[GRASS-SVN] r48309 - in grass/trunk: lib/python lib/temporal temporal/t.remove temporal/tr.register temporal/tr.unregister
Thu Sep 15 19:39:20 EDT 2011
Author: huhabla
Date: 2011-09-15 16:39:19 -0700 (Thu, 15 Sep 2011)
New Revision: 48309
Added:
   grass/trunk/temporal/tr.register/test.tr.register.sh
   grass/trunk/lib/python/tgis_abstract_datasets.py
   grass/trunk/lib/python/tgis_core.py
   grass/trunk/lib/temporal/test.temporal.py
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/tr.register/tr.register.py
   grass/trunk/temporal/tr.unregister/tr.unregister.py
Tests for temporal database handling implemented. All implemented temporal gis modules are now full functional.
Modified: grass/trunk/lib/python/tgis_abstract_datasets.py
--- grass/trunk/lib/python/tgis_abstract_datasets.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/lib/python/tgis_abstract_datasets.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -52,8 +52,11 @@
     def get_relative_time(self):
         """Returns the relative time interval or None if not present"""
         return self.relative_time.get_interval()
+    def get_temporal_type(self):
+        """Return the temporal type of this dataset"""
+        return self.base.get_ttype()
     def get_spatial_extent(self):
         """Return a tuple of spatial extent (north, south, east, west, top, bottom) """
@@ -194,6 +197,17 @@
         self.absolute_time.set_start_time(start_time)
         self.absolute_time.set_end_time(end_time)
         self.absolute_time.set_timezone(timezone)
+    def update_absolute_time(self, start_time, end_time=None, timezone=None):
+        """Update the absolute time
+           @start_time a datetime object specifying the start time of the map
+           @end_time a datetime object specifying the end time of the map
+           @timezone Thee timezone of the map
+        self.set_absolute_time(start_time, end_time, timezone)
+        self.absolute_time.update()
+        self.base.update()
     def set_relative_time(self, interval):
         """Set the relative time interval
@@ -203,8 +217,18 @@
         self.base.set_ttype("relative")
-        self.absolute_time.set_interval(interval)
+        self.relative_time.set_interval(interval)
+    def update_relative_time(self, interval):
+        """Set the relative time interval
+           @interval A double value in days
+        self.set_relative_time(interval)
+        self.relative_time.update()
     def set_spatial_extent(self, north, south, east, west, top=0, bottom=0):
         """Set the spatial extent of the map"""
         self.spatial_extent.set_spatial_extent(north, south, east, west, top, bottom)
@@ -217,37 +241,49 @@
             * Remove the space time dataset register table
         if self.is_in_db():
-            # Get all data
-            self.select()
-            # Remove the map from all registered space time datasets
-            if self.get_stds_register() != None:
-                # Select all stds tables in which this map is registered
-                sql = "SELECT id FROM " + self.get_stds_register()
-                #print sql
-                self.base.connect()
-                self.base.cursor.execute(sql)
-                rows = self.base.cursor.fetchall()
-                self.base.close()
-                # For each stds in which the map is registered
-                if rows:
-                    for row in rows:
-                        # Create a space time dataset object to remove the map
-                        # from its register
-                        strds = self.get_new_stds_instance(row["id"])
-                        strds.select()
-                        strds.unregister_map(self)
-                # Remove the strds register table
-                sql = "DROP TABLE " + self.get_stds_register()
-                #print sql
-                self.base.close()
+            # First we unregister from all dependent space time datasets
+            self.unregister()
+            # Remove the strds register table
+            sql = "DROP TABLE " + self.get_stds_register()
+            #print sql
+            self.base.connect()
+            self.base.cursor.execute(sql)
+            self.base.close()
+            core.verbose("Delete " + self.get_type() + " dataset <" + self.get_id() + "> from temporal database")
             # Delete yourself from the database, trigger functions will take care of dependencies
             self.base.delete()
+    def unregister(self):
+	""" Remove the map entry in each space time dataset in which this map is registered
+        core.verbose("Unregister " + self.get_type() + " dataset <" + self.get_id() + "> from space time datasets")
+        # Select all data from the database
+        self.select()
+        # Remove the map from all registered space time datasets
+        if self.get_stds_register() != None:
+            # Select all stds tables in which this map is registered
+            sql = "SELECT id FROM " + self.get_stds_register()
+            #print sql
+            rows = self.base.cursor.fetchall()
+            self.base.close()
+            # For each stds in which the map is registered
+            if rows:
+                for row in rows:
+                    # Create a space time dataset object to remove the map
+                    # from its register
+                    strds = self.get_new_stds_instance(row["id"])
+                    strds.select()
+                    strds.unregister_map(self)
 class abstract_space_time_dataset(abstract_dataset):
@@ -306,7 +342,7 @@
         # First we need to check if maps are registered in this dataset and
         # unregister them
-        core.info("Delete space time " + self.get_new_map_instance(ident=None).get_type() + " dataset: " + self.get_id())
+        core.verbose("Delete space time " + self.get_new_map_instance(ident=None).get_type() + " dataset <" + self.get_id() + "> from temporal database")
         if self.get_map_register():
             sql = "SELECT id FROM " + self.get_map_register()
@@ -342,7 +378,7 @@
         if map.is_in_db() == False:
             core.fatal("Only maps with absolute or relative valid time can be registered")
-        core.info("Register " + map.get_type() + " map: " + map.get_id())
+        core.verbose("Register " + map.get_type() + " map: " + map.get_id() + " in space time " + map.get_type() + " dataset <" + self.get_id() + ">")
         # First select all data from the database
         map.select()
@@ -372,8 +408,8 @@
             self.base.close()
             # In case of no entry make a new one
             if row and row[0] == map_id:
-                core.warning("Map " + map_id + "is already registered")
-                return False
+                core.warning("Map " + map_id + "is already registered. Will unregister map and register again.")
+                self.unregister_map(map)
         # Create tables
         sql_path = get_sql_template_path()
@@ -400,9 +436,9 @@
             # Set the stds register table name and put it into the DB
             map.set_stds_register(map_register_table)
             map.metadata.update()
+            core.verbose("Created register table <" +  map_register_table + "> for " + map.get_type() + " map <" + map.get_id() + ">")
-            #print "Created map register table ",  map_register_table
         # We need to create the table and register it
         if stds_register_table == None:
             # Read the SQL template
@@ -435,7 +471,7 @@
             self.set_map_register(stds_register_table)
             self.metadata.update()
-            #print "Created stds register table ",  stds_register_table
+            core.verbose("Created register table <" +  stds_register_table + "> for space time " + map.get_type() + " dataset <" + self.get_id() + ">")
         # Register the stds in the map stds register table
         # Check if the entry is already there
@@ -470,9 +506,9 @@
-            core.fatal("Only maps with absolute or relative valid time can be registered")
+            core.fatal("Unable to find map <" + map.get_id() + "> in temporal database")
-        core.info("Unegister " + map.get_type() + " map: " + map.get_id())
+        core.verbose("Unregister " + map.get_type() + " map: " + map.get_id() + " from space time " + map.get_type() + " dataset <" + self.get_id() + ">")
         map.select()
@@ -491,7 +527,8 @@
         # Break if the map is not registered
         if row == None:
-            core.fatal("Map " + map_id + " is not registered in space time dataset " + self.base.get_id())
+            core.warning("Map " + map_id + " is not registered in space time dataset " + self.base.get_id())
+            return False
         # Remove the space time raster dataset from the raster dataset register
         if map_register_table != None:
@@ -505,4 +542,6 @@
             sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
             self.base.connect()
             self.base.cursor.execute(sql, (map_id,))
-            self.base.close()
\ No newline at end of file
+            self.base.close()
+        return True
Modified: grass/trunk/lib/python/tgis_core.py
--- grass/trunk/lib/python/tgis_core.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/lib/python/tgis_core.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -26,20 +26,131 @@
 import os
 import sqlite3
 import core
-from datetime import datetime, date, time
+import copy
+from datetime import datetime, date, time, timedelta
 def get_grass_location_db_path():
     grassenv = core.gisenv()
     dbpath = os.path.join(grassenv["GISDBASE"], grassenv["LOCATION_NAME"])
     return os.path.join(dbpath, "grass.db")
 def get_sql_template_path():
     base = os.getenv("GISBASE")
     base_etc  = os.path.join(base, "etc")
     return os.path.join(base_etc, "sql")
+def test_increment_datetime_by_string():
+    dt = datetime(2001, 9, 1, 0, 0, 0)
+    string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
+    dt1 = datetime(2003,2,18,12,5,0)
+    dt2 = increment_datetime_by_string(dt, string)
+    delta = dt1 -dt2
+    if delta.days != 0 or delta.seconds != 0:
+        core.fatal("increment computation is wrong")
+def increment_datetime_by_string(mydate, increment, mult = 1):
+    """Return a new datetime object incremented with the provided relative dates specified as string.
