[GRASS-SVN] r51407 - in grass/trunk: lib/python/temporal
lib/temporal/SQL temporal temporal/t.info
temporal/t.rast.export temporal/t.rast.import
temporal/t.rast.mapcalc temporal/t.rast.series
temporal/t.rast.to.rast3 temporal/t.register
temporal/t.sample temporal/t.support temporal/t.vect.extract
temporal/t.vect.list temporal/t.vect.what.strds
svn_grass at osgeo.org
Fri Apr 13 07:13:35 EDT 2012
Author: huhabla
Date: 2012-04-13 04:13:35 -0700 (Fri, 13 Apr 2012)
New Revision: 51407
Added:
grass/trunk/temporal/run_all_tests.sh
grass/trunk/temporal/t.vect.extract/
grass/trunk/temporal/t.vect.extract/Makefile
grass/trunk/temporal/t.vect.extract/t.vect.extract.html
grass/trunk/temporal/t.vect.extract/t.vect.extract.py
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.rast.export/test.t.rast.export.sh
grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
grass/trunk/temporal/t.register/test.t.register.raster.file.sh
grass/trunk/temporal/t.register/test.t.register.raster.sh
grass/trunk/temporal/t.register/test.t.register.raster3d.sh
grass/trunk/temporal/t.sample/test.t.sample.sh
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
* Added vector metadata support in temporal database -> API and database layout changes
* New module t.vect.extract to perform spatio-temporal and value based queries on vector maps
* Test update and bugfixing
* API use bugfixing
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -1018,26 +1018,27 @@
core.verbose(_("Unregister %s map <%s>") % (map.get_type(), map.get_map_id()))
# Check if the map is registered in the space time raster dataset
- if dbmi.paramstyle == "qmark":
- sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
- else:
- sql = "SELECT id FROM " + map_register_table + " WHERE id = %s"
- try:
- dbif.cursor.execute(sql, (self.base.get_id(),))
- row = dbif.cursor.fetchone()
- except:
- row = None
- # Break if the map is not registered
- if row == None:
- if map.get_layer():
- core.warning(_("Map <%s> with layer %s is not registered in space time dataset <%s>") %(map.get_map_id(), map.get_layer(), self.base.get_id()))
+ if map_register_table != None:
+ if dbmi.paramstyle == "qmark":
+ sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
else:
- core.warning(_("Map <%s> is not registered in space time dataset <%s>") %(map.get_map_id(), self.base.get_id()))
- if connect == True:
- dbif.close()
- return ""
+ sql = "SELECT id FROM " + map_register_table + " WHERE id = %s"
+ try:
+ dbif.cursor.execute(sql, (self.base.get_id(),))
+ row = dbif.cursor.fetchone()
+ except:
+ row = None
+ # Break if the map is not registered
+ if row == None:
+ if map.get_layer():
+ core.warning(_("Map <%s> with layer %s is not registered in space time dataset <%s>") %(map.get_map_id(), map.get_layer(), self.base.get_id()))
+ else:
+ core.warning(_("Map <%s> is not registered in space time dataset <%s>") %(map.get_map_id(), self.base.get_id()))
+ if connect == True:
+ dbif.close()
+ return ""
# Remove the space time raster dataset from the raster dataset register
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/aggregation.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -143,10 +143,8 @@
# Set the time stamp and write it to the raster map
if dataset.is_time_absolute():
new_map.set_absolute_time(start, end, None)
- new_map.write_absolute_time_to_file()
else:
new_map.set_relative_time(start, end, orig_ds.get_relative_time_unit())
- new_map.write_relative_time_to_file()
# Insert map in temporal database
new_map.insert(dbif)
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/extract.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -23,20 +23,22 @@
-def extract_dataset(input, output, type, where, expression, base, nprocs, register_null=False):
- """!Extract a subset of a space time raster or raster3d dataset
+def extract_dataset(input, output, type, where, expression, base, nprocs=1, register_null=False, layer=1, vtype="point,line,boundary,centroid,area,face"):
+ """!Extract a subset of a space time raster, raster3d or vector dataset
A mapcalc expression can be provided to process the temporal extracted maps.
Mapcalc expressions are supported for raster and raster3d maps.
