[GRASS-SVN] r51378 - grass/trunk/lib/vector/Vlib
Wed Apr 11 10:34:58 EDT 2012
Author: martinl
Date: 2012-04-11 07:34:58 -0700 (Wed, 11 Apr 2012)
New Revision: 51378
   grass/trunk/lib/vector/Vlib/build_pg.c
   grass/trunk/lib/vector/Vlib/close_pg.c
   grass/trunk/lib/vector/Vlib/open_pg.c
   grass/trunk/lib/vector/Vlib/read_pg.c
   grass/trunk/lib/vector/Vlib/rewind_pg.c
   grass/trunk/lib/vector/Vlib/write_pg.c
vlib(pg): follow C indentation rules
          no tabs (tabs -> spaces)
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/build_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -6,18 +6,18 @@
    Higher level functions for reading/writing/manipulating vectors.
    \todo Implement build_topo()
    Line offset is
-    - centroids   : FID
-    - other types : index of the first record (which is FID) in offset array.
+   - centroids   : FID
+   - other types : index of the first record (which is FID) in offset array.
    (C) 2012 by the GRASS Development Team
    This program is free software under the GNU General Public License
    (>=v2). Read the file COPYING that comes with GRASS for details.
    \author Martin Landa <landa.martin gmail.com>
 #include <grass/vector.h>
 #include <grass/glocale.h>
@@ -32,12 +32,12 @@
    \brief Build topology for PostGIS layer
    Build levels:
-    - GV_BUILD_NONE
-    - GV_BUILD_BASE
-    - GV_BUILD_ATTACH_ISLES
-    - GV_BUILD_CENTROIDS
-    - GV_BUILD_ALL
+   - GV_BUILD_NONE
+   - GV_BUILD_BASE
+   - GV_BUILD_ATTACH_ISLES
+   - GV_BUILD_CENTROIDS
+   - GV_BUILD_ALL
    \param Map pointer to Map_info structure
    \param build build level
@@ -50,19 +50,19 @@
     struct Plus_head *plus;
     struct Format_info_pg *pg_info;
-    plus     = &(Map->plus);
-    pg_info  = &(Map->fInfo.pg);
+    plus = &(Map->plus);
+    pg_info = &(Map->fInfo.pg);
     G_debug(1, "Vect_build_pg(): db='%s' table='%s', build=%d",
 	    pg_info->db_name, pg_info->table_name, build);
     if (build == plus->built)
 	return 1;		/* do nothing */
     /* TODO move this init to better place (Vect_open_ ?), because in
        theory build may be reused on level2 */
     if (build >= plus->built && build > GV_BUILD_BASE) {
-	G_free((void *) pg_info->offset.array);
+	G_free((void *)pg_info->offset.array);
 	G_zero(&(pg_info->offset), sizeof(struct Format_info_offset));
@@ -80,17 +80,16 @@
     /* commit transaction block (update mode only) */
-    if (pg_info->inTransaction &&
-	execute(pg_info->conn, "COMMIT") == -1)
+    if (pg_info->inTransaction && execute(pg_info->conn, "COMMIT") == -1)
 	return -1;
     pg_info->inTransaction = FALSE;
     if (build > GV_BUILD_NONE)
 	G_message(_("Using external data format '%s' (feature type '%s')"),
 		  Vect_get_finfo_format_info(Map),
 		  Vect_get_finfo_geometry_type(Map));
     return Vect__build_sfa(Map, build);
 #else
     G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/close_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -11,7 +11,7 @@
 #include <stdlib.h>
@@ -23,57 +23,57 @@
 #endif
-  \brief Close vector map (PostGIS layer) on level 1
+   \brief Close vector map (PostGIS layer) on level 1
-  \param Map pointer to Map_info structure
+   \param Map pointer to Map_info structure
-  \return 0 on success
-  \return non-zero on error
+   \return 0 on success
+   \return non-zero on error
 int V1_close_pg(struct Map_info *Map)
 #ifdef HAVE_POSTGRES
     int i;
     G_debug(3, "V2_close_pg() name = %s mapset = %s", Map->name, Map->mapset);
     if (!VECT_OPEN(Map))
-	return -1;
+        return -1;
     if (Map->mode == GV_MODE_WRITE || Map->mode == GV_MODE_RW)
-	Vect__write_head(Map);
+        Vect__write_head(Map);
     /* close connection */
     if (pg_info->res) {
-	char stmt[DB_SQL_MAX];
-	PQclear(pg_info->res);
-	pg_info->res = NULL;
-	sprintf(stmt, "CLOSE %s_%s%p",
-		pg_info->schema_name, pg_info->table_name, pg_info->conn);
-	if (execute(pg_info->conn, stmt) == -1) {
-	    G_warning(_("Unable to close cursor"));
-	    return -1;
-	execute(pg_info->conn, "COMMIT");
+        char stmt[DB_SQL_MAX];
+        PQclear(pg_info->res);
+        pg_info->res = NULL;
+        sprintf(stmt, "CLOSE %s_%s%p",
+                pg_info->schema_name, pg_info->table_name, pg_info->conn);
+        if (execute(pg_info->conn, stmt) == -1) {
+            G_warning(_("Unable to close cursor"));
+            return -1;
+        execute(pg_info->conn, "COMMIT");
     PQfinish(pg_info->conn);
     /* close DB connection (for atgtributes) */
     if (pg_info->dbdriver) {
-	db_close_database_shutdown_driver(pg_info->dbdriver);
+        db_close_database_shutdown_driver(pg_info->dbdriver);
     /* free allocated space */
     for (i = 0; i < pg_info->cache.lines_alloc; i++) {
-	Vect_destroy_line_struct(pg_info->cache.lines[i]);
+        Vect_destroy_line_struct(pg_info->cache.lines[i]);
     if (pg_info->cache.lines)
-	G_free(pg_info->cache.lines);
+        G_free(pg_info->cache.lines);
     G_free(pg_info->db_name);
     G_free(pg_info->schema_name);
@@ -88,28 +88,28 @@
-  \brief Close vector map (PostGIS layer) on topological level (write out fidx file)
+   \brief Close vector map (PostGIS layer) on topological level (write out fidx file)
 int V2_close_pg(struct Map_info *Map)
-	return -1;
+        return -1;
     /* write fidx for maps in the current mapset */
     if (Vect_save_fidx(Map, &(Map->fInfo.pg.offset)) != 1)
-	G_warning(_("Unable to save feature index file for vector map <%s>"),
-		  Map->name);
+        G_warning(_("Unable to save feature index file for vector map <%s>"),
+                  Map->name);
     G_free(Map->fInfo.pg.offset.array);
     return 0;
 #else
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -26,100 +26,100 @@
 static char *get_key_column(struct Format_info_pg *);
 static SF_FeatureType ftype_from_string(const char *);
 static int drop_table(struct Format_info_pg *);
-static int check_schema(const struct Format_info_pg*);
+static int check_schema(const struct Format_info_pg *);
 static int create_table(struct Format_info_pg *, const struct field_info *);
 #endif
    \brief Open existing PostGIS feature table (level 1 - without topology)
    \todo Check database instead of geometry_columns
    \param[in,out] Map pointer to Map_info structure
    \param update TRUE for write mode, otherwise read-only
    \return 0 success
    \return -1 error
 int V1_open_old_pg(struct Map_info *Map, int update)
     int found;
     PGresult *res;
     if (!pg_info->conninfo) {
-	G_warning(_("Connection string not defined"));
-	return -1;
+        G_warning(_("Connection string not defined"));
+        return -1;
     if (!pg_info->table_name) {
-	G_warning(_("PostGIS feature table not defined"));
-	return -1;
+        G_warning(_("PostGIS feature table not defined"));
+        return -1;
-    G_debug(1, "V1_open_old_pg(): conninfo='%s' table='%s'", pg_info->conninfo,
-	    pg_info->table_name);
+    G_debug(1, "V1_open_old_pg(): conninfo='%s' table='%s'",
+            pg_info->conninfo, pg_info->table_name);
     /* connect database */
     pg_info->conn = PQconnectdb(pg_info->conninfo);
     G_debug(2, "   PQconnectdb(): %s", pg_info->conninfo);
     if (PQstatus(pg_info->conn) == CONNECTION_BAD)
-	G_fatal_error("%s\n%s", _("Connection ton PostgreSQL database failed."),
-		      PQerrorMessage(pg_info->conn));
+        G_fatal_error("%s\n%s",
+                      _("Connection ton PostgreSQL database failed."),
+                      PQerrorMessage(pg_info->conn));
     /* get DB name */
     pg_info->db_name = G_store(PQdb(pg_info->conn));
     if (!pg_info->db_name) {
-	G_warning(_("Unable to get database name"));
-	return -1;
+        G_warning(_("Unable to get database name"));
+        return -1;
     /* if schema not defined, use 'public' */
     if (!pg_info->schema_name) {
-	pg_info->schema_name = G_store("public");
+        pg_info->schema_name = G_store("public");
     /* get fid and geometry column */
     sprintf(stmt, "SELECT f_geometry_column, coord_dimension, srid, type "
-	    "FROM geometry_columns WHERE f_table_schema = '%s' AND "
-	    "f_table_name = '%s'",
-	    pg_info->schema_name, pg_info->table_name);
+            "FROM geometry_columns WHERE f_table_schema = '%s' AND "
+            "f_table_name = '%s'", pg_info->schema_name, pg_info->table_name);
     G_debug(2, "SQL: %s", stmt);
     res = PQexec(pg_info->conn, stmt);
     if (!res || PQresultStatus(res) != PGRES_TUPLES_OK)
-	G_fatal_error("%s\n%s", _("No feature tables found in database."),
-		      PQresultErrorMessage(res));
+        G_fatal_error("%s\n%s", _("No feature tables found in database."),
+                      PQresultErrorMessage(res));
     found = PQntuples(res) > 0 ? TRUE : FALSE;
     if (found) {
-	/* geometry column */
-	pg_info->geom_column = G_store(PQgetvalue(res, 0, 0));
-	G_debug(3, "\t-> table = %s column = %s", pg_info->table_name,
-		pg_info->geom_column);
-	/* fid column */
-	pg_info->fid_column = get_key_column(pg_info);
-	/* coordinates dimension */
-	pg_info->coor_dim = atoi(PQgetvalue(res, 0, 1));
-	/* SRS ID */
-	pg_info->srid = atoi(PQgetvalue(res, 0, 2));
-	/* feature type */
-	pg_info->feature_type = ftype_from_string(PQgetvalue(res, 0, 3));
+        /* geometry column */
+        pg_info->geom_column = G_store(PQgetvalue(res, 0, 0));
+        G_debug(3, "\t-> table = %s column = %s", pg_info->table_name,
+                pg_info->geom_column);
+        /* fid column */
+        pg_info->fid_column = get_key_column(pg_info);
+        /* coordinates dimension */
+        pg_info->coor_dim = atoi(PQgetvalue(res, 0, 1));
+        /* SRS ID */
+        pg_info->srid = atoi(PQgetvalue(res, 0, 2));
+        /* feature type */
+        pg_info->feature_type = ftype_from_string(PQgetvalue(res, 0, 3));
     PQclear(res);
     /* no feature in cache */
     pg_info->cache.fid = -1;
     if (!found) {
-	G_warning(_("Feature table <%s> not found in 'geometry_columns'"),
+        G_warning(_("Feature table <%s> not found in 'geometry_columns'"),
+                  pg_info->table_name);
     return 0;
@@ -133,23 +133,23 @@
    \brief Open existing PostGIS layer (level 2 - feature index)
    \return 0 success
    \return -1 error
 int V2_open_old_pg(struct Map_info *Map)
     G_debug(3, "V2_open_old_pg(): name = %s mapset = %s", Map->name,
-	    Map->mapset);
+            Map->mapset);
     if (Vect_open_fidx(Map, &(Map->fInfo.pg.offset)) != 0) {
-	G_warning(_("Unable to open feature index file for vector map <%s>"),
-		  Vect_get_full_name(Map));
-	G_zero(&(Map->fInfo.pg.offset), sizeof(struct Format_info_offset));
+        G_warning(_("Unable to open feature index file for vector map <%s>"),
+                  Vect_get_full_name(Map));
+        G_zero(&(Map->fInfo.pg.offset), sizeof(struct Format_info_offset));
     return 0;
 #else
@@ -162,104 +162,105 @@
    (level 1)
    \todo To implement
    \param[out] Map pointer to Map_info structure
    \param name name of PostGIS feature table to create
    \param with_z WITH_Z for 3D vector data otherwise WITHOUT_Z
    \return 0 success
    \return -1 error
 int V1_open_new_pg(struct Map_info *Map, const char *name, int with_z)
     PGresult *res;
-	return -1;
+        return -1;
-	return -1;
+        return -1;
-    G_debug(1, "V1_open_new_pg(): conninfo='%s' table='%s'", pg_info->conninfo,
+    G_debug(1, "V1_open_new_pg(): conninfo='%s' table='%s'",
     /* get DB name */
-	return -1;
+        return -1;
     /* if fid_column not defined, use 'ogc_fid' */
     if (!pg_info->fid_column) {
-	pg_info->fid_column = G_store("ogc_fid");
+        pg_info->fid_column = G_store("ogc_fid");
     /* if geom_column not defined, use 'wkb_geometry' */
     if (!pg_info->geom_column) {
-	pg_info->geom_column = G_store("wkb_geometry");
+        pg_info->geom_column = G_store("wkb_geometry");
     /* check if feature table already exists */
     sprintf(stmt, "SELECT * FROM pg_tables "
-	    "WHERE schemaname = '%s' AND tablename = '%s'",
+            "WHERE schemaname = '%s' AND tablename = '%s'",
+            pg_info->schema_name, pg_info->table_name);
     if (PQntuples(res) > 0) {
-	/* table found */
-	if (G_get_overwrite()) {
-	    G_warning(_("PostGIS layer <%s.%s> already exists and will be overwritten"),
-	    if (drop_table(pg_info) == -1) {
-		G_warning(_("Unable to delete PostGIS layer <%s>"),
-		return -1;
-	else {
-	    G_fatal_error(_("PostGIS layer <%s.%s> already exists in database '%s'"),
-			  pg_info->db_name);
-	    return -1;
+        /* table found */
+        if (G_get_overwrite()) {
+            G_warning(_("PostGIS layer <%s.%s> already exists and will be overwritten"),
+            if (drop_table(pg_info) == -1) {
+                G_warning(_("Unable to delete PostGIS layer <%s>"),
+                return -1;
+        else {
+            G_fatal_error(_("PostGIS layer <%s.%s> already exists in database '%s'"),
+                          pg_info->db_name);
+            return -1;
     /* unknown feature type */
     pg_info->feature_type = SF_UNKNOWN;
     PQclear(res);
     return 0;
 #else
@@ -273,90 +274,90 @@
    V1_open_new_pg() is required to be called before this function.
