[GRASS-SVN] r48329 - grass/branches/releasebranch_6_4/vector/v.clean
svn_grass at osgeo.org
Sat Sep 17 05:32:13 EDT 2011
Author: mmetz
Date: 2011-09-17 02:32:13 -0700 (Sat, 17 Sep 2011)
New Revision: 48329
grass/branches/releasebranch_6_4/vector/v.clean/description.html
update manual
Modified: grass/branches/releasebranch_6_4/vector/v.clean/description.html
--- grass/branches/releasebranch_6_4/vector/v.clean/description.html 2011-09-17 09:31:56 UTC (rev 48328)
+++ grass/branches/releasebranch_6_4/vector/v.clean/description.html 2011-09-17 09:32:13 UTC (rev 48329)
@@ -97,12 +97,12 @@
than <em>thresh</em>. If there is no other vertex within <em>thresh</em>,
no snapping will be done. The <em>type</em> option can have a strong
influence on the result. A too large threshold and <em>type=boundary</em>
-can severely damage area topology.
+can severely damage area topology, beyond repair.
<p>
-Snapped boundaries may need to be cleaned with <em>rmdangle,break,rmdupl</em>.
+Snapped boundaries may need to be cleaned with <em>break,rmdupl,rmsa</em>.
<h3>Remove duplicate area centroids</h3>
-<em>tool=rmdupl</em>
+<em>tool=rmdac</em>
<p>
Threshold does not apply, use dummy value if <em>v.clean</em> is
run with several tools.
@@ -174,7 +174,9 @@
</td></tr>
</table>
<p>
-The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>.
+The <em>rmsa</em> tool should be followed by <em>break,rmdupl</em>. The
+<em>rmsa</em> tool followed by <em>break,rmdupl</em> may need to be run
+more than once to remove all small angles.
<h2>NOTES</h2>
