[GRASS-SVN] r48440 - in grass/trunk: lib/python/temporal temporal
temporal/tr.extract temporal/tr.series
svn_grass at osgeo.org
Fri Sep 23 18:34:58 EDT 2011
Author: huhabla
Date: 2011-09-23 15:34:58 -0700 (Fri, 23 Sep 2011)
New Revision: 48440
Added:
grass/trunk/temporal/tr.extract/
grass/trunk/temporal/tr.extract/Makefile
grass/trunk/temporal/tr.extract/test.tr.extract.sh
grass/trunk/temporal/tr.extract/tr.extract.html
grass/trunk/temporal/tr.extract/tr.extract.py
grass/trunk/temporal/tr.series/
grass/trunk/temporal/tr.series/Makefile
grass/trunk/temporal/tr.series/test.tr.series.sh
grass/trunk/temporal/tr.series/tr.series.html
grass/trunk/temporal/tr.series/tr.series.py
grass/trunk/lib/python/temporal/abstract_datasets.py
grass/trunk/temporal/Makefile
Implemented a simple r.series wrapper for space time raster datasets.
Modified: grass/trunk/lib/python/temporal/abstract_datasets.py
--- grass/trunk/lib/python/temporal/abstract_datasets.py 2011-09-23 20:46:58 UTC (rev 48439)
+++ grass/trunk/lib/python/temporal/abstract_datasets.py 2011-09-23 22:34:58 UTC (rev 48440)
@@ -464,6 +464,34 @@
self.metadata.set_title(title)
self.metadata.set_description(description)
+ def get_registered_maps(self, dbif=None, where = None):
+ """Return sqlite rows with ids of all registered maps. In case nothing found None is returned"""
+ connect = False
+ if dbif == None:
+ dbif = sql_database_interface()
+ dbif.connect()
+ connect = True
+ rows = None
+ if self.get_map_register():
+ sql = "SELECT id FROM " + self.get_map_register()
+ if where:
+ sql += " WHERE %s" % (where)
+ try:
+ dbif.cursor.execute(sql)
+ rows = dbif.cursor.fetchall()
+ except:
+ core.error("Unable to get map ids from register table <" + self.get_map_register() + ">")
+ raise
+ if connect == True:
+ dbif.close()
+ return rows
def delete(self, dbif=None):
"""Delete a space time dataset from the database"""
# First we need to check if maps are registered in this dataset and
@@ -479,22 +507,19 @@
connect = True
- sql = "SELECT id FROM " + self.get_map_register()
+ rows = self.get_registered_maps(dbif)
+ # Unregister each registered map in the table
+ if rows:
+ for row in rows:
+ # Unregister map
+ map = self.get_new_map_instance(row["id"])
+ self.unregister_map(map, dbif)
try:
- dbif.cursor.execute(sql)
- rows = dbif.cursor.fetchall()
- # Unregister each registered map in the table
- if rows:
- for row in rows:
- # Unregister map
- map = self.get_new_map_instance(row["id"])
- self.unregister_map(map, dbif)
# Drop remove the map register table
sql = "DROP TABLE " + self.get_map_register()
except:
- core.error("Unable to unregister maps from register table <" + self.get_map_register() + ">")
+ core.error("Unable to drop table <" + self.get_map_register() + ">")
raise
# Remove the primary key, the foreign keys will be removed by trigger
@@ -513,7 +538,6 @@
In case the map is already registered this function will break with a warning
and return False
connect = False
if dbif == None:
@@ -563,6 +587,8 @@
# Create a unique id
uuid_rand = "map_" + str(uuid.uuid4()).replace("-", "")
