[GRASS-SVN] r48294 - sandbox/martinl/v.topo.to.postgis
svn_grass at osgeo.org
Wed Sep 14 07:43:20 EDT 2011
Author: martinl
Date: 2011-09-14 04:43:20 -0700 (Wed, 14 Sep 2011)
New Revision: 48294
sandbox/martinl/v.topo.to.postgis/main.c
sandbox/martinl/v.topo.to.postgis/topo.c
v.topo.to.postgis: add -p flag to print sql statements
Modified: sandbox/martinl/v.topo.to.postgis/main.c
--- sandbox/martinl/v.topo.to.postgis/main.c 2011-09-14 07:40:51 UTC (rev 48293)
+++ sandbox/martinl/v.topo.to.postgis/main.c 2011-09-14 11:43:20 UTC (rev 48294)
@@ -29,9 +29,11 @@
struct GModule *module;
struct {
- struct Option *map, *db;
+ struct Option *map, *db;
} opt;
+ struct {
+ struct Flag *p;
+ } flag;
char *conninfo;
const char *name, *dbname;
struct Map_info Map;
@@ -56,6 +58,11 @@
opt.db->type = TYPE_STRING;
opt.db->key_desc = "name";
+ flag.p = G_define_flag();
+ flag.p->key = 'p';
+ flag.p->description = _("Print SQL statemets and exit");
+ flag.p->suppress_required = YES;
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -67,11 +74,14 @@
Vect_open_old(&Map, name, "");
/* connect database */
- G_asprintf(&conninfo, "dbname=%s", dbname);
- conn = PQconnectdb(conninfo);
- if (PQstatus(conn) != CONNECTION_OK) {
- PQfinish(conn);
- G_fatal_error(_("Unable to open database <%s>"), dbname);
+ conn = NULL;
+ if (!flag.p->answer) {
+ G_asprintf(&conninfo, "dbname=%s", dbname);
+ conn = PQconnectdb(conninfo);
+ if (PQstatus(conn) != CONNECTION_OK) {
+ PQfinish(conn);
+ G_fatal_error(_("Unable to open database <%s>"), dbname);
/* convert GRASS topo to PostGIS */
Modified: sandbox/martinl/v.topo.to.postgis/topo.c
--- sandbox/martinl/v.topo.to.postgis/topo.c 2011-09-14 07:40:51 UTC (rev 48293)
+++ sandbox/martinl/v.topo.to.postgis/topo.c 2011-09-14 11:43:20 UTC (rev 48294)
@@ -59,7 +59,8 @@
PQclear(res);
/* Start a transaction block */
- res = PQexec(conn, "BEGIN");
+ db_set_string(&stmt, "BEGIN");
+ execute(&stmt, conn, &res, "BEGIN", PGRES_COMMAND_OK);
PQclear(res);
/* create topology tables */
@@ -72,7 +73,7 @@
nnodes = Vect_get_num_nodes(Map);
for (node = 1; node <= nnodes; node++) {
Vect_get_node_coor(Map, node, &x, &y, &z);
- G_debug(0, "node %d: x = %f y = %f z = %f", node, x, y, z);
+ G_debug(3, "node %d: x = %f y = %f z = %f", node, x, y, z);
G_asprintf(&sql, "SELECT topology.ST_AddIsoNode('%s', 0, "
"'POINT(%f %f)')", name, x, y);
db_set_string(&stmt, sql);
@@ -87,7 +88,7 @@
G_fatal_error(_("Unable to read line %d"), line);
if (ltype == -2)
break; /* should not happen */
- G_debug(0, "line %d: type = %d npoints = %d", line, ltype,
+ G_debug(3, "line %d: type = %d npoints = %d", line, ltype,
Points->n_points);
switch(ltype) {
@@ -104,6 +105,7 @@
/* -> edge */
add_adge_face(Map, line, Points, name, &stmt);
execute(&stmt, conn, &res, "SELECT", PGRES_TUPLES_OK);
+ break;
default:
G_warning(_("Unsupported type %d"), ltype);
break;
@@ -111,9 +113,13 @@
/* end the transaction */
- res = PQexec(conn, "END");
+ db_set_string(&stmt, "END");
+ execute(&stmt, conn, &res, "END", PGRES_COMMAND_OK);
PQclear(res);
+ if (!conn)
+ fflush(stdout);
Vect_destroy_list(list);
Vect_destroy_line_struct(Points);
@@ -123,8 +129,13 @@
void execute(const dbString *stmt, PGconn *conn, PGresult **res,
const char *cmd, ExecStatusType status)
- G_debug(0, "SQL: %s", db_get_string(stmt));
+ G_debug(1, "SQL: %s", db_get_string(stmt));
+ if (!conn) {
+ fprintf(stdout, "%s;\n", db_get_string(stmt));
+ return;
*res = PQexec(conn, db_get_string(stmt));
if (PQresultStatus(*res) != status) {
PQclear(*res);
