[GRASS-SVN] r48293 - in grass/trunk: lib/python lib/temporal
temporal/tr.register temporal/tr.unregister
svn_grass at osgeo.org
Wed Sep 14 03:40:51 EDT 2011
Author: huhabla
Date: 2011-09-14 00:40:51 -0700 (Wed, 14 Sep 2011)
New Revision: 48293
grass/trunk/lib/python/tgis_abstract_datasets.py
grass/trunk/lib/temporal/map_stds_register_table_template.sql
grass/trunk/lib/temporal/raster_metadata_table.sql
grass/trunk/lib/temporal/stvds_metadata_table.sql
grass/trunk/lib/temporal/test.temporal.py
grass/trunk/lib/temporal/vector_metadata_table.sql
grass/trunk/temporal/tr.register/tr.register.py
grass/trunk/temporal/tr.unregister/tr.unregister.py
Minor fixes in map registration logic.
Modified: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py 2011-09-14 07:40:51 UTC (rev 48293)
@@ -1,20 +1,14 @@
-"""!@package grass.script.tgis_map_datasets
+"""!@package grass.script.tgis_abstract_datasets
@brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS related functions to be used in Python scripts.
+Temporal GIS related functions to be used in temporal GIS Python library package.
Usage:
@code
-from grass.script import tgis_map_datasets as grass
+from grass.script import tgis_abstract_datasets as grass
-raster_ds = grass.raster_database("soil")
-if raster_ds.is_in_db():
- raster_ds.select()
-else:
- raster_ds.load()
@endcode
Modified: grass/trunk/lib/temporal/map_stds_register_table_template.sql
--- grass/trunk/lib/temporal/map_stds_register_table_template.sql 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/temporal/map_stds_register_table_template.sql 2011-09-14 07:40:51 UTC (rev 48293)
@@ -3,14 +3,15 @@
-- which the GRASS_MAP map is registered
-- This table is map specific and created for each GRASS_MAP map which is registered
--- in a STDS. TABLE_NAME is a placeholder for the dataset name.
+-- in a STDS. TABLE_NAME is a placeholder for the table name which must be unique.
+-- A uuid is used as unique identifier across mapsets.
-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
PRAGMA foreign_keys = ON;
--- TABLE_NAME is a placeholder for specific map name (SQL compliant): name_mapset
+-- TABLE_NAME is a placeholder for specific table name (SQL compliant)
-- MAP_ID is a placeholder for specific map id: name at mapset
-- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
-- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
Modified: grass/trunk/lib/temporal/raster_metadata_table.sql
--- grass/trunk/lib/temporal/raster_metadata_table.sql 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/temporal/raster_metadata_table.sql 2011-09-14 07:40:51 UTC (rev 48293)
@@ -11,8 +11,8 @@
-- The metadata table reflects most of the raster metadata available in grass
CREATE TABLE raster_metadata (
- id VARCHAR NOT NULL, -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
- strds_register VARCHAR, -- The name of the table storing all space-time raster datasets in which this map is registered
+ id VARCHAR NOT NULL, -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
+ strds_register VARCHAR, -- The name of the table storing all space-time raster datasets in which this map is registered
datatype VARCHAR NOT NULL,
cols INTEGER NOT NULL,
rows INTEGER NOT NULL,
Modified: grass/trunk/lib/temporal/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/stvds_metadata_table.sql 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/temporal/stvds_metadata_table.sql 2011-09-14 07:40:51 UTC (rev 48293)
@@ -19,7 +19,7 @@
-- Create the views to access all columns for absolute or relative time
CREATE VIEW stvds_view_abs_time AS SELECT
- A1.id, A1.temporal_type,
+ A1.id, A1.name, A1.mapset, A1.temporal_type,
A1.creator, A1.semantic_type,
A1.creation_time, A1.modification_time,
A1.revision, A2.start_time,
@@ -33,7 +33,7 @@
A1.id = A3.id AND A1.id = A4.id;
CREATE VIEW stvds_view_rel_time AS SELECT
A1.revision,
Modified: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/temporal/test.temporal.py 2011-09-14 07:40:51 UTC (rev 48293)
@@ -4,7 +4,7 @@
from grass.script.tgis_temporal_extent import *
from grass.script.tgis_spatial_extent import *
from grass.script.tgis_metadata import *
-from grass.script.tgis_map_datasets import *
+from grass.script.tgis_abstract_datasets import *
from grass.script.tgis_space_time_datasets import *
import grass.script as grass
@@ -716,10 +716,10 @@