+ map_register_table = uuid_rand + "_" + self.get_type() + "_register"
# Read the SQL template
sql = open(os.path.join(sql_path, "map_stds_register_table_template.sql"), 'r').read()
# Create the raster, raster3d and vector tables
@@ -574,11 +600,20 @@
try:
dbif.cursor.executescript(sql)
except:
- core.error("Unable to create the space time " + map.get_type() +\
- " dataset register table for " + map.get_type() + " map <" + map.get_id())
- raise
+ try:
+ # Drop stds register table
+ sql = "DROP TABLE " + map_register_table
+ except:
+ core.error(_("Unable to drop table <%s>" % (map_register_table)))
+ raise
+ try:
+ dbif.cursor.executescript(sql_script)
+ except:
+ core.error("Unable to create the space time " + map.get_type() +\
+ " dataset register table for " + map.get_type() + " map <" + map.get_id())
+ raise
- map_register_table = uuid_rand + "_" + self.get_type() + "_register"
# Set the stds register table name and put it into the DB
map.set_stds_register(map_register_table)
map.metadata.update(dbif)
@@ -587,6 +622,8 @@
# We need to create the table and register it
if stds_register_table == None:
+ # Create table name
+ stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
sql = open(os.path.join(sql_path, "stds_map_register_table_template.sql"), 'r').read()
@@ -603,9 +640,19 @@
try:
except:
- core.error("Unable to create the " + map.get_type() +\
- " map register table for space time " + map.get_type() + " dataset <" + map.get_id())
- raise
+ try:
+ # Drop map register table
+ sql = "DROP TABLE " + stds_register_table
+ except:
+ core.error(_("Unable to drop table <%s>" % (stds_register_table)))
+ raise
+ try:
+ except:
+ core.error("Unable to create the " + map.get_type() +\
+ " map register table for space time " + map.get_type() + " dataset <" + map.get_id())
+ raise
# Trigger have been disabled due to peformance issues while registration
## We need raster specific trigger
@@ -623,8 +670,6 @@
#dbif.cursor.executescript(sql_script)
- stds_register_table = stds_name + "_" + stds_mapset + "_" + map.get_type() + "_register"
# Set the map register table name and put it into the DB
self.set_map_register(stds_register_table)
self.metadata.update(dbif)
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2011-09-23 20:46:58 UTC (rev 48439)
+++ grass/trunk/temporal/Makefile 2011-09-23 22:34:58 UTC (rev 48440)
@@ -8,6 +8,8 @@
t.time.abs \
t.time.rel \
tr.register \
+ tr.series \
+ tr.extract \
tr3.register \
tv.register \
tr.unregister \
Added: grass/trunk/temporal/tr.extract/Makefile
--- grass/trunk/temporal/tr.extract/Makefile (rev 0)
+++ grass/trunk/temporal/tr.extract/Makefile 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = tr.extract
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/tr.extract/test.tr.extract.sh
--- grass/trunk/temporal/tr.extract/test.tr.extract.sh (rev 0)
+++ grass/trunk/temporal/tr.extract/test.tr.extract.sh 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,61 @@
+# This is a test to register and unregister raster maps in
+# space time raster dataset.
