None
- def get_datatype(self):
- """Get the map type
- if self.D.has_key("datatype"):
- return self.D["datatype"]
- else:
- return None
- def get_cols(self):
- """Get number of cols
- if self.D.has_key("cols"):
- return self.D["cols"]
- else:
- return None
- def get_rows(self):
- """Get number of rows
- if self.D.has_key("rows"):
- return self.D["rows"]
- else:
- return None
- def get_number_of_cells(self):
- """Get number of cells
- if self.D.has_key("number_of_cells"):
- return self.D["number_of_cells"]
- else:
- return None
- def get_nsres(self):
- """Get the north-south resolution
- if self.D.has_key("nsres"):
- return self.D["nsres"]
- else:
- return None
- def get_ewres(self):
- """Get east-west resolution
- if self.D.has_key("ewres"):
- return self.D["ewres"]
- else:
- return None
- def get_min(self):
- """Get the minimum cell value
- if self.D.has_key("min"):
- return self.D["min"]
- else:
- return None
- def get_max(self):
- """Get the maximum cell value
- if self.D.has_key("max"):
- return self.D["max"]
- else:
- return None
-class raster_metadata(raster_metadata_base):
- """This is the raster metadata class"""
- def __init__(self, ident=None, strds_register=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
- raster_metadata_base.__init__(self, "raster_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
- self.set_strds_register(strds_register)
- def set_strds_register(self, strds_register):
- """Set the space time raster dataset register table name"""
- self.D["strds_register"] = strds_register
- def get_strds_register(self):
- """Get the space time raster dataset register table name
- if self.D.has_key("strds_register"):
- return self.D["strds_register"]
- else:
- return None
-class raster3d_metadata(raster_metadata_base):
- """This is the raster3d metadata class"""
- def __init__(self, ident=None, str3ds_register=None, datatype=None, cols=None, rows=None, depths=None, number_of_cells=None, nsres=None, ewres=None, tbres=None, min=None, max=None):
- raster_metadata_base.__init__(self, "raster3d_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
- self.set_str3ds_register(str3ds_register)
- self.set_tbres(tbres)
- self.set_depths(depths)
- def set_str3ds_register(self, str3ds_register):
- """Set the space time raster3d dataset register table name"""
- self.D["str3ds_register"] = str3ds_register
- def set_depths(self, depths):
- """Set the number of depths"""
- self.D["depths"] = depths
- def set_tbres(self, tbres):
- """Set the top-bottom resolution"""
- self.D["tbres"] = tbres
- def get_str3ds_register(self):
- """Get the space time raster3d dataset register table name
- if self.D.has_key("str3ds_register"):
- return self.D["str3ds_register"]
- else:
- return None
- def get_depths(self):
- """Get number of depths
- if self.D.has_key("depths"):
- return self.D["depths"]
- else:
- return None
- def get_tbres(self):
- """Get top-bottom resolution
- if self.D.has_key("tbres"):
- return self.D["tbres"]
- else:
- return None
-class vector_metadata(sql_database_interface):
- """This is the vector metadata class"""
- def __init__(self, ident=None, stvds_register=None):
- sql_database_interface.__init__(self, "vector_metadata", ident)
- self.set_stvds_register(stvds_register)
- def set_stvds_register(self, stvds_register):
- """Set the space time vector dataset register table name"""
- self.D["stvds_register"] = stvds_register
- def get_id(self):
- else:
- return None
- def get_stvds_register(self):
- """Get the space time vector dataset register table name
- if self.D.has_key("stvds_register"):
- return self.D["stvds_register"]
- else:
- return None
-class stds_metadata_base(sql_database_interface):
- """This is the space time dataset metadata base class for strds, stvds and str3ds datasets
- setting/getting the id, the title and the description
- def __init__(self, table=None, ident=None, title=None, description=None):
- self.set_title(title)
- self.set_description(description)
- # No setter for this
- self.D["number_of_maps"] = None
- def set_title(self, title):
- """Set the title"""
- self.D["title"] = title
- def set_description(self, description):
- self.D["description"] = description
- def get_id(self):
- else:
- return None
- def get_title(self):
- """Get the title
- if self.D.has_key("title"):
- return self.D["title"]
- else:
- return None
- def get_description(self):
- """Get description
- if self.D.has_key("description"):
- return self.D["description"]
- else:
- return None
- def get_number_of_maps(self):
- """Get the number of registered maps, this value is set in the database
- automatically via SQL trigger, so no setter exists
- if self.D.has_key("number_of_maps"):
- return self.D["number_of_maps"]
- else:
- return None
-class stds_raster_metadata_base(stds_metadata_base):
- """This is the space time dataset metadata base class for strds and str3ds datasets
- Most of the metadata values are set by triggers in the database when
- new raster of voxel maps are added. Therefor only some set- an many get-functions
- are available.
- stds_metadata_base.__init__(self, table, ident, title, description)
- # Initialize the dict to select all values from the db
- self.D["min_max"] = None
- self.D["max_max"] = None
- self.D["min_min"] = None
- self.D["max_min"] = None
- self.D["nsres_min"] = None
- self.D["nsres_max"] = None
- self.D["ewres_min"] = None
- self.D["ewres_max"] = None
- def get_max_min(self):
- """Get the minimal maximum of all registered maps, this value is set in the database
- if self.D.has_key("max_min"):
- return self.D["max_min"]
- else:
- return None
- def get_min_min(self):
- """Get the minimal minimum of all registered maps, this value is set in the database
- if self.D.has_key("min_min"):
- return self.D["min_min"]
- else:
- return None
- def get_max_max(self):
- """Get the maximal maximum of all registered maps, this value is set in the database
- if self.D.has_key("max_max"):
- return self.D["max_max"]
- else:
- return None
- def get_min_max(self):
- """Get the maximal minimum of all registered maps, this value is set in the database
- if self.D.has_key("min_max"):
- return self.D["min_max"]
- else:
- return None
- else:
- return None
- def get_nsres_min(self):
- """Get the minimal north-south resolution of all registered maps, this value is set in the database
- if self.D.has_key("nsres_min"):
- return self.D["nsres_min"]
- else:
- return None
- def get_nsres_max(self):
- """Get the maximal north-south resolution of all registered maps, this value is set in the database
- if self.D.has_key("nsres_max"):
- return self.D["nsres_max"]
- else:
- return None
- def get_ewres_min(self):
- """Get the minimal east-west resolution of all registered maps, this value is set in the database
- if self.D.has_key("ewres_min"):
- return self.D["ewres_min"]
- else:
- return None
- def get_ewres_max(self):
- """Get the maximal east-west resolution of all registered maps, this value is set in the database
- if self.D.has_key("ewres_max"):
- return self.D["ewres_max"]
- else:
- return None
-class strds_metadata(stds_raster_metadata_base):
- def __init__(self, ident=None, raster_register=None, title=None, description=None):
- stds_raster_metadata_base.__init__(self, "strds_metadata", ident, title, description)
- self.set_raster_register(raster_register)
- def set_raster_register(self, raster_register):
- """Set the raster map register table name"""
- self.D["raster_register"] = raster_register
- def get_raster_register(self):
- """Get the raster map register table name
- if self.D.has_key("raster_register"):
- return self.D["raster_register"]
- else:
- return None
-class str3ds_metadata(stds_raster_metadata_base):
- """This is the space time raster3d metadata class"""
- def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
- stds_raster_metadata_base.__init__(self, "str3ds_metadata", ident, title, description)
- self.set_raster3d_register(raster3d_register)
- self.D["tbres_min"] = None
- self.D["tbres_max"] = None
- def set_raster3d_register(self, raster3d_register):
- self.D["raster3d_register"] = raster3d_register
- def get_raster3d_register(self):
- """Get the raster3d map register table name
- if self.D.has_key("raster3d_register"):
- return self.D["raster3d_register"]
- else:
- return None
- def get_tbres_min(self):
- """Get the minimal top-bottom resolution of all registered maps, this value is set in the database
- if self.D.has_key("tbres_min"):
- return self.D["tbres_min"]
- else:
- return None
- def get_tbres_max(self):
- """Get the maximal top-bottom resolution of all registered maps, this value is set in the database
- if self.D.has_key("tbres_max"):
- return self.D["tbres_max"]
- else:
- return None
-class stvds_metadata(stds_metadata_base):
- def __init__(self, ident=None, vector_register=None, title=None, description=None):
- stds_metadata_base.__init__(self, "stvds_metadata", ident, title, description)
- self.set_vector_register(vector_register)
- def set_vector_register(self, vector_register):
- """Set the vector map register table name"""
- self.D["vector_register"] = vector_register
- def get_vector_register(self):
- """Get the vector map register table name
- if self.D.has_key("vector_register"):
- return self.D["vector_register"]
- else:
- return None
-class abstract_dataset():
- """This is the base class for all datasets (raster, vector, raster3d, strds, stvds, str3ds)"""
- def get_type(self):
- """Return the type of this class"""
- raise IOError("This method must be implemented in the subclasses")
- def get_new_instance(self, ident):
- """Return a new instance with the type of this class"""
- def get_absolute_time(self):
- """Returns a tuple of the start, the end valid time and the timezone of the map
- @return A tuple of (start_time, end_time, timezone)
- start = self.absolute_time.get_start_time()
- end = self.absolute_time.get_end_time()
- tz = self.absolute_time.get_timezone()
- return (start, end, tz)
- def get_relative_time(self):
- """Returns the relative time interval or None if not present"""
- return self.relative_time.get_interval()
- """Return a tuple of spatial extent (north, south, east, west, top, bottom) """
- north = self.spatial_extent.get_north()
- south = self.spatial_extent.get_south()
- east = self.spatial_extent.get_east()
- west = self.spatial_extent.get_west()
- top = self.spatial_extent.get_top()
- bottom = self.spatial_extent.get_bottom()
- return (north, south, east, west, top, bottom)
- def select(self):
- """Select temporal dataset entry from database and fill up the internal structure"""
- self.base.select()
- if self.is_time_absolute():
- self.absolute_time.select()
- if self.is_time_relative():
- self.relative_time.select()
- self.spatial_extent.select()
- self.metadata.select()
- """Check if the temporal dataset entry is in the database"""
- return self.base.is_in_db()
- def delete(self):
- """Delete temporal dataset entry from database if it exists"""
- if self.is_in_db():
- self.base.delete()
- def insert(self):
- """Insert temporal dataset entry into database from the internal structure"""
- self.base.insert()
- self.absolute_time.insert()
- self.relative_time.insert()
- self.spatial_extent.insert()
- self.metadata.insert()
- def update(self):
- """Update temporal dataset entry of database from the internal structure"""
- self.base.update()
- self.absolute_time.update()
- self.relative_time.update()
- self.spatial_extent.update()
- self.metadata.update()
- """Print the content of the internal structure to stdout"""
- self.base.print_self()
- self.absolute_time.print_self()
- self.relative_time.print_self()
- self.spatial_extent.print_self()
- self.metadata.print_self()
- def set_time_to_absolute(self):
- self.base.set_ttype("absolute")
- def set_time_to_relative(self):
- self.base.Dset_ttype("relative")
- def is_time_absolute(self):
- if self.base.D.has_key("temporal_type"):
- return self.base.get_ttype() == "absolute"
- else:
- return None
- def is_time_relative(self):
- return self.base.get_ttype() == "relative"
- else:
- return None
- """Return the temporal relation of this and the provided temporal raster map"""
- if self.is_time_absolute() and map.is_time_absolute():
- return self.absolute_time.temporal_relation(map.absolute_time)
- if self.is_time_relative() and map.is_time_relative():
- return self.relative_time.temporal_relation(map.absolute_time)
- return None
-class abstract_map_dataset(abstract_dataset):
- """This is the base class for all maps (raster, vector, raster3d)
- providing additional function to set the valid time and the spatial extent.