@param input The name of the input space time raster/raster3d dataset
@param output The name of the extracted new space time raster/raster3d dataset
- @param type The type of the dataset: "raster" or "raster3d"
- @param where The SQL WHERE statement for subset extraction
- @param expression The r(3).mapcalc expression
+ @param type The type of the dataset: "raster", "raster3d" or vector
+ @param where The temporal SQL WHERE statement for subset extraction
+ @param expression The r(3).mapcalc expression or the v.extract where statement
@param base The base name of the new created maps in case a mapclac expression is provided
@param nprocs The number of parallel processes to be used for mapcalc processing
- @param register_null Set this number True to register empty maps
+ @param register_null Set this number True to register empty maps (only raster and raster3d maps)
+ @param layer The vector layer number to be used when no timestamped layer is present, default is 1
+ @param vtype The feature type to be extracted for vector maps, default is point,line,boundary,centroid,area and face
mapset = core.gisenv()["MAPSET"]
@@ -48,10 +50,13 @@
if type == "raster":
sp = space_time_raster_dataset(id)
- else:
+ elif type == "raster3d":
sp = space_time_raster3d_dataset(id)
+ elif type == "vector":
+ sp = space_time_vector_dataset(id)
+ dummy = sp.get_new_map_instance(None)
dbif = sql_database_interface_connection()
dbif.connect()
@@ -77,8 +82,10 @@
if core.overwrite() == False:
dbif.close()
core.fatal(_("Space time %s dataset <%s> is already in database, use overwrite flag to overwrite") % (type, out_id))
- rows = sp.get_registered_maps("id", where, "start_time", dbif)
+ if type == "vector":
+ rows = sp.get_registered_maps("id,layer", where, "start_time", dbif)
+ else:
+ rows = sp.get_registered_maps("id", where, "start_time", dbif)
new_maps = {}
if rows:
@@ -91,19 +98,25 @@
count = 0
proc_count = 0
proc_list = []
for row in rows:
count += 1
core.percent(count, num_rows, 1)
map_name = "%s_%i" % (base, count)
- expr = "%s = %s" % (map_name, expression)
- expr = expr.replace(sp.base.get_map_id(), row["id"])
- expr = expr.replace(sp.base.get_name(), row["id"])
+ # We need to modify the r(3).mapcalc expression
+ if type != "vector":
+ expr = "%s = %s" % (map_name, expression)
- map_id = map_name + "@" + mapset
+ expr = expr.replace(sp.base.get_map_id(), row["id"])
+ expr = expr.replace(sp.base.get_name(), row["id"])
+ # We need to build the id
+ map_id = dummy.build_id(map_name, mapset)
+ else:
+ map_id = dummy.build_id(map_name, mapset, row["layer"])
new_map = sp.get_new_map_instance(map_id)
@@ -116,17 +129,27 @@
else:
core.error(_("Map <%s> is already in temporal database, use overwrite flag to overwrite")%(new_map.get_map_id()))
continue
- core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
+ # Add process to the process list
+ core.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
proc_list.append(Process(target=run_mapcalc2d, args=(expr,)))
- else:
+ core.verbose(_("Apply r3.mapcalc expression: \"%s\"") % expr)
proc_list.append(Process(target=run_mapcalc3d, args=(expr,)))
+ core.verbose(_("Apply v.extract where statement: \"%s\"") % expression)
+ if row["layer"]:
+ proc_list.append(Process(target=run_vector_extraction, args=(row["id"], map_name, row["layer"], vtype, expression)))
+ else:
+ proc_list.append(Process(target=run_vector_extraction, args=(row["id"], map_name, layer, vtype, expression)))
proc_list[proc_count].start()
proc_count += 1
- if proc_count == nprocs:
+ # Join processes if the maximum number of processes are reached or the end of the
+ # loop is reached
+ if proc_count == nprocs or proc_count == num_rows:
proc_count = 0
exitcodes = 0
for proc in proc_list:
@@ -135,9 +158,9 @@
if exitcodes != 0:
dbif.close()
- core.fatal(_("Error while mapcalc computation"))
+ core.fatal(_("Error while computation"))
- # Empty proc list
+ # Empty process list
proc_list = []
# Store the new maps
@@ -155,6 +178,9 @@
new_sp.set_initial_values(temporal_type, semantic_type, title, description)
new_sp.insert(dbif)
+ # collect empty maps to remove them
+ empty_maps = []
# Register the maps in the database
count = 0
for row in rows:
@@ -173,10 +199,17 @@
# Read the raster map data
new_map.load()
- # In case of a null map continue, do not register null maps
- if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
- if not register_null:
- continue
+ # In case of a empty map continue, do not register empty maps
+ if type == "raster" or type == "raster3d":
+ if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+ if not register_null:
+ empty_maps.append(new_map)
+ continue
+ if new_map.metadata.get_primitives() == 0 or new_map.metadata.get_primitives() == None:
+ continue
if old_map.is_time_absolute():