    List of currently supported types:
-    - GV_POINT     (SF_POINT)
-    - GV_LINE      (SF_LINESTRING)
-    - GV_BOUNDARY  (SF_POLYGON)
+   - GV_POINT     (SF_POINT)
+   - GV_LINE      (SF_LINESTRING)
+   - GV_BOUNDARY  (SF_POLYGON)
    \param type feature type (GV_POINT, GV_LINE, ...)
    \return 0 success
    \return -1 error
 int V2_open_new_pg(struct Map_info *Map, int type)
     int ndblinks;
     struct field_info *Fi;
     struct Key_Value *projinfo, *projunits;
     Fi = NULL;
-	return -1;
+        return -1;
-	return -1;
+        return -1;
     G_debug(1, "V2_open_new_pg(): conninfo='%s' table='%s' -> type = %d",
-	    pg_info->conninfo, pg_info->table_name, type);
+            pg_info->conninfo, pg_info->table_name, type);
     /* get spatial reference */
-    projinfo  = G_get_projinfo();
+    projinfo = G_get_projinfo();
     projunits = G_get_projunits();
-    pg_info->srid = 0; /* TODO */
+    pg_info->srid = 0;          /* TODO */
     // Ogr_spatial_ref = GPJ_grass_to_osr(projinfo, projunits);
     G_free_key_value(projinfo);
     G_free_key_value(projunits);
     /* determine geometry type */
-    switch(type) {
+    switch (type) {
     case GV_POINT:
-	pg_info->feature_type = SF_POINT;
-	break;
+        pg_info->feature_type = SF_POINT;
+        break;
     case GV_LINE:
-	pg_info->feature_type = SF_LINESTRING;
-	break;
+        pg_info->feature_type = SF_LINESTRING;
+        break;
     case GV_BOUNDARY:
-	pg_info->feature_type = SF_POLYGON;
-	break;
+        pg_info->feature_type = SF_POLYGON;
+        break;
     default:
-	G_warning(_("Unsupported geometry type (%d)"), type);
-	return -1;
+        G_warning(_("Unsupported geometry type (%d)"), type);
+        return -1;
     /* coordinate dimension */
     pg_info->coor_dim = Vect_is_3d(Map) ? 3 : 2;
     /* create new PostGIS table */
     ndblinks = Vect_get_num_dblinks(Map);
     if (ndblinks > 0) {
-	Fi = Vect_get_dblink(Map, 0);
-	if (Fi) {
-	    if (ndblinks > 1)
-		G_warning(_("More layers defined, using driver <%s> and "
-			    "database <%s>"), Fi->driver, Fi->database);
-	else {
-	    G_warning(_("Database connection not defined. "
-			"Unable to write attributes."));
+        Fi = Vect_get_dblink(Map, 0);
+        if (Fi) {
+            if (ndblinks > 1)
+                G_warning(_("More layers defined, using driver <%s> and "
+                            "database <%s>"), Fi->driver, Fi->database);
+        else {
+            G_warning(_("Database connection not defined. "
+                        "Unable to write attributes."));
     if (create_table(pg_info, Fi) == -1) {
-	G_warning(_("Unable to create new PostGIS table"));
-	return -1;
+        G_warning(_("Unable to create new PostGIS table"));
+        return -1;
-    if (Fi)
-	G_free(Fi);
+    if (Fi)
+        G_free(Fi);
     return 0;
 #else
@@ -369,36 +370,36 @@
     char *key_column;
     PGresult *res;
     sprintf(stmt,
-	    "SELECT kcu.column_name "
-	    "FROM INFORMATION_SCHEMA.TABLES t "
-	    "LEFT JOIN INFORMATION_SCHEMA.TABLE_CONSTRAINTS tc "
-	    "ON tc.table_catalog = t.table_catalog "
-	    "AND tc.table_schema = t.table_schema "
-	    "AND tc.table_name = t.table_name "
-	    "AND tc.constraint_type = 'PRIMARY KEY' "
-	    "LEFT JOIN INFORMATION_SCHEMA.KEY_COLUMN_USAGE kcu "
-	    "ON kcu.table_catalog = tc.table_catalog "
-	    "AND kcu.table_schema = tc.table_schema "
-	    "AND kcu.table_name = tc.table_name "
-	    "AND kcu.constraint_name = tc.constraint_name "
-	    "WHERE t.table_schema = '%s' AND t.table_name = '%s'",
+            "SELECT kcu.column_name "
+            "FROM INFORMATION_SCHEMA.TABLES t "
+            "LEFT JOIN INFORMATION_SCHEMA.TABLE_CONSTRAINTS tc "
+            "ON tc.table_catalog = t.table_catalog "
+            "AND tc.table_schema = t.table_schema "
+            "AND tc.table_name = t.table_name "
+            "AND tc.constraint_type = 'PRIMARY KEY' "
+            "LEFT JOIN INFORMATION_SCHEMA.KEY_COLUMN_USAGE kcu "
+            "ON kcu.table_catalog = tc.table_catalog "
+            "AND kcu.table_schema = tc.table_schema "
+            "AND kcu.table_name = tc.table_name "
+            "AND kcu.constraint_name = tc.constraint_name "
+            "WHERE t.table_schema = '%s' AND t.table_name = '%s'",
     if (!res || PQresultStatus(res) != PGRES_TUPLES_OK ||
-	PQntuples(res) != 1 || strlen(PQgetvalue(res, 0, 0)) < 1) {
-	G_warning(_("No key column detected."));
-	if (res)
-	    PQclear(res);
-	return NULL;
+        PQntuples(res) != 1 || strlen(PQgetvalue(res, 0, 0)) < 1) {
+        G_warning(_("No key column detected."));
+        if (res)
+            PQclear(res);
+        return NULL;
     key_column = G_store(PQgetvalue(res, 0, 0));
     PQclear(res);
     return key_column;
@@ -409,24 +410,24 @@
     SF_FeatureType sf_type;
     if (G_strcasecmp(type, "POINT") == 0)
-	return SF_POINT;
+        return SF_POINT;
     else if (G_strcasecmp(type, "LINESTRING") == 0)
-	return SF_LINESTRING;
+        return SF_LINESTRING;
     else if (G_strcasecmp(type, "POLYGON") == 0)
-	return SF_POLYGON;
+        return SF_POLYGON;
     else if (G_strcasecmp(type, "MULTIPOINT") == 0)
-	return SF_MULTIPOINT;
+        return SF_MULTIPOINT;
     else if (G_strcasecmp(type, "MULTILINESTRING") == 0)
-	return SF_MULTILINESTRING;
+        return SF_MULTILINESTRING;
     else if (G_strcasecmp(type, "MULTIPOLYGON") == 0)
-	return SF_MULTIPOLYGON;
+        return SF_MULTIPOLYGON;
     else if (G_strcasecmp(type, "GEOMETRYCOLLECTION") == 0)
-	return SF_GEOMETRYCOLLECTION;
+        return SF_GEOMETRYCOLLECTION;
     return SF_UNKNOWN;
     G_debug(3, "ftype_from_string(): type='%s' -> %d", type, sf_type);
     return sf_type;
@@ -435,12 +436,12 @@
     sprintf(stmt, "DROP TABLE \"%s\".\"%s\"",
-	return -1;
+        return -1;
     return 0;
@@ -448,38 +449,39 @@
     int i, found, nschema;
     PGresult *result;
     /* add geometry column */
     sprintf(stmt, "SELECT nspname FROM pg_namespace");
     result = PQexec(pg_info->conn, stmt);
     if (!result || PQresultStatus(result) != PGRES_TUPLES_OK) {
-	PQclear(result);
-	execute(pg_info->conn, "ROLLBACK");
-	return -1;
+        PQclear(result);
+        execute(pg_info->conn, "ROLLBACK");
+        return -1;
     found = FALSE;
     nschema = PQntuples(result);
     for (i = 0; i < nschema && !found; i++) {
-	if (strcmp(pg_info->schema_name, PQgetvalue(result, i, 0)) == 0)
-	    found = TRUE;
+        if (strcmp(pg_info->schema_name, PQgetvalue(result, i, 0)) == 0)
+            found = TRUE;
     PQclear(result);
     if (!found) {
-	sprintf(stmt, "CREATE SCHEMA %s", pg_info->schema_name);
-	    return -1;
-	G_warning(_("Schema <%s> doesn't exist, created"), pg_info->schema_name);
+        sprintf(stmt, "CREATE SCHEMA %s", pg_info->schema_name);
+            return -1;
+        G_warning(_("Schema <%s> doesn't exist, created"),
+                  pg_info->schema_name);
     return 0;
@@ -493,194 +495,195 @@
     /* by default create spatial index & add primary key */
     spatial_index = primary_key = TRUE;
     if (G_find_file2("", "PG", G_mapset())) {
-	FILE *fp;
-	const char *p;
-	struct Key_Value *key_val;
-	fp = G_fopen_old("", "PG", G_mapset());
-	if (!fp) {
-	    G_fatal_error(_("Unable to open PG file"));
-	key_val = G_fread_key_value(fp);
-	fclose(fp);
-	/* disable spatial index ? */
-	p = G_find_key_value("spatial_index", key_val);
-	if (p && G_strcasecmp(p, "off") == 0)
-	    spatial_index = FALSE;
-	/* disable primary key ? */
-	p = G_find_key_value("primary_key", key_val);
-	    primary_key = FALSE;
+        FILE *fp;
+        const char *p;
+        struct Key_Value *key_val;
+        fp = G_fopen_old("", "PG", G_mapset());
+        if (!fp) {
+            G_fatal_error(_("Unable to open PG file"));
+        key_val = G_fread_key_value(fp);
+        fclose(fp);
+        /* disable spatial index ? */
+        p = G_find_key_value("spatial_index", key_val);
+        if (p && G_strcasecmp(p, "off") == 0)
+            spatial_index = FALSE;
+        /* disable primary key ? */
+        p = G_find_key_value("primary_key", key_val);
+            primary_key = FALSE;
     /* create schema if not exists */
     if (G_strcasecmp(pg_info->schema_name, "public") != 0) {
-	if (check_schema(pg_info) != 0)
-	    return -1;
+        if (check_schema(pg_info) != 0)
+            return -1;
     /* prepare CREATE TABLE statement */
     sprintf(stmt, "CREATE TABLE \"%s\".\"%s\" (%s SERIAL",
-	    pg_info->fid_column);
+            pg_info->schema_name, pg_info->table_name, pg_info->fid_column);
     if (Fi) {
-	/* append attributes */
-	int col, ncols, sqltype, length, ctype;
-	char stmt_col[DB_SQL_MAX];
-	const char *colname;
-	dbString dbstmt;
-	dbHandle  handle;
-	dbDriver *driver;
-	dbCursor  cursor;
-	dbTable  *table;
-	dbColumn *column;
-	db_init_string(&dbstmt);
-	db_init_handle(&handle);
-	pg_info->dbdriver = driver = db_start_driver(Fi->driver);
-	if (!driver) {
-	    G_warning(_("Unable to start driver <%s>"), Fi->driver);
-	    return -1;
-	db_set_handle(&handle, Fi->database, NULL);
-	if (db_open_database(driver, &handle) != DB_OK) {
-	    G_warning(_("Unable to open database <%s> by driver <%s>"),
-		      Fi->database, Fi->driver);
-	    db_close_database_shutdown_driver(driver);
-	    pg_info->dbdriver = NULL;
-	    return -1;
+        /* append attributes */
+        int col, ncols, sqltype, length, ctype;
+        char stmt_col[DB_SQL_MAX];
+        const char *colname;
-	/* describe table */
-	db_set_string(&dbstmt, "select * from ");
-	db_append_string(&dbstmt, Fi->table);
-	db_append_string(&dbstmt, " where 0 = 1");
-	if (db_open_select_cursor(driver, &dbstmt,
-				  &cursor, DB_SEQUENTIAL) != DB_OK) {
-	    G_warning(_("Unable to open select cursor: '%s'"),
-		      db_get_string(&dbstmt));
-	    return -1;
-	table = db_get_cursor_table(&cursor);
-	ncols = db_get_table_number_of_columns(table);
-	G_debug(3, "copying attributes: driver = %s database = %s table = %s cols = %d",
-		Fi->driver, Fi->database, Fi->table, ncols);
-	for (col = 0; col < ncols; col++) {
-	    column = db_get_table_column(table, col);
-	    colname = db_get_column_name(column);
-	    sqltype = db_get_column_sqltype(column);
-	    ctype = db_sqltype_to_Ctype(sqltype);
-	    length = db_get_column_length(column);
-	    G_debug(3, "\tcolumn = %d name = %s type = %d length = %d",
-		    col, colname, sqltype, length);
-	    if (strcmp(pg_info->fid_column, colname) == 0) {
-		/* skip fid column if exists */
-		G_debug(3, "\t%s skipped", pg_info->fid_column);
-		continue;
-	    /* append column */
-	    sprintf(stmt_col, ",%s %s", colname, db_sqltype_name(sqltype));
-	    strcat(stmt, stmt_col);
-	    if (ctype == DB_C_TYPE_STRING) {
-		/* length only for string columns */
-		sprintf(stmt_col, "(%d)", length);
+        dbString dbstmt;
+        dbHandle handle;
+        dbDriver *driver;
+        dbCursor cursor;
+        dbTable *table;
+        dbColumn *column;
-	db_free_string(&dbstmt);
+        db_init_string(&dbstmt);
+        db_init_handle(&handle);
+        pg_info->dbdriver = driver = db_start_driver(Fi->driver);
+        if (!driver) {
+            G_warning(_("Unable to start driver <%s>"), Fi->driver);
+            return -1;
+        db_set_handle(&handle, Fi->database, NULL);
+        if (db_open_database(driver, &handle) != DB_OK) {
+            G_warning(_("Unable to open database <%s> by driver <%s>"),
+                      Fi->database, Fi->driver);
+            db_close_database_shutdown_driver(driver);
+            pg_info->dbdriver = NULL;
+            return -1;
+        /* describe table */
+        db_set_string(&dbstmt, "select * from ");
+        db_append_string(&dbstmt, Fi->table);
+        db_append_string(&dbstmt, " where 0 = 1");
+        if (db_open_select_cursor(driver, &dbstmt,
+                                  &cursor, DB_SEQUENTIAL) != DB_OK) {
+            G_warning(_("Unable to open select cursor: '%s'"),
+                      db_get_string(&dbstmt));
+            return -1;
+        table = db_get_cursor_table(&cursor);
+        ncols = db_get_table_number_of_columns(table);
+        G_debug(3,
