[GRASS-SVN] r51375 - in grass/trunk: lib/python/temporal temporal
temporal/t.info temporal/t.rast.extract
temporal/t.rast.mapcalc temporal/t.rast3d.extract
temporal/t.rast3d.mapcalc
svn_grass at osgeo.org
Wed Apr 11 05:57:54 EDT 2012
Author: huhabla
Date: 2012-04-11 02:57:54 -0700 (Wed, 11 Apr 2012)
New Revision: 51375
Added:
grass/trunk/temporal/t.rast3d.mapcalc/
grass/trunk/temporal/t.rast3d.mapcalc/Makefile
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
grass/trunk/lib/python/temporal/Makefile
grass/trunk/lib/python/temporal/__init__.py
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.rast.extract/t.rast.extract.py
grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh
Parallelized implementation of mapcalc expressions in space time dataset extract and mapcalc modules.
New space time raster3d dataset mapcalc module.
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/lib/python/temporal/Makefile 2012-04-11 09:57:54 UTC (rev 51375)
@@ -8,7 +8,7 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation
+MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation extract mapcalc
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/lib/python/temporal/__init__.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -13,3 +13,5 @@
from temporal_relationships import *
from unit_tests import *
from aggregation import *
+from extract import *
+from mapcalc import *
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/Makefile 2012-04-11 09:57:54 UTC (rev 51375)
@@ -23,6 +23,7 @@
t.rast.extract \
t.rast3d.list \
t.rast3d.extract \
+ t.rast3d.mapcalc \
t.vect.list \
t.vect.what.strds \
t.vect.observe.strds
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.info/t.info.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -15,7 +15,7 @@
#%module
-#% description: List informtion about space time and map datasets
+#% description: List information about space time datasets and maps
#% keywords: temporal
#% keywords: info
#%end
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.py
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -74,163 +74,10 @@
# Make sure the temporal database exists
tgis.create_temporal_database()
- mapset = grass.gisenv()["MAPSET"]
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = tgis.space_time_raster_dataset(id)
+ tgis.extract_dataset(input, output, "raster", where, expression, base, nprocs, register_null)
- dbif = tgis.sql_database_interface_connection()
- dbif.connect()
- if sp.is_in_db(dbif) == False:
- dbif.close()
- grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
- if expression and not base:
- dbif.close()
- grass.fatal(_("Please specify base="))
- sp.select(dbif)
- if output.find("@") >= 0:
- out_id = output
- else:
- out_id = output + "@" + mapset
- # The new space time raster dataset
- new_sp = tgis.space_time_raster_dataset(out_id)
- if new_sp.is_in_db():
- if grass.overwrite() == False:
- dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
- rows = sp.get_registered_maps("id", where, "start_time", dbif)
- new_maps = {}
- if rows:
- num_rows = len(rows)
- grass.percent(0, num_rows, 1)
- # Run the r.mapcalc expression
- if expression:
- count = 0
- proc_count = 0
- proc_list = []
- for row in rows:
- count += 1
- grass.percent(count, num_rows, 1)
- map_name = "%s_%i" % (base, count)
- expr = "%s = %s" % (map_name, expression.replace(sp.get_id(), row["id"]))
- expr = expr.replace(sp.base.get_name(), row["id"])
- map_id = map_name + "@" + mapset
- new_map = sp.get_new_map_instance(map_id)
- # Check if new map is in the temporal database
- if new_map.is_in_db(dbif):
- if grass.overwrite() == True:
- # Remove the existing temporal database entry
- new_map.delete(dbif)
- else:
- grass.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
- continue
- grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
- proc_list.append(Process(target=run_mapcalc, args=(expr,)))
- proc_list[proc_count].start()
- proc_count += 1
- if proc_count == nprocs:
- proc_count = 0
- exitcodes = 0
- for proc in proc_list:
- proc.join()
- exitcodes += proc.exitcode
- if exitcodes != 0:
- dbif.close()
- grass.fatal(_("Error while r.mapcalc computation"))
- # Empty proc list
- proc_list = []
- new_maps[row["id"]] = new_map
- # Insert the new space time raster dataset
- new_sp.delete(dbif)
- temporal_type, semantic_type, title, description = sp.get_initial_values()
- new_sp.set_initial_values(temporal_type, semantic_type, title, description)
- new_sp.insert(dbif)
- # Register the maps in the database
- count = 0
- for row in rows:
- count += 1
- old_map = sp.get_new_map_instance(row["id"])
