[GRASS-SVN] r48308 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Thu Sep 15 17:45:29 EDT 2011
Author: martinl
Date: 2011-09-15 14:45:29 -0700 (Thu, 15 Sep 2011)
New Revision: 48308
grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: attempt to fix #1448 (run model menu item does not seem to work)
(merge r48307 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-09-15 21:42:53 UTC (rev 48307)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py 2011-09-15 21:45:29 UTC (rev 48308)
@@ -317,15 +317,18 @@
for rel in data['rels']:
actionItem = self.FindAction(rel['id'])
if rel['dir'] == 'from':
- relation = ModelRelation(dataItem, actionItem, rel['name'])
+ relation = ModelRelation(parent = self, fromShape = dataItem,
+ toShape = actionItem, param = rel['name'])
else:
- relation = ModelRelation(actionItem, dataItem, rel['name'])
+ relation = ModelRelation(parent = self, fromShape = actionItem,
+ toShape = dataItem, param = rel['name'])
relation.SetControlPoints(rel['points'])
actionItem.AddRelation(relation)
dataItem.AddRelation(relation)
- dataItem.Update()
+ if self.canvas:
+ dataItem.Update()
# load loops
for loop in gxmXml.loops:
loopItem = ModelLoop(parent = self,
@@ -407,7 +410,7 @@
def Run(self, log, onDone):
"""!Run model"""
- for action in self.actions:
+ for action in self.GetItems(objType = ModelAction):
if not action.IsEnabled():
continue
log.RunCmd(command = action.GetLog(string = False),
@@ -1309,9 +1312,11 @@
p.get('prompt', ''))
if data:
if p.get('age', 'old') == 'old':
- rel = ModelRelation(data, layer, p.get('name', ''))
+ rel = ModelRelation(parent = self, fromShape = data,
+ toShape = layer, param = p.get('name', ''))
else:
- rel = ModelRelation(layer, data, p.get('name', ''))
+ rel = ModelRelation(parent = self, fromShape = layer,
+ toShape = data, param = p.get('name', ''))
layer.AddRelation(rel)
data.AddRelation(rel)
self.AddLine(rel)
@@ -1326,9 +1331,11 @@
data.Show(True)
else:
self.AddLine(rel)
@@ -1491,7 +1498,7 @@
loop.Clear()
for item in items:
- rel = ModelRelation(parent, item)
+ rel = ModelRelation(parent = self, fromShape = parent, toShape = item)
dx = item.GetX() - parent.GetX()
dy = item.GetY() - parent.GetY()
loop.AddRelation(rel)
@@ -1503,7 +1510,7 @@
# close loop
item = loop.GetItems()[-1]
- rel = ModelRelation(item, loop)
+ rel = ModelRelation(parent = self, fromShape = item, toShape = loop)
self.AddLine(rel)
dx = (item.GetX() - loop.GetX()) + loop.GetWidth() / 2 + 50
@@ -1538,7 +1545,8 @@
dy = condition.GetY()
for branch in items.keys():
for item in items[branch]:
+ toShape = item)
condition.AddRelation(rel)
self.AddLine(rel)
rel.MakeLineControlPoints(0)
@@ -1855,8 +1863,9 @@
def SetParameterized(self, isparameterized):
"""!Set action parameterized"""
self.isParameterized = isparameterized
- self._setPen()
+ if self.parent.GetCanvas():
+ self._setPen()
def IsParameterized(self):
"""!Check if action is parameterized"""
return self.isParameterized
@@ -2148,7 +2157,8 @@
drel['from'] = shape
elif drel['to'] is None:
drel['to'] = shape
- rel = ModelRelation(drel['from'], drel['to'])
+ rel = ModelRelation(parent = self.frame, fromShape = drel['from'],
+ toShape = drel['to'])
dlg = ModelRelationDialog(parent = self.frame,
shape = rel)
if dlg.IsValid():
@@ -2514,14 +2524,16 @@
class ModelRelation(ogl.LineShape):
"""!Data - action relation"""
- def __init__(self, fromShape, toShape, param = ''):
+ def __init__(self, parent, fromShape, toShape, param = ''):
self.fromShape = fromShape
self.toShape = toShape
self.param = param
+ self.parent = parent
self._points = None
- ogl.LineShape.__init__(self)
+ ogl.LineShape.__init__(self)
def __del__(self):
self.fromShape.rels.remove(self)
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-09-15 21:42:53 UTC (rev 48307)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2011-09-15 21:45:29 UTC (rev 48308)
@@ -353,7 +353,7 @@
win.Show()
- def OnDone(self, returncode):
+ def OnDone(self, cmd, returncode):
"""Command execution finised"""
if hasattr(self, "model"):
self.model.DeleteIntermediateData(log = self.goutput)
