[GRASS-SVN] r51291 - in grass/branches/develbranch_6/scripts: r.pack r.unpack
Fri Apr 6 10:56:24 EDT 2012
Author: martinl
Date: 2012-04-06 07:56:24 -0700 (Fri, 06 Apr 2012)
New Revision: 51291
   grass/branches/develbranch_6/scripts/r.pack/r.pack
   grass/branches/develbranch_6/scripts/r.unpack/r.unpack
r.pack & r.unpack: define basic keywords
       (merge r51289 from relbr64)
Modified: grass/branches/develbranch_6/scripts/r.pack/r.pack
--- grass/branches/develbranch_6/scripts/r.pack/r.pack	2012-04-06 14:53:11 UTC (rev 51290)
+++ grass/branches/develbranch_6/scripts/r.pack/r.pack	2012-04-06 14:56:24 UTC (rev 51291)
@@ -2,17 +2,17 @@
 #  r.pack   --  pack up a raster map:
 #     collect raster map elements => gzip
-#   (c) 2004-2008 GRASS Development Team
+#   (c) 2004-2008, 2012 GRASS Development Team
 #   AUTHOR: Hamish Bowman, Otago University, New Zealand
-#   This program is free software under the GNU General Public
-#   License (>=v2). Read the file COPYING that comes with GRASS
-#   for details.
+#   This program is free software under the GNU General Public License
+#   (>=v2). Read the file COPYING that comes with GRASS for details.
-#%Module
-#%  description: Packs up a raster map and support files for copying.
-#%End
+#%module
+#% description: Packs up a raster map and support files for copying.
+#% keywords: raster, copying
+#%end
 #%option
 #% key: input
 #% type: string
@@ -27,7 +27,7 @@
 #% gisprompt: new_file,file,output
 #% description: Name for output file (default is input-map.pack)
 #% key_desc: name
-#% required : no
+#% required: no
 #%end
Modified: grass/branches/develbranch_6/scripts/r.unpack/r.unpack
--- grass/branches/develbranch_6/scripts/r.unpack/r.unpack	2012-04-06 14:53:11 UTC (rev 51290)
+++ grass/branches/develbranch_6/scripts/r.unpack/r.unpack	2012-04-06 14:56:24 UTC (rev 51291)
@@ -2,7 +2,7 @@
 #  r.unpack   --  unpack up a raster map packed with r.pack:
 #     tar+gzip'd map elements => GRASS 6 mapset structure
@@ -10,26 +10,28 @@
 #   for details.
-#%Module
-#%  description: Unpacks a raster map packed with r.pack.
-#%End
+#%module
+#% description: Unpacks a raster map packed with r.pack.
+#%end
 #%option
 #% key: input
 #% type: string
 #% gisprompt: old,file,input
 #% description: Name of input pack file
-#% required : yes
+#% required: yes
 #%end
 #%option
 #% key: output
 #% type: string
+#% key_desc: name
 #% gisprompt: new,cell,raster
 #% description: Name for output raster map (default: taken from input file internals)
 #% required : no
 #%end
 #%flag
-#%  key: o
-#%  description: Override projection check (use current location's projection)
+#% key: o
+#% description: Override projection check (use current location's projection)
 #%end