- old_map.select(dbif)
- if expression:
- if new_maps.has_key(row["id"]):
- new_map = new_maps[row["id"]]
- # Read the raster map data
- new_map.load()
- # In case of a null map continue, do not register null maps
- if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
- if not register_null:
- continue
- # Set the time stamp
- if old_map.is_time_absolute():
- start, end, tz = old_map.get_absolute_time()
- new_map.set_absolute_time(start, end, tz)
- else:
- start, end = old_map.get_relative_time()
- new_map.set_relative_time(start, end)
- # Insert map in temporal database
- new_map.insert(dbif)
- new_sp.register_map(new_map, dbif)
- else:
- new_sp.register_map(old_map, dbif)
- # Update the spatio-temporal extent and the raster metadata table entries
- new_sp.update_from_registered_maps(dbif)
- grass.percent(num_rows, num_rows, 1)
- dbif.close()
-def run_mapcalc(expr):
- """Helper function to run r.mapcalc in parallel"""
- return grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
if __name__ == "__main__":
options, flags = grass.parser()
main()
Modified: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2012-04-11 09:57:54 UTC (rev 51375)
@@ -2,8 +2,7 @@
# We need to set a specific region in the
# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
+# raster with r.mapcalc
# The region setting should work for UTM and LL test locations
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
@@ -17,15 +16,13 @@
t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-# The first @test
-# We create the space time raster inputs and register the raster maps with absolute time interval
+# The @test
t.rast.extract --o --v input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" \
expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=2
t.info type=strds input=precip_abs2
t.rast.extract --o --v -n input=precip_abs1 output=precip_abs3 where="start_time > '2001-06-01'" \
- expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
+ expression=" if(precip_abs1 at PERMANENT > 400, precip_abs1 at PERMANENT, null())" base=new_prec nprocs=4
t.info type=strds input=precip_abs3
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -87,275 +87,10 @@
- # We need a database interface for fast computation
- dbif.connect()
+ tgis.dataset_mapcalculator(inputs, output, "raster", expression, base, method, nprocs, register_null, spatial)
- input_name_list = inputs.split(",")
- # Process the first input
- if input_name_list[0].find("@") >= 0:
- id = input_name_list[0]
- else:
- id = input_name_list[0] + "@" + mapset
- first_input = tgis.space_time_raster_dataset(id)
- if first_input.is_in_db(dbif) == False:
- dbif.close()
- # Fill the object with data from the temporal database
- first_input.select(dbif)
- # All additional inputs in reverse sorted order to avoid wrong name substitution
- input_name_list = input_name_list[1:]
- input_name_list.sort()
- input_name_list.reverse()
- input_list = []
- for input in input_name_list:
- id = input
- else:
- dbif.close()
- grass.fatal(_("Space time raster dataset <%s> not found in temporal database") % (id))
- sp.select(dbif)
- input_list.append(copy.copy(sp))
- # Create the new space time raster dataset
- out_id = output
- else:
- # Check if in database
- if new_sp.is_in_db(dbif):
- dbif.close()
- # Sample all inputs by the first input and create a sample matrix
- if spatial:
- grass.message(_("Start spatio-temporal sampling"))
- else:
- grass.message(_("Start temporal sampling"))
- map_matrix = []
- id_list = []
- sample_map_list = []
- # First entry is the first dataset id
- id_list.append(first_input.get_name())
- if len(input_list) > 0:
- has_samples = False
- for dataset in input_list:
- list = dataset.sample_by_dataset(stds=first_input, method=method, spatial=spatial, dbif=dbif)
- # In case samples are not found
- if not list and len(list) == 0:
- dbif.close()
- grass.message(_("No samples found for map calculation"))
- return 0
- # The fist entries are the samples
- map_name_list = []
- if has_samples == False:
- for entry in list:
- granule = entry["granule"]
- # Do not consider gaps
- if granule.get_id() == None:
- continue
- sample_map_list.append(granule)
- map_name_list.append(granule.get_name())
- # Attach the map names
- map_matrix.append(copy.copy(map_name_list))
- has_samples = True
- maplist = entry["samples"]
- # Do not consider gaps in the sampler
- continue
- if len(maplist) > 1:
- grass.warning(_("Found more than a single map in a sample granule. "\
- "Only the first map is used for computation. "\
- "Use t.rast.aggregate.ds to create synchronous datasets."))