@@ -197,6 +230,23 @@
new_sp.update_from_registered_maps(dbif)
core.percent(num_rows, num_rows, 1)
+ # Remove empty maps
+ if len(empty_maps) > 0:
+ names = ""
+ count = 0
+ for map in empty_maps:
+ if count == 0:
+ names += "%s"%(map.get_name())
+ else:
+ names += ",%s"%(map.get_name())
+ count += 1
+ if type == "raster":
+ core.run_command("g.remove", rast=names, quiet=True)
+ core.run_command("g.remove", rast3d=names, quiet=True)
+ core.run_command("g.remove", vect=names, quiet=True)
dbif.close()
@@ -209,4 +259,10 @@
def run_mapcalc3d(expr):
"""Helper function to run r3.mapcalc in parallel"""
- return core.run_command("r3.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
\ No newline at end of file
+ return core.run_command("r3.mapcalc", expression=expr, overwrite=core.overwrite(), quiet=True)
+def run_vector_extraction(input, output, layer, type, where):
+ """Helper function to run r.mapcalc in parallel"""
+ return core.run_command("v.extract", input=input, output=output, layer=layer, type=type, where=where, overwrite=core.overwrite(), quiet=True)
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -176,7 +176,6 @@
# Attach the map names
map_matrix.append(copy.copy(map_name_list))
# Needed for map registration
map_list = []
@@ -283,6 +282,9 @@
count = 0
+ empty_maps = []
# Insert maps in the temporal database and in the new space time dataset
for new_map in map_list:
@@ -295,6 +297,7 @@
continue
@@ -304,8 +307,23 @@
# Update the spatio-temporal extent and the metadata table entries
core.percent(1, 1, 1)
+ names = ""
+ count = 0
+ if count == 0:
+ else:
+ count += 1
dbif.close()
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/metadata.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -276,12 +276,27 @@
class vector_metadata(sql_database_interface):
"""!This is the vector metadata class"""
- def __init__(self, ident=None, stvds_register=None):
+ def __init__(self, ident=None, stvds_register=None, is_3d=False, points=None, lines=None, boundaries=None,\
+ centroids=None, faces=None, kernels=None, primitives=None, nodes=None, areas=None, \
+ islands=None, holes=None, volumes=None):
sql_database_interface.__init__(self, "vector_metadata", ident)
self.set_id(ident)
self.set_stvds_register(stvds_register)
+ self.set_3d_info(is_3d)
+ self.set_points(points)
+ self.set_lines(lines)
+ self.set_boundaries(boundaries)
+ self.set_centroids(centroids)
+ self.set_faces(faces)
+ self.set_kernels(kernels)
+ self.set_primitives(primitives)
+ self.set_nodes(nodes)
+ self.set_areas(areas)
+ self.set_islands(islands)
+ self.set_holes(holes)
+ self.set_volumes(volumes)
def set_id(self, ident):
"""!Convenient method to set the unique identifier (primary key)"""
@@ -292,6 +307,58 @@
"""!Set the space time vector dataset register table name"""
self.D["stvds_register"] = stvds_register
+ def set_3d_info(self, is_3d):
+ """!Set True if the vector map is three dimensional"""
+ self.D["is_3d"] = is_3d
+ def set_points(self, points):
+ """!Set the number of points of the vector map"""
+ self.D["points"] = points
+ def set_lines(self, lines):
+ """!Set the number of lines of the vector map"""
+ self.D["lines"] = lines
+ def set_boundaries(self, boundaries):
+ """!Set the number of boundaries of the vector map"""
+ self.D["boundaries"] = boundaries
+ def set_centroids(self, centroids):
+ """!Set the number of centroids of the vector map"""
+ self.D["centroids"] = centroids
+ def set_faces(self, faces):
+ """!Set the number of faces of the vector map"""
+ self.D["faces"] = faces
+ def set_kernels(self, kernels):
+ """!Set the number of kernels of the vector map"""
+ self.D["kernels"] = kernels
+ def set_primitives(self, primitives):
+ """!Set the number of primitives of the vector map"""
+ self.D["primitives"] = primitives
+ def set_nodes(self, nodes):
+ """!Set the number of nodes of the vector map"""
+ self.D["nodes"] = nodes
+ def set_areas(self, areas):
+ """!Set the number of areas of the vector map"""
+ self.D["areas"] = areas
+ def set_islands(self, islands):
+ """!Set the number of islands of the vector map"""
+ self.D["islands"] = islands
+ def set_holes(self, holes):
+ """!Set the number of holes of the vector map"""
+ self.D["holes"] = holes
+ def set_volumes(self, volumes):
+ """!Set the number of volumes of the vector map"""
+ self.D["volumes"] = volumes
def get_id(self):
"""!Convenient method to get the unique identifier (primary key)
@return None if not found
@@ -308,17 +375,145 @@
return self.D["stvds_register"]
else:
return None
+ def get_3d_info(self):
+ """!Return True if the map is three dimensional, False if not and None if not info was found"""
+ if self.D.has_key("is_3d"):
+ return self.D["is_3d"]
+ else:
+ return None
+ def get_points(self):
+ """!Get the number of points of the vector map