- Valid time and spatial extent will be set automatically in the space-time datasets
- def get_new_stds_instance(self, ident):
- """Return a new space time dataset instance in which maps are stored with the type of this class"""
- def get_stds_register(self):
- """Return the space time dataset register table name in which stds are listed in which this map is registered"""
- def set_stds_register(self, name):
- """Set the space time dataset register table name in which stds are listed in which this map is registered"""
- def set_absolute_time(self, start_time, end_time=None, timezone=None):
- """Set the absolute time interval with start time and end time
- @start_time a datetime object specifying the start time of the map
- @end_time a datetime object specifying the end time of the map
- @timezone Thee timezone of the map
- self.absolute_time.set_start_time(start_time)
- self.absolute_time.set_end_time(end_time)
- self.absolute_time.set_timezone(timezone)
- def set_relative_time(self, interval):
- """Set the relative time interval
- @interval A double value in days
- self.base.set_ttype("relative")
- self.absolute_time.set_interval(interval)
- def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
- """Set the spatial extent of the map"""
- self.spatial_extent.set_spatial_extent(north, south, east, west, top, bottom)
- def delete(self):
- """Delete a map entry from database if it exists
- Remove dependent entries:
- * Remove the map entry in each space time dataset in which this map is registered
- * Remove the space time dataset register table
- # Get all data
- self.select()
- # Remove the map from all registered space time datasets
- if self.get_stds_register() != None:
- # Select all stds tables in which this map is registered
- sql = "SELECT id FROM " + self.get_stds_register()
- #print sql
- self.base.connect()
- self.base.cursor.execute(sql)
- rows = self.base.cursor.fetchall()
- self.base.close()
- # For each stds in which the map is registered
- if rows:
- for row in rows:
- # Create a space time dataset object to remove the map
- # from its register
- strds = self.get_new_stds_instance(row["id"])
- strds.select()
- strds.unregister_map(self)
- # Remove the strds register table
- sql = "DROP TABLE " + self.get_stds_register()
- #print sql
- self.base.close()
- # Delete yourself from the database, trigger functions will take care of dependencies
-class raster_dataset(abstract_map_dataset):
- """Raster dataset class
- This class provides functions to select, update, insert or delete raster
- map informations and valid time stamps into the SQL temporal database.
- def __init__(self, ident):
- self.reset(ident)
- return "raster"
- return raster_dataset(ident)
- return space_time_raster_dataset(ident)
- return self.metadata.get_strds_register()
- self.metadata.set_strds_register(name)
- def reset(self, ident):
- """Reset the internal structure and set the identifier"""
- self.base = raster_base(ident=ident)
- self.absolute_time = raster_absolute_time(ident=ident)
- self.relative_time = raster_relative_time(ident=ident)
- self.spatial_extent = raster_spatial_extent(ident=ident)
- self.metadata = raster_metadata(ident=ident)
- def load(self):
- """Load all info from an existing raster map into the internal structure"""
- # Get the data from an existing raster map
- kvp = raster.raster_info(self.ident)
- # Fill base information
- self.base.set_name(self.ident.split("@")[0])
- self.base.set_mapset(self.ident.split("@")[1])
- self.base.set_creator(str(getpass.getuser()))
- # Fill spatial extent
- self.set_spatial_extent(north=kvp["north"], south=kvp["south"], \
- east=kvp["east"], west=kvp["west"])
- # Fill metadata
- self.metadata.set_nsres(kvp["nsres"])
- self.metadata.set_ewres(kvp["ewres"])
- self.metadata.set_datatype(kvp["datatype"])
- self.metadata.set_min(kvp["min"])
- self.metadata.set_max(kvp["max"])
- rows = int((kvp["north"] - kvp["south"])/kvp["nsres"] + 0.5)
- cols = int((kvp["east"] - kvp["west"])/kvp["ewres"] + 0.5)
- ncells = cols * rows
- self.metadata.set_cols(cols)
- self.metadata.set_rows(rows)
- self.metadata.set_number_of_cells(ncells)
-class raster3d_dataset(abstract_map_dataset):
- """Raster3d dataset class
- This class provides functions to select, update, insert or delete raster3d
- self.reset(ident)
- return "raster3d"
- return raster3d_dataset(ident)
- return space_time_raster3d_dataset(ident)
- return self.metadata.get_str3ds_register()
- self.metadata.set_str3ds_register(name)
- self.base = raster3d_base(ident=ident)
- self.absolute_time = raster3d_absolute_time(ident=ident)
- self.relative_time = raster3d_relative_time(ident=ident)
- self.spatial_extent = raster3d_spatial_extent(ident=ident)
- self.metadata = raster3d_metadata(ident=ident)
- def load(self):
- """Load all info from an existing raster3d map into the internal structure"""
- kvp = raster3d.raster3d_info(self.ident)
- east=kvp["east"], west=kvp["west"],\
- top=kvp["top"], bottom=kvp["bottom"])
- # Fill metadata
- self.metadata.set_tbres(kvp["tbres"])
- depths = int((kvp["top"] - kvp["bottom"])/kvp["tbres"] + 0.5)
- ncells = cols * rows * depths
- self.metadata.set_depths(depths)
-class vector_dataset(abstract_map_dataset):
- """Vector dataset class
- This class provides functions to select, update, insert or delete vector
- self.reset(ident)
- return "vector"
- return vector_dataset(ident)
- return space_time_vector_dataset(ident)
- return self.metadata.get_stvds_register()
- self.metadata.set_stvds_register(name)
- self.base = vector_base(ident=ident)
- self.absolute_time = vector_absolute_time(ident=ident)
- self.relative_time = vector_relative_time(ident=ident)
- self.spatial_extent = vector_spatial_extent(ident=ident)
- self.metadata = vector_metadata(ident=ident)
- def load(self):
- """Load all info from an existing vector map into the internal structure"""
- kvp = vector.vector_info(self.ident)
- # Fill metadata .. no metadata yet
-class abstract_space_time_dataset(abstract_dataset):
- """Abstract space time dataset class
- This class represents a space time dataset. Convenient functions
- to select, update, insert or delete objects of this type int the SQL
- temporal database exists as well as functions to register or deregister
- raster maps.
- Parts of the temporal logic are implemented in the SQL temporal database,
- like the computation of the temporal and spatial extent as well as the
- collecting of metadata.
- self.reset(ident)
- def get_new_map_instance(self, ident):
- """Return a new instance of a map dataset which is associated with the type of this class"""
- def get_map_register(self):
- """Return the name of the map register table"""
- def set_map_register(self, name):
- """Set the name of the map register table"""
- def set_initial_values(self, granularity, temporal_type, semantic_type, \
- title=None, description=None):
- if temporal_type == "absolute":
- self.set_time_to_absolute()
- self.absolute_time.set_granularity(granularity)
- elif temporal_type == "relative":
- self.set_time_to_relative()
- self.relative_time.set_granularity(granularity)
- else:
- core.error("Unkown temporal type \"" + temporal_type + "\"")
- self.base.set_semantic_type(semantic_type)
- self.metadata.set_title(title)
- self.metadata.set_description(description)
- def register_map(self, map):
- """Register a map in the space time raster dataset.
- This method takes care of the registration of a map
- in a space time dataset.
- if map.is_in_db() == False:
- core.error("Only maps with absolute or relative valid time can be registered")
- # First select all data from the database
- map.select()
- map_id = map.base.get_id()
- map_name = map.base.get_name()
- map_mapset = map.base.get_mapset()
- map_register_table = map.get_stds_register()
- # Get basic info
- stds_name = self.base.get_name()
- stds_mapset = self.base.get_mapset()
- stds_register_table = self.get_map_register()
- if stds_mapset != map_mapset:
- core.error("You can only register raster maps from the same mapset")
- # Check if map is already registred
- if stds_register_table:
- sql = "SELECT id FROM " + stds_register_table + " WHERE id = (?)"
- self.base.cursor.execute(sql, (map_id,))
- row = self.base.cursor.fetchone()
- # In case of no entry make a new one
- if row and row[0] == map_id:
- core.error("Map is already registered")
- self.base.close()
- # Create tables
- sql_path = get_sql_template_path()
- # We need to create the stmap raster register table bevor we can register the map
- if map_register_table == None:
- # Read the SQL template
- sql = open(os.path.join(sql_path, "map_stds_register_table_template.sql"), 'r').read()
- sql = sql.replace("GRASS_MAP", map.get_type())
- sql = sql.replace("MAP_NAME", map_name + "_" + map_mapset )
- sql = sql.replace("MAP_ID", map_id)
- sql = sql.replace("STDS", self.get_type())
- self.base.cursor.executescript(sql)
- self.base.close()
- map_register_table = map_name + "_" + map_mapset + "_" + self.get_type() + "_register"
- # Set the stds register table name and put it into the DB
- map.set_stds_register(map_register_table)
- map.metadata.update()
- # We need to create the table and register it
- if stds_register_table == None:
- sql = open(os.path.join(sql_path, "stds_map_register_table_template.sql"), 'r').read()
- sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
- sql = sql.replace("SPACETIME_ID", self.base.get_id())
- self.base.close()
- # We need raster specific trigger
- sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
- self.base.close()
- stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
- # Set the map register table name and put it into the DB
- self.set_map_register(stds_register_table)
- # Register the stds in the map stds register table
- # Check if the entry is already there
- sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
- self.base.cursor.execute(sql, (self.base.get_id(),))
- self.base.close()
- if row == None:
- sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (?)"
- self.base.close()
- # Now put the raster name in the stds map register table
- sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (?)"
- self.base.close()
- def unregister_map(self, map):
- """Remove a register a raster map from the space time raster dataset.
- This method takes care of the unregistration of a raster map
- in a space time raster dataset.
- map.select()
- # Get basic info
- # Check if the map is registered in the space time raster dataset
- self.base.close()
- # Break if the map is not registered
- if row == None:
- core.error("Map " + map_id + " is not registered in space time dataset " + self.base.get_id())
- # Remove the space time raster dataset from the raster dataset register
- if map_register_table != None:
- sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
- self.base.close()
- # Remove the raster map from the space time raster dataset register
- if stds_register_table != None:
- sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
- self.base.close()
-class space_time_raster_dataset(abstract_space_time_dataset):
- """Space time raster dataset class
- This class represents a space time raster dataset. Convenient functions
- raster maps.
