[GRASS-SVN] r48332 - grass/trunk/db/drivers/sqlite
svn_grass at osgeo.org
Sat Sep 17 10:38:38 EDT 2011
Author: mmetz
Date: 2011-09-17 07:38:36 -0700 (Sat, 17 Sep 2011)
New Revision: 48332
grass/trunk/db/drivers/sqlite/create_table.c
grass/trunk/db/drivers/sqlite/describe.c
grass/trunk/db/drivers/sqlite/execute.c
grass/trunk/db/drivers/sqlite/fetch.c
grass/trunk/db/drivers/sqlite/index.c
grass/trunk/db/drivers/sqlite/main.c
grass/trunk/db/drivers/sqlite/select.c
SQLITE driver: fix for #548
Modified: grass/trunk/db/drivers/sqlite/create_table.c
--- grass/trunk/db/drivers/sqlite/create_table.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/create_table.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -112,26 +112,38 @@
G_debug(3, " SQL: %s", db_get_string(&sql));
- ret = sqlite3_prepare(sqlite, db_get_string(&sql), -1, &statement, &rest);
+ /* SQLITE bug?
+ * If the database schema has changed, sqlite can prepare a statement,
+ * but sqlite can not step, the statement needs to be prepared anew again */
+ while (1) {
+ ret = sqlite3_prepare(sqlite, db_get_string(&sql), -1, &statement, &rest);
- if (ret != SQLITE_OK) {
- append_error("Cannot create table:\n");
- append_error(db_get_string(&sql));
- append_error("\n");
- append_error((char *)sqlite3_errmsg(sqlite));
- report_error();
- sqlite3_finalize(statement);
- db_free_string(&sql);
- return DB_FAILED;
+ if (ret != SQLITE_OK) {
+ append_error("Cannot create table:\n");
+ append_error(db_get_string(&sql));
+ append_error("\n");
+ append_error((char *)sqlite3_errmsg(sqlite));
+ report_error();
+ sqlite3_finalize(statement);
+ db_free_string(&sql);
+ return DB_FAILED;
- ret = sqlite3_step(statement);
+ ret = sqlite3_step(statement);
- if (ret != SQLITE_DONE) {
- append_error("Error in sqlite3_step():\n");
- report_error();
- return DB_FAILED;
+ if (ret == SQLITE_SCHEMA) {
+ /* try again */
+ else if (ret != SQLITE_DONE) {
+ append_error("Error in sqlite3_step():\n");
+ report_error();
+ return DB_FAILED;
+ else
+ break;
Modified: grass/trunk/db/drivers/sqlite/describe.c
--- grass/trunk/db/drivers/sqlite/describe.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/describe.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -49,30 +49,43 @@
db_append_string(&sql, db_get_string(table_name));
db_append_string(&sql, " where oid < 0");
- while (ret == SQLITE_BUSY || ret == SQLITE_IOERR_BLOCKED) {
- ret = sqlite3_busy_handler(sqlite, sqlite_busy_callback, NULL);
+ /* SQLITE bug?
+ while (1) {
- append_error("Error in sqlite3_prepare():");
- report_error();
- return DB_FAILED;
+ append_error("Error in sqlite3_prepare():");
+ report_error();
+ return DB_FAILED;
+ if (describe_table(statement, table, NULL) == DB_FAILED) {
+ ret = sqlite3_errcode(sqlite);
+ /* try again */
+ else {
+ append_error("Cannot describe table:\n");
+ report_error();
+ return DB_FAILED;
+ else
+ break;
- if (describe_table(statement, table, NULL) == DB_FAILED) {
- append_error("Cannot describe table\n");
- report_error();
- return DB_FAILED;
return DB_OK;
@@ -94,15 +107,19 @@
int describe_table(sqlite3_stmt * statement, dbTable ** table, cursor * c)
- int i, ncols, nkcols;
+ int i, ncols, nkcols, ret;
G_debug(3, "describe_table()");
ncols = sqlite3_column_count(statement);
- G_debug(3, "ncols = %d", ncols);
/* Try to get first row */
- sqlite3_step(statement);
+ if (ret != SQLITE_DONE && ret != SQLITE_ROW) {
+ ret = sqlite3_reset(statement);
+ G_warning(_("SQLite driver: %s"), sqlite3_errmsg(sqlite));
+ return DB_FAILED;
/* Count columns of known type */
nkcols = 0;
Modified: grass/trunk/db/drivers/sqlite/execute.c
--- grass/trunk/db/drivers/sqlite/execute.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/execute.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -41,23 +41,34 @@
G_debug(3, "execute: %s", s);
- ret = sqlite3_prepare(sqlite, s, -1, &stmt, &rest);
+ /* SQLITE bug?
