[GRASS-SVN] r48328 - grass/branches/develbranch_6/vector/v.clean
Sat Sep 17 05:31:57 EDT 2011
Author: mmetz
Date: 2011-09-17 02:31:56 -0700 (Sat, 17 Sep 2011)
New Revision: 48328
   grass/branches/develbranch_6/vector/v.clean/description.html
update manual
Modified: grass/branches/develbranch_6/vector/v.clean/description.html
--- grass/branches/develbranch_6/vector/v.clean/description.html	2011-09-17 09:31:21 UTC (rev 48327)
+++ grass/branches/develbranch_6/vector/v.clean/description.html	2011-09-17 09:31:56 UTC (rev 48328)
@@ -97,12 +97,12 @@
 than <em>thresh</em>. If there is no other vertex within <em>thresh</em>,
 no snapping will be done. The <em>type</em> option can have a strong
 influence on the result. A too large threshold and <em>type=boundary</em>
-can severely damage area topology.
+can severely damage area topology, beyond repair.
 <p>
-Snapped boundaries may need to be cleaned with <em>rmdangle,break,rmdupl</em>.
+Snapped boundaries may need to be cleaned with <em>break,rmdupl,rmsa</em>.
 <h3>Remove duplicate area centroids</h3>
-<em>tool=rmdupl</em>
+<em>tool=rmdac</em>
 <p>
 Threshold does not apply, use dummy value if <em>v.clean</em> is
 run with several tools.
@@ -174,7 +174,9 @@
 </td></tr>
 </table>
 <p>
-The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>.
+The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>. The
+<em>rmsa</em> tool followed by <em>break,rmdupl</em> may need to be run
+more than once to remove all small angles.
 <h2>NOTES</h2>