+       Additional a multiplier can be specified to multiply the increment bevor adding to the provided datetime object.
+       @mydate A datetime object to incremented
+       @increment A string providing increment information:
+                  The string may include comma separated values of type seconds, minutes, hours, days, weeks, months and years
+                  Example: Increment the datetime 2001-01-01 00:00:00 with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
+                  will result in the datetime 2003-02-18 12:05:00
+        @mult A multiplier, default is 1
+    if increment:
+        seconds = 0
+        minutes = 0
+        hours = 0
+        days = 0
+        weeks = 0
+        months = 0
+        years = 0
+        inclist = []
+        # Split the increment string
+        incparts = increment.split(",")
+        for incpart in incparts:
+            inclist.append(incpart.strip().split(" "))
+        for inc in inclist:
+            if inc[1].find("seconds") >= 0:
+                seconds = mult * int(inc[0])
+            elif inc[1].find("minutes") >= 0:
+                minutes = mult * int(inc[0])
+            elif inc[1].find("hours") >= 0:
+                hours = mult * int(inc[0])
+            elif inc[1].find("days") >= 0:
+                days = mult * int(inc[0])
+            elif inc[1].find("weeks") >= 0:
+                weeks = mult * int(inc[0])
+            elif inc[1].find("months") >= 0:
+                months = mult * int(inc[0])
+            elif inc[1].find("years") >= 0:
+                years = mult * int(inc[0])
+            else:
+                core.fatal("Wrong increment format: " + increment)
+        return increment_datetime(mydate, years, months, weeks, days, hours, minutes, seconds)
+    return mydate
+def increment_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0, minutes=0, seconds=0):
+    """Return a new datetime object incremented with the provided relative dates"""
+    tdelta_seconds = timedelta(seconds=seconds)
+    tdelta_minutes = timedelta(minutes=minutes)
+    tdelta_hours = timedelta(hours=hours)
+    tdelta_days = timedelta(days=days)
+    tdelta_weeks = timedelta(weeks=weeks)
+    tdelta_months = timedelta(0)
+    tdelta_years = timedelta(0)
+    if months > 0:
+        # Compute the actual number of days in the month to add as timedelta
+        year = mydate.year
+        month = mydate.month
+        all_months = int(months + month)
+        years_to_add = int(all_months/12)
+        residual_months = all_months%12
+        # Make a deep copy of the datetime object
+        dt1 = copy.copy(mydate)
+        # Make sure the montha starts with a 1
+        if residual_months == 0:
+            residual_months = 1
+        dt1 = dt1.replace(year = year + years_to_add, month = residual_months)
+        tdelta_months = dt1 - mydate
+    if years > 0:
+        # Compute the number of days
+        dt1 = dt1.replace(year=mydate.year + int(years))
+        tdelta_years = dt1 - mydate
+    return mydate + tdelta_seconds + tdelta_minutes + tdelta_hours + \
+                    tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
 def create_temporal_database():
     """This function creates the grass location database structure for raster, vector and raster3d maps
     as well as for the space-time datasets strds, str3ds and stvds"""
Modified: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/lib/temporal/test.temporal.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -815,13 +815,13 @@
 test_dict_sql_serializer()
-test_dataset_identifer()
-test_absolute_timestamp()
-test_relative_timestamp()
-test_spatial_extent()
-test_map_metadata()
-test_base_absolute_time_extent_metadata()
-test_absolut_time_temporal_relations()
+#test_dataset_identifer()
+#test_absolute_timestamp()
+#test_relative_timestamp()
+#test_spatial_extent()
+#test_map_metadata()
+#test_base_absolute_time_extent_metadata()
+#test_absolut_time_temporal_relations()
 test_raster_dataset()
 test_raster3d_dataset()
@@ -829,4 +829,5 @@
 test_strds_dataset()
 test_str3ds_dataset()
-test_stvds_dataset()
+test_stvds_dataset()
+test_increment_datetime_by_string()
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/temporal/t.remove/t.remove.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -24,7 +24,7 @@
 #%option
 #% key: dataset
 #% type: string
-#% description: Name of the new space time or map dataset
+#% description: Name(s) of the space time or map dataset to be removed from the temporal database
 #% required: yes
 #% multiple: no
 #%end
@@ -45,34 +45,41 @@
 def main():
     # Get the options
-    name = options["dataset"]
+    names = options["dataset"]
     type = options["type"]
     # Make sure the temporal database exists
     grass.create_temporal_database()
     mapset =  grass.gisenv()["MAPSET"]
-    id = name + "@" + mapset
+    for name in names.split(","):
+        name = name.strip()
+        # Check for the mapset in name
+        if name.find("@") < 0:
+            id = name + "@" + mapset
+        else:
+            id = name
-    if type == "strds":
-        sp = grass.space_time_raster_dataset(id)
-    if type == "str3ds":
-        sp = grass.space_time_raster3d_dataset(id)
-    if type == "stvds":
-        sp = grass.space_time_vector_dataset(id)
-    if type == "raster":