+                "copying attributes: driver = %s database = %s table = %s cols = %d",
+                Fi->driver, Fi->database, Fi->table, ncols);
+        for (col = 0; col < ncols; col++) {
+            column = db_get_table_column(table, col);
+            colname = db_get_column_name(column);
+            sqltype = db_get_column_sqltype(column);
+            ctype = db_sqltype_to_Ctype(sqltype);
+            length = db_get_column_length(column);
+            G_debug(3, "\tcolumn = %d name = %s type = %d length = %d",
+                    col, colname, sqltype, length);
+            if (strcmp(pg_info->fid_column, colname) == 0) {
+                /* skip fid column if exists */
+                G_debug(3, "\t%s skipped", pg_info->fid_column);
+                continue;
+            /* append column */
+            sprintf(stmt_col, ",%s %s", colname, db_sqltype_name(sqltype));
+            strcat(stmt, stmt_col);
+            if (ctype == DB_C_TYPE_STRING) {
+                /* length only for string columns */
+                sprintf(stmt_col, "(%d)", length);
+        db_free_string(&dbstmt);
-    strcat(stmt, ")"); /* close CREATE TABLE statement */
+    strcat(stmt, ")");          /* close CREATE TABLE statement */
     /* begin transaction (create table) */
     if (execute(pg_info->conn, "BEGIN") == -1) {
-	return -1;
+        return -1;
     /* create table */
-	return -1;
+        return -1;
     /* add primary key ? */
     if (primary_key) {
-	sprintf(stmt, "ALTER TABLE \"%s\".\"%s\" ADD PRIMARY KEY (%s)",
-	G_debug(2, "SQL: %s", stmt);
-	    return -1;
+        sprintf(stmt, "ALTER TABLE \"%s\".\"%s\" ADD PRIMARY KEY (%s)",
+                pg_info->fid_column);
+        G_debug(2, "SQL: %s", stmt);
+            return -1;
     /* determine geometry type (string) */
-    switch(pg_info->feature_type) {
+    switch (pg_info->feature_type) {
     case (SF_POINT):
-	geom_type = "POINT";
-	break;
+        geom_type = "POINT";
+        break;
     case (SF_LINESTRING):
-	geom_type = "LINESTRING";
-	break;
+        geom_type = "LINESTRING";
+        break;
     case (SF_POLYGON):
-	geom_type = "POLYGON";
-	break;
+        geom_type = "POLYGON";
+        break;
     default:
-	G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
-	return -1;
+        G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
+        return -1;
     sprintf(stmt, "SELECT AddGeometryColumn('%s', '%s', "
-	    "'%s', %d, '%s', %d)",
-	    pg_info->geom_column, pg_info->srid,
-	    geom_type, pg_info->coor_dim);
+            "'%s', %d, '%s', %d)",
+            pg_info->geom_column, pg_info->srid,
+            geom_type, pg_info->coor_dim);
-	PQclear(result);
-	return -1;
+        PQclear(result);
+        return -1;
     /* create index ? */
     if (spatial_index) {
-	sprintf(stmt, "CREATE INDEX %s_%s_idx ON \"%s\".\"%s\" USING GIST (%s)",
-		pg_info->table_name, pg_info->geom_column,
-	    return -1;
+        sprintf(stmt,
+                "CREATE INDEX %s_%s_idx ON \"%s\".\"%s\" USING GIST (%s)",
+                pg_info->table_name, pg_info->geom_column,
+            return -1;
     /* close transaction (create table) */
     if (execute(pg_info->conn, "COMMIT") == -1) {
-	return -1;
+        return -1;
     return 0;
 #endif
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/read_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -1,21 +1,21 @@
-  \file lib/vector/Vlib/read_pg.c
-  \brief Vector library - reading features (PostGIS format)
-  Higher level functions for reading/writing/manipulating vectors.
-  \todo Currently only points, linestrings and polygons are supported,
-  implement also other types
-  (C) 2011-2012 by the GRASS Development Team
-  This program is free software under the GNU General Public License
-  (>=v2). Read the file COPYING that comes with GRASS for details.
-  \author Martin Landa <landa.martin gmail.com>
+   \file lib/vector/Vlib/read_pg.c
+   \brief Vector library - reading features (PostGIS format)
+   Higher level functions for reading/writing/manipulating vectors.
+   \todo Currently only points, linestrings and polygons are supported,
+   implement also other types
+   (C) 2011-2012 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
+   \author Martin Landa <landa.martin gmail.com>
 #include <stdlib.h>
 #include <string.h>
 #include <limits.h>
@@ -28,21 +28,21 @@
 #include "pg_local_proto.h"
 static unsigned char *wkb_data;
-static unsigned int   wkb_data_length;
+static unsigned int wkb_data_length;
 static int read_next_line_pg(struct Map_info *,
-		      struct line_pnts *, struct line_cats *, int);
+                             struct line_pnts *, struct line_cats *, int);
 SF_FeatureType get_feature(struct Format_info_pg *, int);
 static unsigned char *hex_to_wkb(const char *, int *);
 static int point_from_wkb(const unsigned char *, int, int, int,
-			  struct line_pnts *);
+                          struct line_pnts *);
 static int linestring_from_wkb(const unsigned char *, int, int, int,
-			       struct line_pnts *, int);
+                               struct line_pnts *, int);
 static int polygon_from_wkb(const unsigned char *, int, int, int,
-			    struct Format_info_cache *, int *);
+                            struct Format_info_cache *, int *);
 static int geometry_collection_from_wkb(const unsigned char *, int, int, int,
-					struct feat_parts *);
+                                        struct feat_parts *);
 static int error_corrupted_data(const char *);
 static int set_initial_query();
 static void reallocate_cache(struct Format_info_cache *, int);
@@ -50,34 +50,33 @@
 #endif
-  \brief Read next feature from PostGIS layer. Skip
-  empty features (level 1 without topology).
-  t
-  This function implements sequential access.
-  The action of this routine can be modified by:
+   \brief Read next feature from PostGIS layer. Skip
+   empty features (level 1 without topology).
+   t
+   This function implements sequential access.
+   The action of this routine can be modified by:
    - Vect_read_constraint_region()
    - Vect_read_constraint_type()
    - Vect_remove_constraints()
-  \param[out] line_p container used to store line points within
-  (pointer to line_pnts struct)
-  \param[out] line_c container used to store line categories within
-  (pointer line_cats struct)
-  \return feature type
-  \return -2 no more features (EOF)
-  \return -1 out of memory
+   \param[out] line_p container used to store line points within
+   (pointer to line_pnts struct)
+   \param[out] line_c container used to store line categories within
+   (pointer line_cats struct)
+   \return feature type
+   \return -2 no more features (EOF)
+   \return -1 out of memory
 int V1_read_next_line_pg(struct Map_info *Map,
-			 struct line_pnts *line_p,
-			 struct line_cats *line_c)
+                         struct line_pnts *line_p, struct line_cats *line_c)
     G_debug(3, "V1_read_next_line_pg()");
-    /* constraints not ignored */
+    /* constraints not ignored */
     return read_next_line_pg(Map, line_p, line_c, FALSE);
 #else
@@ -86,196 +85,196 @@
-  \brief Read next feature from PostGIS layer on topological level.
+   \brief Read next feature from PostGIS layer on topological level.
-  (pointer to line_cats struct)
-  \return -1 on failure
+   (pointer to line_cats struct)
+   \return -1 on failure
 int V2_read_next_line_pg(struct Map_info *Map, struct line_pnts *line_p,
+                         struct line_cats *line_c)
     int line, ret;
     struct P_line *Line;
     struct bound_box lbox, mbox;
     G_debug(3, "V2_read_next_line_pg()");
     if (Map->constraint.region_flag)
-	Vect_get_constraint_box(Map, &mbox);
+        Vect_get_constraint_box(Map, &mbox);
     ret = -1;
-    while(TRUE) {
-	line = Map->next_line;
+    while (TRUE) {
+        line = Map->next_line;
-	if (Map->next_line > Map->plus.n_lines)
-	    return -2;
+        if (Map->next_line > Map->plus.n_lines)
+            return -2;
-	Line = Map->plus.Line[line];
-	if (Line == NULL) {	/* skip dead features */
-	    Map->next_line++;
-	    continue;
+        Line = Map->plus.Line[line];
+        if (Line == NULL) {     /* skip dead features */
+            Map->next_line++;
+            continue;
-	if (Map->constraint.type_flag) {
-	    /* skip by type */
-	    if (!(Line->type & Map->constraint.type)) {
-		Map->next_line++;
-		continue;
+        if (Map->constraint.type_flag) {
+            /* skip by type */
+            if (!(Line->type & Map->constraint.type)) {
+                Map->next_line++;
+                continue;
-	if (Line->type == GV_CENTROID) {
-	    G_debug(4, "Centroid");
-	    Map->next_line++;
-	    if (line_p != NULL) {
-		int i, found;
-		struct bound_box box;
-		struct boxlist list;
-		struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
-		/* get area bbox */
-		Vect_get_area_box(Map, topo->area, &box);
-		/* search in spatial index for centroid with area bbox */
-		dig_init_boxlist(&list, TRUE);
-		Vect_select_lines_by_box(Map, &box, Line->type, &list);
-		found = -1;
-		for (i = 0; i < list.n_values; i++) {
-		    if (list.id[i] == line) {
-			found = i;
-			break;
-		if (found > -1) {
-		    Vect_reset_line(line_p);
-		    Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
-	    if (line_c != NULL) {
-		/* cat = FID and offset = FID for centroid */
-		Vect_reset_cats(line_c);
-		Vect_cat_set(line_c, 1, (int) Line->offset);
+        if (Line->type == GV_CENTROID) {
+            G_debug(4, "Centroid");
-	    ret = GV_CENTROID;
-	else {
-	    /* ignore constraints, Map->next_line incremented */
-	    ret = read_next_line_pg(Map, line_p, line_c, TRUE);
-	    if (ret != Line->type)
-		G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
-			      ret, Line->type);
+            Map->next_line++;
-	if (Map->constraint.region_flag) {
-	    /* skip by region */
-	    Vect_line_box(line_p, &lbox);
-	    if (!Vect_box_overlap(&lbox, &mbox)) {
-		continue;
-	/* skip by field ignored */
-	return ret;
+            if (line_p != NULL) {
+                int i, found;
+                struct bound_box box;
+                struct boxlist list;
+                struct P_topo_c *topo = (struct P_topo_c *)Line->topo;
+                /* get area bbox */
+                Vect_get_area_box(Map, topo->area, &box);
+                /* search in spatial index for centroid with area bbox */
+                dig_init_boxlist(&list, TRUE);
+                Vect_select_lines_by_box(Map, &box, Line->type, &list);
+                found = -1;
+                for (i = 0; i < list.n_values; i++) {
+                    if (list.id[i] == line) {
+                        found = i;
+                        break;
+                if (found > -1) {
+                    Vect_reset_line(line_p);
+                    Vect_append_point(line_p, list.box[found].E,
+                                      list.box[found].N, 0.0);
+            if (line_c != NULL) {
+                /* cat = FID and offset = FID for centroid */
+                Vect_reset_cats(line_c);
+                Vect_cat_set(line_c, 1, (int)Line->offset);
+            ret = GV_CENTROID;
+        else {
+            /* ignore constraints, Map->next_line incremented */
+            ret = read_next_line_pg(Map, line_p, line_c, TRUE);
+            if (ret != Line->type)
+                G_fatal_error(_("Unexpected feature type (%s) - should be (%d)"),
+                              ret, Line->type);
+        if (Map->constraint.region_flag) {
+            /* skip by region */
+            Vect_line_box(line_p, &lbox);
+            if (!Vect_box_overlap(&lbox, &mbox)) {
+                continue;
+        /* skip by field ignored */
+        return ret;
 #else
 #endif
-    return -1; /* not reached */
+    return -1;                  /* not reached */
-  \brief Read feature from PostGIS layer at given offset (level 1 without topology)
-  This function implements random access on level 1.
+   \brief Read feature from PostGIS layer at given offset (level 1 without topology)
-  (pointer line_pnts struct)
-  \param offset given offset
-  \return line type
-  \return 0 dead line
+   This function implements random access on level 1.
