[GRASS-SVN] r51374 - in grass-addons/grass6/raster: . r.in.ign
svn_grass at osgeo.org
Wed Apr 11 05:51:50 EDT 2012
Author: vincent
Date: 2012-04-11 02:51:50 -0700 (Wed, 11 Apr 2012)
New Revision: 51374
Added:
grass-addons/grass6/raster/r.in.ign/
grass-addons/grass6/raster/r.in.ign/Makefile
grass-addons/grass6/raster/r.in.ign/r.in.ign
grass-addons/grass6/raster/r.in.ign/r.in.ign.html
new AddOn for french IGN wms-c streams handling
Added: grass-addons/grass6/raster/r.in.ign/Makefile
--- grass-addons/grass6/raster/r.in.ign/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.in.ign/Makefile 2012-04-11 09:51:50 UTC (rev 51374)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.in.ign
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/raster/r.in.ign/r.in.ign
--- grass-addons/grass6/raster/r.in.ign/r.in.ign (rev 0)
+++ grass-addons/grass6/raster/r.in.ign/r.in.ign 2012-04-11 09:51:50 UTC (rev 51374)
@@ -0,0 +1,211 @@
+#!/bin/bash
+# MODULE: r.in.ign
+# AUTHOR(S): Vincent Bain
+# PURPOSE: Retrieve wms-c channel from IGN, see http://api.ign.fr
+# Developed for internal use
+# COPYRIGHT: (C) 2012 by the GRASS Development Team and Toraval-Vincent Bain
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that comes
+# with GRASS for details.
+# VERSION: 1.0
+# Currently only works on orthoimagery layers within
+# french metropole (geoportalfxx projection) at scale
+# 1/2000 i.e. res=0.5 m
+#%Module
+#% description: this module imports raster data from IGN wms-c server. Available layers comply with the INSPIRE directive. For more information see http://inspire.ign.fr/, http://api.ign.fr and http://inspire.jrc.ec.europa.eu/
+#% keywords: raster, import, wms, ign
+#%End
+#%flag
+#% key: c
+#% description: output a RGB raster rather than 3 separate-band rasters
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: raster map to import
+#% required : yes
+#%end
+# Get environnment
+if test "$GISBASE" = ""; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+GIS_DBASE=`g.gisenv get=GISDBASE`
+GIS_LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
+GIS_MAPSET=`g.gisenv get=MAPSET`
+GIS_MAP_PATH="${GIS_DBASE}/${GIS_LOCATION_NAME}/${GIS_MAPSET}"
+# Check for GDAL Tools
+if [ ! -x "`which gdalwarp`" ] ; then
+ g.message -e "gdalwarp required, please install GDAL Tools first"
+ exit 1
+fi
+if [ ! -x "`which gdal_translate`" ] ; then
+ g.message -e "gdal_translate required, please install GDAL Tools first"
+ exit 1
+fi
+if [ ! -x "`which gcps2wld.py`" ] ; then
+ g.message -e "gcps2wld required, please install GDAL Tools first"
+ exit 1
+fi
+# Check for maptools
+if [ ! -x "`which cs2cs`" ] ; then
+ g.message -e "cs2cs required, install Maptools first"
+ exit 1
+fi
+# Check for awk
+if ! echo test | awk '{print $0}' > /dev/null 2>&1; then
+ g.message -e "`basename $0`: awk required, please install awk/gawk first" 1>&2
+ exit 1
+fi
+# save command line
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ CMDLINE=`basename "$0"`
+ for arg in "$@" ; do
+ CMDLINE="$CMDLINE \"$arg\""
+ done
+ export CMDLINE
+ exec g.parser "$0" "$@"
+fi
+# Functions handling user break
+Cleanup()
+ # cleaning temporary directory
+ if [ -d "$GIS_MAP_PATH/.tmp/inspire" ]; then
+ rm -r "$GIS_MAP_PATH"/.tmp/inspire/
+ fi
+Cleanexit()
+ g.message -w "User break !"
+ Cleanup
+ exit 1
+trap "Cleanexit" 2 3 15
+# Setting up various variables
+# s_srs to match current location proj
+curproj=`eval g.proj -jf`
+# working directory
+if [ ! -d "$GIS_MAP_PATH/.tmp/inspire" ] ; then
+ mkdir "$GIS_MAP_PATH/.tmp/inspire"
+fi
+# step parameter, corresponds to tiles dimensions : should be adjustable to region extent in a future release, so one can choose between available resolutions in the server's pyramids.
+pas=128
+# translating region extents in the correct projection
+eval `g.region -g`
+wfxx=`echo "$w $s" | cs2cs $curproj +to +init=IGNF:GEOPORTALFXX | awk -F" " '{print $1}'`
+sfxx=`echo "$w $s" | cs2cs $curproj +to +init=IGNF:GEOPORTALFXX | awk -F" " '{print $2}'`
+efxx=`echo "$e $n" | cs2cs $curproj +to +init=IGNF:GEOPORTALFXX | awk -F" " '{print $1}'`
+nfxx=`echo "$e $n" | cs2cs $curproj +to +init=IGNF:GEOPORTALFXX | awk -F" " '{print $2}'`
+wfxx=`echo "${wfxx/.*/}"` # bail out decimal part, for bash arythmetic...
