[GRASS-SVN] r51406 - grass/trunk/man
svn_grass at osgeo.org
Fri Apr 13 06:49:02 EDT 2012
Author: martinl
Date: 2012-04-13 03:49:02 -0700 (Fri, 13 Apr 2012)
New Revision: 51406
grass/trunk/man/Makefile
grass/trunk/man/build_html.py
manual pages: add temporal commands
Modified: grass/trunk/man/Makefile
--- grass/trunk/man/Makefile 2012-04-13 10:13:52 UTC (rev 51405)
+++ grass/trunk/man/Makefile 2012-04-13 10:49:02 UTC (rev 51406)
@@ -20,6 +20,7 @@
ps:postscript \
r:raster \
r3:raster3D \
+ t:temporal \
v:vector
IDXCATS := $(foreach cat,$(categories),$(lastword $(subst :, ,$(cat))))
Modified: grass/trunk/man/build_html.py
--- grass/trunk/man/build_html.py 2012-04-13 10:13:52 UTC (rev 51405)
+++ grass/trunk/man/build_html.py 2012-04-13 10:49:02 UTC (rev 51406)
@@ -135,15 +135,16 @@
<li><a href="grass7.html">GRASS startup manual page</a></li>
<li><a href="general.html">General commands manual</a></li>
</ul></td>
- <td valign="top" bgcolor="${box_color}" class="box"><h3> Miscellaneous</h3>
+ <td valign="top" bgcolor="${box_color}" class="box"><h3> Miscellaneous & Variables</h3>
<ul>
- <li><a href="misc.html">Misc. commands manual</a></li>
+ <li><a href="misc.html">Miscellaneous commands manual</a></li>
+ <li><a href="variables.html">GRASS variables and environment variables</a></li>
</ul></td>
</tr>
<tr>
- <td valign="top" bgcolor="${box_color}" class="box"><h3> Variables</h3>
+ <td valign="top" bgcolor="${box_color}" class="box"><h3> Temporal processing</h3>
<ul>
- <li><a href="variables.html">GRASS variables and environment variables</a></li>
+ <li><a href="temporal.html">Temporal commands manual</a></li>
</ul></td>
<td valign="top" bgcolor="${box_color}" class="box"><h3> Printing</h3>
<ul>
@@ -195,6 +196,7 @@
<tr><td> <a href="full_index.html#ps">ps.*</a> </td><td>postscript commands</td></tr>
<tr><td> <a href="full_index.html#r">r.*</a> </td><td>raster commands</td></tr>
<tr><td> <a href="full_index.html#r3">r3.*</a> </td><td>raster3D commands</td></tr>
+<tr><td> <a href="full_index.html#t">t.*</a> </td><td>temporal commands</td></tr>
<tr><td> <a href="full_index.html#v">v.*</a> </td><td>vector commands</td></tr>
<tr><td> <a href="nviz.html">nviz</a> </td><td>visualization suite</td></tr>
<tr><td> <a href="wxGUI.html">wxGUI</a> </td><td>wxPython-based GUI frontend</td></tr>
@@ -249,39 +251,39 @@
def try_mkdir(path):
try:
- os.mkdir(path)
+ os.mkdir(path)
except OSError, e:
- pass
+ pass
def replace_file(name):
temp = name + ".tmp"
if os.path.exists(name) and os.path.exists(temp) and read_file(name) == read_file(temp):
- os.remove(temp)
+ os.remove(temp)
else:
- try:
- os.remove(name)
- except OSError, e:
- pass
- os.rename(temp, name)
+ try:
+ os.remove(name)
+ except OSError, e:
+ pass
+ os.rename(temp, name)
def copy_file(src, dst):
write_file(dst, read_file(src))
def html_files(cls = None):
for cmd in sorted(os.listdir(html_dir)):
- if cmd.endswith(".html") and \
- (cls in [None, '*'] or cmd.startswith(cls + ".")) and \
- (cls != '*' or len(cmd.split('.')) >= 3) and \
- cmd not in ["full_index.html", "index.html"] and \
- cmd not in exclude_mods and \
- not cmd.startswith("wxGUI."):
- yield cmd
+ if cmd.endswith(".html") and \
+ (cls in [None, '*'] or cmd.startswith(cls + ".")) and \
+ (cls != '*' or len(cmd.split('.')) >= 3) and \
+ cmd not in ["full_index.html", "index.html"] and \
+ cmd not in exclude_mods and \
+ not cmd.startswith("wxGUI."):
+ yield cmd
def write_html_header(f, title, ismain = False):
f.write(header1_tmpl.substitute(title = title))
if ismain and macosx:
- f.write(macosx_tmpl.substitute(grass_version = grass_version,
- grass_mmver = grass_mmver))
+ f.write(macosx_tmpl.substitute(grass_version = grass_version,
+ grass_mmver = grass_mmver))
f.write(header2_tmpl.substitute(grass_version = grass_version))
def write_html_cmd_overview(f):
@@ -294,24 +296,24 @@
def get_desc(cmd):
f = open(cmd, 'r')
while True:
- line = f.readline()
- if not line:
- return ""
- if "NAME" in line:
- break
+ line = f.readline()
+ if not line:
+ return ""
+ if "NAME" in line:
+ break
while True:
- if not line:
- return ""
- if "SYNOPSIS" in line:
- break
- if "<em>" in line:
- sp = line.split('-',1)
- if len(sp) > 1:
- return sp[1].strip()
- else:
- return None
+ if not line:
+ return ""
+ if "SYNOPSIS" in line:
+ break
+ if "<em>" in line:
+ sp = line.split('-',1)
+ if len(sp) > 1:
+ return sp[1].strip()
+ else:
+ return None
return ""
@@ -329,4 +331,3 @@
macosx = "darwin" in os.environ['ARCH'].lower()