-        sp = grass.raster_dataset(id)
-    if type == "raster3d":
-        sp = grass.raster3d_dataset(id)
-    if type == "vector":
-        sp = grass.vector_dataset(id)
+        if type == "strds":
+            sp = grass.space_time_raster_dataset(id)
+        if type == "str3ds":
+            sp = grass.space_time_raster3d_dataset(id)
+        if type == "stvds":
+            sp = grass.space_time_vector_dataset(id)
+        if type == "raster":
+            sp = grass.raster_dataset(id)
+        if type == "raster3d":
+            sp = grass.raster3d_dataset(id)
+        if type == "vector":
+            sp = grass.vector_dataset(id)
-    if sp.is_in_db() == False:
-        grass.fatal("Dataset <" + name + "> not found in temporal database")
+        if sp.is_in_db() == False:
+            grass.fatal("Dataset <" + name + "> not found in temporal database")
-    # Insert content from db
-    sp.select()
-    sp.delete()
+        # We need to read some data from the temporal database
+        sp.select()
+        sp.delete()
 if __name__ == "__main__":
     options, flags = grass.core.parser()
Added: grass/trunk/temporal/tr.register/test.tr.register.sh
--- grass/trunk/temporal/tr.register/test.tr.register.sh	                        (rev 0)
+++ grass/trunk/temporal/tr.register/test.tr.register.sh	2011-09-15 23:39:19 UTC (rev 48309)
@@ -0,0 +1,59 @@
+# This is a test to register and unregister raster maps in
+# space time raster dataset.
+# The raster maps will be registered in different space time raster
+# datasets
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster datasets
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+# The first @test
+# We create the space time raster datasets and register the raster maps with absolute time interval
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs1 gran="1 senconds" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs2 gran="1 minutes" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs3 gran="1 hours" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs4 gran="1 days" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs5 gran="1 weeks" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs6 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs7 gran="1 years" title="A test" descr="A test"
+tr.register --v dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
+t.info type=strds dataset=precip_abs1
+tr.unregister --v dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+tr.register --v dataset=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=strds dataset=precip_abs2
+tr.register --v dataset=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
+t.info type=strds dataset=precip_abs3
+tr.unregister --v maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+tr.register dataset=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
+t.info type=strds dataset=precip_abs4
+tr.register dataset=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
+t.info type=strds dataset=precip_abs5
+tr.register dataset=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
+t.info type=strds dataset=precip_abs6
+tr.register dataset=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=strds dataset=precip_abs7
+t.remove --v type=raster dataset=prec_1,prec_2,prec_3
+t.remove --v type=strds dataset=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7
+t.remove --v type=raster dataset=prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/tr.register/tr.register.py
--- grass/trunk/temporal/tr.register/tr.register.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/temporal/tr.register/tr.register.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -39,7 +39,7 @@
 #%option
 #% key: start
 #% type: string
-#% description: The start date and time of the first raster map, in case the map has no date (format absolute: "yyyy-mm-dd HH:MM:SS", relative 5.0)
+#% description: The start date and time of the first raster map, in case the map has no date (format absolute: "yyyy-mm-dd HH:MM:SS", format relative 5.0)
 #% required: no
 #% multiple: no
 #%end
@@ -47,15 +47,14 @@
 #%option
 #% key: increment
 #% type: string
-#% description: Time increment between maps for time stamp creation (NNN seconds, minutes, hours, days, weeks)
+#% description: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative: 1.0)
 #% required: no
 #% multiple: no
 #%end
 import datetime
-from datetime import timedelta
-import time
 import grass.script as grass
+from copy import *
@@ -67,6 +66,9 @@
     start = options["start"]
     increment = options["increment"]
+    # Make sure the temporal database exists
+    grass.create_temporal_database()
@@ -81,13 +83,6 @@
         maplist = (maps,)
     else:
         maplist = tuple(maps.split(","))
-    if increment:
-        if sp.is_time_absolute():
-            inc_value = float(increment.split(" ")[0])
-            inc_unit = increment.split(" ")[1]
-        else:
-            inc_value = float(increment)
     count = 0
     for mapname in maplist:
@@ -99,52 +94,39 @@
         # Put the map into the database
             map.load()
-            # Put map with time interval in the database
             map.insert()
         else:
             map.select()
-        if map.get_temporal_type() != sp.get_temporal_type():
-            grass.fatal("Unable to register map. The map has a different temporal types.")