+   (pointer line_pnts struct)
+   \param offset given offset
+   \return line type
+   \return 0 dead line
 int V1_read_line_pg(struct Map_info *Map,
-		    struct line_pnts *line_p, struct line_cats *line_c, off_t offset)
+                    struct line_pnts *line_p, struct line_cats *line_c,
+                    off_t offset)
     long fid;
-    int  ipart, type;
-    struct Format_info_pg     *pg_info;
+    int ipart, type;
+    struct Format_info_pg *pg_info;
     G_debug(3, "V1_read_line_pg(): offset = %lu offset_num = %lu",
-	    (long) offset, (long) pg_info->offset.array_num);
+            (long)offset, (long)pg_info->offset.array_num);
     if (offset >= pg_info->offset.array_num)
-	return -2; /* nothing to read */
+        return -2;              /* nothing to read */
     if (line_p != NULL)
     if (line_c != NULL)
     fid = pg_info->offset.array[offset];
     G_debug(4, "  fid = %ld", fid);
     /* read feature to cache if necessary */
     if (pg_info->cache.fid != fid) {
-	int type;
-	G_debug(3, "read (%s) feature (fid = %ld) to cache",
-		pg_info->table_name, fid);
-	get_feature(pg_info, fid);
-	if (pg_info->cache.sf_type == SF_NONE) {
-	    G_warning(_("Feature %d without geometry skipped"), fid);
-	    return -1;
-	type = (int) pg_info->cache.sf_type;
-	if (type < 0) /* -1 || - 2 */
-	    return type;
+        int type;
+        G_debug(3, "read (%s) feature (fid = %ld) to cache",
+                pg_info->table_name, fid);
+        get_feature(pg_info, fid);
+        if (pg_info->cache.sf_type == SF_NONE) {
+            G_warning(_("Feature %d without geometry skipped"), fid);
+            return -1;
+        type = (int)pg_info->cache.sf_type;
+        if (type < 0)           /* -1 || - 2 */
+            return type;
     /* get data from cache */
     if (pg_info->cache.sf_type == SF_POINT ||
-	pg_info->cache.sf_type == SF_LINESTRING)
-	ipart = 0;
-    else
-	ipart = pg_info->offset.array[offset + 1];
-    type  = pg_info->cache.lines_types[ipart];
-    G_debug(3, "read feature part: %d -> type = %d",
-	    ipart, type);
+        pg_info->cache.sf_type == SF_LINESTRING)
+        ipart = 0;
+    else
+        ipart = pg_info->offset.array[offset + 1];
+    type = pg_info->cache.lines_types[ipart];
+    G_debug(3, "read feature part: %d -> type = %d", ipart, type);
     if (line_p)
-	Vect_append_points(line_p,
-			   pg_info->cache.lines[ipart], GV_FORWARD);
+        Vect_append_points(line_p, pg_info->cache.lines[ipart], GV_FORWARD);
     if (line_c)
-	Vect_cat_set(line_c, 1, (int) fid);
+        Vect_cat_set(line_c, 1, (int)fid);
     return type;
 #else
@@ -285,552 +284,561 @@
-  \param ignore_constraints TRUE to ignore constraints (type, region)
+   \param ignore_constraints TRUE to ignore constraints (type, region)
 int read_next_line_pg(struct Map_info *Map,
-		      int ignore_constraints)
+                      int ignore_constraints)
     int line, itype;
     struct bound_box mbox, lbox;
     struct line_pnts *iline;
     if (Map->constraint.region_flag && !ignore_constraints)
     while (TRUE) {
-	line = Map->next_line++; /* level 2 only */
-	/* reset data structures */
+        line = Map->next_line++;        /* level 2 only */
-	/* read feature to cache if necessary */
-	while (pg_info->cache.lines_next == pg_info->cache.lines_num) {
-	    /* cache feature -> line_p & line_c */
-	    sf_type = get_feature(pg_info, -1);
-	    if (sf_type == SF_NONE) {
-			  line);
-		return -1;
+        /* reset data structures */
-	    if ((int) sf_type < 0) /* -1 || - 2 */
-		return (int) sf_type;
+        /* read feature to cache if necessary */
+        while (pg_info->cache.lines_next == pg_info->cache.lines_num) {
+            /* cache feature -> line_p & line_c */
+            sf_type = get_feature(pg_info, -1);
-	    if (sf_type == SF_UNKNOWN || sf_type == SF_NONE) {
-		G_warning(_("Feature without geometry. Skipped."));
-		pg_info->cache.lines_next = pg_info->cache.lines_num = 0;
-		continue;
-	    G_debug(4, "%d lines read to cache", pg_info->cache.lines_num);
-	/* get data from cache */
-	itype = pg_info->cache.lines_types[pg_info->cache.lines_next];
-	iline = pg_info->cache.lines[pg_info->cache.lines_next];
-	G_debug(4, "read next cached line %d (type = %d)",
-		pg_info->cache.lines_next, itype);
+            if (sf_type == SF_NONE) {
+                G_warning(_("Feature %d without geometry skipped"), line);
+                return -1;
-	/* apply constraints */
-	if (Map->constraint.type_flag && !ignore_constraints) {
-	    /* skip feature by type */
-	    if (!(itype & Map->constraint.type))
-		continue;
+            if ((int)sf_type < 0)       /* -1 || - 2 */
+                return (int)sf_type;
-	if (line_p && Map->constraint.region_flag &&
-	    !ignore_constraints) {
-	    /* skip feature by region */
-	    Vect_line_box(iline, &lbox);
-		continue;
-	/* skip feature by field ignored */
-	if (line_p)
-	    Vect_append_points(line_p, iline, GV_FORWARD);
-	if (line_c)
-	    Vect_cat_set(line_c, 1, (int) pg_info->cache.fid);
-	pg_info->cache.lines_next++;
-	return itype;
+            if (sf_type == SF_UNKNOWN || sf_type == SF_NONE) {
+                G_warning(_("Feature without geometry. Skipped."));
+                pg_info->cache.lines_next = pg_info->cache.lines_num = 0;
+                continue;
+            G_debug(4, "%d lines read to cache", pg_info->cache.lines_num);
+        /* get data from cache */
+        itype = pg_info->cache.lines_types[pg_info->cache.lines_next];
+        iline = pg_info->cache.lines[pg_info->cache.lines_next];
+        G_debug(4, "read next cached line %d (type = %d)",
+                pg_info->cache.lines_next, itype);
+        /* apply constraints */
+        if (Map->constraint.type_flag && !ignore_constraints) {
+            /* skip feature by type */
+            if (!(itype & Map->constraint.type))
+                continue;
+        if (line_p && Map->constraint.region_flag && !ignore_constraints) {
+            /* skip feature by region */
+            Vect_line_box(iline, &lbox);
+                continue;
+        /* skip feature by field ignored */
+        if (line_p)
+            Vect_append_points(line_p, iline, GV_FORWARD);
+        if (line_c)
+            Vect_cat_set(line_c, 1, (int)pg_info->cache.fid);
+        pg_info->cache.lines_next++;
+        return itype;
-  \brief Read feature geometry
+   \brief Read feature geometry
-  Geometry is stored in lines cache.
-  \param[in,out] pg_info pointer to Format_info_pg struct
-  \param fid feature id to be read (-1 for next)
-  \param[out] line_c pointer to line_cats structure (or NULL)
+   Geometry is stored in lines cache.
-  \return simple feature type (SF_POINT, SF_LINESTRING, ...)
-  \return -1 on error
-SF_FeatureType get_feature(struct Format_info_pg *pg_info, int fid)
+   \param[in,out] pg_info pointer to Format_info_pg struct
+   \param fid feature id to be read (-1 for next)
+   \param[out] line_c pointer to line_cats structure (or NULL)
+   \return simple feature type (SF_POINT, SF_LINESTRING, ...)
+   \return -1 on error
+SF_FeatureType get_feature(struct Format_info_pg * pg_info, int fid)
     char *data;
-	G_warning(_("No geometry column defined"));
-	return -1;
+        G_warning(_("No geometry column defined"));
+        return -1;
     if (fid < 1) {
-	/* next (read n features) */
-	if (!pg_info->res) {
-	    if (set_initial_query(pg_info) == -1)
-		return -1;
+        /* next (read n features) */
+        if (!pg_info->res) {
+            if (set_initial_query(pg_info) == -1)
+                return -1;
     else {
-	if (!pg_info->fid_column) {
-	    G_warning(_("Random access not supported. "
-			"Primary key not defined."));
-	    return -1;
-	if (execute(pg_info->conn, "BEGIN") == -1)
-	    return -1;
-	sprintf(stmt, "DECLARE %s_%s%p CURSOR FOR SELECT %s FROM \"%s\".\"%s\" "
-		"WHERE %s = %d",
-		pg_info->schema_name, pg_info->table_name, pg_info->conn,
-		pg_info->geom_column, pg_info->schema_name,
-		pg_info->table_name, pg_info->fid_column, fid);
+        if (!pg_info->fid_column) {
+            G_warning(_("Random access not supported. "
+                        "Primary key not defined."));
+            return -1;
-	    return -1;
-	sprintf(stmt, "FETCH ALL in %s_%s%p",
-	pg_info->res = PQexec(pg_info->conn, stmt);
-	pg_info->next_line = 0;
+        if (execute(pg_info->conn, "BEGIN") == -1)
+            return -1;
+        sprintf(stmt,
+                "DECLARE %s_%s%p CURSOR FOR SELECT %s FROM \"%s\".\"%s\" "
+                "WHERE %s = %d", pg_info->schema_name, pg_info->table_name,
+                pg_info->conn, pg_info->geom_column, pg_info->schema_name,
+                pg_info->table_name, pg_info->fid_column, fid);
+            return -1;
+        sprintf(stmt, "FETCH ALL in %s_%s%p",
+        pg_info->res = PQexec(pg_info->conn, stmt);
+        pg_info->next_line = 0;
     if (!pg_info->res || PQresultStatus(pg_info->res) != PGRES_TUPLES_OK) {
-	return -1; /* reading failed */
+        return -1;              /* reading failed */
     /* do we need to fetch more records ? */
     if (PQntuples(pg_info->res) == CURSOR_PAGE &&
         PQntuples(pg_info->res) == pg_info->next_line) {
-	sprintf(stmt, "FETCH %d in %s_%s%p", CURSOR_PAGE,
-	    return -1;
+        sprintf(stmt, "FETCH %d in %s_%s%p", CURSOR_PAGE,
+            return -1;
     /* out of results ? */
     if (PQntuples(pg_info->res) == pg_info->next_line) {
-	if (pg_info->res) {
-		return -1;
-	return -2;
+        if (pg_info->res) {
+                return -1;
+        return -2;
     data = (char *)PQgetvalue(pg_info->res, pg_info->next_line, 0);
-    pg_info->cache.sf_type = cache_feature(data, FALSE, &(pg_info->cache), NULL);
+        cache_feature(data, FALSE, &(pg_info->cache), NULL);
     if (fid < 0) {
-	pg_info->cache.fid = atoi(PQgetvalue(pg_info->res, pg_info->next_line, 1));
-	pg_info->next_line++;
+        pg_info->cache.fid =
+            atoi(PQgetvalue(pg_info->res, pg_info->next_line, 1));
+        pg_info->next_line++;
     else {
-	pg_info->cache.fid = fid;
+        pg_info->cache.fid = fid;
-	    return -1;
-	if (execute(pg_info->conn, "COMMIT") == -1)
-	    return -1;
+            return -1;
+        if (execute(pg_info->conn, "COMMIT") == -1)
+            return -1;
     return pg_info->cache.sf_type;
-  \brief Convert HEX to WKB data
+   \brief Convert HEX to WKB data
-  \param hex_data HEX data
-  \param[out] nbytes number of bytes in output buffer
+   \param hex_data HEX data
+   \param[out] nbytes number of bytes in output buffer
-  \return pointer to WKB data buffer
+   \return pointer to WKB data buffer
 unsigned char *hex_to_wkb(const char *hex_data, int *nbytes)
     unsigned int length;
     int i;
     length = strlen(hex_data) / 2 + 1;
     if (length > wkb_data_length) {
-	wkb_data_length = length;
-	wkb_data = G_realloc(wkb_data, wkb_data_length);
+        wkb_data_length = length;
+        wkb_data = G_realloc(wkb_data, wkb_data_length);
     *nbytes = length - 1;
     for (i = 0; i < (*nbytes); i++) {
-        wkb_data[i] = (unsigned char) ((hex_data[2 * i] > 'F' ? hex_data[2 * i] - 0x57 :
-					hex_data[2 * i] > '9' ? hex_data[2 * i] - 0x37 :
-					hex_data[2 * i] - 0x30) << 4);
-        wkb_data[i] |= (unsigned char) (hex_data[2 * i + 1] > 'F' ? hex_data[2 * i + 1] - 0x57 :
-					hex_data[2 * i + 1] > '9' ? hex_data[2 * i + 1] - 0x37 :
-					hex_data[2 * i + 1] - 0x30);
+        wkb_data[i] =
+            (unsigned
+             char)((hex_data[2 * i] >
+                    'F' ? hex_data[2 * i] - 0x57 : hex_data[2 * i] >
+                    '9' ? hex_data[2 * i] - 0x37 : hex_data[2 * i] -
+                    0x30) << 4);
+        wkb_data[i] |=
+            (unsigned char)(hex_data[2 * i + 1] >
+                            'F' ? hex_data[2 * i + 1] -
+                            0x57 : hex_data[2 * i + 1] >
+                            '9' ? hex_data[2 * i + 1] -
+                            0x37 : hex_data[2 * i + 1] - 0x30);
     wkb_data[(*nbytes)] = 0;
     return wkb_data;
-  \brief Read geometry from HEX data
+   \brief Read geometry from HEX data
-  This code is inspired by OGRGeometryFactory::createFromWkb() from
-  GDAL/OGR library.
+   This code is inspired by OGRGeometryFactory::createFromWkb() from
+   GDAL/OGR library.