+ @return None if not found"""
+ if self.D.has_key("points"):
+ return self.D["points"]
+ else:
+ return None
+ def get_lines(self):
+ """!Get the number of lines of the vector map
+ if self.D.has_key("lines"):
+ return self.D["lines"]
+ else:
+ return None
+ def get_boundaries(self):
+ """!Get the number of boundaries of the vector map
+ if self.D.has_key("boundaries"):
+ return self.D["boundaries"]
+ else:
+ return None
+ def get_centroids(self):
+ """!Get the number of centroids of the vector map
+ if self.D.has_key("centroids"):
+ return self.D["centroids"]
+ else:
+ return None
+ def get_faces(self):
+ """!Get the number of faces of the vector map
+ if self.D.has_key("faces"):
+ return self.D["faces"]
+ else:
+ return None
+ def get_kernels(self):
+ """!Get the number of kernels of the vector map
+ if self.D.has_key("kernels"):
+ return self.D["kernels"]
+ else:
+ return None
+ def get_primitives(self):
+ """!Get the number of primitives of the vector map
+ if self.D.has_key("primitives"):
+ return self.D["primitives"]
+ else:
+ return None
+ def get_nodes(self):
+ """!Get the number of nodes of the vector map
+ if self.D.has_key("nodes"):
+ return self.D["nodes"]
+ else:
+ return None
+ def get_areas(self):
+ """!Get the number of areas of the vector map
+ if self.D.has_key("areas"):
+ return self.D["areas"]
+ else:
+ return None
+ def get_islands(self):
+ """!Get the number of islands of the vector map
+ if self.D.has_key("islands"):
+ return self.D["islands"]
+ else:
+ return None
+ def get_holes(self):
+ """!Get the number of holes of the vector map
+ if self.D.has_key("holes"):
+ return self.D["holes"]
+ else:
+ return None
+ def get_volumes(self):
+ """!Get the number of volumes of the vector map
+ if self.D.has_key("volumes"):
+ return self.D["volumes"]
+ else:
+ return None
def print_info(self):
"""!Print information about this class in human readable style"""
# 0123456789012345678901234567890
print " +-------------------- Metadata information ----------------------------------+"
print " | STVDS register table ....... " + str(self.get_stvds_register())
+ print " | Is map 3d .................. " + str(self.get_3d_info())
+ print " | Number of points ........... " + str(self.get_points())
+ print " | Number of lines ............ " + str(self.get_lines())
+ print " | Number of boundaries ....... " + str(self.get_boundaries())
+ print " | Number of centroids ........ " + str(self.get_centroids())
+ print " | Number of faces ............ " + str(self.get_faces())
+ print " | Number of kernels .......... " + str(self.get_kernels())
+ print " | Number of primitives ....... " + str(self.get_primitives())
+ print " | Number of nodes ............ " + str(self.get_nodes())
+ print " | Number of areas ............ " + str(self.get_areas())
+ print " | Number of islands .......... " + str(self.get_islands())
+ print " | Number of holes ............ " + str(self.get_holes())
+ print " | Number of volumes .......... " + str(self.get_volumes())
def print_shell_info(self):
"""!Print information about this class in shell style"""
print "stvds_register=" + str(self.get_stvds_register())
+ print "is_3d=" + str(self.get_3d_info())
+ print "points=" + str(self.get_points())
+ print "lines=" + str(self.get_lines())
+ print "boundaries=" + str(self.get_boundaries())
+ print "centroids=" + str(self.get_centroids())
+ print "faces=" + str(self.get_faces())
+ print "kernels=" + str(self.get_kernels())
+ print "primitives=" + str(self.get_primitives())
+ print "nodes=" + str(self.get_nodes())
+ print "areas=" + str(self.get_areas())
+ print "islands=" + str(self.get_islands())
+ print "holes=" + str(self.get_holes())
+ print "volumes=" + str(self.get_volumes())
@@ -614,16 +809,79 @@
class stvds_metadata(stds_metadata_base):
"""!This is the raster metadata class"""
- def __init__(self, ident=None, vector_register=None, title=None, description=None):
+ def __init__(self, ident=None, vector_register=None, title=None, description=None, \
+ points=None, lines=None, boundaries=None,\
stds_metadata_base.__init__(self, "stvds_metadata", ident, title, description)
self.set_vector_register(vector_register)
def set_vector_register(self, vector_register):
"""!Set the vector map register table name"""
self.D["vector_register"] = vector_register
def get_vector_register(self):
"""!Get the vector map register table name
@@ -632,16 +890,136 @@
else:
return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
+ else:
+ return None
stds_metadata_base.print_info(self)
print " | Vector register table:...... " + str(self.get_vector_register())
stds_metadata_base.print_shell_info(self)
print "vector_register=" + str(self.get_vector_register())
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -22,13 +22,11 @@