+ while (1) {
+ ret = sqlite3_prepare(sqlite, s, -1, &stmt, &rest);
- append_error("Error in sqlite3_prepare():\n");
- report_error();
- return DB_FAILED;
+ append_error("Error in sqlite3_prepare():\n");
+ report_error();
+ return DB_FAILED;
- ret = sqlite3_step(stmt);
- /* check if sqlite is still busy preparing the statement? */
+ ret = sqlite3_step(stmt);
- report_error();
- return DB_FAILED;
+ sqlite3_finalize(stmt);
+ /* try again */
+ report_error();
+ ret = sqlite3_finalize(stmt);
+ return DB_FAILED;
+ else
+ break;
@@ -69,11 +80,6 @@
return DB_FAILED;
- if ( rest )
- G_free ( rest );
return DB_OK;
Modified: grass/trunk/db/drivers/sqlite/fetch.c
--- grass/trunk/db/drivers/sqlite/fetch.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/fetch.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -249,7 +249,7 @@
cursor *c;
dbToken token;
- int row;
+ int row, ret;
/* get cursor token */
token = db_get_cursor_token(cn);
@@ -268,10 +268,18 @@
sqlite3_reset(c->statement);
c->nrows = 0;
- while (sqlite3_step(c->statement) == SQLITE_ROW) {
+ while ((ret = sqlite3_step(c->statement)) == SQLITE_ROW) {
c->nrows++;
+ if (ret != SQLITE_DONE) {
+ ret = sqlite3_reset(c->statement);
+ append_error("Cannot get number of rows\n");
+ report_error();
+ return DB_FAILED;
/* Reset cursor position */
Modified: grass/trunk/db/drivers/sqlite/index.c
--- grass/trunk/db/drivers/sqlite/index.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/index.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -65,26 +65,37 @@
+ /* SQLITE bug?
+ while (1) {
- append_error("Cannot create index:\n");
- report_error();
- return DB_FAILED;
+ append_error("Cannot create index:\n");
+ report_error();
+ return DB_FAILED;
- report_error();
- return DB_FAILED;
+ /* try again */
+ report_error();
+ return DB_FAILED;
+ else
+ break;
Modified: grass/trunk/db/drivers/sqlite/main.c
--- grass/trunk/db/drivers/sqlite/main.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/main.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -15,7 +15,9 @@
#include <stdlib.h>
#include <time.h>
+#include <grass/gis.h>
#include <grass/dbmi.h>
+#include <grass/glocale.h>
#include "globals.h"
#include "dbdriver.h"
@@ -31,21 +33,23 @@
static time_t start_time = 0;
time_t curr_time;
- int min;
- static int last_min = -1;
+ int sec;
+ static int last_sec = -1;
+ G_debug(4, "sqlite_busy_callback()");
/* do something here while waiting? */
- if (n_calls > 0 && last_min > -1) {
+ if (n_calls > 0 && last_sec > -1) {
time(&curr_time);
- min = (curr_time - start_time) / 60;
- if (min > 1 && min > last_min) {
- last_min = min;
- G_debug(3, "Already waiting for %d minutes...", min);
+ sec = (curr_time - start_time);
+ if (sec > 1 && sec > last_sec && sec % 10 == 0) {
+ last_sec = sec;
+ G_warning(_("Busy SQLITE db, already waiting for %d seconds..."), sec);
else {
time(&start_time);
- last_min = 0;
+ last_sec = 0;
return 1;
Modified: grass/trunk/db/drivers/sqlite/select.c
--- grass/trunk/db/drivers/sqlite/select.c 2011-09-17 12:12:23 UTC (rev 48331)
+++ grass/trunk/db/drivers/sqlite/select.c 2011-09-17 14:38:36 UTC (rev 48332)
@@ -53,26 +53,41 @@
str = G_str_replace(db_get_string(sel), "\\", "\\\\");
G_debug(3, "Escaped SQL: %s", str);
- ret = sqlite3_prepare(sqlite, str, -1, &(c->statement), &rest);
+ /* SQLITE bug?
+ while (1) {
+ ret = sqlite3_prepare(sqlite, str, -1, &(c->statement), &rest);
+ append_error(db_get_string(sel));
+ report_error();
+ return DB_FAILED;
+ if (describe_table(c->statement, &table, c) == DB_FAILED) {
+ sqlite3_finalize(c->statement);
+ /* try again */
+ else {
+ append_error("Cannot describe table\n");
+ report_error();
+ return DB_FAILED;
+ else
+ break;
if (str)
G_free(str);
- append_error(db_get_string(sel));
- report_error();
- return DB_FAILED;
- if (describe_table(c->statement, &table, c) == DB_FAILED) {
- report_error();
- return DB_FAILED;
c->nrows = -1;
c->row = -1;