-  \param data HEX data
-  \param skip_polygon skip polygons (level 1)
-  \param[out] cache lines cache
-  \param[out] fparts used for building pseudo-topology (or NULL)
-  \return SF_UNKNOWN on error
+   \param data HEX data
+   \param skip_polygon skip polygons (level 1)
+   \param[out] cache lines cache
+   \param[out] fparts used for building pseudo-topology (or NULL)
+   \return SF_UNKNOWN on error
 SF_FeatureType cache_feature(const char *data, int skip_polygon,
-			     struct Format_info_cache *cache,
-			     struct feat_parts *fparts)
+                             struct Format_info_cache * cache,
+                             struct feat_parts * fparts)
     int ret, byte_order, nbytes, is3D;
     unsigned int wkb_flags;
     SF_FeatureType ftype;
     /* reset cache */
     cache->lines_num = 0;
-    cache->fid       = -1;
+    cache->fid = -1;
     /* next to be read from cache */
     cache->lines_next = 0;
     if (fparts)
-	fparts->n_parts = 0;
+        fparts->n_parts = 0;
     wkb_flags = 0;
-    wkb_data  = hex_to_wkb(data, &nbytes);
+    wkb_data = hex_to_wkb(data, &nbytes);
     if (nbytes < 5) {
-	/* G_free(wkb_data); */
-	if (nbytes > 0) {
-	    G_debug(3, "cache_feature(): invalid geometry");
-	    G_warning(_("Invalid WKB content: %d bytes"), nbytes);
-	    return SF_UNKNOWN;
-	else {
-	    G_debug(3, "cache_feature(): no geometry");
-	    return SF_NONE;
+        /* G_free(wkb_data); */
+        if (nbytes > 0) {
+            G_debug(3, "cache_feature(): invalid geometry");
+            G_warning(_("Invalid WKB content: %d bytes"), nbytes);
+            return SF_UNKNOWN;
+        else {
+            G_debug(3, "cache_feature(): no geometry");
+            return SF_NONE;
     /* parsing M coordinate not supported */
     memcpy(&wkb_flags, wkb_data + 1, 4);
     byte_order = (wkb_data[0] == 0 ? ENDIAN_BIG : ENDIAN_LITTLE);
     if (byte_order == ENDIAN_BIG)
-	wkb_flags = SWAP32(wkb_flags);
+        wkb_flags = SWAP32(wkb_flags);
     if (wkb_flags & 0x40000000) {
         G_warning(_("Reading EWKB with 4-dimensional coordinates (XYZM) "
-		    "is not supported"));
+                    "is not supported"));
     /* PostGIS EWKB format includes an  SRID, but this won't be
        understood by OGR, so if the SRID flag is set, we remove the
        SRID (bytes at offset 5 to 8).
     if (nbytes > 9 &&
         ((byte_order == ENDIAN_BIG && (wkb_data[1] & 0x20)) ||
-	 (byte_order == ENDIAN_LITTLE && (wkb_data[4] & 0x20)))) {
-        memmove(wkb_data + 5, wkb_data + 9, nbytes -9);
+         (byte_order == ENDIAN_LITTLE && (wkb_data[4] & 0x20)))) {
+        memmove(wkb_data + 5, wkb_data + 9, nbytes - 9);
         nbytes -= 4;
-        if(byte_order == ENDIAN_BIG)
+        if (byte_order == ENDIAN_BIG)
             wkb_data[1] &= (~0x20);
         else
             wkb_data[4] &= (~0x20);
     if (nbytes < 9 && nbytes != -1) {
-   /* Get the geometry feature type. For now we assume that geometry
-      type is between 0 and 255 so we only have to fetch one byte.
+    /* Get the geometry feature type. For now we assume that geometry
+       type is between 0 and 255 so we only have to fetch one byte.
     if (byte_order == ENDIAN_LITTLE) {
         ftype = (SF_FeatureType) wkb_data[1];
-	is3D = wkb_data[4] & 0x80 || wkb_data[2] & 0x80;
+        is3D = wkb_data[4] & 0x80 || wkb_data[2] & 0x80;
     else {
         ftype = (SF_FeatureType) wkb_data[4];
-	is3D = wkb_data[1] & 0x80 || wkb_data[3] & 0x80;
+        is3D = wkb_data[1] & 0x80 || wkb_data[3] & 0x80;
     G_debug(3, "cache_feature(): sf_type = %d", ftype);
     /* allocate space in lines cache - be minimalistic
        more lines require eg. polygon with more rings, multi-features
        or geometry collections
     if (!cache->lines) {
-	reallocate_cache(cache, 1);
+        reallocate_cache(cache, 1);
     ret = -1;
     if (ftype == SF_POINT) {
-	cache->lines_num = 1;
-	cache->lines_types[0] = GV_POINT;
-	ret = point_from_wkb(wkb_data, nbytes, byte_order,
-			     is3D, cache->lines[0]);
-	add_fpart(fparts, ftype, 0, 1);
+        cache->lines_num = 1;
+        cache->lines_types[0] = GV_POINT;
+        ret = point_from_wkb(wkb_data, nbytes, byte_order,
+                             is3D, cache->lines[0]);
+        add_fpart(fparts, ftype, 0, 1);
     else if (ftype == SF_LINESTRING) {
-	cache->lines_types[0] = GV_LINE;
-	ret = linestring_from_wkb(wkb_data, nbytes, byte_order,
-				  is3D, cache->lines[0], FALSE);
+        cache->lines_types[0] = GV_LINE;
+        ret = linestring_from_wkb(wkb_data, nbytes, byte_order,
+                                  is3D, cache->lines[0], FALSE);
     else if (ftype == SF_POLYGON && !skip_polygon) {
-	int nrings;
-	ret = polygon_from_wkb(wkb_data, nbytes, byte_order,
-			       is3D, cache, &nrings);
-	add_fpart(fparts, ftype, 0, nrings);
+        int nrings;
+        ret = polygon_from_wkb(wkb_data, nbytes, byte_order,
+                               is3D, cache, &nrings);
+        add_fpart(fparts, ftype, 0, nrings);
     else if (ftype == SF_MULTIPOINT ||
-	     ftype == SF_MULTILINESTRING ||
-	     ftype == SF_MULTIPOLYGON ||
-	     ftype == SF_GEOMETRYCOLLECTION) {
-	ret = geometry_collection_from_wkb(wkb_data, nbytes, byte_order,
-					   is3D, cache, fparts);
+             ftype == SF_MULTILINESTRING ||
+             ftype == SF_MULTIPOLYGON || ftype == SF_GEOMETRYCOLLECTION) {
+        ret = geometry_collection_from_wkb(wkb_data, nbytes, byte_order,
+                                           is3D, cache, fparts);
-    else  {
-	G_warning(_("Unsupported feature type %d"), ftype);
+    else {
+        G_warning(_("Unsupported feature type %d"), ftype);
     /* read next feature from cache */
     return ret > 0 ? ftype : SF_UNKNOWN;
-  \brief Read point for WKB data
+   \brief Read point for WKB data
-  See OGRPoint::importFromWkb() from GDAL/OGR library
+   See OGRPoint::importFromWkb() from GDAL/OGR library
-  \param wkb_data WKB data
-  \param nbytes number of bytes (WKB data buffer)
-  \param byte_order byte order (ENDIAN_LITTLE, ENDIAN_BIG)
-  \param with_z WITH_Z for 3D data
-  \param[out] line_p point geometry (pointer to line_pnts struct)
+   \param wkb_data WKB data
+   \param nbytes number of bytes (WKB data buffer)
+   \param byte_order byte order (ENDIAN_LITTLE, ENDIAN_BIG)
+   \param with_z WITH_Z for 3D data
+   \param[out] line_p point geometry (pointer to line_pnts struct)
-  \return wkb size
+   \return wkb size
 int point_from_wkb(const unsigned char *wkb_data, int nbytes, int byte_order,
-		    int with_z, struct line_pnts *line_p)
+                   int with_z, struct line_pnts *line_p)
     double x, y, z;
-    if (nbytes < 21 && nbytes != -1 )
-	return -1;
+    if (nbytes < 21 && nbytes != -1)
+        return -1;
     /* get vertex */
     memcpy(&x, wkb_data + 5, 8);
     memcpy(&y, wkb_data + 5 + 8, 8);
     if (byte_order == ENDIAN_BIG) {
         SWAPDOUBLE(&x);
         SWAPDOUBLE(&y);
     if (with_z) {
-        if (nbytes < 29 && nbytes != -1 )
+        if (nbytes < 29 && nbytes != -1)
             return -1;
         memcpy(&z, wkb_data + 5 + 16, 8);
-	if (byte_order == ENDIAN_BIG) {
-	    SWAPDOUBLE(&z);
+        if (byte_order == ENDIAN_BIG) {
+            SWAPDOUBLE(&z);
     else {
         z = 0.0;
     if (line_p) {
-	Vect_append_point(line_p, x, y, z);
+        Vect_append_point(line_p, x, y, z);
     return 5 + 8 * (with_z == WITH_Z ? 3 : 2);
-  \brief Read line for WKB data
+   \brief Read line for WKB data
-  See OGRLineString::importFromWkb() from GDAL/OGR library
+   See OGRLineString::importFromWkb() from GDAL/OGR library
-  \param[out] line_p line geometry (pointer to line_pnts struct)
+   \param[out] line_p line geometry (pointer to line_pnts struct)
-  \return wkb size
-int linestring_from_wkb(const unsigned char *wkb_data, int nbytes, int byte_order,
-			int with_z, struct line_pnts *line_p, int is_ring)
+   \return wkb size
+int linestring_from_wkb(const unsigned char *wkb_data, int nbytes,
+                        int byte_order, int with_z, struct line_pnts *line_p,
+                        int is_ring)
     int npoints, point_size, buff_min_size, offset;
     int i;
     double x, y, z;
     if (is_ring)
-	offset = 5;
+        offset = 5;
     else
-	offset = 0;
+        offset = 0;
     if (is_ring && nbytes < 4 && nbytes != -1)
         return error_corrupted_data(NULL);
     /* get the vertex count */
     memcpy(&npoints, wkb_data + (5 - offset), 4);
-       npoints = SWAP32(npoints);
+        npoints = SWAP32(npoints);
     /* check if the wkb stream buffer is big enough to store fetched
        number of points.  16 or 24 - size of point structure
     point_size = with_z ? 24 : 16;
     if (npoints < 0 || npoints > INT_MAX / point_size)
     buff_min_size = point_size * npoints;
     if (nbytes != -1 && buff_min_size > nbytes - (9 - offset))
         return error_corrupted_data(_("Length of input WKB is too small"));
     if (line_p)
     /* get the vertex */
     for (i = 0; i < npoints; i++) {
-	memcpy(&x, wkb_data + (9 - offset) + i * point_size, 8);
-	memcpy(&y, wkb_data + (9 - offset) + 8 + i * point_size, 8);
-	if (with_z)
+        memcpy(&x, wkb_data + (9 - offset) + i * point_size, 8);
+        memcpy(&y, wkb_data + (9 - offset) + 8 + i * point_size, 8);
+        if (with_z)
             memcpy(&z, wkb_data + (9 - offset) + 16 + i * point_size, 8);
         else
-	    z = 0.0;
+            z = 0.0;
-	    SWAPDOUBLE(&x);
-	    SWAPDOUBLE(&y);
-	    if (with_z)
-		SWAPDOUBLE(&z);
-	if (line_p)
+            SWAPDOUBLE(&x);
+            SWAPDOUBLE(&y);
+            if (with_z)
+                SWAPDOUBLE(&z);
+        if (line_p)
     return (9 - offset) + (with_z == WITH_Z ? 3 : 2) * 8 * line_p->n_points;
-  \brief Read polygon for WKB data
+   \brief Read polygon for WKB data
-  See OGRPolygon::importFromWkb() from GDAL/OGR library
+   See OGRPolygon::importFromWkb() from GDAL/OGR library
-  \param[out] line_p array of rings (pointer to line_pnts struct)
-  \param[out] nrings number of rings
-  \return wkb size
-int polygon_from_wkb(const unsigned char *wkb_data, int nbytes, int byte_order,
-		     int with_z, struct Format_info_cache *cache, int *nrings)
+   \param[out] line_p array of rings (pointer to line_pnts struct)
+   \param[out] nrings number of rings
+   \return wkb size
+int polygon_from_wkb(const unsigned char *wkb_data, int nbytes,
+                     struct Format_info_cache *cache, int *nrings)
     int data_offset, i, nsize, isize;
     struct line_pnts *line_i;
-	return -1;
+        return -1;
     /* get the ring count */
     memcpy(nrings, wkb_data + 5, 4);
@@ -839,11 +847,11 @@
     if (*nrings < 0) {
         return -1;
     /* reallocate space for islands if needed */
     reallocate_cache(cache, *nrings);
     cache->lines_num += *nrings;
     /* each ring has a minimum of 4 bytes (point count) */
     if (nbytes != -1 && nbytes - 9 < (*nrings) * 4) {
@@ -852,60 +860,61 @@
     data_offset = 9;
     if (nbytes != -1)
         nbytes -= data_offset;
     /* get the rings */
     nsize = 9;
-    for (i = 0; i < (*nrings); i++ ) {
-	if (cache->lines_next >= cache->lines_num)
-	    G_fatal_error(_("Invalid cache index %d (max: %d)"),
-			  cache->lines_next, cache->lines_num);
-	line_i = cache->lines[cache->lines_next];
-	cache->lines_types[cache->lines_next++] = GV_BOUNDARY;
-	linestring_from_wkb(wkb_data + data_offset, nbytes, byte_order,
-			    with_z, line_i, TRUE);
+    for (i = 0; i < (*nrings); i++) {
+        if (cache->lines_next >= cache->lines_num)
+            G_fatal_error(_("Invalid cache index %d (max: %d)"),
+                          cache->lines_next, cache->lines_num);
+        line_i = cache->lines[cache->lines_next];
+        cache->lines_types[cache->lines_next++] = GV_BOUNDARY;
+        linestring_from_wkb(wkb_data + data_offset, nbytes, byte_order,
+                            with_z, line_i, TRUE);
         if (nbytes != -1) {
-	    isize = 4 + 8 * (with_z == WITH_Z ? 3 : 2) * line_i->n_points;
-	    nbytes -= isize;
-	nsize += isize;
+            isize = 4 + 8 * (with_z == WITH_Z ? 3 : 2) * line_i->n_points;
+            nbytes -= isize;