@author Soeren Gebbert
import getpass
-import grass.script.raster as raster
-import grass.script.vector as vector
-import grass.script.raster3d as raster3d
from ctypes import *
import grass.lib.gis as libgis
import grass.lib.raster as libraster
+import grass.lib.vector as libvector
+import grass.lib.raster3d as libraster3d
from datetime_math import *
from abstract_map_dataset import *
@@ -176,21 +174,33 @@
if libraster.Rast_map_is_fp(name, mapset):
range = libraster.FPRange()
libraster.Rast_init_fp_range (byref(range))
- libraster.Rast_read_fp_range(name, mapset, byref(range))
- min = libgis.DCELL()
- max = libgis.DCELL()
- libraster.Rast_get_fp_range_min_max(byref(range), byref(min), byref(max))
- kvp["min"] = float(min.value)
- kvp["max"] = float(max.value)
+ ret = libraster.Rast_read_fp_range(name, mapset, byref(range))
+ if ret < 0:
+ core.fatal(_("Unable to read range file"))
+ if ret == 2:
+ kvp["min"] = None
+ kvp["max"] = None
+ else:
+ min = libgis.DCELL()
+ max = libgis.DCELL()
+ libraster.Rast_get_fp_range_min_max(byref(range), byref(min), byref(max))
+ kvp["min"] = min.value
+ kvp["max"] = max.value
else:
range = libraster.Range()
libraster.Rast_init_range (byref(range))
- libraster.Rast_read_range(name, mapset, byref(range))
- min = libgis.CELL()
- max = libgis.CELL()
- kvp["min"] = int(min.value)
- kvp["max"] = int(max.value)
+ ret = libraster.Rast_read_range(name, mapset, byref(range))
+ if ret < 0:
+ if ret == 2:
+ kvp["min"] = None
+ kvp["max"] = None
+ else:
+ min = libgis.CELL()
+ max = libgis.CELL()
+ libraster.Rast_get_range_min_max(byref(range), byref(min), byref(max))
return kvp
@@ -268,7 +278,7 @@
return self.spatial_extent.overlapping_2d(dataset.spatial_extent)
def spatial_relation(self, dataset):
- """Return the two or three dimensional spatial relation"""
+ """!Return the two or three dimensional spatial relation"""
if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
return self.spatial_extent.spatial_relation(dataset.spatial_extent)
@@ -334,26 +344,95 @@
return True
+ def read_info(self):
+ """!Read the raster3d map info from the file system and store the content
+ into a dictionary
+ This method uses the ctypes interface to the gis and raster3d libraries
+ to read the map metadata information
+ kvp = {}
+ name = self.get_name()
+ mapset = self.get_mapset()
+ if not self.map_exists():
+ core.fatal(_("Raster3d map <%s> not found" % name))
+ # Read the region information
+ region = libraster3d.RASTER3D_Region()
+ libraster3d.Rast3d_read_region_map(name, mapset, byref(region))
+ kvp["north"] = region.north
+ kvp["south"] = region.south
+ kvp["east"] = region.east
+ kvp["west"] = region.west
+ kvp["nsres"] = region.ns_res
+ kvp["ewres"] = region.ew_res
+ kvp["tbres"] = region.tb_res
+ kvp["rows"] = region.cols
+ kvp["cols"] = region.rows
+ kvp["depths"] = region.depths
+ kvp["top"] = region.top
+ kvp["bottom"] = region.bottom
+ # We need to open the map, this function returns a void pointer
+ # but we may need the correct type which is RASTER3D_Map, hence the casting
+ g3map = cast(libraster3d.Rast3d_open_cell_old(name, mapset, \
+ libraster3d.RASTER3D_DEFAULT_WINDOW, libraster3d.RASTER3D_TILE_SAME_AS_FILE, \
+ libraster3d.RASTER3D_NO_CACHE), POINTER(libraster3d.RASTER3D_Map))
+ if not g3map:
+ core.fatal(_("Unable to open 3D raster map <%s>"%(name)));
+ maptype = libraster3d.Rast3d_file_type_map(g3map)
+ if maptype == libraster.DCELL_TYPE:
+ kvp["datatype"] = "DCELL"
+ elif maptype == libraster.FCELL_TYPE:
+ kvp["datatype"] = "FCELL"
+ # Read range
+ ret = libraster3d.Rast3d_range_load(g3map)
+ if not ret:
+ core.fatal(_("Unable to load range of 3D raster map <%s>"%(name)));
+ libraster3d.Rast3d_range_min_max(g3map, byref(min), byref(max))
+ if min.value != min.value:
+ kvp["min"] = None
+ else:
+ kvp["min"] = float(min.value)
+ if max.value != max.value:
+ kvp["max"] = None
+ else:
+ kvp["max"] = float(max.value)
+ if not libraster3d.Rast3d_close(g3map):
+ G_fatal_error(_("Unable to close 3D raster map <%s>"%(name)))
+ return kvp
def load(self):
"""!Load all info from an existing raster3d map into the internal structure"""
- # Get the data from an existing raster map
- kvp = raster3d.raster3d_info(self.get_map_id())
# Fill base information
self.base.set_name(self.ident.split("@")[0])
self.base.set_mapset(self.ident.split("@")[1])
self.base.set_creator(str(getpass.getuser()))
# Fill spatial extent
+ # Get the data from an existing raster map
+ kvp = self.read_info()
self.set_spatial_extent(north=kvp["north"], south=kvp["south"], \
east=kvp["east"], west=kvp["west"],\
top=kvp["top"], bottom=kvp["bottom"])
# Fill metadata
self.metadata.set_nsres(kvp["nsres"])
self.metadata.set_ewres(kvp["ewres"])
self.metadata.set_tbres(kvp["tbres"])
@@ -361,10 +440,12 @@