+sfxx=`echo "${sfxx/.*/}"`
+efxx=`echo "${efxx/.*/}"`
+nfxx=`echo "${nfxx/.*/}"`
+coli=$(( wfxx / pas )) # returns integer part, actually what we need
+xi=$(( coli * pas ))
+rowi=$(( sfxx / pas ))
+yi=$(( rowi * pas ))
+colf=$(( efxx / pas ))
+rowf=$(( nfxx / pas ))
+iterx=$(( colf - coli ))
+itery=$(( rowf - rowi ))
+# loop downloading tiles
+for i in `seq 0 "$iterx"`; do
+ xk1=$(( xi + i * pas ))
+ for j in `seq 0 "$itery"`; do
+ yk1=$(( yi + j * pas ))
+ xk2=$(( xk1 + pas ))
+ yk2=$(( yk1 + pas ))
+ # in the next request, LAYERS parameter is set to orthoimagery. Should be adjustable in a future release
+ wget "http://127.0.0.1:10001/wmsc?LAYERS=ORTHOIMAGERY.ORTHOPHOTOS&FORMAT=image/jpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=IGNF:GEOPORTALFXX&BBOX=$xk1,$yk1,$xk2,$yk2&WIDTH=256&HEIGHT=256&TILED=true" -O "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".jpg
+ # georeferencing tile
+ gdal_translate -gcp 0 0 "$xk1" "$yk2" -gcp 256 256 "$xk2" "$yk1" -gcp 256 0 "$xk2" "$yk2" "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".jpg "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".tif
+ gcps2wld.py "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".tif>"$GIS_MAP_PATH"/.tmp/inspire/insp$i$j.tfw
+ gdal_translate -of GTiff -a_srs +init=IGNF:GEOPORTALFXX "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".tif "$GIS_MAP_PATH"/.tmp/inspire/inspr"$i$j".tif
+ # cleaning up temp files
+ rm "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".jpg
+ rm "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".tif
+ rm "$GIS_MAP_PATH"/.tmp/inspire/insp"$i$j".tfw
+ ((j++))
+ done
+ ((i++))
+done
+# assembling tiles into a single image
+gdal_merge.py -o "$GIS_MAP_PATH"/.tmp/inspire/inspirefxx.tif "$GIS_MAP_PATH"/.tmp/inspire/inspr*.tif
+# projecting the image in t_srs=curproj
+gdalwarp -s_srs "+init=IGNF:GEOPORTALFXX" -t_srs "$curproj" -rc -tr 0.5 0.5 -co "INTERLEAVE=PIXEL" -dstnodata 255 -dstalpha "$GIS_MAP_PATH"/.tmp/inspire/inspirefxx.tif "$GIS_MAP_PATH"/.tmp/inspire/inspire.tif
+# retrieving the latter as a GRASS raster map
+r.in.gdal input="$GIS_MAP_PATH"/.tmp/inspire/inspire.tif output="$GIS_OPT_OUTPUT"
+# optionnally make a composite rgb raster
+if [ "$GIS_FLAG_C" -eq 1 ] ; then
+ r.composite output="$GIS_OPT_OUTPUT" red="$GIS_OPT_OUTPUT".red green="$GIS_OPT_OUTPUT".green blue="$GIS_OPT_OUTPUT".blue
+ g.mremove -f rast="$GIS_OPT_OUTPUT".red,"$GIS_OPT_OUTPUT".green,"$GIS_OPT_OUTPUT".blue,"$GIS_OPT_OUTPUT".alpha
+ # write support data
+ r.support map="$GIS_OPT_OUTPUT" title="orthoimagery extracted from ign wms service"
+ r.support map="$GIS_OPT_OUTPUT" history="${CMDLINE}"
+fi
+g.message "Done."
+Cleanup
+exit 0
Property changes on: grass-addons/grass6/raster/r.in.ign/r.in.ign
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass6/raster/r.in.ign/r.in.ign.html
--- grass-addons/grass6/raster/r.in.ign/r.in.ign.html (rev 0)
+++ grass-addons/grass6/raster/r.in.ign/r.in.ign.html 2012-04-11 09:51:50 UTC (rev 51374)
@@ -0,0 +1,26 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.ign</em> imports raster data from <a href="http://api.ign.fr">IGN WMS-C stream service</A>. Available layers comply with the <a href="http://inspire.jrc.ec.europa.eu">INSPIRE directive</A>.<br>For more information see <a href="http://inspire.ign.fr">http://inspire.ign.fr</A>.
+<h2>NOTES</h2>
+<p><em>r.in.ign</em> lets you query a dataset via a contract. Beware the conditions that come with it and terms of use that apply to data.</p><p>It is yet a very rough module: right now it only works on the orthoimagery layer, at the finest scale (1/2000 i.e. resolution=0.5 m), and for data over french metropole only (i.e. data in GEOPORTALFXX coordinate system) -- all this being easily adaptable to one's personnal needs.</p><p>
+Connecting to the WMS-C streams of Géoportail is not straight, in cause a restricted access protected by a GeoDRM process. The module works behind a proxy configured with a personal apiKey that comes with your contract. See practical details concerning registration on the <a href="http://api.ign.fr/geoportail/api/doc/index.html">official website</A>.
+</p>
+<h2>EXAMPLE</h2>
+This command imports orthoimagery from IGN wms-c server to the raster map <em>orthoign</em>:
+<p><tt>
+r.in.ign -c output=orthoign
+</tt></p>
+<h2>SEE ALSO</h2>
+<em><a href="http://grass.osgeo.org/grass64/manuals/html64_user/r.in.wms.html">r.in.wms</a></em>
+<h2>AUTHOR</h2>
+Vincent Bain, Toraval, France
+<p><i>Last changed: $Date$</i>
\ No newline at end of file