+        nsize += isize;
         data_offset += isize;
     return nsize;
-  \brief Read geometry collection for WKB data
+   \brief Read geometry collection for WKB data
-  See OGRGeometryCollection::importFromWkbInternal() from GDAL/OGR library
+   See OGRGeometryCollection::importFromWkbInternal() from GDAL/OGR library
-  \param ipart part to cache (starts at 0)
-  \param[in,out] fparts feature parts (required for building pseudo-topology)
+   \param ipart part to cache (starts at 0)
+   \param[in,out] fparts feature parts (required for building pseudo-topology)
-  \return number of parts
-int geometry_collection_from_wkb(const unsigned char *wkb_data, int nbytes, int byte_order,
+   \return number of parts
+int geometry_collection_from_wkb(const unsigned char *wkb_data, int nbytes,
+                                 struct feat_parts *fparts)
     int ipart, nparts, data_offset, nsize;
     unsigned char *wkb_subdata;
-       return error_corrupted_data(NULL);
+        return error_corrupted_data(NULL);
     /* get the geometry count */
-    memcpy(&nparts, wkb_data + 5, 4 );
+    memcpy(&nparts, wkb_data + 5, 4);
         nparts = SWAP32(nparts);
@@ -913,7 +922,7 @@
     G_debug(5, "\t(geometry collections) parts: %d", nparts);
     /* each geometry has a minimum of 9 bytes */
     if (nbytes != -1 && nbytes - 9 < nparts * 9) {
@@ -925,133 +934,133 @@
     /* reallocate space for parts if needed */
     reallocate_cache(cache, nparts);
     /* get parts */
     for (ipart = 0; ipart < nparts; ipart++) {
-	wkb_subdata = (unsigned char *)wkb_data + data_offset;
-	if (nbytes < 9 && nbytes != -1)
-	if (byte_order == ENDIAN_LITTLE) {
-	    ftype = (SF_FeatureType) wkb_subdata[1];
-	else {
-	    ftype = (SF_FeatureType) wkb_subdata[4];
-	if (ftype == SF_POINT) {
-	    cache->lines_types[cache->lines_next] = GV_POINT;
-	    nsize = point_from_wkb(wkb_subdata, nbytes, byte_order, with_z,
-				   cache->lines[cache->lines_next]);
-	    cache->lines_num++;
-	    add_fpart(fparts, ftype, cache->lines_next, 1);
-	    cache->lines_next++;
-	else if (ftype == SF_LINESTRING) {
-	    cache->lines_types[cache->lines_next] = GV_LINE;
-	    nsize = linestring_from_wkb(wkb_subdata, nbytes, byte_order, with_z,
-					cache->lines[cache->lines_next],
-					FALSE);
-	else if (ftype == SF_POLYGON) {
-	    int idx, nrings;
+        wkb_subdata = (unsigned char *)wkb_data + data_offset;
+        if (nbytes < 9 && nbytes != -1)
-	    idx = cache->lines_next;
-	    nsize = polygon_from_wkb(wkb_subdata, nbytes, byte_order,
-				     with_z, cache, &nrings);
-	    add_fpart(fparts, ftype, idx, nrings);
-	else if (ftype == SF_GEOMETRYCOLLECTION ||
-		 ftype == SF_MULTIPOLYGON) {
-	    geometry_collection_from_wkb(wkb_subdata, nbytes, byte_order,
-					 with_z, cache, fparts);
-	else  {
+        if (byte_order == ENDIAN_LITTLE) {
+            ftype = (SF_FeatureType) wkb_subdata[1];
+        else {
+            ftype = (SF_FeatureType) wkb_subdata[4];
+        if (ftype == SF_POINT) {
+            cache->lines_types[cache->lines_next] = GV_POINT;
+            nsize = point_from_wkb(wkb_subdata, nbytes, byte_order, with_z,
+                                   cache->lines[cache->lines_next]);
+            cache->lines_num++;
+            add_fpart(fparts, ftype, cache->lines_next, 1);
+            cache->lines_next++;
+        else if (ftype == SF_LINESTRING) {
+            cache->lines_types[cache->lines_next] = GV_LINE;
+            nsize =
+                linestring_from_wkb(wkb_subdata, nbytes, byte_order, with_z,
+                                    cache->lines[cache->lines_next], FALSE);
+        else if (ftype == SF_POLYGON) {
+            int idx, nrings;
+            idx = cache->lines_next;
+            nsize = polygon_from_wkb(wkb_subdata, nbytes, byte_order,
+                                     with_z, cache, &nrings);
+            add_fpart(fparts, ftype, idx, nrings);
+        else if (ftype == SF_GEOMETRYCOLLECTION ||
+                 ftype == SF_MULTILINESTRING || ftype == SF_MULTIPOLYGON) {
+            geometry_collection_from_wkb(wkb_subdata, nbytes, byte_order,
+                                         with_z, cache, fparts);
+        else {
         if (nbytes != -1) {
-	    nbytes -= nsize;
+            nbytes -= nsize;
         data_offset += nsize;
     return nparts;
-  \brief Report error message
+   \brief Report error message
-  \param msg message (NULL)
+   \param msg message (NULL)
-  \return -1
+   \return -1
 int error_corrupted_data(const char *msg)
     if (msg)
-	G_warning(_("Corrupted data. %s."), msg);
+        G_warning(_("Corrupted data. %s."), msg);
     else
-	G_warning(_("Corrupted data"));
+        G_warning(_("Corrupted data"));
     return -1;
-  \brief Set initial SQL query for sequential access
+   \brief Set initial SQL query for sequential access
-  \param pg_info pointer to Format_info_pg struct
+   \param pg_info pointer to Format_info_pg struct
 int set_initial_query(struct Format_info_pg *pg_info)
-	return -1;
-    sprintf(stmt, "DECLARE %s_%s%p CURSOR FOR SELECT %s,%s FROM \"%s\".\"%s\"",
-	    pg_info->geom_column, pg_info->fid_column,
+        return -1;
+    sprintf(stmt,
+            "DECLARE %s_%s%p CURSOR FOR SELECT %s,%s FROM \"%s\".\"%s\"",
+            pg_info->schema_name, pg_info->table_name, pg_info->conn,
+            pg_info->geom_column, pg_info->fid_column, pg_info->schema_name,
-	return -1;
+        return -1;
-	return -1;
+        return -1;
     return 0;
-  \brief Execute SQL statement
+   \brief Execute SQL statement
-  See pg_local_proto.h
+   See pg_local_proto.h
-  \param conn pointer to PGconn
-  \param stmt query
+   \param conn pointer to PGconn
+   \param stmt query
-int execute(PGconn *conn, const char *stmt)
+int execute(PGconn * conn, const char *stmt)
     PGresult *result;
@@ -1060,10 +1069,10 @@
     G_debug(3, "execute(): %s", stmt);
     result = PQexec(conn, stmt);
     if (!result || PQresultStatus(result) != PGRES_COMMAND_OK) {
-	PQclear(result);
+        PQclear(result);
-	G_warning(_("Execution failed: %s"), PQerrorMessage(conn));
-	return -1;
+        G_warning(_("Execution failed: %s"), PQerrorMessage(conn));
+        return -1;
     PQclear(result);
@@ -1071,66 +1080,66 @@
-  \brief Reallocate lines cache
+   \brief Reallocate lines cache
 void reallocate_cache(struct Format_info_cache *cache, int num)
     int i;
     if (cache->lines_alloc >= num)
-	return;
+        return;
-	/* most of features requires only one line cache */
-	cache->lines_alloc = 1;
+        /* most of features requires only one line cache */
+        cache->lines_alloc = 1;
     else {
-	cache->lines_alloc += 20;
+        cache->lines_alloc += 20;
-    cache->lines = (struct line_pnts **) G_realloc(cache->lines,
-						   cache->lines_alloc *
-						   sizeof(struct line_pnts *));
-    cache->lines_types = (int *) G_realloc(cache->lines_types,
-					   sizeof(int));
+    cache->lines = (struct line_pnts **)G_realloc(cache->lines,
+                                                  cache->lines_alloc *
+                                                  sizeof(struct line_pnts *));
+    cache->lines_types = (int *)G_realloc(cache->lines_types,
+                                          cache->lines_alloc * sizeof(int));
     if (cache->lines_alloc > 1) {
-	for (i = cache->lines_alloc - 20; i < cache->lines_alloc; i++) {
-	    cache->lines[i] = Vect_new_line_struct();
-	    cache->lines_types[i] = -1;
+        for (i = cache->lines_alloc - 20; i < cache->lines_alloc; i++) {
+            cache->lines[i] = Vect_new_line_struct();
+            cache->lines_types[i] = -1;
     else {
-	cache->lines[0] = Vect_new_line_struct();
-	cache->lines_types[0] = -1;
+        cache->lines[0] = Vect_new_line_struct();
+        cache->lines_types[0] = -1;
 void add_fpart(struct feat_parts *fparts, SF_FeatureType ftype,
-	       int idx, int nlines)
+               int idx, int nlines)
     if (!fparts)
-	return;
+        return;
     if (fparts->a_parts == 0 || fparts->n_parts >= fparts->a_parts) {
-	if (fparts->a_parts == 0)
-	    fparts->a_parts = 1;
-	else
-	    fparts->a_parts += 20;
-	fparts->ftype  = (SF_FeatureType *) G_realloc(fparts->ftype,
-						      fparts->a_parts * sizeof(SF_FeatureType));
-	fparts->nlines = (int *) G_realloc(fparts->nlines,
-					   fparts->a_parts * sizeof(int));
-	fparts->idx    = (int *) G_realloc(fparts->idx,
+        if (fparts->a_parts == 0)
+            fparts->a_parts = 1;
+        else
+            fparts->a_parts += 20;
+        fparts->ftype = (SF_FeatureType *) G_realloc(fparts->ftype,
+                                                     fparts->a_parts *
+                                                     sizeof(SF_FeatureType));
+        fparts->nlines =
+            (int *)G_realloc(fparts->nlines, fparts->a_parts * sizeof(int));
+        fparts->idx =
+            (int *)G_realloc(fparts->idx, fparts->a_parts * sizeof(int));
-    fparts->ftype[fparts->n_parts]  = ftype;
-    fparts->idx[fparts->n_parts]    = idx;
+    fparts->ftype[fparts->n_parts] = ftype;
+    fparts->idx[fparts->n_parts] = idx;
     fparts->nlines[fparts->n_parts] = nlines;
     fparts->n_parts++;
 #endif
Modified: grass/trunk/lib/vector/Vlib/rewind_pg.c
--- grass/trunk/lib/vector/Vlib/rewind_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/rewind_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -11,7 +11,7 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
@@ -21,46 +21,46 @@
 #endif
-  \brief Rewind vector map (PostGIS layer) to cause reads to start
-  at beginning (level 1)
+   \brief Rewind vector map (PostGIS layer) to cause reads to start
+   at beginning (level 1)
 int V1_rewind_pg(struct Map_info *Map)
     G_debug(2, "V1_rewind_pg(): name = %s", Map->name);
     pg_info = &(Map->fInfo.pg);
     /* reset reading */
     /* reset cache */
     pg_info->cache.lines_num = pg_info->cache.lines_next = 0;
     /* close DB cursor if necessary */
     if (pg_info->res) {
-	    return -1;
+            return -1;
     return 0;
 #else
     G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
@@ -69,13 +69,13 @@
-  at beginning on topological level (level 2)
-  \param Map pointer to Map_info structure
+   at beginning on topological level (level 2)
-  \return 0 on success
+   \param Map pointer to Map_info structure
+   \return 0 on success
 int V2_rewind_pg(struct Map_info *Map)
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2012-04-11 10:42:29 UTC (rev 51377)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2012-04-11 14:34:58 UTC (rev 51378)
@@ -32,159 +32,155 @@
 #define WKBSRIDFLAG 0x20000000
 static char *binary_to_hex(int, const unsigned char *);
-static unsigned char *point_to_wkb(int, const struct line_pnts *,
-				   int, int*);
+static unsigned char *point_to_wkb(int, const struct line_pnts *, int, int *);
 static unsigned char *linestring_to_wkb(int, const struct line_pnts *,
-					int, int*);
+                                        int, int *);
 static unsigned char *polygon_to_wkb(int, const struct line_pnts *,
-				     int, int*);
-static int write_feature(struct Format_info_pg *,
-			 int, const struct line_pnts *, int,
-			 int, const struct field_info *);
+                                     int, int *);
+static int write_feature(struct Format_info_pg *,
+                         int, const struct line_pnts *, int,
+                         int, const struct field_info *);
 static char *build_insert_stmt(const struct Format_info_pg *, const char *,
 #endif
-  \brief Writes feature on level 1 (PostGIS interface)
+   \brief Writes feature on level 1 (PostGIS interface)
-  Note:
+   Note:
    - centroids are not supported in PostGIS, pseudotopo holds virtual
-     centroids
+   centroids
    - boundaries are not supported in PostGIS, pseudotopo treats polygons
-     as boundaries
-  \param type feature type (GV_POINT, GV_LINE, ...)
-  \param points pointer to line_pnts structure (feature geometry)
-  \param cats pointer to line_cats structure (feature categories)
-  \return feature offset into file
+   as boundaries
+   \param type feature type (GV_POINT, GV_LINE, ...)