+# The raster maps will be registered in different space time raster
+# datasets
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster datasets
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+# The first @test
+# We create the space time raster datasets and register the raster maps with absolute time interval
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs1 gran="1 senconds" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs2 gran="1 minutes" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs3 gran="1 hours" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs4 gran="1 days" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs5 gran="1 weeks" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs6 gran="1 months" title="A test" descr="A test"
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs7 gran="1 years" title="A test" descr="A test"
+tr.register --v dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
+t.info type=strds dataset=precip_abs1
+tr.unregister --v dataset=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+tr.register --v dataset=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.info type=strds dataset=precip_abs2
+tr.register --v dataset=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
+t.info type=strds dataset=precip_abs3
+tr.unregister --v maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+tr.register dataset=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
+t.info type=strds dataset=precip_abs4
+tr.register dataset=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
+t.info type=strds dataset=precip_abs5
+tr.register dataset=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
+t.info type=strds dataset=precip_abs6
+tr.register dataset=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.info type=strds dataset=precip_abs7
+# Register with different valid time again
+tr.register dataset=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.remove --v type=raster dataset=prec_1,prec_2,prec_3
+t.remove --v type=strds dataset=precip_abs1,precip_abs2,precip_abs3,precip_abs4,precip_abs5,precip_abs6,precip_abs7
+t.remove --v type=raster dataset=prec_4,prec_5,prec_6
Added: grass/trunk/temporal/tr.extract/tr.extract.html
Added: grass/trunk/temporal/tr.extract/tr.extract.py
--- grass/trunk/temporal/tr.extract/tr.extract.py (rev 0)
+++ grass/trunk/temporal/tr.extract/tr.extract.py 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,70 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: tr.extract
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Register raster maps in a space time raster dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Register raster maps in a space time raster dataset
+#% keywords: spacetime raster dataset
+#% keywords: raster
+#% keywords: extract
+#%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of an existing space time raster dataset
+#% required: yes
+#% multiple: yes
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The r.mapcalc expression assigned to all extracted raster maps
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name of the output space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ where = options["where"]
+ expression = options["expression"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/tr.extract/tr.extract.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/tr.series/Makefile
--- grass/trunk/temporal/tr.series/Makefile (rev 0)
+++ grass/trunk/temporal/tr.series/Makefile 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,7 @@
+PGM = tr.series
Added: grass/trunk/temporal/tr.series/test.tr.series.sh
--- grass/trunk/temporal/tr.series/test.tr.series.sh (rev 0)
+++ grass/trunk/temporal/tr.series/test.tr.series.sh 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,32 @@
+# datasets
+# The first @test
+t.create --v --o type=strds temporaltype=absolute dataset=precip_abs gran="1 months" title="A test" descr="A test"
+tr.register --v dataset=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+tr.series --o input=precip_abs method=average output=prec_average
+tr.series --o input=precip_abs method=maximum output=prec_max
+tr.series --o input=precip_abs method=quantile output=prec_quant quantile=0.9
+#t.remove --v type=raster dataset=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+#t.remove --v type=strds dataset=precip_abs
Added: grass/trunk/temporal/tr.series/tr.series.html
Added: grass/trunk/temporal/tr.series/tr.series.py
--- grass/trunk/temporal/tr.series/tr.series.py (rev 0)
+++ grass/trunk/temporal/tr.series/tr.series.py 2011-09-23 22:34:58 UTC (rev 48440)
@@ -0,0 +1,108 @@
+# MODULE: tr.series
+# PURPOSE: Performe different aggregation algorithms from r.series on all raster maps of a space time raster dataset
+# for details.
+#%module
+#% description: Performe different aggregation algorithms from r.series on all raster maps of a space time raster dataset
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Aggregate operation
+#% required: yes
+#% multiple: no
+#% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
+#% answer: average
+#%end
+#%option
+#% key: quantile
+#% type: string
+#% description: Quantile to calculate for method=quantile
+#% required: no
+#% multiple: no
+#% options: 0.0-1.0
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+def main():
+ # Get the options
+ quantile = options["quantile"]
+ method = options["method"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ mapset = grass.gisenv()["MAPSET"]
+ id = input + "@" + mapset
+ sp = tgis.space_time_raster_dataset(id)
+ if sp.is_in_db() == False:
+ grass.fatal("Dataset <%s> not found in temporal database" % (id))
+ sp.select()
+ rows = sp.get_registered_maps()
+ if rows:
+ inputs = ""
+ count = 0
+ for row in rows:
+ if count == 0:
+ inputs += row["id"]
+ else:
+ inputs += "," + row["id"]
+ count += 1
+ print inputs
+ if grass.overwrite() == True:
+ grass.run_command("r.series", input=inputs, output=output, overwrite=True, method=method, quantile=quantile)
+ else:
+ grass.run_command("r.series", input=inputs, output=output, overwrite=False, method=method, quantile=quantile)
+ main()
Property changes on: grass/trunk/temporal/tr.series/tr.series.py