# We need to specify the name and the mapset as identifier
r3ds = raster3d_dataset(ident)
- # Load data from the raster map in the mapset
+ # Load data from the raster3d map in the mapset
r3ds.load()
- print "Is raster in db: ", r3ds.is_in_db()
+ print "Is raster3d in db: ", r3ds.is_in_db()
if r3ds.is_in_db():
r3ds.select()
@@ -734,7 +734,7 @@
end_time= datetime(year=2000, month=i + 1, day=1))
# Insert the map data into the SQL database
r3ds.insert()
- # Register the map in the space time raster dataset
+ # Register the map in the space time raster3d dataset
str3ds.register_map(r3ds)
# Print self info
#r3ds.print_self()
Modified: grass/trunk/lib/temporal/vector_metadata_table.sql
--- grass/trunk/lib/temporal/vector_metadata_table.sql 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/lib/temporal/vector_metadata_table.sql 2011-09-14 07:40:51 UTC (rev 48293)
@@ -10,7 +10,7 @@
CREATE TABLE vector_metadata (
stvds_register VARCHAR, -- The name of the table storing all space-time vector datasets in which this map is registered
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES vector_base (id) ON DELETE CASCADE
Modified: grass/trunk/temporal/tr.register/tr.register.py
--- grass/trunk/temporal/tr.register/tr.register.py 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/temporal/tr.register/tr.register.py 2011-09-14 07:40:51 UTC (rev 48293)
@@ -88,55 +88,63 @@
inc_unit = increment.split(" ")[1]
else:
inc_value = float(increment)
count = 0
for mapname in maplist:
mapid = mapname + "@" + mapset
map = grass.raster_dataset(mapid)
- map.load()
# In case the map is already registered print a message and continue to the next map
# Put the map into the database
if map.is_in_db() == False:
+ map.load()
- # Set the time interval
- if start:
- grass.info("Set time interval for map " + mapname)
- if sp.is_time_absolute():
- if start.find(":") > 0:
- time_format = "%Y-%m-%d %H:%M:%S"
- else:
- time_format = "%Y-%m-%d"
+ # Put map with time interval in the database
+ map.insert()
+ else:
+ map.select()
+ if map.get_temporal_type() != sp.get_temporal_type():
+ grass.fatal("Unable to register map. The map has a different temporal types.")
- start_time = datetime.datetime.fromtimestamp(time.mktime(time.strptime(start, time_format)))
- end_time = None
+ # Set the time interval
+ if start:
+ grass.info("Set/overwrite time interval for map " + mapname)
+ if sp.is_time_absolute():
- if increment:
- if inc_unit.find("seconds") >= 0:
- tdelta = timedelta(seconds=inc_value)
- elif inc_unit.find("minutes") >= 0:
- tdelta = timedelta(minutes=inc_value)
- elif inc_unit.find("hours") >= 0:
- tdelta = timedelta(hours=inc_value)
- elif inc_unit.find("days") >= 0:
- tdelta = timedelta(days=inc_value)
- elif inc_unit.find("weeks") >= 0:
- tdelta = timedelta(weeks=inc_value)
- else:
- grass.fatal("Wrong increment format: " + increment)
+ if start.find(":") > 0:
+ time_format = "%Y-%m-%d %H:%M:%S"
+ else:
+ time_format = "%Y-%m-%d"
- start_time += count * tdelta
- end_time = start_time + tdelta
+ start_time = datetime.datetime.fromtimestamp(time.mktime(time.strptime(start, time_format)))
+ end_time = None
- map.set_absolute_time(start_time, end_time)
- else:
- interval = float(start) + count * inc_value
- map.set_relative_time(interval)
- # Put map with time interval in the database
- map.insert()
+ if increment:
+ if inc_unit.find("seconds") >= 0:
+ tdelta = timedelta(seconds=inc_value)
+ elif inc_unit.find("minutes") >= 0:
+ tdelta = timedelta(minutes=inc_value)
+ elif inc_unit.find("hours") >= 0:
+ tdelta = timedelta(hours=inc_value)
+ elif inc_unit.find("days") >= 0:
+ tdelta = timedelta(days=inc_value)
+ elif inc_unit.find("weeks") >= 0:
+ tdelta = timedelta(weeks=inc_value)
+ else:
+ grass.fatal("Wrong increment format: " + increment)
+ start_time += count * tdelta
+ end_time = start_time + tdelta
+ map.set_absolute_time(start_time, end_time)
+ map.absolute_time.update()
+ else:
+ interval = float(start) + count * inc_value
+ map.set_relative_time(interval)
+ map.arelative_time.update()
# Register map
sp.register_map(map)
Modified: grass/trunk/temporal/tr.unregister/tr.unregister.py
--- grass/trunk/temporal/tr.unregister/tr.unregister.py 2011-09-14 05:04:43 UTC (rev 48292)
+++ grass/trunk/temporal/tr.unregister/tr.unregister.py 2011-09-14 07:40:51 UTC (rev 48293)
@@ -36,11 +36,6 @@
#% multiple: yes
#%end
-import sys
-import os
-import getpass
-import subprocess
