[GRASS-SVN] r51290 -
grass/branches/releasebranch_6_4/gui/wxpython/xml
svn_grass at osgeo.org
Fri Apr 6 10:53:11 EDT 2012
Author: martinl
Date: 2012-04-06 07:53:11 -0700 (Fri, 06 Apr 2012)
New Revision: 51290
grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
wxGUI menu: add r.pack & r.unpack
update labels by update_menudata.py
Modified: grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml
--- grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2012-04-06 14:51:26 UTC (rev 51289)
+++ grass/branches/releasebranch_6_4/gui/wxpython/xml/menudata.xml 2012-04-06 14:53:11 UTC (rev 51290)
@@ -170,12 +170,20 @@
<handler>OnMenuCmd</handler>
<command>r.in.aster</command>
</menuitem>
- <separator />
<menuitem>
<label>WMS import</label>
<help>Downloads and imports data from WMS servers</help>
- <handler>OnImportWMS</handler>
+ <keywords>wms</keywords><handler>OnImportWMS</handler>
+ <command>r.in.wms</command>
</menuitem>
+ <separator />
+ <menuitem>
+ <label>Unpack raster map</label>
+ <help>Unpacks a raster map packed with r.pack.</help>
+ <keywords>raster,copying</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>r.unpack</command>
+ </menuitem>
</items>
</menu>
<menu>
@@ -369,7 +377,7 @@
<menuitem>
<label>MPEG-1 export</label>
<help>Raster File Series to MPEG Conversion.</help>
- <keywords>raster,export,animation</keywords>
+ <keywords>raster,export</keywords>
<command>r.out.mpeg</command>
</menuitem>
@@ -422,6 +430,14 @@
<command>r.out.vtk</command>
</menuitem>
+ <separator />
+ <menuitem>
+ <label>Pack raster map</label>
+ <help>Packs up a raster map and support files for copying.</help>
+ <command>r.pack</command>
+ </menuitem>
</items>
</menu>
<menu>
@@ -429,7 +445,7 @@
<items>
<menuitem>
<label>Common export formats</label>
- <help>Converts to one of the supported OGR vector formats.</help>
+ <help>Converts GRASS vector map to one of the supported OGR vector formats.</help>
<keywords>vector,export</keywords>
<command>v.out.ogr</command>
@@ -593,7 +609,7 @@
<items>
<menuitem>
<label>Raster to vector</label>
- <help>Converts a raster map into a vector map.</help>
+ <help>Converts a raster map into a vector map layer.</help>
<keywords>raster,conversion,vectorization</keywords>
<command>r.to.vect</command>
@@ -1074,7 +1090,7 @@
<items>
<menuitem>
@@ -1274,7 +1290,7 @@
</menuitem>
<menuitem>
<label>Distance to features</label>
- <help>Generates a raster map of distance to features in input raster map.</help>
+ <help>Generates a raster map layer of distance to features in input layer.</help>
<keywords>raster,geometry</keywords>
<command>r.grow.distance</command>
@@ -1321,7 +1337,7 @@
<items>
<menuitem>
<label>Carve stream channels</label>
- <help>Generates stream channels.</help>
+ <help>Takes vector stream data, transforms it to raster and subtracts depth from the output DEM.</help>
<keywords>raster,hydrology</keywords>
<command>r.carve</command>
@@ -1350,14 +1366,14 @@
</menuitem>
<menuitem>
<label>Flow lines</label>
- <help>Constructs flow lines.</help>
+ <help>Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM).</help>
<command>r.flow</command>
</menuitem>
<menuitem>
<label>Watershed analysis</label>
- <help>Watershed basin analysis program</help>
+ <help>Watershed basin analysis program.</help>
<command>r.watershed</command>
@@ -1371,7 +1387,7 @@
</menuitem>
<menuitem>
<label>Watershed basin creation</label>
- <help>Creates watershed basins.</help>
+ <help>Watershed basin creation program.</help>
<command>r.water.outlet</command>
@@ -1380,7 +1396,7 @@
<menuitem>
<label>Groundwater modeling</label>
<help>Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.</help>
- <keywords>raster</keywords>
+ <keywords>raster,hydrology</keywords>
<command>r.gwflow</command>
</menuitem>
@@ -1604,8 +1620,8 @@
</menuitem>
<menuitem>
<label>Reclassify</label>
- <help>Reclassify raster map based on category values.</help>
- <keywords>raster,reclassification</keywords>
+ <help>Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer.</help>
+ <keywords>raster,statistics,reclass</keywords>
<command>r.reclass</command>
</menuitem>
@@ -1825,7 +1841,7 @@
</menuitem>
<menuitem>
<label>Sum area by raster map and category</label>
- <help>Reports statistics for raster maps.</help>
+ <help>Reports statistics for raster map layers.</help>
<keywords>raster,statistics</keywords>
<command>r.report</command>
@@ -1928,7 +1944,7 @@
<separator />
<menuitem>
<label>Parallel lines</label>
- <help>Create parallel line to input lines</help>
+ <help>Creates parallel line to input vector lines.</help>
<keywords>vector,geometry</keywords>
<command>v.parallel</command>
@@ -2596,7 +2612,7 @@
<separator />
<menuitem>
<label>Mosaic images</label>
- <help>Mosaics up to four images, extending the color table.</help>
+ <help>Mosaics up to 4 images and extends colormap; creates map *.mosaic</help>
<keywords>raster,imagery,mosaicking</keywords>
<command>i.image.mosaic</command>
@@ -2780,7 +2796,7 @@
<separator />
<menuitem>
<label>Modis quality control</label>
- <help>Extract quality control parameters from Modis QC layers</help>
+ <help>Extracts quality control parameters from Modis QC layers.</help>
<keywords>QC,Quality Control,surface reflectance,Modis</keywords>
<command>i.modis.qc</command>
@@ -2950,7 +2966,7 @@
<items>
<menuitem>
<label>List drivers</label>
- <help>List all database drivers.</help>
+ <help>Lists all database drivers.</help>
<keywords>database,attribute table</keywords>
<command>db.drivers</command>