- abstract_space_time_dataset.__init__(self, ident)
- return "strds"
- return self.metadata.get_raster_register()
- self.metadata.set_raster_register(name)
- self.base = strds_base(ident=ident)
- self.absolute_time = strds_absolute_time(ident=ident)
- self.relative_time = strds_relative_time(ident=ident)
- self.spatial_extent = strds_spatial_extent(ident=ident)
- self.metadata = strds_metadata(ident=ident)
-class space_time_raster3d_dataset(abstract_space_time_dataset):
- """Space time raster3d dataset class
- This class represents a space time raster3d dataset. Convenient functions
- raster maps.
- return "str3ds"
- return self.metadata.get_raster3d_register()
- self.metadata.set_raster3d_register(name)
- self.base = str3ds_base(ident=ident)
- self.absolute_time = str3ds_absolute_time(ident=ident)
- self.relative_time = str3ds_relative_time(ident=ident)
- self.spatial_extent = str3ds_spatial_extent(ident=ident)
- self.metadata = str3ds_metadata(ident=ident)
-class space_time_vector_dataset(abstract_space_time_dataset):
- """Space time vector dataset class
- This class represents a space time vector dataset. Convenient functions
- raster maps.
- return "stvds"
- return self.metadata.get_vectorr_register()
- self.metadata.set_vector_register(name)
- self.base = stvds_base(ident=ident)
- self.absolute_time = stvds_absolute_time(ident=ident)
- self.relative_time = stvds_relative_time(ident=ident)
- self.spatial_extent = stvds_spatial_extent(ident=ident)
- self.metadata = stvds_metadata(ident=ident)
Added: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py (rev 0)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,514 @@
+"""!@package grass.script.tgis_map_datasets
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+from grass.script import tgis_map_datasets as grass
+raster_ds = grass.raster_database("soil")
+if raster_ds.is_in_db():
+ raster_ds.select()
+else:
+ raster_ds.load()
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import uuid
+class abstract_dataset(object):
+ """This is the base class for all datasets (raster, vector, raster3d, strds, stvds, str3ds)"""
+ def get_type(self):
+ """Return the type of this class"""
+ raise IOError("This method must be implemented in the subclasses")
+ def get_new_instance(self, ident):
+ """Return a new instance with the type of this class"""
+ def get_id(self):
+ return self.base.get_id()
+ def get_absolute_time(self):
+ """Returns a tuple of the start, the end valid time and the timezone of the map
+ @return A tuple of (start_time, end_time, timezone)
+ start = self.absolute_time.get_start_time()
+ end = self.absolute_time.get_end_time()
+ tz = self.absolute_time.get_timezone()
+ return (start, end, tz)
+ def get_relative_time(self):
+ """Returns the relative time interval or None if not present"""
+ return self.relative_time.get_interval()
+ def get_spatial_extent(self):
+ """Return a tuple of spatial extent (north, south, east, west, top, bottom) """
+ north = self.spatial_extent.get_north()
+ south = self.spatial_extent.get_south()
+ east = self.spatial_extent.get_east()
+ west = self.spatial_extent.get_west()
+ top = self.spatial_extent.get_top()
+ bottom = self.spatial_extent.get_bottom()
+ return (north, south, east, west, top, bottom)
+ def select(self):
+ """Select temporal dataset entry from database and fill up the internal structure"""
+ self.base.select()
+ if self.is_time_absolute():
+ self.absolute_time.select()
+ if self.is_time_relative():
+ self.relative_time.select()
+ self.spatial_extent.select()
+ self.metadata.select()
+ def is_in_db(self):
+ """Check if the temporal dataset entry is in the database"""
+ return self.base.is_in_db()
+ def delete(self):
+ """Delete temporal dataset entry from database if it exists"""
+ def insert(self):
+ """Insert temporal dataset entry into database from the internal structure"""
+ self.base.insert()
+ self.absolute_time.insert()
+ self.relative_time.insert()
+ self.spatial_extent.insert()
+ self.metadata.insert()
+ def update(self):
+ """Update temporal dataset entry of database from the internal structure"""
+ self.base.update()
+ self.absolute_time.update()
+ self.relative_time.update()
+ self.spatial_extent.update()
+ self.metadata.update()
+ def print_self(self):
+ """Print the content of the internal structure to stdout"""
+ self.base.print_self()
+ self.absolute_time.print_self()
+ self.relative_time.print_self()
+ self.spatial_extent.print_self()
+ self.metadata.print_self()
+ def print_info(self):
+ """Print information about this class in human readable style"""
+ self.base.print_info()
+ self.absolute_time.print_info()
+ self.relative_time.print_info()
+ self.spatial_extent.print_info()
+ self.metadata.print_info()
+ def print_shell_info(self):
+ """Print information about this class in shell style"""
+ self.base.print_shell_info()
+ self.absolute_time.print_shell_info()
+ self.relative_time.print_shell_info()
+ self.spatial_extent.print_shell_info()
+ self.metadata.print_shell_info()
+ def set_time_to_absolute(self):
+ self.base.set_ttype("absolute")
+ def set_time_to_relative(self):
+ self.base.set_ttype("relative")
+ def is_time_absolute(self):
+ if self.base.D.has_key("temporal_type"):
+ return self.base.get_ttype() == "absolute"
+ else:
+ return None
+ def is_time_relative(self):
+ return self.base.get_ttype() == "relative"
+ else:
+ return None
+ def temporal_relation(self, map):
+ """Return the temporal relation of this and the provided temporal raster map"""
+ if self.is_time_absolute() and map.is_time_absolute():
+ return self.absolute_time.temporal_relation(map.absolute_time)
+ if self.is_time_relative() and map.is_time_relative():
+ return self.relative_time.temporal_relation(map.absolute_time)
+ return None
+class abstract_map_dataset(abstract_dataset):
+ """This is the base class for all maps (raster, vector, raster3d)
+ providing additional function to set the valid time and the spatial extent.
+ Valid time and spatial extent will be set automatically in the space-time datasets
+ def get_new_stds_instance(self, ident):
+ """Return a new space time dataset instance in which maps are stored with the type of this class"""
+ def get_stds_register(self):
+ """Return the space time dataset register table name in which stds are listed in which this map is registered"""
+ def set_stds_register(self, name):
+ """Set the space time dataset register table name in which stds are listed in which this map is registered"""
+ def set_absolute_time(self, start_time, end_time=None, timezone=None):
+ """Set the absolute time interval with start time and end time
+ @start_time a datetime object specifying the start time of the map
+ @end_time a datetime object specifying the end time of the map
+ @timezone Thee timezone of the map
+ self.absolute_time.set_start_time(start_time)
+ self.absolute_time.set_end_time(end_time)
+ self.absolute_time.set_timezone(timezone)
+ def set_relative_time(self, interval):
+ """Set the relative time interval
+ @interval A double value in days
+ self.absolute_time.set_interval(interval)
+ def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
+ """Set the spatial extent of the map"""
+ self.spatial_extent.set_spatial_extent(north, south, east, west, top, bottom)
+ def delete(self):
+ """Delete a map entry from database if it exists
+ Remove dependent entries:
+ * Remove the map entry in each space time dataset in which this map is registered
+ * Remove the space time dataset register table
+ if self.is_in_db():
+ # Get all data
+ self.select()
+ # Remove the map from all registered space time datasets
+ if self.get_stds_register() != None:
+ # Select all stds tables in which this map is registered
+ sql = "SELECT id FROM " + self.get_stds_register()
+ #print sql
+ self.base.connect()
+ self.base.cursor.execute(sql)
+ rows = self.base.cursor.fetchall()
+ self.base.close()
+ # For each stds in which the map is registered
+ if rows:
+ for row in rows:
+ # Create a space time dataset object to remove the map
+ # from its register
+ strds = self.get_new_stds_instance(row["id"])
+ strds.select()
+ strds.unregister_map(self)
+ # Remove the strds register table
+ sql = "DROP TABLE " + self.get_stds_register()
+ #print sql
+ self.base.close()
+ # Delete yourself from the database, trigger functions will take care of dependencies
+ self.base.delete()
+class abstract_space_time_dataset(abstract_dataset):
+ """Abstract space time dataset class
+ This class represents a space time dataset. Convenient functions
+ to select, update, insert or delete objects of this type int the SQL
+ temporal database exists as well as functions to register or unregister
+ raster maps.
+ Parts of the temporal logic are implemented in the SQL temporal database,
+ like the computation of the temporal and spatial extent as well as the
+ collecting of metadata.
+ def __init__(self, ident):
+ self.reset(ident)
+ def get_new_map_instance(self, ident):
+ """Return a new instance of a map dataset which is associated with the type of this class"""
+ def get_map_register(self):
+ """Return the name of the map register table"""
+ def set_map_register(self, name):
+ """Set the name of the map register table"""
+ def reset(self, ident):
+ """Reset the internal structure and set the identifier"""
+ def set_initial_values(self, granularity, temporal_type, semantic_type, \
+ title=None, description=None):
+ if temporal_type == "absolute":
+ self.set_time_to_absolute()
+ self.absolute_time.set_granularity(granularity)
+ elif temporal_type == "relative":
+ self.set_time_to_relative()
+ self.relative_time.set_granularity(granularity)
+ else:
+ core.fatal("Unkown temporal type \"" + temporal_type + "\"")
+ self.base.set_semantic_type(semantic_type)
+ self.metadata.set_title(title)
+ self.metadata.set_description(description)
+ def delete(self):
+ """Delete a space time dataset from the database"""
+ # First we need to check if maps are registered in this dataset and
+ # unregister them
+ core.info("Delete space time " + self.get_new_map_instance(ident=None).get_type() + " dataset: " + self.get_id())
+ if self.get_map_register():
+ sql = "SELECT id FROM " + self.get_map_register()
+ self.base.close()
+ # Unregister each registered map in the table
+ if rows:
+ for row in rows:
+ # Unregister map
+ map = self.get_new_map_instance(row["id"])
+ self.unregister_map(map)
+ # Drop remove the map register table
+ sql = "DROP TABLE " + self.get_map_register()
+ self.base.close()
+ # Remove the primary key, the foreign keys will be removed by trigger
+ def register_map(self, map):
+ """Register a map in the space time dataset.
+ This method takes care of the registration of a map
+ in a space time dataset.
+ Break with a warning in case the map is already registered.