+   \param points pointer to line_pnts structure (feature geometry)
+   \param cats pointer to line_cats structure (feature categories)
+   \return feature offset into file
 off_t V1_write_line_pg(struct Map_info *Map, int type,
-		       const struct line_pnts *points,
-		       const struct line_cats *cats)
+                       const struct line_pnts *points,
+                       const struct line_cats *cats)
 #ifdef HAVE_POSTGRES
     int cat;
     off_t offset;
     struct Format_info_offset *offset_info;
     offset_info = &(pg_info->offset);
     if (!pg_info->conn) {
-	G_warning(_("No connection defined"));
-	return -1;
+        G_warning(_("No connection defined"));
+        return -1;
-	return -1;
+        return -1;
     if (pg_info->feature_type == SF_UNKNOWN) {
-	/* create PostGIS table if doesn't exist */
-	if (V2_open_new_pg(Map, type) < 0)
-	    return -1;
+        /* create PostGIS table if doesn't exist */
+        if (V2_open_new_pg(Map, type) < 0)
+            return -1;
-    Fi = NULL; /* no attributes to be written */
+    Fi = NULL;                  /* no attributes to be written */
     cat = -1;
     if (cats->n_cats > 0 && Vect_get_num_dblinks(Map) > 0) {
-	/* check for attributes */
-	if (Fi) {
-	    if (!Vect_cat_get(cats, Fi->number, &cat))
-		G_warning(_("No category defined for layer %d"), Fi->number);
-	    if (cats->n_cats > 1) {
-		G_warning(_("Feature has more categories, using "
-			    "category %d (from layer %d)"),
-			  cat, cats->field[0]);
+        /* check for attributes */
+        if (Fi) {
+            if (!Vect_cat_get(cats, Fi->number, &cat))
+                G_warning(_("No category defined for layer %d"), Fi->number);
+            if (cats->n_cats > 1) {
+                G_warning(_("Feature has more categories, using "
+                            "category %d (from layer %d)"),
+                          cat, cats->field[0]);
     sf_type = pg_info->feature_type;
     /* determine matching PostGIS feature geometry type */
     if (type & (GV_POINT | GV_KERNEL)) {
-	if (sf_type != SF_POINT &&
-	    sf_type != SF_POINT25D) {
-	    G_warning(_("Feature is not a point. Skipping."));
-	    return -1;
+        if (sf_type != SF_POINT && sf_type != SF_POINT25D) {
+            G_warning(_("Feature is not a point. Skipping."));
+            return -1;
     else if (type & GV_LINE) {
-	if (sf_type != SF_LINESTRING &&
-	    sf_type != SF_LINESTRING25D) {
-	    G_warning(_("Feature is not a line. Skipping."));
-	    return -1;
+        if (sf_type != SF_LINESTRING && sf_type != SF_LINESTRING25D) {
+            G_warning(_("Feature is not a line. Skipping."));
+            return -1;
     else if (type & GV_BOUNDARY) {
-	if (sf_type != SF_POLYGON) {
-	    G_warning(_("Feature is not a polygon. Skipping."));
-	    return -1;
+        if (sf_type != SF_POLYGON) {
+            G_warning(_("Feature is not a polygon. Skipping."));
+            return -1;
     else if (type & GV_FACE) {
-	if (sf_type != SF_POLYGON25D) {
-	    G_warning(_("Feature is not a face. Skipping."));
-	    return -1;
+        if (sf_type != SF_POLYGON25D) {
+            G_warning(_("Feature is not a face. Skipping."));
+            return -1;
     else {
-	G_warning(_("Unsupported feature type (%d)"), type);
-	return -1;
+        G_warning(_("Unsupported feature type (%d)"), type);
+        return -1;
     G_debug(3, "V1_write_line_pg(): type = %d n_points = %d cat = %d",
-	    type, points->n_points, cat);
+            type, points->n_points, cat);
     if (sf_type == SF_POLYGON || sf_type == SF_POLYGON25D) {
-	int npoints;
-	npoints = points->n_points - 1;
-	if (points->x[0] != points->x[npoints] ||
-	    points->y[0] != points->y[npoints] ||
-	    points->z[0] != points->z[npoints]) {
-	    G_warning(_("Boundary is not closed. Skipping."));
-	    return -1;
+        int npoints;
+        npoints = points->n_points - 1;
+        if (points->x[0] != points->x[npoints] ||
+            points->y[0] != points->y[npoints] ||
+            points->z[0] != points->z[npoints]) {
+            G_warning(_("Boundary is not closed. Skipping."));
+            return -1;
     /* write feature's geometry and fid */
     if (-1 == write_feature(pg_info, type, points,
-			    Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z,
-			    cat, Fi)) {
-	return -1;
+                            Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z, cat, Fi)) {
+        return -1;
     /* update offset array */
     if (offset_info->array_num >= offset_info->array_alloc) {
-	offset_info->array_alloc += 1000;
-	offset_info->array = (int *) G_realloc(offset_info->array,
-					       offset_info->array_alloc *
-					       sizeof(int));
+        offset_info->array_alloc += 1000;
+        offset_info->array = (int *)G_realloc(offset_info->array,
+                                              offset_info->array_alloc *
+                                              sizeof(int));
     offset = offset_info->array_num;
     offset_info->array[offset_info->array_num++] = cat;
-	/* register first part in offset array */
-	offset_info->array[offset_info->array_num++] = 0;
+        /* register first part in offset array */
+        offset_info->array[offset_info->array_num++] = 0;
     G_debug(3, "V1_write_line_pg(): -> offset = %lu offset_num = %d cat = %d",
-	    (unsigned long) offset, offset_info->array_num, cat);
+            (unsigned long)offset, offset_info->array_num, cat);
     return offset;
 #else
@@ -194,27 +190,28 @@
-  \brief Rewrites feature at the given offset (level 1) (PostGIS interface)
-  \param offset feature offset
-  \param points feature geometry
-  \param cats feature categories
-  \return feature offset (rewriten feature)
-off_t V1_rewrite_line_pg(struct Map_info *Map,
-			 int line, int type, off_t offset,
-			 const struct line_pnts *points, const struct line_cats *cats)
+   \brief Rewrites feature at the given offset (level 1) (PostGIS interface)
+   \param offset feature offset
+   \param points feature geometry
+   \param cats feature categories
+   \return feature offset (rewriten feature)
+off_t V1_rewrite_line_pg(struct Map_info * Map,
+                         int line, int type, off_t offset,
+                         const struct line_pnts * points,
+                         const struct line_cats * cats)
     G_debug(3, "V1_rewrite_line_pg(): line=%d type=%d offset=%llu",
-	    line, type, offset);
+            line, type, offset);
     if (type != V1_read_line_pg(Map, NULL, NULL, offset)) {
-	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
-	return -1;
+        G_warning(_("Unable to rewrite feature (incompatible feature types)"));
+        return -1;
     /* delete old */
@@ -228,56 +225,56 @@
-  \brief Deletes feature at the given offset (level 1)
-  \param Map pointer Map_info structure
+   \brief Deletes feature at the given offset (level 1)
+   \param Map pointer Map_info structure
 int V1_delete_line_pg(struct Map_info *Map, off_t offset)
     long fid;
     char stmt[DB_SQL_MAX];
     if (!pg_info->conn || !pg_info->table_name) {
-	return -1;
+        return -1;
     if (offset >= pg_info->offset.array_num) {
-	G_warning(_("Invalid offset (%d)"), offset);
-	return -1;
+        G_warning(_("Invalid offset (%d)"), offset);
+        return -1;
     G_debug(3, "V1_delete_line_pg(), offset = %lu -> fid = %ld",
-	    (unsigned long) offset, fid);
+            (unsigned long)offset, fid);
     if (!pg_info->inTransaction) {
-	/* start transaction */
-	pg_info->inTransaction = TRUE;
-	    return -1;
+        /* start transaction */
+        pg_info->inTransaction = TRUE;
+            return -1;
     sprintf(stmt, "DELETE FROM %s WHERE %s = %ld",
     if (execute(pg_info->conn, stmt) == -1) {
-	G_warning(_("Unable to delete feature"));
-	return -1;
+        G_warning(_("Unable to delete feature"));
+        return -1;
     return 0;
 #else
@@ -287,29 +284,29 @@
-  \brief Binary data to HEX
+   \brief Binary data to HEX
-  Allocated buffer should be freed by G_free().
-  \param nbytes number of bytes to allocate
+   Allocated buffer should be freed by G_free().
-  \return allocated buffer with HEX data
+   \param nbytes number of bytes to allocate
+   \return allocated buffer with HEX data
 char *binary_to_hex(int nbytes, const unsigned char *wkb_data)
     char *hex_data;
     int i, nlow, nhigh;
     static const char ach_hex[] = "0123456789ABCDEF";
-    hex_data = (char *) G_malloc(nbytes * 2 + 1);
+    hex_data = (char *)G_malloc(nbytes * 2 + 1);
     hex_data[nbytes * 2] = '\0';
     for (i = 0; i < nbytes; i++) {
-        nlow  = wkb_data[i] & 0x0f;
+        nlow = wkb_data[i] & 0x0f;
         nhigh = (wkb_data[i] & 0xf0) >> 4;
-        hex_data[i * 2]     = ach_hex[nhigh];
+        hex_data[i * 2] = ach_hex[nhigh];
         hex_data[i * 2 + 1] = ach_hex[nlow];
@@ -317,50 +314,50 @@
-  \bried Write point into WKB buffer
+   \bried Write point into WKB buffer
-  See OGRPoint::exportToWkb from GDAL/OGR library
+   See OGRPoint::exportToWkb from GDAL/OGR library
-  \param byte_order byte order (ENDIAN_LITTLE or BIG_ENDIAN)
-  \param[out] nsize buffer size
-  \return allocated WKB buffer
-  \return NULL on error
+   \param byte_order byte order (ENDIAN_LITTLE or BIG_ENDIAN)
+   \param[out] nsize buffer size
+   \return allocated WKB buffer
+   \return NULL on error
 unsigned char *point_to_wkb(int byte_order,
-			    const struct line_pnts *points, int with_z,
-			    int *nsize)
+                            const struct line_pnts *points, int with_z,
+                            int *nsize)
     unsigned int sf_type;
     if (points->n_points != 1)
-	return NULL;
+        return NULL;
     /* allocate buffer */
     *nsize = with_z ? 29 : 21;
     wkb_data = G_malloc(*nsize);
     G_zero(wkb_data, *nsize);
     G_debug(5, "\t->point size=%d (with_z = %d)", *nsize, with_z);
     /* set the byte order */
-	wkb_data[0] = '\001';
+        wkb_data[0] = '\001';
     else
-	wkb_data[0] = '\000';
+        wkb_data[0] = '\000';
     /* set the geometry feature type */
     sf_type = with_z ? SF_POINT25D : SF_POINT;
-	sf_type = LSBWORD32(sf_type);
+        sf_type = LSBWORD32(sf_type);
     else
         sf_type = MSBWORD32(sf_type);
     memcpy(wkb_data + 1, &sf_type, 4);
     /* copy in the raw data */
     memcpy(wkb_data + 5, &(points->x[0]), 8);
     memcpy(wkb_data + 5 + 8, &(points->y[0]), 8);
@@ -371,9 +368,9 @@
     /* swap if needed */
-	SWAPDOUBLE(wkb_data + 5);
+        SWAPDOUBLE(wkb_data + 5);
         SWAPDOUBLE(wkb_data + 5 + 8);
         if (with_z)
             SWAPDOUBLE(wkb_data + 5 + 16);
@@ -382,28 +379,28 @@
-  \bried Write linestring into WKB buffer
+   \bried Write linestring into WKB buffer
-  See OGRLineString::exportToWkb from GDAL/OGR library
+   See OGRLineString::exportToWkb from GDAL/OGR library
-  \param byte_order byte order (ENDIAN_LITTLE or ENDIAN_BIG)
+   \param byte_order byte order (ENDIAN_LITTLE or ENDIAN_BIG)
 unsigned char *linestring_to_wkb(int byte_order,
-				 int *nsize)
+                                 int *nsize)
     int i, point_size;
     if (points->n_points < 1)
-	return NULL;
+        return NULL;
     point_size = 8 * (with_z ? 3 : 2);
@@ -415,42 +412,41 @@
     else
     sf_type = with_z ? SF_LINESTRING25D : SF_LINESTRING;
     else
     /* copy in the data count */
     memcpy(wkb_data + 5, &(points->n_points), 4);
     for (i = 0; i < points->n_points; i++) {
-	memcpy(wkb_data + 9 + point_size * i, &(points->x[i]), 8);
-	memcpy(wkb_data + 9 + 8 + point_size * i, &(points->y[i]), 8);
-	if (with_z) {
-	    memcpy(wkb_data + 9 + 16 + point_size * i, &(points->z[i]), 8);
+        memcpy(wkb_data + 9 + point_size * i, &(points->x[i]), 8);
+        memcpy(wkb_data + 9 + 8 + point_size * i, &(points->y[i]), 8);
+        if (with_z) {
+            memcpy(wkb_data + 9 + 16 + point_size * i, &(points->z[i]), 8);
         int npoints, nitems;
         npoints = SWAP32(points->n_points);
-        memcpy(wkb_data+5, &npoints, 4);
+        memcpy(wkb_data + 5, &npoints, 4);
-	nitems = (with_z ? 3 : 2) * points->n_points;
-        for(i = 0; i < nitems; i++ )
+        nitems = (with_z ? 3 : 2) * points->n_points;
+        for (i = 0; i < nitems; i++) {
             SWAPDOUBLE(wkb_data + 9 + 4 + 8 * i);
@@ -459,28 +455,28 @@
-  \bried Write polygon into WKB buffer
+   \bried Write polygon into WKB buffer
-  See OGRPolygon::exportToWkb from GDAL/OGR library
+   See OGRPolygon::exportToWkb from GDAL/OGR library
 unsigned char *polygon_to_wkb(int byte_order,
-			      int *nsize)
+                              int *nsize)
     int i, point_size, nrings;
     if (points->n_points < 3)
-	return NULL;
+        return NULL;
@@ -491,53 +487,54 @@
     G_debug(5, "\t->polygon size=%d (with_z = %d)", *nsize, with_z);
     else
