[GRASS-SVN] r51377 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Apr 11 06:42:29 EDT 2012
Author: huhabla
Date: 2012-04-11 03:42:29 -0700 (Wed, 11 Apr 2012)
New Revision: 51377
Added:
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
New extraction algorithm for raster and raster3d space time datasets
Added: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py (rev 0)
+++ grass/trunk/lib/python/temporal/extract.py 2012-04-11 10:42:29 UTC (rev 51377)
@@ -0,0 +1,212 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+import grass.temporal as tgis
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from space_time_datasets import *
+from multiprocessing import Process
+def extract_dataset(input, output, type, where, expression, base, nprocs, register_null=False):
+ """!Extract a subset of a space time raster or raster3d dataset
+ A mapcalc expression can be provided to process the temporal extracted maps.
+ Mapcalc expressions are supported for raster and raster3d maps.
+ @param input The name of the input space time raster/raster3d dataset
+ @param output The name of the extracted new space time raster/raster3d dataset
+ @param type The type of the dataset: "raster" or "raster3d"
+ @param where The SQL WHERE statement for subset extraction
+ @param expression The r(3).mapcalc expression
+ @param base The base name of the new created maps in case a mapclac expression is provided
+ @param nprocs The number of parallel processes to be used for mapcalc processing
+ @param register_null Set this number True to register empty maps
+ mapset = core.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ if type == "raster":
+ sp = space_time_raster_dataset(id)
+ else:
+ sp = space_time_raster3d_dataset(id)
+ dbif = sql_database_interface_connection()
+ dbif.connect()
+ if sp.is_in_db(dbif) == False:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> not found") % (type, id))
+ if expression and not base:
+ dbif.close()
+ core.fatal(_("Please specify base="))
+ sp.select(dbif)
+ if output.find("@") >= 0:
+ out_id = output
+ else:
+ out_id = output + "@" + mapset
+ # The new space time dataset
+ new_sp = sp.get_new_instance(out_id)
+ if new_sp.is_in_db():
+ if core.overwrite() == False:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is already in database, use overwrite flag to overwrite") % (type, out_id))
+ rows = sp.get_registered_maps("id", where, "start_time", dbif)
+ new_maps = {}
+ if rows:
+ num_rows = len(rows)
+ core.percent(0, num_rows, 1)
+ # Run the mapcalc expression
+ if expression:
+ count = 0
+ proc_count = 0
+ proc_list = []
+ for row in rows:
+ count += 1
+ core.percent(count, num_rows, 1)
+ map_name = "%s_%i" % (base, count)
+ expr = "%s = %s" % (map_name, expression)
+ expr = expr.replace(sp.base.get_map_id(), row["id"])
+ expr = expr.replace(sp.base.get_name(), row["id"])
+ map_id = map_name + "@" + mapset
+ new_map = sp.get_new_map_instance(map_id)
+ # Check if new map is in the temporal database
+ if new_map.is_in_db(dbif):
+ if core.overwrite() == True:
+ # Remove the existing temporal database entry
+ new_map.delete(dbif)
+ else:
+ core.error(_("Map <%s> is already in temporal database, use overwrite flag to overwrite")%(new_map.get_map_id()))
+ continue
+ core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
+ proc_list.append(Process(target=run_mapcalc2d, args=(expr,)))
+ else:
+ proc_list.append(Process(target=run_mapcalc3d, args=(expr,)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ if proc_count == nprocs:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ dbif.close()
+ core.fatal(_("Error while mapcalc computation"))
+ # Empty proc list
+ proc_list = []
+ # Store the new maps
+ new_maps[row["id"]] = new_map
+ # Insert the new space time dataset
+ if new_sp.is_in_db(dbif):
+ new_sp.delete(dbif)
+ temporal_type, semantic_type, title, description = sp.get_initial_values()
+ new_sp.set_initial_values(temporal_type, semantic_type, title, description)
+ new_sp.insert(dbif)
+ # Register the maps in the database
+ count = 0
+ for row in rows:
+ count += 1
+ old_map = sp.get_new_map_instance(row["id"])
+ old_map.select(dbif)
+ if expression:
+ # Register the new maps
+ if new_maps.has_key(row["id"]):
+ new_map = new_maps[row["id"]]
+ # Read the raster map data
+ new_map.load()
+ # In case of a null map continue, do not register null maps
+ if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+ if not register_null:
+ continue
+ # Set the time stamp
+ if old_map.is_time_absolute():
+ start, end, tz = old_map.get_absolute_time()
+ new_map.set_absolute_time(start, end, tz)
+ else:
+ start, end = old_map.get_relative_time()
+ new_map.set_relative_time(start, end)
+ # Insert map in temporal database
+ new_map.insert(dbif)
+ new_sp.register_map(new_map, dbif)
+ else:
+ new_sp.register_map(old_map, dbif)
+ # Update the spatio-temporal extent and the metadata table entries
+ new_sp.update_from_registered_maps(dbif)
+ core.percent(num_rows, num_rows, 1)
+ dbif.close()
+def run_mapcalc2d(expr):
+ """Helper function to run r.mapcalc in parallel"""
+ return core.run_command("r.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
+def run_mapcalc3d(expr):
+ """Helper function to run r3.mapcalc in parallel"""
+ return core.run_command("r3.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
\ No newline at end of file
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2012-04-11 09:59:47 UTC (rev 51376)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2012-04-11 10:42:29 UTC (rev 51377)
@@ -252,7 +252,7 @@
proc_count += 1
- if proc_count == nprocs:
+ if proc_count == nprocs or proc_count == num:
proc_count = 0
exitcodes = 0