+ if map.is_in_db() == False:
+ core.fatal("Only maps with absolute or relative valid time can be registered")
+ core.info("Register " + map.get_type() + " map: " + map.get_id())
+ # First select all data from the database
+ map.select()
+ map_id = map.base.get_id()
+ map_name = map.base.get_name()
+ map_mapset = map.base.get_mapset()
+ map_register_table = map.get_stds_register()
+ #print "Map register table", map_register_table
+ # Get basic info
+ stds_name = self.base.get_name()
+ stds_mapset = self.base.get_mapset()
+ stds_register_table = self.get_map_register()
+ #print "STDS register table", stds_register_table
+ if stds_mapset != map_mapset:
+ core.fatal("You can only register maps from the same mapset")
+ # Check if map is already registred
+ if stds_register_table:
+ sql = "SELECT id FROM " + stds_register_table + " WHERE id = (?)"
+ self.base.cursor.execute(sql, (map_id,))
+ row = self.base.cursor.fetchone()
+ self.base.close()
+ # In case of no entry make a new one
+ if row and row[0] == map_id:
+ core.warning("Map " + map_id + "is already registered")
+ return False
+ # Create tables
+ sql_path = get_sql_template_path()
+ # We need to create the stmap raster register table bevor we can register the map
+ if map_register_table == None:
+ # Create a unique id
+ uuid_rand = "map_" + str(uuid.uuid4()).replace("-", "")
+ # Read the SQL template
+ sql = open(os.path.join(sql_path, "map_stds_register_table_template.sql"), 'r').read()
+ # Create the raster, raster3d and vector tables
+ sql = sql.replace("GRASS_MAP", map.get_type())
+ sql = sql.replace("MAP_NAME", map_name + "_" + map_mapset )
+ sql = sql.replace("TABLE_NAME", uuid_rand )
+ sql = sql.replace("MAP_ID", map_id)
+ sql = sql.replace("STDS", self.get_type())
+ self.base.cursor.executescript(sql)
+ self.base.close()
+ map_register_table = uuid_rand + "_" + self.get_type() + "_register"
+ # Set the stds register table name and put it into the DB
+ map.set_stds_register(map_register_table)
+ map.metadata.update()
+ #print "Created map register table ", map_register_table
+ # We need to create the table and register it
+ if stds_register_table == None:
+ sql = open(os.path.join(sql_path, "stds_map_register_table_template.sql"), 'r').read()
+ sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
+ sql = sql.replace("SPACETIME_ID", self.base.get_id())
+ self.base.close()
+ # We need raster specific trigger
+ sql = open(os.path.join(sql_path, "stds_" + map.get_type() + "_register_trigger_template.sql"), 'r').read()
+ self.base.close()
+ stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
+ # Set the map register table name and put it into the DB
+ self.set_map_register(stds_register_table)
+ #print "Created stds register table ", stds_register_table
+ # Register the stds in the map stds register table
+ # Check if the entry is already there
+ sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
+ self.base.cursor.execute(sql, (self.base.get_id(),))
+ self.base.close()
+ if row == None:
+ sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (?)"
+ #print sql
+ self.base.close()
+ # Now put the raster name in the stds map register table
+ sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (?)"
+ #print sql
+ self.base.close()
+ return True
+ def unregister_map(self, map):
+ """Remove a register a map from the space time dataset.
+ This method takes care of the unregistration of a map
+ core.info("Unegister " + map.get_type() + " map: " + map.get_id())
+ map.select()
+ # Get basic info
+ # Check if the map is registered in the space time raster dataset
+ self.base.close()
+ # Break if the map is not registered
+ if row == None:
+ core.fatal("Map " + map_id + " is not registered in space time dataset " + self.base.get_id())
+ # Remove the space time raster dataset from the raster dataset register
+ if map_register_table != None:
+ sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
+ self.base.close()
+ # Remove the raster map from the space time raster dataset register
+ if stds_register_table != None:
+ sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
+ self.base.close()
\ No newline at end of file
Added: grass/trunk/lib/python/tgis_base.py
--- grass/trunk/lib/python/tgis_base.py (rev 0)
+++ grass/trunk/lib/python/tgis_base.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,237 @@
+"""!@package grass.script.tgis_base
+Temporal GIS basic functions and classes to be used in other
+Python temporal gis packages.
+This packages includes all base classes to stor basic information like id, name,
+mapset creation and modification time.
+Usage:
+ at code
+from grass.script import tgis_core as grass
+rbase = grass.raster_base(ident="soil")
+ at endcode
+for details.
+from tgis_core import *
+class dataset_base(sql_database_interface):
+ """This is the base class for all maps and spacetime datasets storing basic information"""
+ def __init__(self, table=None, ident=None, name=None, mapset=None, creator=None, ctime=None,\
+ mtime=None, ttype=None, revision=1):
+ sql_database_interface.__init__(self, table, ident)
+ self.set_id(ident)
+ self.set_name(name)
+ self.set_mapset(mapset)
+ self.set_creator(creator)
+ self.set_ctime(ctime)
+ self.set_mtime(mtime)
+ self.set_ttype(ttype)
+ self.set_revision(revision)
+ def set_id(self, ident):
+ """Convenient method to set the unique identifier (primary key)"""
+ self.ident = ident
+ self.D["id"] = ident
+ def set_name(self, name):
+ """Set the name of the map"""
+ self.D["name"] = name
+ def set_mapset(self, mapset):
+ """Set the mapset of the map"""
+ self.D["mapset"] = mapset
+ def set_creator(self, creator):
+ """Set the creator of the map"""
+ self.D["creator"] = creator
+ def set_ctime(self, ctime=None):
+ """Set the creation time of the map, if nothing set the current time is used"""
+ if ctime == None:
+ self.D["creation_time"] = datetime.now()
+ else:
+ self.D["creation_time"] = ctime
+ def set_mtime(self, mtime=None):
+ """Set the modification time of the map, if nothing set the current time is used"""
+ if mtime == None:
+ self.D["modification_time"] = datetime.now()
+ else:
+ self.D["modification_time"] = mtime
+ def set_ttype(self, ttype):
+ """Set the temporal type of the map: absolute or relative, if nothing set absolute time will assumed"""
+ if ttype == None or (ttype != "absolute" and ttype != "relative"):
+ self.D["temporal_type"] = "absolute"
+ else:
+ self.D["temporal_type"] = ttype
+ def set_revision(self, revision=1):
+ """Set the revision of the map: if nothing set revision 1 will assumed"""
+ self.D["revision"] = revision
+ def get_id(self):
+ """Convenient method to get the unique identifier (primary key)
+ @return None if not found
+ if self.D.has_key("id"):
+ return self.D["id"]
+ else:
+ return None
+ def get_name(self):
+ """Get the name of the map
+ @return None if not found"""
+ if self.D.has_key("name"):
+ return self.D["name"]
+ else:
+ return None
+ def get_mapset(self):
+ """Get the mapset of the map
+ if self.D.has_key("mapset"):
+ return self.D["mapset"]
+ else:
+ return None
+ def get_creator(self):
+ """Get the creator of the map
+ if self.D.has_key("creator"):
+ return self.D["creator"]
+ else:
+ return None
+ def get_ctime(self):
+ """Get the creation time of the map, datatype is datetime
+ if self.D.has_key("creation_time"):
+ return self.D["creation_time"]
+ else:
+ return None
+ def get_mtime(self):
+ """Get the modification time of the map, datatype is datetime
+ if self.D.has_key("modification_time"):
+ return self.D["modification_time"]
+ else:
+ return None
+ def get_ttype(self):
+ """Get the temporal type of the map
+ if self.D.has_key("temporal_type"):
+ return self.D["temporal_type"]
+ else:
+ return None
+ def get_revision(self):
+ """Get the revision of the map
+ if self.D.has_key("revision"):
+ return self.D["revision"]
+ else:
+ return None
+ # 0123456789012345678901234567890
+ print " Id: ........................ " + str(self.get_id())
+ print " Name: ...................... " + str(self.get_name())
+ print " Mapset: .................... " + str(self.get_mapset())
+ print " Creator: ................... " + str(self.get_creator())
+ print " Creation time: ............. " + str(self.get_ctime())
+ print " Modification time: ......... " + str(self.get_mtime())
+ print " Temporal type: ............. " + str(self.get_ttype())
+ print " Revision in database: ...... " + str(self.get_revision())
+ print "id=" + str(self.get_id())
+ print "name=" + str(self.get_name())
+ print "mapset=" + str(self.get_mapset())
+ print "creator=" + str(self.get_creator())
+ print "creation_time=" + str(self.get_ctime())
+ print "modification_time=" + str(self.get_mtime())
+ print "temporal_type=" + str(self.get_ttype())
+ print "revision=" + str(self.get_revision())
+class raster_base(dataset_base):
+ def __init__(self, ident=None, name=None, mapset=None, creator=None, creation_time=None,\
+ modification_time=None, temporal_type=None, revision=1):
+ dataset_base.__init__(self, "raster_base", ident, name, mapset, creator, creation_time,\
+ modification_time, temporal_type, revision)
+class raster3d_base(dataset_base):
+ dataset_base.__init__(self, "raster3d_base", ident, name, mapset, creator, creation_time,\
+class vector_base(dataset_base):
+ dataset_base.__init__(self, "vector_base", ident, name, mapset, creator, creation_time,\
+class stds_base(dataset_base):
+ def __init__(self, table=None, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
+ dataset_base.__init__(self, table, ident, name, mapset, creator, creation_time,\
+ self.set_semantic_type(semantic_type)
+ def set_semantic_type(self, semantic_type):
+ """Set the sematnic type of the space time dataset"""
+ self.D["semantic_type"] = semantic_type
+ def get_semantic_type(self):
+ """Get the semantic_type of the space time dataset
+ if self.D.has_key("semantic_type"):
+ return self.D["semantic_type"]
+ else:
+ return None
+class strds_base(stds_base):
+ def __init__(self, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
+ stds_base.__init__(self, "strds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class str3ds_base(stds_base):
+ stds_base.__init__(self, "str3ds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class stvds_base(stds_base):
+ stds_base.__init__(self, "stvds_base", ident, name, mapset, semantic_type, creator, creation_time,\
Added: grass/trunk/lib/python/tgis_core.py
--- grass/trunk/lib/python/tgis_core.py (rev 0)
+++ grass/trunk/lib/python/tgis_core.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,317 @@
+"""!@package grass.script.tgis_core
+Temporal GIS core functions to be used in Python tgis packages.
+This class provides the SQL interface for serialization and deserialization
+of map and space time dataset data.
+Usage:
+ at code
+grass.create_temporal_database()
+ at endcode
+for details.