- # Store all maps! This includes non existent maps, identified by id == None
- map_name_list.append(maplist[0].get_name())
- id_list.append(dataset.get_name())
- else:
- list = first_input.get_registered_maps_as_objects(dbif=dbif)
- if list == None:
- dbif.close()
- grass.message(_("No maps in input dataset"))
- return 0
- for map in list:
- map_name_list.append(map.get_name())
- sample_map_list.append(map)
- # Needed for map registration
- map_list = []
- if len(map_matrix) > 0:
- grass.message(_("Start r.mapcalc computation"))
- count = 0
- # Get the number of samples
- num = len(map_matrix[0])
- # Parallel processing
- proc_list = []
- proc_count = 0
- # For all samples
- for i in range(num):
- count += 1
- grass.percent(count, num, 1)
- # Create the r.mapcalc statement for the current time step
- expr = "%s = %s" % (map_name, expression)
- # Check that all maps are in the sample
- valid_maps = True
- # Replace all dataset names with their map names of the current time step
- for j in range(len(map_matrix)):
- if map_matrix[j][i] == None:
- valid_maps = False
- break
- # Substitute the dataset name with the map name
- expr = expr.replace(id_list[j], map_matrix[j][i])
- # Proceed with the next sample
- if valid_maps == False:
- continue
- # Create the new map id and check if the map is already in the database
- new_map = first_input.get_new_map_instance(map_id)
- else:
- continue
- if sample_map_list[i].is_time_absolute():
- start, end, tz = sample_map_list[i].get_absolute_time()
- else:
- start, end = sample_map_list[i].get_relative_time()
- map_list.append(new_map)
- # Start the parallel r.mapcalc computation
- proc_count += 1
- proc_count = 0
- exitcodes = 0
- proc.join()
- dbif.close()
- # Empty process list
- proc_list = []
- # Register the new maps in the output space time dataset
- grass.message(_("Start map registration in temporal database"))
- # Overwrite an existing dataset if requested
- # Copy the ids from the first input
- temporal_type, semantic_type, title, description = first_input.get_initial_values()
- # Insert the dataset in the temporal database
- count = 0
- for new_map in map_list:
- count += 1
- new_map.load()
- continue
- grass.percent(1, 1, 1)
- dbif.close()
main()
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -45,6 +45,15 @@
#% multiple: no
#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: The number of r3.mapcalc processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
#%flag
#% key: n
#% description: Register Null maps
@@ -63,126 +72,14 @@
where = options["where"]
expression = options["expression"]
base = options["base"]
+ nprocs = int(options["nprocs"])
register_null = flags["n"]
- grass.fatal(_("Please specify %s=")%"base")
+ tgis.extract_dataset(input, output, "raster3d", where, expression, base, nprocs, register_null)
- id = input
- else:
- sp = tgis.space_time_raster3d_dataset(id)
- if sp.is_in_db() == False:
- dbif.connect()
- sp.select(dbif)
- out_id = output
- else:
- # The new space time raster3d dataset
- new_sp = tgis.space_time_raster3d_dataset(out_id)
- else:
- grass.fatal(_("Space time raster3d dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
- if rows:
- count = 0
- for row in rows:
- count += 1
- if expression:
- else:
- grass.error(_("Raster3d map <%s> is already in temporal database, use overwrite flag to overwrite"))
- continue
- grass.verbose(_("Apply r3.mapcalc expression: \"%s\"") % expr)
- ret = grass.run_command("r3.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
- if ret != 0:
- grass.error(_("Error while r3.mapcalc computation, continue with next map"))
- break
- # Read the raster3d map data
- new_map.load()
- print new_map.metadata.get_min(), new_map.metadata.get_max()
- print("Found null map")
- continue
- else:
- else:
- # Update the spatio-temporal extent and the raster3d metadata table entries
- dbif.close()
main()
Modified: grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh
--- grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh 2012-04-11 09:51:50 UTC (rev 51374)