self.metadata.set_min(kvp["min"])
self.metadata.set_max(kvp["max"])
- rows = int((kvp["north"] - kvp["south"])/kvp["nsres"] + 0.5)
- cols = int((kvp["east"] - kvp["west"])/kvp["ewres"] + 0.5)
- depths = int((kvp["top"] - kvp["bottom"])/kvp["tbres"] + 0.5)
+ rows = kvp["rows"]
+ cols = kvp["cols"]
+ depths = kvp["depths"]
+ ncells = cols * rows
ncells = cols * rows * depths
self.metadata.set_cols(cols)
@@ -412,7 +493,7 @@
- """Return the two dimensional spatial relation"""
+ """!Return the two dimensional spatial relation"""
return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
@@ -475,11 +556,86 @@
return True
+ """!Read the vector map info from the file system and store the content
+ into a dictionary
+ This method uses the ctypes interface to the vector libraries
+ kvp = {}
+ core.fatal(_("Vector map <%s> not found" % name))
+ # The vector map structure
+ Map = libvector.Map_info()
+ # We open the maps always in topology mode first
+ libvector.Vect_set_open_level(2)
+ with_topo = True
+ # Code lend from v.info main.c
+ if libvector.Vect_open_old_head2(byref(Map), name, mapset, "1") < 2:
+ # force level 1, open fully
+ # NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available
+ libvector.Vect_close(byref(Map))
+ libvector.Vect_set_open_level(1) # no topology
+ with_topo = False
+ if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
+ core.fatal(_("Unable to open vector map <%s>"%(libvector.Vect_get_full_name(byref(Map)))))
+ # Read the extent information
+ bbox = libvector.bound_box()
+ libvector.Vect_get_map_box(byref(Map), byref(bbox));
+ kvp["north"] = bbox.N
+ kvp["south"] = bbox.S
+ kvp["east"] = bbox.E
+ kvp["west"] = bbox.W
+ kvp["top"] = bbox.T
+ kvp["bottom"] = bbox.B
+ kvp["is_3d"] = bool(libvector.Vect_is_3d(byref(Map)))
+ # Read number of features
+ kvp["points"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_POINT)
+ kvp["lines"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_LINE)
+ kvp["boundaries"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_BOUNDARY)
+ kvp["centroids"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_CENTROID)
+ kvp["faces"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_FACE)
+ kvp["kernels"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_KERNEL)
+ # Summarize the primitives
+ kvp["primitives"] = kvp["points"] + kvp["lines"] + kvp["boundaries"] + kvp["centroids"]
+ if kvp["is_3d"]:
+ kvp["primitives"] += kvp["faces"] + kvp["kernels"]
+ # Read topology information
+ if with_topo:
+ kvp["nodes"] = libvector.Vect_get_num_nodes(byref(Map))
+ kvp["areas"] = libvector.Vect_get_num_areas(byref(Map))
+ kvp["islands"] = libvector.Vect_get_num_islands(byref(Map))
+ kvp["holes"] = libvector.Vect_get_num_holes(byref(Map))
+ kvp["volumes"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_VOLUME)
+ else:
+ kvp["nodes"] = None
+ kvp["areas"] = None
+ kvp["islands"] = None
+ kvp["holes"] = None
+ kvp["volumes"] = None
+ return kvp
def load(self):
"""!Load all info from an existing vector map into the internal structure"""
- kvp = vector.vector_info(self.get_map_id())
if self.ident.find(":") >= 0:
@@ -490,13 +646,28 @@
- # Fill metadata .. no metadata yet
+ # Fill metadata
+ self.metadata.set_3d_info(kvp["is_3d"])
+ self.metadata.set_points(kvp["points"])
+ self.metadata.set_lines(kvp["lines"])
+ self.metadata.set_boundaries(kvp["boundaries"])
+ self.metadata.set_centroids(kvp["centroids"])
+ self.metadata.set_faces(kvp["faces"])
+ self.metadata.set_kernels(kvp["kernels"])
+ self.metadata.set_primitives(kvp["primitives"])
+ self.metadata.set_nodes(kvp["nodes"])
+ self.metadata.set_areas(kvp["areas"])
+ self.metadata.set_islands(kvp["islands"])
+ self.metadata.set_holes(kvp["holes"])
+ self.metadata.set_volumes(kvp["volumes"])
@@ -531,7 +702,7 @@
@@ -588,7 +759,7 @@
@@ -645,7 +816,7 @@
Modified: grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql 2012-04-13 11:13:35 UTC (rev 51407)
@@ -13,6 +13,18 @@
number_of_maps INTEGER, -- The number of registered vector maps
title VARCHAR, -- Title of the space-time vector dataset
description VARCHAR, -- Detailed description of the space-time vector dataset
+ points INTEGER, -- The number of points accumulated from all registered maps
+ lines INTEGER, -- The number of lines accumulated from all registered maps
+ boundaries INTEGER, -- The number of boundaries accumulated from all registered maps
+ centroids INTEGER, -- The number of centroids accumulated from all registered maps
+ faces INTEGER, -- The number of faces accumulated from all registered maps
+ kernels INTEGER, -- The number of kernels accumulated from all registered maps
+ primitives INTEGER, -- All primitives accumulated (points, lines,boundaries,centroids,faces,kernels)
+ nodes INTEGER, -- Number of nodes accumulated from all registered maps (topological information)