     sf_type = with_z ? SF_POLYGON25D : SF_POLYGON;
     else
         int ncount;
         ncount = SWAP32(nrings);
         memcpy(wkb_data + 5, &ncount, 4);
     else {
         memcpy(wkb_data + 5, &nrings, 4);
     /* serialize ring */
     memcpy(wkb_data + 9, &(points->n_points), 4);
-	memcpy(wkb_data + 9 + 4 + point_size * i, &(points->x[i]), 8);
-	memcpy(wkb_data + 9 + 4 + 8 + point_size * i, &(points->y[i]), 8);
-	if (with_z) {
-	    memcpy(wkb_data + 9 + 4 + 16 + point_size * i, &(points->z[i]), 8);
+        memcpy(wkb_data + 9 + 4 + point_size * i, &(points->x[i]), 8);
+        memcpy(wkb_data + 9 + 4 + 8 + point_size * i, &(points->y[i]), 8);
+        if (with_z) {
+            memcpy(wkb_data + 9 + 4 + 16 + point_size * i, &(points->z[i]),
+                   8);
-        for(i = 0; i < nitems; i++ ) {
@@ -546,65 +543,65 @@
-  \brief Insert feature into table
+   \brief Insert feature into table
-  \param cat category number (-1 for no category)
-  \param Fi pointer to field_info (attributes to copy, NULL for no attributes)
+   \param cat category number (-1 for no category)
+   \param Fi pointer to field_info (attributes to copy, NULL for no attributes)
-  \retirn 0 on success
+   \retirn 0 on success
 int write_feature(struct Format_info_pg *pg_info,
-		  int type, const struct line_pnts *points, int with_z,
-		  int cat, const struct field_info *Fi)
+                  int type, const struct line_pnts *points, int with_z,
+                  int cat, const struct field_info *Fi)
-    int   byte_order, nbytes, nsize;
+    int byte_order, nbytes, nsize;
-    char  *stmt, *text_data, *text_data_p, *hex_data;
+    char *stmt, *text_data, *text_data_p, *hex_data;
     if (with_z && pg_info->coor_dim != 3) {
-	G_warning(_("Trying to insert 3D data into feature table "
-		    "which store 2D data only"));
-	return -1;
+        G_warning(_("Trying to insert 3D data into feature table "
+                    "which store 2D data only"));
+        return -1;
     if (!with_z && pg_info->coor_dim != 2) {
-	G_warning(_("Trying to insert 2D data into feature table "
-		    "which store 3D data only"));
-	return -1;
+        G_warning(_("Trying to insert 2D data into feature table "
+                    "which store 3D data only"));
+        return -1;
     byte_order = ENDIAN_LITTLE; /* TODO: get endianness for system from dig__byte_order_out()? */
     /* get wkb data */
     nbytes = -1;
     wkb_data = NULL;
-    if (type == GV_POINT)
-	wkb_data = point_to_wkb(byte_order, points, with_z, &nbytes);
+    if (type == GV_POINT)
+        wkb_data = point_to_wkb(byte_order, points, with_z, &nbytes);
     else if (type == GV_LINE)
-	wkb_data = linestring_to_wkb(byte_order, points, with_z, &nbytes);
-    else if (type == GV_BOUNDARY)
-	wkb_data = polygon_to_wkb(byte_order, points, with_z, &nbytes);
+        wkb_data = linestring_to_wkb(byte_order, points, with_z, &nbytes);
+    else if (type == GV_BOUNDARY)
+        wkb_data = polygon_to_wkb(byte_order, points, with_z, &nbytes);
     if (!wkb_data || nbytes < 1) {
-	G_warning(_("Unsupported feature type %d"), type);
-	return -1;
+        G_warning(_("Unsupported feature type %d"), type);
+        return -1;
     /* When converting to hex, each byte takes 2 hex characters. In
        addition we add in 8 characters to represent the SRID integer
        in hex, and one for a null terminator */
     nsize = nbytes * 2 + 8 + 1;
-    text_data = text_data_p = (char *) G_malloc(nsize);
+    text_data = text_data_p = (char *)G_malloc(nsize);
     /* convert the 1st byte, which is the endianess flag, to hex */
     hex_data = binary_to_hex(1, wkb_data);
     strcpy(text_data_p, hex_data);
-    G_free (hex_data);
+    G_free(hex_data);
     text_data_p += 2;
     /* get the geom type which is bytes 2 through 5 */
@@ -612,25 +609,27 @@
     /* add the SRID flag if an SRID is provided */
     if (pg_info->srid > 0) {
-	unsigned int srs_flag;
-	/* change the flag to little endianess */
+        unsigned int srs_flag;
+        /* change the flag to little endianess */
         srs_flag = LSBWORD32(WKBSRIDFLAG);
         /* apply the flag */
         sf_type = sf_type | srs_flag;
     /* write the geom type which is 4 bytes */
-    hex_data = binary_to_hex(4, (unsigned char*) &sf_type);
+    hex_data = binary_to_hex(4, (unsigned char *)&sf_type);
     G_free(hex_data);
     text_data_p += 8;
     /* include SRID if provided */
-	unsigned int srs_id;
+        unsigned int srs_id;
         /* force the srsid to little endianess */
         srs_id = LSBWORD32(pg_info->srid);
-        hex_data = binary_to_hex(sizeof(srs_id), (unsigned char*) &srs_id);
+        hex_data = binary_to_hex(sizeof(srs_id), (unsigned char *)&srs_id);
         G_free(hex_data);
         text_data_p += 8;
@@ -645,157 +644,157 @@
     /* build INSERT statement */
     stmt = build_insert_stmt(pg_info, text_data, cat, Fi);
-	    return -1;
+            return -1;
-	/* rollback transaction */
-	execute(pg_info->conn, "ROLLBACK");
-	return -1;
+        /* rollback transaction */
+        execute(pg_info->conn, "ROLLBACK");
+        return -1;
     G_free(wkb_data);
     G_free(text_data);
     G_free(stmt);
     return 0;
-  \brief Build INSERT statement to insert new feature to the table
+   \brief Build INSERT statement to insert new feature to the table
-  \param pg_info pointer to Format_info_pg structure
-  \param cat category number (or -1 for no category)
-  \param Fi pointer to field_info structure (NULL for no attributes)
+   \param pg_info pointer to Format_info_pg structure
+   \param cat category number (or -1 for no category)
+   \param Fi pointer to field_info structure (NULL for no attributes)
-  \return allocated string with INSERT statement
+   \return allocated string with INSERT statement
 char *build_insert_stmt(const struct Format_info_pg *pg_info,
-			const char *geom_data,
+                        const char *geom_data,
     char *stmt, buf[DB_SQL_MAX];
     stmt = NULL;
     if (Fi && cat > -1) {
-	int col, ncol, more;
-	int sqltype, ctype;
-	char buf_val[DB_SQL_MAX], buf_tmp[DB_SQL_MAX];
-	char *str_val;
-	const char *colname;
-	dbString  dbstmt;
-	dbCursor  cursor;
-	dbTable  *table;
-	dbColumn *column;
-	dbValue  *value;
-	db_init_string(&dbstmt);
-	buf_val[0] = '\0';
-	/* read & set attributes */
-	sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
-		cat);
-	G_debug(4, "SQL: %s", buf);
-	db_set_string(&dbstmt, buf);
+        int col, ncol, more;
+        int sqltype, ctype;
+        char buf_val[DB_SQL_MAX], buf_tmp[DB_SQL_MAX];
+        char *str_val;
-	/* prepare INSERT statement */
-	sprintf(buf, "INSERT INTO \"%s\".\"%s\" (%s",
-		pg_info->geom_column);
-	/* select data */
-	if (db_open_select_cursor(pg_info->dbdriver, &dbstmt,
-				  &cursor, DB_SEQUENTIAL) != DB_OK) {
-	    G_warning(_("Unable to select attributes for category %d"),
-		      cat);
-	else {
-	    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
-		G_warning(_("Unable to fetch data from table <%s>"),
-			  Fi->table);
-	    if (!more) {
-		G_warning(_("No database record for category %d, "
-			    "no attributes will be written"), cat);
-	    else {
-		table = db_get_cursor_table(&cursor);
-		ncol = db_get_table_number_of_columns(table);
+        const char *colname;
-		for (col = 0; col < ncol; col++) {
-		    column = db_get_table_column(table, col);
-		    colname = db_get_column_name(column);
-		    /* skip fid column */
-		    if (strcmp(pg_info->fid_column, colname) == 0)
-			continue;
-		    /* -> columns */
-		    sprintf(buf_tmp, ",%s", colname);
-		    strcat(buf, buf_tmp);
-		    /* -> values */
-		    value = db_get_column_value(column);
-		    	/* for debug only */
-		    db_convert_column_value_to_string(column, &dbstmt);
-		    G_debug(2, "col %d : val = %s", col,
-			    db_get_string(&dbstmt));
+        dbString dbstmt;
+        dbCursor cursor;
+        dbTable *table;
+        dbColumn *column;
+        dbValue *value;
-		    sqltype = db_get_column_sqltype(column);
-		    ctype = db_sqltype_to_Ctype(sqltype);
+        db_init_string(&dbstmt);
+        buf_val[0] = '\0';
-		    /* prevent writing NULL values */
-		    if (!db_test_value_isnull(value)) {
-			switch (ctype) {
-			case DB_C_TYPE_INT:
-			    sprintf(buf_tmp, ",%d", db_get_value_int(value));
-			    break;
-			case DB_C_TYPE_DOUBLE:
-			    sprintf(buf_tmp, ",%.14f", db_get_value_double(value));
-			    break;
-			case DB_C_TYPE_STRING:
-			    str_val = G_store(db_get_value_string(value));
-			    G_str_to_sql(str_val);
-			    sprintf(buf_tmp, ",'%s'", str_val);
-			    G_free(str_val);
-			    break;
-			case DB_C_TYPE_DATETIME:
-							      &dbstmt);
-			    sprintf(buf_tmp, ",%s", db_get_string(&dbstmt));
-			    break;
-			default:
-			    G_warning(_("Unsupported column type %d"), ctype);
-			    sprintf(buf_tmp, ",NULL");
-			    break;
-		    else {
-		    strcat(buf_val, buf_tmp);
-		G_asprintf(&stmt, "%s) VALUES ('%s'::GEOMETRY%s)",
-			   buf, geom_data, buf_val);
+        /* read & set attributes */
+        sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
+                cat);
+        G_debug(4, "SQL: %s", buf);
+        db_set_string(&dbstmt, buf);
+        /* prepare INSERT statement */
+        sprintf(buf, "INSERT INTO \"%s\".\"%s\" (%s",
+                pg_info->geom_column);
+        /* select data */
+        if (db_open_select_cursor(pg_info->dbdriver, &dbstmt,
+                                  &cursor, DB_SEQUENTIAL) != DB_OK) {
+            G_warning(_("Unable to select attributes for category %d"), cat);
+        else {
+            if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+                G_warning(_("Unable to fetch data from table <%s>"),
+                          Fi->table);
+            if (!more) {
+                G_warning(_("No database record for category %d, "
+                            "no attributes will be written"), cat);
+            else {
+                table = db_get_cursor_table(&cursor);
+                ncol = db_get_table_number_of_columns(table);
+                for (col = 0; col < ncol; col++) {
+                    column = db_get_table_column(table, col);
+                    colname = db_get_column_name(column);
+                    /* skip fid column */
+                    if (strcmp(pg_info->fid_column, colname) == 0)
+                        continue;
+                    /* -> columns */
+                    sprintf(buf_tmp, ",%s", colname);
+                    strcat(buf, buf_tmp);
+                    /* -> values */
+                    value = db_get_column_value(column);
+                    /* for debug only */
+                    db_convert_column_value_to_string(column, &dbstmt);
+                    G_debug(2, "col %d : val = %s", col,
+                            db_get_string(&dbstmt));
+                    sqltype = db_get_column_sqltype(column);
+                    ctype = db_sqltype_to_Ctype(sqltype);
+                    /* prevent writing NULL values */
+                    if (!db_test_value_isnull(value)) {
+                        switch (ctype) {
+                        case DB_C_TYPE_INT:
+                            sprintf(buf_tmp, ",%d", db_get_value_int(value));
+                            break;
+                        case DB_C_TYPE_DOUBLE:
+                            sprintf(buf_tmp, ",%.14f",
+                                    db_get_value_double(value));
+                            break;
+                        case DB_C_TYPE_STRING:
+                            str_val = G_store(db_get_value_string(value));
+                            G_str_to_sql(str_val);
+                            sprintf(buf_tmp, ",'%s'", str_val);
+                            G_free(str_val);
+                            break;
+                        case DB_C_TYPE_DATETIME:
+                                                              &dbstmt);
+                            sprintf(buf_tmp, ",%s", db_get_string(&dbstmt));
+                            break;
+                        default:
+                            G_warning(_("Unsupported column type %d"), ctype);
+                            sprintf(buf_tmp, ",NULL");
+                            break;
+                    else {
+                    strcat(buf_val, buf_tmp);
+                G_asprintf(&stmt, "%s) VALUES ('%s'::GEOMETRY%s)",
+                           buf, geom_data, buf_val);
     if (!stmt) {
-	/* no attributes */
-	G_asprintf(&stmt, "INSERT INTO \"%s\".\"%s\" (%s) VALUES "
-		   "('%s'::GEOMETRY)",
-		   pg_info->geom_column, geom_data);
+        /* no attributes */
+        G_asprintf(&stmt, "INSERT INTO \"%s\".\"%s\" (%s) VALUES "
+                   "('%s'::GEOMETRY)",
+                   pg_info->geom_column, geom_data);
     return stmt;