+import os
+import sqlite3
+import core
+from datetime import datetime, date, time
+def get_grass_location_db_path():
+ grassenv = core.gisenv()
+ dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
+ return os.path.join(dbpath, "grass.db")
+def get_sql_template_path():
+ base = os.getenv("GISBASE")
+ base_etc = os.path.join(base, "etc")
+ return os.path.join(base_etc, "sql")
+def create_temporal_database():
+ """This function creates the grass location database structure for raster, vector and raster3d maps
+ as well as for the space-time datasets strds, str3ds and stvds"""
+ database = get_grass_location_db_path()
+ # Check if it already exists
+ if os.path.exists(database):
+ return False
+ # Read all SQL scripts and templates
+ map_tables_template_sql = open(os.path.join(get_sql_template_path(), "map_tables_template.sql"), 'r').read()
+ raster_metadata_sql = open(os.path.join(get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
+ raster3d_metadata_sql = open(os.path.join(get_sql_template_path(), "raster3d_metadata_table.sql"), 'r').read()
+ vector_metadata_sql = open(os.path.join(get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
+ stds_tables_template_sql = open(os.path.join(get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
+ strds_metadata_sql = open(os.path.join(get_sql_template_path(), "strds_metadata_table.sql"), 'r').read()
+ str3ds_metadata_sql = open(os.path.join(get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
+ stvds_metadata_sql = open(os.path.join(get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
+ raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
+ vector_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "vector")
+ raster3d_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster3d")
+ # Create the space-time raster, raster3d and vector dataset tables
+ strds_tables_sql = stds_tables_template_sql.replace("STDS", "strds")
+ stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
+ str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
+ # Check for completion
+ sqlite3.complete_statement(raster_tables_sql)
+ sqlite3.complete_statement(vector_tables_sql)
+ sqlite3.complete_statement(raster3d_tables_sql)
+ sqlite3.complete_statement(raster_metadata_sql)
+ sqlite3.complete_statement(vector_metadata_sql)
+ sqlite3.complete_statement(raster3d_metadata_sql)
+ sqlite3.complete_statement(strds_tables_sql)
+ sqlite3.complete_statement(stvds_tables_sql)
+ sqlite3.complete_statement(str3ds_tables_sql)
+ sqlite3.complete_statement(strds_metadata_sql)
+ sqlite3.complete_statement(stvds_metadata_sql)
+ sqlite3.complete_statement(str3ds_metadata_sql)
+ # Connect to database
+ connection = sqlite3.connect(database)
+ cursor = connection.cursor()
+ # Execute the SQL statements
+ # Create the global tables for the native grass datatypes
+ cursor.executescript(raster_tables_sql)
+ cursor.executescript(raster_metadata_sql)
+ cursor.executescript(vector_tables_sql)
+ cursor.executescript(vector_metadata_sql)
+ cursor.executescript(raster3d_tables_sql)
+ cursor.executescript(raster3d_metadata_sql)
+ # Create the tables for the new space-time datatypes
+ cursor.executescript(strds_tables_sql)
+ cursor.executescript(strds_metadata_sql)
+ cursor.executescript(stvds_tables_sql)
+ cursor.executescript(stvds_metadata_sql)
+ cursor.executescript(str3ds_tables_sql)
+ cursor.executescript(str3ds_metadata_sql)
+ connection.commit()
+ cursor.close()
+class dict_sql_serializer(object):
+ def __init__(self):
+ self.D = {}
+ def serialize(self, type, table, where=None):
+ """Convert the internal dictionary into a string of semicolon separated SQL statements
+ The keys are the colum names and the values are the row entries
+ @type must be SELECT. INSERT, UPDATE
+ @table The name of the table to select, insert or update
+ @where The optinal where statment
+ @return the sql string
+ sql = ""
+ args = []
+ # Create ordered select statement
+ if type == "SELECT":
+ sql += 'SELECT '
+ count = 0
+ for key in self.D.keys():
+ if count == 0:
+ sql += ' %s ' % key
+ else:
+ sql += ' , %s ' % key
+ count += 1
+ sql += ' FROM ' + table + ' '
+ if where:
+ sql += where
+ # Create insert statement
+ if type =="INSERT":
+ count = 0
+ sql += 'INSERT INTO ' + table + ' ('
+ if count == 0:
+ else:
+ sql += ' ,%s ' % key
+ count += 1
+ count = 0
+ sql += ') VALUES ('
+ if count == 0:
+ sql += '?'
+ else:
+ sql += ',?'
+ count += 1
+ args.append(self.D[key])
+ sql += ') '
+ if where:
+ sql += where
+ # Create update statement
+ if type =="UPDATE":
+ count = 0
+ sql += 'UPDATE ' + table + ' SET '
+ # Update only entries which are not None
+ if self.D[key] != None:
+ if count == 0:
+ sql += ' %s = ? ' % key
+ else:
+ sql += ' ,%s = ? ' % key
+ count += 1
+ if where:
+ sql += where
+ return sql, tuple(args)
+ def deserialize(self, row):
+ """Convert the content of the sqlite row into the internal dictionary"""
+ self.D = {}
+ for key in row.keys():
+ self.D[key] = row[key]
+ def clear(self):
+ """Remove all the content of this class"""
+ self.D = {}
+ print self.D
+ def test(self):
+ t = dict_sql_serializer()
+ t.D["id"] = "soil at PERMANENT"
+ t.D["name"] = "soil"
+ t.D["mapset"] = "PERMANENT"
+ t.D["creator"] = "soeren"
+ t.D["creation_time"] = datetime.now()
+ t.D["modification_time"] = datetime.now()
+ t.D["revision"] = 1
+ sql, values = t.serialize(type="SELECT", table="raster_base")
+ print sql, '\n', values
+ sql, values = t.serialize(type="INSERT", table="raster_base")
+ sql, values = t.serialize(type="UPDATE", table="raster_base")
+class sql_database_interface(dict_sql_serializer):
+ """This is the sql database interface to sqlite3"""
+ def __init__(self, table=None, ident=None, database=None):
+ dict_sql_serializer.__init__(self)
+ self.table = table # Name of the table, set in the subclass
+ if database == None:
+ self.database = get_grass_location_db_path()
+ else:
+ self.database = database
+ def get_table_name(self):
+ return self.table
+ def connect(self):
+ self.connection = sqlite3.connect(self.database, detect_types=sqlite3.PARSE_DECLTYPES|sqlite3.PARSE_COLNAMES)
+ self.connection.row_factory = sqlite3.Row
+ self.cursor = self.connection.cursor()
+ def close(self):
+ self.connection.commit()
+ self.cursor.close()
+ def get_delete_statement(self):
+ return "DELETE FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
+ def delete(self):
+ self.connect()
+ sql = self.get_delete_statement()
+ #print sql
+ self.cursor.execute(sql)
+ self.close()
+ def get_is_in_db_statement(self):
+ return "SELECT id FROM " + self.get_table_name() + " WHERE id = \"" + str(self.ident) + "\""
+ self.connect()
+ sql = self.get_is_in_db_statement()
+ #print sql
+ row = self.cursor.fetchone()
+ self.close()
+ # Nothing found
+ if row == None:
+ return False
+ return True
+ def get_select_statement(self):
+ return self.serialize("SELECT", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
+ def select(self):
+ self.connect()
+ sql, args = self.get_select_statement()
+ #print sql
+ #print args
+ if len(args) == 0:
+ else:
+ self.cursor.execute(sql, args)
+ # Nothing found
+ if row == None:
+ return False
+ if len(row) > 0:
+ self.deserialize(row)
+ else:
+ raise IOError
+ self.close()
+ return True
+ def get_insert_statement(self):
+ return self.serialize("INSERT", self.get_table_name())
+ def insert(self):
+ self.connect()
+ sql, args = self.get_insert_statement()
+ #print sql
+ #print args
+ self.close()
+ def get_update_statement(self):
+ return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \"" + str(self.ident) + "\"")
+ def update(self):
+ if self.ident == None:
+ raise IOError("Missing identifer");
+ sql, args = self.get_update_statement()
+ #print sql
+ #print args
+ self.connect()
+ self.close()
Added: grass/trunk/lib/python/tgis_metadata.py
--- grass/trunk/lib/python/tgis_metadata.py (rev 0)
+++ grass/trunk/lib/python/tgis_metadata.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,606 @@
+"""!@package grass.script.tgis_metadata
+Temporal GIS related metadata functions to be used in Python scripts and tgis packages.
+Usage:
+ at code
+from grass.script import tgis_metadata as grass
+meta = grass.raster_metadata()
+ at endcode
+for details.