+++ grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh 2012-04-11 09:57:54 UTC (rev 51375)
@@ -1,9 +1,8 @@
-# Test the extraction of a subset of a space time raster input
+# Test the extraction of a subset of a space time raster3d input
@@ -17,9 +16,7 @@
t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.register -i type=rast3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-# The first @test
+# The @test
t.rast3d.extract --o input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec
t.info type=str3ds input=precip_abs2
Added: grass/trunk/temporal/t.rast3d.mapcalc/Makefile
--- grass/trunk/temporal/t.rast3d.mapcalc/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc/Makefile 2012-04-11 09:57:54 UTC (rev 51375)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast3d.mapcalc
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html
Added: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-04-11 09:57:54 UTC (rev 51375)
@@ -0,0 +1,99 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast3d.mapcalc
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Perform r3.mapcalc expressions on maps of sampled space time raster3d datasets
+# COPYRIGHT: (C) 2012 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Perform r3.mapcalc expressions on maps of sampled space time raster3d datasets
+#% keywords: temporal
+#% keywords: mapcalc
+#%end
+#%option G_OPT_STR3DS_INPUTS
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The r3.mapcalc expression applied to each time step of the sampled data
+#% required: yes
+#% multiple: no
+#%end
+#%option G_OPT_T_SAMPLE
+#% key: method
+#% answer: during,overlap,contain,equal
+#%end
+#%option G_OPT_STR3DS_OUTPUT
+#%end
+#%option G_OPT_R_BASE
+#% required: yes
+#% description: Name of the base raster3d map
+#% gisprompt: old,grid3,3d-raster
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+#%flag
+#% key: s
+#% description: Check spatial overlap
+#%end
+from multiprocessing import Process
+import copy
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ inputs = options["inputs"]
+ output = options["output"]
+ expression = options["expression"]
+ base = options["base"]
+ method = options["method"]
+ register_null = flags["n"]
+ spatial = flags["s"]
+ # Create the method list
+ method = method.split(",")
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ tgis.dataset_mapcalculator(inputs, output, "raster3d", expression, base, method, nprocs, register_null, spatial)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
--- grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh (rev 0)
+++ grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh 2012-04-11 09:57:54 UTC (rev 51375)
@@ -0,0 +1,37 @@
+# Test for t.rast.mapcalc
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create several space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r3.mapcalc --o expr="prec_1 = rand(0, 550)"
+r3.mapcalc --o expr="prec_2 = rand(0, 450)"
+r3.mapcalc --o expr="prec_3 = rand(0, 320)"
+r3.mapcalc --o expr="prec_4 = rand(0, 510)"
+r3.mapcalc --o expr="prec_5 = rand(0, 300)"
+r3.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.create --o type=str3ds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.register -i type=rast3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+t.register type=rast3d input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.info type=str3ds input=precip_abs1
+t.info type=str3ds input=precip_abs2
+# The first @test
+t.rast3d.mapcalc --o --v -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
+ expression=" precip_abs1 + precip_abs2" base=new_prec \
+ method=equal nprocs=6
+t.info type=str3ds input=precip_abs3
+t.rast3d.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
+ expression=" (precip_abs1 + precip_abs2) / precip_abs3 at PERMANENT " base=new_prec \
+t.info type=str3ds input=precip_abs4
+t.unregister type=rast3d maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=rast3d maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
+t.remove type=str3ds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