+ areas INTEGER, -- The number of areas accumulated from all registered maps (topological information)
+ islands INTEGER, -- The number of islands accumulated from all registered maps (topological information)
+ holes INTEGER, -- The number of holes accumulated from all registered maps (topological information)
+ volumes INTEGER, -- The number of volumes accumulated from all registered maps (topological information)
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES stvds_base (id) ON DELETE CASCADE
@@ -30,7 +42,10 @@
A3.north, A3.south, A3.east, A3.west, A3.proj,
A4.vector_register,
A4.number_of_maps,
- A4.title, A4.description
+ A4.title, A4.description, A4.points, A4.lines,
+ A4.boundaries, A4.centroids, A4.faces, A4.kernels,
+ A4.primitives, A4.nodes, A4.areas, A4.islands,
+ A4.holes, A4.volumes
FROM stvds_base A1, stvds_absolute_time A2,
stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
A1.id = A3.id AND A1.id = A4.id;
@@ -46,7 +61,10 @@
A4.vector_register,
A4.number_of_maps,
FROM stvds_base A1, stvds_relative_time A2,
Modified: grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
--- grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql 2012-04-13 11:13:35 UTC (rev 51407)
@@ -3,4 +3,57 @@
-- concept is clear
-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
+-- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant): name_mapset
+-- SPACETIME_ID is a placeholder for specific stds id: name at mapset
+-- Update the vector features and topology
+UPDATE stvds_metadata SET points =
+ (SELECT sum(points) FROM vector_metadata WHERE vector_metadata.id IN
+ (SELECT id FROM SPACETIME_NAME_vector_register)
+ ) WHERE id = 'SPACETIME_ID';
+UPDATE stvds_metadata SET lines =
+ (SELECT sum(lines) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET boundaries =
+ (SELECT sum(boundaries) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET centroids =
+ (SELECT sum(centroids) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET faces =
+ (SELECT sum(faces) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET kernels =
+ (SELECT sum(kernels) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET primitives =
+ (SELECT sum(primitives) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET nodes =
+ (SELECT sum(nodes) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET areas =
+ (SELECT sum(areas) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET islands =
+ (SELECT sum(islands) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET holes =
+ (SELECT sum(holes) FROM vector_metadata WHERE vector_metadata.id IN
+UPDATE stvds_metadata SET volumes =
+ (SELECT sum(volumes) FROM vector_metadata WHERE vector_metadata.id IN
Modified: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-04-13 11:13:35 UTC (rev 51407)
@@ -12,6 +12,19 @@
CREATE TABLE vector_metadata (
id VARCHAR NOT NULL, -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
stvds_register VARCHAR, -- The name of the table storing all space-time vector datasets in which this map is registered
+ is_3d INTEGER, -- This is 1 if the vector map is 3d and 0 otherwise
+ nodes INTEGER, -- Number of nodes (topological information)
+ areas INTEGER, -- The number of areas (topological information)
+ islands INTEGER, -- The number of islands (topological information)
+ holes INTEGER, -- The number of holes (topological information)
+ volumes INTEGER, -- The number of volumes (topological information)
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES vector_base (id) ON DELETE CASCADE
@@ -27,7 +40,10 @@
A1.creator,
A2.start_time, A2.end_time, A2.timezone,
- A4.stvds_register
+ A4.stvds_register, A4.is_3d, A4.points, A4.lines,
FROM vector_base A1, vector_absolute_time A2,
vector_spatial_extent A3, vector_metadata A4
WHERE A1.id = A2.id AND A1.id = A3.id AND A1.id = A4.id;
@@ -41,7 +57,10 @@
A1.creator,
- A4.stvds_register
FROM vector_base A1, vector_relative_time A2,
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/Makefile 2012-04-13 11:13:35 UTC (rev 51407)
@@ -25,6 +25,7 @@
t.rast3d.extract \
t.rast3d.mapcalc \
t.vect.list \
+ t.vect.extract \
t.vect.what.strds \
t.vect.observe.strds
Added: grass/trunk/temporal/run_all_tests.sh
--- grass/trunk/temporal/run_all_tests.sh (rev 0)
+++ grass/trunk/temporal/run_all_tests.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -0,0 +1,19 @@
+#!/usr/bin/env bash
+# This scripts runs all tests available in the temporal module directory
+# Logs a written to "run.log"
+LOG_FILE="/tmp/run.log"
+echo "Logfile\n\n" > $LOG_FILE
+# For each directory
+for dir in `ls -d t*` ; do
+ if [ -d $dir ] ; then
+ echo $dir
+ cd $dir
+ for file in `ls test.* | grep -v '~'` ; do
+ bash $file >> $LOG_FILE 2>&1
+ done
+ cd -
+ fi
+done
+cp $LOG_FILE .