+            if map.get_temporal_type() != sp.get_temporal_type():
+                grass.fatal("Unable to register map <" + map.get_id() + ">. The temporal types are different.")
         # Set the time interval
         if start:
-            grass.info("Set/overwrite time interval for map " + mapname)
+                # Create the start time object
                 if start.find(":") > 0:
                     time_format = "%Y-%m-%d %H:%M:%S"
                 else:
                     time_format = "%Y-%m-%d"
-                start_time = datetime.datetime.fromtimestamp(time.mktime(time.strptime(start, time_format)))
+                start_time = datetime.datetime.strptime(start, time_format)
                 end_time = None
+                # Add the increment
                 if increment:
-                    if inc_unit.find("seconds") >= 0:
-                        tdelta = timedelta(seconds=inc_value)
-                    elif inc_unit.find("minutes") >= 0:
-                        tdelta = timedelta(minutes=inc_value)
-                    elif inc_unit.find("hours") >= 0:
-                        tdelta = timedelta(hours=inc_value)
-                    elif inc_unit.find("days") >= 0:
-                        tdelta = timedelta(days=inc_value)
-                    elif inc_unit.find("weeks") >= 0:
-                        tdelta = timedelta(weeks=inc_value)
-                    else:
-                        grass.fatal("Wrong increment format: " + increment)
+                    start_time = grass.increment_datetime_by_string(start_time, increment, count)
+                    end_time = grass.increment_datetime_by_string(start_time, increment, 1)
-                    start_time += count * tdelta
-                    end_time = start_time + tdelta
-                map.set_absolute_time(start_time, end_time)
-                map.absolute_time.update()
+                grass.verbose("Set absolute time interval for map <" + mapid + "> to " + str(start_time) + " - " + str(end_time))
+                map.update_absolute_time(start_time, end_time)
             else:
-                interval = float(start) + count * inc_value
-                map.set_relative_time(interval)
-                map.arelative_time.update()
+                if increment:
+                    interval = float(start) + count * float(increment)
+                else:
+                grass.verbose("Set relative time interval for map <" + mapid + "> to " + str(interval))
+                map.update_relative_time(interval)
         # Register map
         sp.register_map(map)
Modified: grass/trunk/temporal/tr.unregister/tr.unregister.py
--- grass/trunk/temporal/tr.unregister/tr.unregister.py	2011-09-15 21:45:29 UTC (rev 48308)
+++ grass/trunk/temporal/tr.unregister/tr.unregister.py	2011-09-15 23:39:19 UTC (rev 48309)
@@ -5,7 +5,7 @@
 # MODULE:	tr.unregister
 # AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Unregister raster map a space time raster dataset
+# PURPOSE:	Unregister raster maps from space time raster datasets
 # COPYRIGHT:	(C) 2011 by the GRASS Development Team
 #		This program is free software under the GNU General Public
@@ -15,16 +15,16 @@
 #%module
-#% description: Register raster maps in a space time raster dataset
+#% description: Unregister raster map(s) from a specific or all space time raster dataset in which it is registered
 #% keywords: spacetime raster dataset
 #% keywords: raster
 #%end
 #%option
-#% key: input
+#% key: dataset
 #% type: string
-#% description: Name of an existing space time raster dataset
-#% required: yes
+#% description: Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered.
+#% required: no
 #% multiple: no
 #%end
@@ -42,9 +42,44 @@
 def main():
     # Get the options
-    input = options["input"]
+    name = options["dataset"]
     maps = options["maps"]
+    mapset =  grass.gisenv()["MAPSET"]
+    # In case a space time raster dataset is specified
+    if name:
+        # Read content from db
+        sp.select()
+            grass.fatal("Space time " + sp.get_new_map_instance(None).get_type() + " dataset <" + name + "> not found")
+    # Build the list of maps
+    if maps.find(",") == -1:
+        maplist = (maps,)
+    else:
+        maplist = tuple(maps.split(","))
+    for mapname in maplist:
+        mapid = mapname + "@" + mapset
+        map = grass.raster_dataset(mapid)
+        # Unregister map if in database
+        if map.is_in_db() == True:
+            if name:
+                sp.unregister_map(map)
+            else:
+                map.select()
+                map.unregister()
     main()
