[GRASS-SVN] r48333 - grass/trunk/vector/v.reclass
svn_grass at osgeo.org
Sat Sep 17 10:39:21 EDT 2011
Author: mmetz
Date: 2011-09-17 07:39:21 -0700 (Sat, 17 Sep 2011)
New Revision: 48333
grass/trunk/vector/v.reclass/main.c
v.reclass: fix for #548
Modified: grass/trunk/vector/v.reclass/main.c
--- grass/trunk/vector/v.reclass/main.c 2011-09-17 14:38:36 UTC (rev 48332)
+++ grass/trunk/vector/v.reclass/main.c 2011-09-17 14:39:21 UTC (rev 48333)
@@ -148,7 +148,7 @@
G_debug(3, "nrec = %d", nrec);
else if (ctype == DB_C_TYPE_STRING) {
- int i, more, nrows, newval, len;
+ int i, more, nrows, ncols, newval, len;
dbString stmt, stmt2;
dbString lastval;
dbCursor cursor;
@@ -171,7 +171,44 @@
database,
&Out));
+ /* get string column length */
+ db_set_string(&stmt, Fi->table);
+ if (db_describe_table(Driver, &stmt, &table) != DB_OK) {
+ G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+ column = NULL;
+ ncols = db_get_table_number_of_columns(table);
+ G_debug(3, "ncol = %d", ncols);
+ len = 0;
+ for (i = 0; i < ncols; i++) {
+ column = db_get_table_column(table, i);
+ if (G_strcasecmp(db_get_column_name(column), col_opt->answer) == 0) {
+ /* String column length */
+ len = db_get_column_length(column);
+ break;
+ db_free_table(table);
+ /* Create table */
+ sprintf(buf, "create table %s (cat integer, %s varchar(%d))",
+ NewFi->table, col_opt->answer, len);
+ db_set_string(&stmt2, buf);
+ if (db_execute_immediate(Driver2, &stmt2) != DB_OK) {
+ Vect_close(&Out);
+ db_close_database_shutdown_driver(Driver);
+ db_close_database_shutdown_driver(Driver2);
+ G_fatal_error("Unable to create table: '%s'",
+ db_get_string(&stmt2));
+ db_begin_transaction(Driver2);
+ /* select values */
sprintf(buf, "SELECT %s, %s FROM %s ORDER BY %s", Fi->key,
col_opt->answer, Fi->table, col_opt->answer);
db_set_string(&stmt, buf);
@@ -186,7 +223,7 @@
nrows = db_get_num_rows(&cursor);
G_debug(3, " %d rows selected", nrows);
- if (nrows < 0)
+ if (nrows <= 0)
G_fatal_error(_("No records selected from table <%s>"),
Fi->table);
@@ -205,34 +242,6 @@
cvarr.ctype = DB_C_TYPE_INT;
- /* String column length */
- column = db_get_table_column(table, 1);
- len = db_get_column_length(column);
- /* Create table */
- sprintf(buf, "create table %s (cat integer, %s varchar(%d))",
- NewFi->table, col_opt->answer, len);
- db_set_string(&stmt2, buf);
- if (db_execute_immediate(Driver2, &stmt2) != DB_OK) {
- Vect_close(&Out);
- db_close_database_shutdown_driver(Driver);
- db_close_database_shutdown_driver(Driver2);
- G_fatal_error("Unable to create table: '%s'",
- db_get_string(&stmt2));
- if (db_create_index2(Driver2, NewFi->table, NewFi->key) != DB_OK)
- G_warning(_("Unable to create index for table <%s>, key <%s>"),
- NewFi->table, NewFi->key);
- if (db_grant_on_table(Driver2, NewFi->table, DB_PRIV_SELECT,
- DB_GROUP | DB_PUBLIC) != DB_OK) {
- G_fatal_error(_("Unable to grant privileges on table <%s>"),
- NewFi->table);
newval = 0;
/* fetch the data */
@@ -281,12 +290,23 @@
cvarr.n_values = nrows;
db_close_cursor(&cursor);
db_free_string(&stmt);
db_free_string(&lastval);
+ db_commit_transaction(Driver2);
+ if (db_create_index2(Driver2, NewFi->table, NewFi->key) != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ NewFi->table, NewFi->key);
+ if (db_grant_on_table(Driver2, NewFi->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ NewFi->table);
qsort((void *)cvarr.value, nrows, sizeof(dbCatVal), cmpcat);
else {