+from tgis_base import *
+class raster_metadata_base(sql_database_interface):
+ """This is the raster metadata base class for raster and raster3d maps"""
+ def __init__(self, table=None, ident=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
+ self.set_datatype(datatype)
+ self.set_cols(cols)
+ self.set_rows(rows)
+ self.set_number_of_cells(number_of_cells)
+ self.set_nsres(nsres)
+ self.set_ewres(ewres)
+ self.set_min(min)
+ self.set_max(max)
+ def set_datatype(self, datatype):
+ """Set the datatype"""
+ self.D["datatype"] = datatype
+ def set_cols(self, cols):
+ """Set the number of cols"""
+ self.D["cols"] = cols
+ def set_rows(self, rows):
+ """Set the number of rows"""
+ self.D["rows"] = rows
+ def set_number_of_cells(self, number_of_cells):
+ """Set the number of cells"""
+ self.D["number_of_cells"] = number_of_cells
+ def set_nsres(self, nsres):
+ """Set the north-south resolution"""
+ self.D["nsres"] = nsres
+ def set_ewres(self, ewres):
+ """Set the east-west resolution"""
+ self.D["ewres"] = ewres
+ def set_min(self, min):
+ """Set the minimum raster value"""
+ self.D["min"] = min
+ def set_max(self, max):
+ """Set the maximum raster value"""
+ self.D["max"] = max
+ def get_id(self):
+ else:
+ return None
+ def get_datatype(self):
+ """Get the map type
+ if self.D.has_key("datatype"):
+ return self.D["datatype"]
+ else:
+ return None
+ def get_cols(self):
+ """Get number of cols
+ if self.D.has_key("cols"):
+ return self.D["cols"]
+ else:
+ return None
+ def get_rows(self):
+ """Get number of rows
+ if self.D.has_key("rows"):
+ return self.D["rows"]
+ else:
+ return None
+ def get_number_of_cells(self):
+ """Get number of cells
+ if self.D.has_key("number_of_cells"):
+ return self.D["number_of_cells"]
+ else:
+ return None
+ def get_nsres(self):
+ """Get the north-south resolution
+ if self.D.has_key("nsres"):
+ return self.D["nsres"]
+ else:
+ return None
+ def get_ewres(self):
+ """Get east-west resolution
+ if self.D.has_key("ewres"):
+ return self.D["ewres"]
+ else:
+ return None
+ def get_min(self):
+ """Get the minimum cell value
+ if self.D.has_key("min"):
+ return self.D["min"]
+ else:
+ return None
+ def get_max(self):
+ """Get the maximum cell value
+ if self.D.has_key("max"):
+ return self.D["max"]
+ else:
+ return None
+ print " Datatype:................... " + str(self.get_datatype())
+ print " Number of columns:.......... " + str(self.get_cols())
+ print " Number of rows:............. " + str(self.get_rows())
+ print " Number of cells:............ " + str(self.get_number_of_cells())
+ print " North-South resolution:..... " + str(self.get_nsres())
+ print " East-west resolution:....... " + str(self.get_ewres())
+ print " Minimum value:.............. " + str(self.get_min())
+ print " Maximum value:.............. " + str(self.get_max())
+ print "datatype=" + str(self.get_datatype())
+ print "cols=" + str(self.get_cols())
+ print "rows=" + str(self.get_rows())
+ print "number_of_cells=" + str(self.get_number_of_cells())
+ print "nsres=" + str(self.get_nsres())
+ print "ewres=" + str(self.get_ewres())
+ print "min=" + str(self.get_min())
+ print "max=" + str(self.get_max())
+class raster_metadata(raster_metadata_base):
+ """This is the raster metadata class"""
+ def __init__(self, ident=None, strds_register=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
+ raster_metadata_base.__init__(self, "raster_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
+ self.set_strds_register(strds_register)
+ def set_strds_register(self, strds_register):
+ """Set the space time raster dataset register table name"""
+ self.D["strds_register"] = strds_register
+ def get_strds_register(self):
+ """Get the space time raster dataset register table name
+ if self.D.has_key("strds_register"):
+ return self.D["strds_register"]
+ else:
+ return None
+ raster_metadata_base.print_info(self)
+ raster_metadata_base.print_shell_info(self)
+class raster3d_metadata(raster_metadata_base):
+ """This is the raster3d metadata class"""
+ def __init__(self, ident=None, str3ds_register=None, datatype=None, cols=None, rows=None, depths=None, number_of_cells=None, nsres=None, ewres=None, tbres=None, min=None, max=None):
+ raster_metadata_base.__init__(self, "raster3d_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
+ self.set_str3ds_register(str3ds_register)
+ self.set_tbres(tbres)
+ self.set_depths(depths)
+ def set_str3ds_register(self, str3ds_register):
+ """Set the space time raster3d dataset register table name"""
+ self.D["str3ds_register"] = str3ds_register
+ def set_depths(self, depths):
+ """Set the number of depths"""
+ self.D["depths"] = depths
+ def set_tbres(self, tbres):
+ """Set the top-bottom resolution"""
+ self.D["tbres"] = tbres
+ def get_str3ds_register(self):
+ """Get the space time raster3d dataset register table name
+ if self.D.has_key("str3ds_register"):
+ return self.D["str3ds_register"]
+ else:
+ return None
+ def get_depths(self):
+ """Get number of depths
+ if self.D.has_key("depths"):
+ return self.D["depths"]
+ else:
+ return None
+ def get_tbres(self):
+ """Get top-bottom resolution
+ if self.D.has_key("tbres"):
+ return self.D["tbres"]
+ else:
+ return None
+class vector_metadata(sql_database_interface):
+ """This is the vector metadata class"""
+ def __init__(self, ident=None, stvds_register=None):
+ sql_database_interface.__init__(self, "vector_metadata", ident)
+ self.set_stvds_register(stvds_register)
+ def set_stvds_register(self, stvds_register):
+ """Set the space time vector dataset register table name"""
+ self.D["stvds_register"] = stvds_register
+ def get_id(self):
+ else:
+ return None
+ def get_stvds_register(self):
+ """Get the space time vector dataset register table name
+ if self.D.has_key("stvds_register"):
+ return self.D["stvds_register"]
+ else:
+ return None
+ print " STVDS register table ....... " + str(self.get_stvds_register())
+ print "stvds_register=" + str(self.get_stvds_register())
+class stds_metadata_base(sql_database_interface):
+ """This is the space time dataset metadata base class for strds, stvds and str3ds datasets
+ setting/getting the id, the title and the description
+ def __init__(self, table=None, ident=None, title=None, description=None):
+ self.set_title(title)
+ self.set_description(description)
+ # No setter for this
+ self.D["number_of_maps"] = None
+ def set_title(self, title):
+ """Set the title"""
+ self.D["title"] = title
+ def set_description(self, description):
+ self.D["description"] = description
+ def get_id(self):
+ else:
+ return None
+ def get_title(self):
+ """Get the title
+ if self.D.has_key("title"):
+ return self.D["title"]
+ else:
+ return None
+ def get_description(self):
+ """Get description
+ if self.D.has_key("description"):
+ return self.D["description"]
+ else:
+ return None
+ def get_number_of_maps(self):
+ """Get the number of registered maps, this value is set in the database
+ automatically via SQL trigger, so no setter exists
+ if self.D.has_key("number_of_maps"):
+ return self.D["number_of_maps"]
+ else:
+ return None
+ print " Number of registered maps:.. " + str(self.get_number_of_maps())
+ print " Title:"
+ print " " + str(self.get_title())
+ print " Description:"
+ print " " + str(self.get_description())
+ print "number_of_maps=" + str(self.get_number_of_maps())
+class stds_raster_metadata_base(stds_metadata_base):
+ """This is the space time dataset metadata base class for strds and str3ds datasets
+ Most of the metadata values are set by triggers in the database when
+ new raster of voxel maps are added. Therefor only some set- an many get-functions
+ are available.
+ stds_metadata_base.__init__(self, table, ident, title, description)
+ # Initialize the dict to select all values from the db
+ self.D["min_max"] = None
+ self.D["max_max"] = None
+ self.D["min_min"] = None
+ self.D["max_min"] = None
+ self.D["nsres_min"] = None
+ self.D["nsres_max"] = None
+ self.D["ewres_min"] = None
+ self.D["ewres_max"] = None
+ def get_max_min(self):
+ """Get the minimal maximum of all registered maps, this value is set in the database
+ if self.D.has_key("max_min"):
+ return self.D["max_min"]
+ else:
+ return None
+ def get_min_min(self):
+ """Get the minimal minimum of all registered maps, this value is set in the database
+ if self.D.has_key("min_min"):
+ return self.D["min_min"]
+ else:
+ return None
+ def get_max_max(self):
+ """Get the maximal maximum of all registered maps, this value is set in the database
+ if self.D.has_key("max_max"):
+ return self.D["max_max"]
+ else:
+ return None
+ def get_min_max(self):
+ """Get the maximal minimum of all registered maps, this value is set in the database
+ if self.D.has_key("min_max"):
+ return self.D["min_max"]
+ else:
+ return None
+ else:
+ return None
+ def get_nsres_min(self):
+ """Get the minimal north-south resolution of all registered maps, this value is set in the database
+ if self.D.has_key("nsres_min"):
+ return self.D["nsres_min"]
+ else:
+ return None
+ def get_nsres_max(self):
+ """Get the maximal north-south resolution of all registered maps, this value is set in the database
+ if self.D.has_key("nsres_max"):
+ return self.D["nsres_max"]
+ else:
+ return None
+ def get_ewres_min(self):
+ """Get the minimal east-west resolution of all registered maps, this value is set in the database
+ if self.D.has_key("ewres_min"):
+ return self.D["ewres_min"]
+ else:
+ return None
+ def get_ewres_max(self):
+ """Get the maximal east-west resolution of all registered maps, this value is set in the database
+ if self.D.has_key("ewres_max"):
+ return self.D["ewres_max"]
+ else:
+ return None
+ stds_metadata_base.print_info(self)
+ stds_metadata_base.print_shell_info(self)
+class strds_metadata(stds_raster_metadata_base):
+ def __init__(self, ident=None, raster_register=None, title=None, description=None):
+ stds_raster_metadata_base.__init__(self, "strds_metadata", ident, title, description)
+ self.set_raster_register(raster_register)
+ def set_raster_register(self, raster_register):
+ """Set the raster map register table name"""
+ self.D["raster_register"] = raster_register
+ def get_raster_register(self):
+ """Get the raster map register table name
+ if self.D.has_key("raster_register"):
+ return self.D["raster_register"]
+ else:
+ return None
+ stds_raster_metadata_base.print_info(self)
+ stds_raster_metadata_base.print_shell_info(self)
+class str3ds_metadata(stds_raster_metadata_base):
+ """This is the space time raster3d metadata class"""
+ def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
+ stds_raster_metadata_base.__init__(self, "str3ds_metadata", ident, title, description)
+ self.set_raster3d_register(raster3d_register)
+ self.D["tbres_min"] = None
+ self.D["tbres_max"] = None
+ def set_raster3d_register(self, raster3d_register):
+ self.D["raster3d_register"] = raster3d_register
+ def get_raster3d_register(self):
+ """Get the raster3d map register table name
+ if self.D.has_key("raster3d_register"):
+ return self.D["raster3d_register"]
+ else:
+ return None
+ def get_tbres_min(self):
+ """Get the minimal top-bottom resolution of all registered maps, this value is set in the database
+ if self.D.has_key("tbres_min"):
+ return self.D["tbres_min"]
+ else:
+ return None
+ def get_tbres_max(self):
+ """Get the maximal top-bottom resolution of all registered maps, this value is set in the database
+ if self.D.has_key("tbres_max"):
+ return self.D["tbres_max"]
+ else:
+ return None
+class stvds_metadata(stds_metadata_base):
+ def __init__(self, ident=None, vector_register=None, title=None, description=None):
+ stds_metadata_base.__init__(self, "stvds_metadata", ident, title, description)
+ self.set_vector_register(vector_register)
+ def set_vector_register(self, vector_register):
+ """Set the vector map register table name"""
+ self.D["vector_register"] = vector_register
+ def get_vector_register(self):
+ """Get the vector map register table name
+ if self.D.has_key("vector_register"):
+ return self.D["vector_register"]
+ else:
+ return None
Added: grass/trunk/lib/python/tgis_space_time_datasets.py
--- grass/trunk/lib/python/tgis_space_time_datasets.py (rev 0)
+++ grass/trunk/lib/python/tgis_space_time_datasets.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,371 @@
+"""!@package grass.script.tgis_space_time_dataset
+Usage:
+ at code
+from grass.script import tgis_space_time_dataset as grass
+strds = grass.space_time_raster_dataset("soils_1950_2010")
+ at endcode
+for details.
+import getpass
+import raster
+import vector
+import raster3d
+from tgis_abstract_datasets import *
+class raster_dataset(abstract_map_dataset):
+ """Raster dataset class
+ This class provides functions to select, update, insert or delete raster
+ map informations and valid time stamps into the SQL temporal database.
