[GRASS-SVN] r48439 - grass/trunk/vector/v.out.ascii
Fri Sep 23 16:46:58 EDT 2011
Author: martinl
Date: 2011-09-23 13:46:58 -0700 (Fri, 23 Sep 2011)
New Revision: 48439
   grass/trunk/vector/v.out.ascii/args.c
v.out.ascii: add descriotions for <format> option
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c	2011-09-23 20:36:54 UTC (rev 48438)
+++ grass/trunk/vector/v.out.ascii/args.c	2011-09-23 20:46:58 UTC (rev 48439)
@@ -46,7 +46,10 @@
     format_opt->options = "point,standard,wkt";
     format_opt->answer = "point";
     format_opt->description = _("Output format");
+    format_opt->descriptions = _("point;Simple point format (point per row);"
+				 "standard;GRASS ASCII vector format;"
+				 "wkt;OGC well-known text;");
     delim_opt = G_define_standard_option(G_OPT_F_SEP);
     delim_opt->description = _("Field separator (points mode)");
     delim_opt->guisection = _("Points");