+ self.reset(ident)
+ return "raster"
+ return raster_dataset(ident)
+ return space_time_raster_dataset(ident)
+ return self.metadata.get_strds_register()
+ self.metadata.set_strds_register(name)
+ self.base = raster_base(ident=ident)
+ self.absolute_time = raster_absolute_time(ident=ident)
+ self.relative_time = raster_relative_time(ident=ident)
+ self.spatial_extent = raster_spatial_extent(ident=ident)
+ self.metadata = raster_metadata(ident=ident)
+ def load(self):
+ """Load all info from an existing raster map into the internal structure"""
+ # Get the data from an existing raster map
+ kvp = raster.raster_info(self.ident)
+ # Fill base information
+ self.base.set_name(self.ident.split("@")[0])
+ self.base.set_mapset(self.ident.split("@")[1])
+ self.base.set_creator(str(getpass.getuser()))
+ # Fill spatial extent
+ self.set_spatial_extent(north=kvp["north"], south=kvp["south"], \
+ east=kvp["east"], west=kvp["west"])
+ # Fill metadata
+ self.metadata.set_nsres(kvp["nsres"])
+ self.metadata.set_ewres(kvp["ewres"])
+ self.metadata.set_datatype(kvp["datatype"])
+ self.metadata.set_min(kvp["min"])
+ self.metadata.set_max(kvp["max"])
+ rows = int((kvp["north"] - kvp["south"])/kvp["nsres"] + 0.5)
+ cols = int((kvp["east"] - kvp["west"])/kvp["ewres"] + 0.5)
+ ncells = cols * rows
+ self.metadata.set_cols(cols)
+ self.metadata.set_rows(rows)
+ self.metadata.set_number_of_cells(ncells)
+class raster3d_dataset(abstract_map_dataset):
+ """Raster3d dataset class
+ This class provides functions to select, update, insert or delete raster3d
+ self.reset(ident)
+ return "raster3d"
+ return raster3d_dataset(ident)
+ return space_time_raster3d_dataset(ident)
+ return self.metadata.get_str3ds_register()
+ self.metadata.set_str3ds_register(name)
+ self.base = raster3d_base(ident=ident)
+ self.absolute_time = raster3d_absolute_time(ident=ident)
+ self.relative_time = raster3d_relative_time(ident=ident)
+ self.spatial_extent = raster3d_spatial_extent(ident=ident)
+ self.metadata = raster3d_metadata(ident=ident)
+ def load(self):
+ """Load all info from an existing raster3d map into the internal structure"""
+ kvp = raster3d.raster3d_info(self.ident)
+ east=kvp["east"], west=kvp["west"],\
+ top=kvp["top"], bottom=kvp["bottom"])
+ # Fill metadata
+ self.metadata.set_tbres(kvp["tbres"])
+ depths = int((kvp["top"] - kvp["bottom"])/kvp["tbres"] + 0.5)
+ ncells = cols * rows * depths
+ self.metadata.set_depths(depths)
+class vector_dataset(abstract_map_dataset):
+ """Vector dataset class
+ This class provides functions to select, update, insert or delete vector
+ self.reset(ident)
+ return "vector"
+ return vector_dataset(ident)
+ return space_time_vector_dataset(ident)
+ return self.metadata.get_stvds_register()
+ self.metadata.set_stvds_register(name)
+ self.base = vector_base(ident=ident)
+ self.absolute_time = vector_absolute_time(ident=ident)
+ self.relative_time = vector_relative_time(ident=ident)
+ self.spatial_extent = vector_spatial_extent(ident=ident)
+ self.metadata = vector_metadata(ident=ident)
+ def load(self):
+ """Load all info from an existing vector map into the internal structure"""
+ kvp = vector.vector_info(self.ident)
+ # Fill metadata .. no metadata yet
+class space_time_raster_dataset(abstract_space_time_dataset):
+ """Space time raster dataset class
+ abstract_space_time_dataset.__init__(self, ident)
+ return "strds"
+ return self.metadata.get_raster_register()
+ self.metadata.set_raster_register(name)
+ self.base = strds_base(ident=ident)
+ if ident != None:
+ self.absolute_time = strds_absolute_time(ident=ident)
+ self.relative_time = strds_relative_time(ident=ident)
+ self.spatial_extent = strds_spatial_extent(ident=ident)
+ self.metadata = strds_metadata(ident=ident)
+class space_time_raster3d_dataset(abstract_space_time_dataset):
+ """Space time raster3d dataset class
+ return "str3ds"
+ return self.metadata.get_raster3d_register()
+ self.metadata.set_raster3d_register(name)
+ self.base = str3ds_base(ident=ident)
+ self.absolute_time = str3ds_absolute_time(ident=ident)
+ self.relative_time = str3ds_relative_time(ident=ident)
+ self.spatial_extent = str3ds_spatial_extent(ident=ident)
+ self.metadata = str3ds_metadata(ident=ident)
+class space_time_vector_dataset(abstract_space_time_dataset):
+ """Space time vector dataset class
+ return "stvds"
+ return self.metadata.get_vector_register()
+ self.metadata.set_vector_register(name)
+ self.base = stvds_base(ident=ident)
+ self.absolute_time = stvds_absolute_time(ident=ident)
+ self.relative_time = stvds_relative_time(ident=ident)
+ self.spatial_extent = stvds_spatial_extent(ident=ident)
+ self.metadata = stvds_metadata(ident=ident)
Added: grass/trunk/lib/python/tgis_spatial_extent.py
--- grass/trunk/lib/python/tgis_spatial_extent.py (rev 0)
+++ grass/trunk/lib/python/tgis_spatial_extent.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,289 @@
+"""!@package grass.script.tgis_spatial_extent
+Temporal GIS related spatial extent functions to be used in Python scripts and tgis packages.
+Usage:
+ at code
+from grass.script import tgis_spatial_extent as grass
+extent = grass.raster_spatial_extent()
+ at endcode
+for details.
+class spatial_extent(sql_database_interface):
+ """This is the spatial extent base class for all maps and spacetime datasets"""
+ def __init__(self, table=None, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None, proj="XY"):
+ self.set_spatial_extent(north, south, east, west, top, bottom)
+ self.set_projection(proj)
+ def overlap_2d(self, extent):
+ """Return True if the 2d extents overlap. Code is lend from wind_overlap.c in lib/gis"""
+ if self.get_projection() != extent.get_projection():
+ core.error("Projections are different. Unable to compute overlap_2d for spatial extents")
+ N = extent.get_north()
+ S = extent.get_south()
+ E = extent.get_east()
+ W = extent.get_west()
+ if(self.get_north() <= S):
+ return False
+ if(self.get_south() >= N):
+ return False
+ # Adjust the east and west in case of LL projection
+ if self.get_proj() == "LL":
+ while E < self.get_west():
+ E += 360.0
+ W += 360.0
+ while W > self.get_east():
+ E -= 360.0
+ W -= 360.0
+ if self.get_east() <= W:
+ return False
+ if self.get_west() >= E:
+ return False
+ return True
+ def overlap(self, extent):
+ """Return True if the extents overlap."""
+ if self.overlap_2d(extent) == False:
+ return False
+ T = extent.get_top()
+ B = extent.get_bottom()
+ if self.get_top() <= B:
+ return False
+ if self.get_bottom() >= T:
+ return False
+ return True
+ def set_spatial_extent(self, north, south, east, west, top, bottom):
+ """Set the spatial extent"""
+ self.set_north(north)
+ self.set_south(south)
+ self.set_east(east)
+ self.set_west(west)
+ self.set_top(top)
+ self.set_bottom(bottom)
+ def set_projection(self, proj):
+ """Set the projection of the spatial extent it should be XY or LL.
+ As default the projection is XY
+ if proj == None or (proj != "XY" and proj != "LL"):
+ self.D["proj"] = "XY"
+ else:
+ self.D["proj"] = proj
+ def set_spatial_extent_2d(self, north, south, east, west):
+ self.set_top(0)
+ self.set_bottom(0)
+ def set_north(self, north):
+ """Set the northern edge of the map"""
+ self.D["north"] = north
+ def set_south(self, sourth):
+ """Set the sourthern edge of the map"""
+ self.D["south"] = sourth
+ def set_west(self, west):
+ """Set the western edge of the map"""
+ self.D["west"] = west
+ def set_east(self, east):
+ """Set the eastern edge of the map"""
+ self.D["east"] = east
+ def set_top(self, top):
+ """Set the top edge of the map"""
+ self.D["top"] = top
+ def set_bottom(self, bottom):
+ """Set the bottom edge of the map"""
+ self.D["bottom"] = bottom
+ def get_id(self):
+ else:
+ return None
+ def get_projection(self):
+ """Get the projection of the spatial extent"""
+ return self.D["proj"]
+ def get_volume(self):
+ """Compute the volume of the extent, in case z is zero (top == bottom or top - bottom = 1) the area is returned"""
+ if self.get_projection() == "LL":
+ core.error("Volume computation is not supported for LL projections")
+ area = self.get_area()
+ bbox = self.get_spatial_extent()
+ z = abs(bbox[4] - bbox[5])
+ if z == 0:
+ z = 1.0
+ return area*z
+ def get_area(self):
+ """Compute the area of the extent, extent in z direction is ignored"""
+ core.error("Area computation is not supported for LL projections")
+ y = abs(bbox[0] - bbox[1])
+ x = abs(bbox[2] - bbox[3])
+ return x*y
+ """Return a tuple (north, south, east, west, top, bottom) of the spatial extent"""
+ return (self.get_north(), self.get_south, self.get_east(), self.get_west(), \
+ self.get_top(), self.get_bottom())
+ def get_spatial_extent_2d(self):
+ """Return a tuple (north, south, east, west,) of the 2d spatial extent"""
+ return (self.get_north(), self.get_south, self.get_east(), self.get_west())
+ def get_north(self):
+ """Get the northern edge of the map
+ if self.D.has_key("north"):
+ return self.D["north"]
+ else:
+ return None
+ def get_south(self):
+ """Get the southern edge of the map
+ if self.D.has_key("south"):
+ return self.D["south"]
+ else:
+ return None
+ def get_east(self):
+ """Get the eastern edge of the map
+ if self.D.has_key("east"):
+ return self.D["east"]
+ else:
+ return None
+ def get_west(self):
+ """Get the western edge of the map
+ if self.D.has_key("west"):
+ return self.D["west"]
+ else:
+ return None
+ def get_top(self):
+ """Get the top edge of the map
+ if self.D.has_key("top"):
+ return self.D["top"]
+ else:
+ return None
+ def get_bottom(self):
+ """Get the bottom edge of the map
+ if self.D.has_key("bottom"):
+ return self.D["bottom"]
+ else:
+ return None
+ print " North:...................... " + str(self.get_north())
+ print " South:...................... " + str(self.get_south())
+ print " East:.. .................... " + str(self.get_east())
+ print " West:....................... " + str(self.get_west())
+ print " Top:........................ " + str(self.get_top())
+ print " Bottom:..................... " + str(self.get_bottom())
+ print "north=" + str(self.get_north())
+ print "south=" + str(self.get_south())
+ print "east=" + str(self.get_east())
+ print "west=" + str(self.get_west())
+ print "top=" + str(self.get_top())
+ print "bottom=" + str(self.get_bottom())
+class raster_spatial_extent(spatial_extent):
+ def __init__(self, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
+ spatial_extent.__init__(self, "raster_spatial_extent", ident, north, south, east, west, top, bottom)
+class raster3d_spatial_extent(spatial_extent):
+ spatial_extent.__init__(self, "raster3d_spatial_extent", ident, north, south, east, west, top, bottom)
+class vector_spatial_extent(spatial_extent):
+ spatial_extent.__init__(self, "vector_spatial_extent", ident, north, south, east, west, top, bottom)
+class strds_spatial_extent(spatial_extent):
+ spatial_extent.__init__(self, "strds_spatial_extent", ident, north, south, east, west, top, bottom)
+class str3ds_spatial_extent(spatial_extent):
+ spatial_extent.__init__(self, "str3ds_spatial_extent", ident, north, south, east, west, top, bottom)
+class stvds_spatial_extent(spatial_extent):
+ spatial_extent.__init__(self, "stvds_spatial_extent", ident, north, south, east, west, top, bottom)
Added: grass/trunk/lib/python/tgis_temporal_extent.py
--- grass/trunk/lib/python/tgis_temporal_extent.py (rev 0)
+++ grass/trunk/lib/python/tgis_temporal_extent.py 2011-09-14 01:00:28 UTC (rev 48288)
@@ -0,0 +1,485 @@
+"""!@package grass.script.tgis_temporal_extent
+Temporal GIS related temporal extent functions to be used in Python scripts and tgis packages.
+Usage:
+ at code
+from grass.script import tgis_temporal_extent as grass
+grass.raster_temporal_extent()
+ at endcode
+for details.
+class absolute_temporal_extent(sql_database_interface):
+ """This is the absolute time base class for all maps and spacetime datasets"""
+ def __init__(self, table=None, ident=None, start_time=None, end_time=None, timezone=None):
+ self.set_start_time(start_time)
+ self.set_end_time(end_time)
+ self.set_timezone(timezone)
+ def starts(self, map):
+ """Return True if this absolute time object starts at the start of the provided absolute time object and finishes within it
+ A |-----|
+ B |---------|
+ if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] < map.D["end_time"]:
+ return True
+ else:
+ return False
+ def started(self, map):
+ """Return True if this absolute time object is started at the start of the provided absolute time object
+ A |---------|
+ B |-----|
+ if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] > map.D["end_time"]:
+ return True
+ else:
+ return False
+ def finishes(self, map):
+ """Return True if this absolute time object finishes at the end and within of the provided absolute time object
+ A |-----|
+ B |---------|
+ if self.D["end_time"] == map.D["end_time"] and self.D["start_time"] > map.D["start_time"] :
+ return True
+ else:
+ return False
+ def finished(self, map):
+ """Return True if this absolute time object finished at the end of the provided absolute time object
+ A |---------|
+ B |-----|
+ if self.D["end_time"] == map.D["end_time"] and self.D["start_time"] < map.D["start_time"] :
+ return True
+ else:
+ return False
+ def after(self, map):
+ """Return True if this absolute time object is temporal located after the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["start_time"] > map.D["end_time"]:
+ return True
+ else:
+ return False
+ def before(self, map):
+ """Return True if this absolute time object is temporal located bevor the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["end_time"] < map.D["start_time"]:
+ return True
+ else:
+ return False
+ def adjacent(self, map):
+ """Return True if this absolute time object is a meeting neighbour the provided absolute time object
+ A |---------|
+ B |---------|
+ A |---------|
+ B |---------|
+ if (self.D["start_time"] == map.D["end_time"]) or (self.D["end_time"] == map.D["start_time"]):
+ return True
+ else:
+ return False
+ def follows(self, map):
+ """Return True if this absolute time object is temporal follows the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["start_time"] == map.D["end_time"]:
+ return True
+ else:
+ return False
+ def precedes(self, map):
+ """Return True if this absolute time object is temporal precedes the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["end_time"] == map.D["start_time"]:
+ return True
+ else:
+ return False
+ def during(self, map):
+ """Return True if this absolute time object is temporal located during the provided absolute time object
+ A |-------|
+ B |---------|
+ if self.D["start_time"] > map.D["start_time"] and self.D["end_time"] < map.D["end_time"]:
+ return True
+ else:
+ return False
+ def contains(self, map):
+ A |---------|
+ B |-------|
+ if self.D["start_time"] < map.D["start_time"] and self.D["end_time"] > map.D["end_time"]:
+ return True
+ else:
+ return False
+ def equivalent(self, map):
+ """Return True if this absolute time object is temporal located equivalent the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["start_time"] == map.D["start_time"] and self.D["end_time"] == map.D["end_time"]:
+ return True
+ else:
+ return False
+ def overlaps(self, map):
+ """Return True if this absolute time object is temporal overlaps the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["start_time"] < map.D["start_time"] and self.D["end_time"] < map.D["end_time"] and\
+ self.D["end_time"] > map.D["start_time"]:
+ return True
+ else:
+ return False
+ def overlapped(self, map):
+ """Return True if this absolute time object is temporal overlaped by the provided absolute time object
+ A |---------|
+ B |---------|
+ if self.D["start_time"] > map.D["start_time"] and self.D["end_time"] > map.D["end_time"] and\
+ self.D["start_time"] < map.D["end_time"]:
+ return True
+ else:
+ return False
+ """Returns the temporal relation between absolute time temporal objects
+ Temporal relationsships are implemented after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
+ if self.equivalent(map):
+ return "equivalent"
+ if self.during(map):
+ return "during"
+ if self.contains(map):
+ return "contains"
+ if self.overlaps(map):
+ return "overlaps"
+ if self.overlapped(map):
+ return "overlapped"
+ if self.after(map):
+ return "after"
+ if self.before(map):
+ return "before"
+ if self.starts(map):
+ return "starts"
+ if self.finishes(map):
+ return "finishes"
+ if self.started(map):
+ return "started"
+ if self.finished(map):
+ return "finished"
+ if self.follows(map):
+ return "follows"
+ if self.precedes(map):
+ return "precedes"
+ return None
+ def set_start_time(self, start_time):
+ """Set the valid start time of the map, this should be of type datetime"""
+ self.D["start_time"] = start_time
+ def set_end_time(self, end_time):
+ """Set the valid end time of the map, this should be of type datetime"""
+ self.D["end_time"] = end_time
+ def set_timezone(self, timezone):
+ """Set the timezone of the map, integer from 1 - 24"""
+ self.D["timezone"] = timezone
+ def get_id(self):
+ else:
+ return None
+ def get_start_time(self):
+ """Get the valid start time of the map
+ if self.D.has_key("start_time"):
+ return self.D["start_time"]
+ else:
+ return None
+ def get_end_time(self):
+ """Get the valid end time of the map
+ if self.D.has_key("end_time"):
+ return self.D["end_time"]
+ else:
+ return None
+ def get_timezone(self):
+ """Get the timezone of the map
+ if self.D.has_key("timezone"):
+ return self.D["timezone"]
+ else:
+ return None
+ print " Start time:................. " + str(self.get_start_time())
+ print " End time:................... " + str(self.get_end_time())
+ print " Timezone:................... " + str(self.get_timezone())
+ print "start_time=" + str(self.get_start_time())
+ print "end_time=" + str(self.get_end_time())
+ print "timezone=" + str(self.get_timezone())
+class raster_absolute_time(absolute_temporal_extent):
+ def __init__(self, ident=None, start_time=None, end_time=None, timezone=None):
+ absolute_temporal_extent.__init__(self, "raster_absolute_time", ident, start_time, end_time, timezone)
+class raster3d_absolute_time(absolute_temporal_extent):
+ absolute_temporal_extent.__init__(self, "raster3d_absolute_time", ident, start_time, end_time, timezone)
+class vector_absolute_time(absolute_temporal_extent):
+ absolute_temporal_extent.__init__(self, "vector_absolute_time", ident, start_time, end_time, timezone)
+class stds_absolute_time(absolute_temporal_extent):
+ def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
+ absolute_temporal_extent.__init__(self, table, ident, start_time, end_time, timezone)
+ self.set_granularity(granularity)
+ def set_granularity(self, granularity):
+ """Set the granularity of the space time dataset"""
+ self.D["granularity"] = granularity
+ def get_granularity(self):
+ """Get the granularity of the space time dataset
+ if self.D.has_key("granularity"):
+ return self.D["granularity"]
+ else:
+ return None
+ absolute_temporal_extent.print_info(self)
+ print " Granularity:................ " + str(self.get_granularity())
+ absolute_temporal_extent.print_shell_info(self)
+ print "granularity=" + str(self.get_granularity())
+class strds_absolute_time(stds_absolute_time):
+ def __init__(self, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
+ stds_absolute_time.__init__(self, "strds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class str3ds_absolute_time(stds_absolute_time):
+ stds_absolute_time.__init__(self, "str3ds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class stvds_absolute_time(stds_absolute_time):
+ stds_absolute_time.__init__(self, "stvds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class relative_temporal_extent(sql_database_interface):
+ """This is the relative time base class for all maps and spacetime datasets"""
+ def __init__(self, table=None, ident=None, interval=None):
+ self.set_interval(interval)
+ """Return True if this relative time object is temporal located after the provided relative time object
+ A |
+ B |
+ if self.D["interval"] > map.D["interval"]:
+ return True
+ else:
+ return False
+ """Return True if this relative time object is temporal located bevor the provided relative time object
+ A |
+ B |
+ if self.D["interval"] < map.D["interval"]:
+ return True
+ else:
+ return False
+ """Return True if this relative time object is equivalent to the provided relative time object
+ A |
+ B |
+ if self.D["interval"] == map.D["interval"]:
+ return True
+ else:
+ return False
+ """Returns the temporal relation between relative time temporal objects
+ return "after"
+ return "before"
+ return None
+ def set_interval(self, interval):
+ """Set the valid interval time of the map, this should be of type datetime"""
+ self.D["interval"] = interval
+ def get_id(self):
+ else:
+ return None
+ def get_interval(self):
+ """Get the valid interval time of the map
+ if self.D.has_key("interval"):
+ return self.D["interval"]
+ else:
+ return None
+ print " Interval:................... " + str(self.get_interval())
+ print "interval=" + str(self.get_interval())
+class raster_relative_time(relative_temporal_extent):
+ def __init__(self, ident=None, interval=None):
+ relative_temporal_extent.__init__(self, "raster_relative_time", ident, interval)
+class raster3d_relative_time(relative_temporal_extent):
+ relative_temporal_extent.__init__(self, "raster3d_relative_time", ident, interval)
+class vector_relative_time(relative_temporal_extent):
+ relative_temporal_extent.__init__(self, "vector_relative_time", ident, interval)
+class stds_relative_time(relative_temporal_extent):
+ def __init__(self, table=None, ident=None, interval=None, granularity=None):
+ relative_temporal_extent.__init__(self, table, ident, interval)
+ else:
+ return None
+ def print_info(self):
+ """Print information about this class in human readable style"""
+ relative_temporal_extent.print_info(self)
+ def print_shell_info(self):
+ """Print information about this class in shell style"""
+ relative_temporal_extent.print_shell_info(self)
+class strds_relative_time(stds_relative_time):
+ def __init__(self, ident=None, interval=None, granularity=None):
+ stds_relative_time.__init__(self, "strds_relative_time", ident, interval, granularity)
+class str3ds_relative_time(stds_relative_time):
+ stds_relative_time.__init__(self, "str3ds_relative_time", ident, interval, granularity)
+class stvds_relative_time(stds_relative_time):
+ stds_relative_time.__init__(self, "stvds_relative_time", ident, interval, granularity)