Property changes on: grass/trunk/temporal/run_all_tests.sh
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.info/t.info.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -81,17 +81,17 @@
mapset = grass.gisenv()["MAPSET"]
id = name + "@" + mapset
- sp = tgis.dataset_factory(type, id)
+ ds = tgis.dataset_factory(type, id)
- if sp.is_in_db() == False:
- grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ if ds.is_in_db() == False:
+ grass.fatal(_("Dataset <%s> not found") % (id))
- sp.select()
+ ds.select()
if shellstyle == True:
- sp.print_shell_info()
+ ds.print_shell_info()
else:
- sp.print_info()
+ ds.print_info()
if __name__ == "__main__":
options, flags = grass.parser()
Modified: grass/trunk/temporal/t.rast.export/test.t.rast.export.sh
--- grass/trunk/temporal/t.rast.export/test.t.rast.export.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.rast.export/test.t.rast.export.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -32,3 +32,4 @@
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=strds input=precip_abs1
+rm strds_export.tar.bz2
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -44,3 +44,5 @@
g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+rm -rf test
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -24,14 +24,25 @@
# The first @test
t.rast.mapcalc --o --v -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
expression=" precip_abs1 + precip_abs2" base=new_prec \
- method=equal nprocs=6
+ method=equal nprocs=5
t.info type=strds input=precip_abs3
t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
expression=" (precip_abs1 + precip_abs2) / precip_abs3 at PERMANENT " base=new_prec \
t.info type=strds input=precip_abs4
+t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+ expression=" (precip_abs1 + precip_abs2) * null() " base=new_prec \
+t.info type=strds input=precip_abs4
+t.rast.mapcalc --o --v -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+# @postprocess
t.unregister type=rast maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -118,10 +118,8 @@
if sp.is_time_absolute():
map.set_absolute_time(start_time, end_time, tz)
- map.write_absolute_time_to_file()
else:
map.set_relative_time(start_time, end_time)
- map.write_relative_time_to_file()
# Register the map in the temporal database
if map.is_in_db():
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -128,10 +128,8 @@
r3ds.set_absolute_time(start, end)
- r3ds.write_absolute_time_to_file()
else:
r3ds.set_relative_time(start, end, sp.get_relative_time_unit())
- r3ds.write_relative_time_to_file()
r3ds.insert()
Modified: grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.reltime.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -66,33 +66,33 @@
# File 1
t.register -i input=precip_abs8 file="${n1}" start=0 increment=7 unit=days
t.info type=strds input=precip_abs8
-tr.list input=precip_abs8
+t.rast.list input=precip_abs8
# File 1
t.unregister --v type=rast file="${n1}"
t.register input=precip_abs8 file="${n1}" start=20 unit=years
# File 2
t.register input=precip_abs8 file="${n2}" unit=minutes
# File 2 ERROR ERROR -- Increment computation needs to be fixed
t.register input=precip_abs8 file="${n2}" increment=14 unit=days
t.register -i input=precip_abs8 file="${n2}" increment=14 unit=days
# File 3
t.register -i input=precip_abs8 file="${n3}" unit=seconds
Modified: grass/trunk/temporal/t.register/test.t.register.raster.file.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.file.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.register/test.t.register.raster.file.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -59,23 +59,23 @@
# File 1
t.register -i input=precip_abs8 file="${n1}" start="2001-01-01" increment="1 months"
# File 1
t.register input=precip_abs8 file="${n1}" start="2001-01-01"
# File 2
# File 2
t.register input=precip_abs8 file="${n2}" increment="1 months"
# File 3
t.remove --v type=strds input=precip_abs8
Modified: grass/trunk/temporal/t.register/test.t.register.raster.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.register/test.t.register.raster.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -32,62 +32,62 @@
t.info type=strds input=precip_abs1
t.info -g type=strds input=precip_abs1
r.info map=prec_1
-tr.list input=precip_abs1
+t.rast.list input=precip_abs1
t.topology input=precip_abs1
t.register -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
t.info type=strds input=precip_abs2
t.info -g type=strds input=precip_abs2
r.info map=prec_1
-tr.list input=precip_abs2
+t.rast.list input=precip_abs2
t.topology input=precip_abs2
t.register -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
t.info -g type=strds input=precip_abs3
r.info map=prec_1
-tr.list input=precip_abs3
+t.rast.list input=precip_abs3
t.topology input=precip_abs3
t.register input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
t.info -g type=strds input=precip_abs4
r.info map=prec_1
-tr.list input=precip_abs4
+t.rast.list input=precip_abs4
t.topology input=precip_abs4
t.register input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
t.info -g type=strds input=precip_abs5
r.info map=prec_1
-tr.list input=precip_abs5
+t.rast.list input=precip_abs5
t.topology input=precip_abs5
t.register input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
t.info -g type=strds input=precip_abs6
r.info map=prec_1
-tr.list input=precip_abs6
+t.rast.list input=precip_abs6
t.topology input=precip_abs6
t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
t.info -g type=strds input=precip_abs7
r.info map=prec_1
-tr.list input=precip_abs7
+t.rast.list input=precip_abs7
t.topology input=precip_abs7
# Register with different valid time again
t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
r.info map=prec_1
# Register with different valid time again creating an interval
t.register -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
r.info map=prec_1
t.register input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
r.info map=prec_1
Modified: grass/trunk/temporal/t.register/test.t.register.raster3d.sh
--- grass/trunk/temporal/t.register/test.t.register.raster3d.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.register/test.t.register.raster3d.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -30,7 +30,7 @@
t.register type=rast3d --v -i input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="1 seconds"
t.info type=str3ds input=volume_abs1
-tr3.unregister --v input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
+t.unregister --v type=rast3d input=volume_abs1 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6
t.register type=rast3d --v -i input=volume_abs2 maps=volume_1,volume_2,volume_3,volume_4,volume_5,volume_6 start="2001-01-01" increment="20 seconds, 5 minutes"
Modified: grass/trunk/temporal/t.sample/test.t.sample.sh
--- grass/trunk/temporal/t.sample/test.t.sample.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.sample/test.t.sample.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -56,11 +56,11 @@
t.create --o type=stvds temporaltype=absolute output=pnts_abs1 title="A test with vector input files" descr="A test with vector input files"
t.register type=rast -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
-tr.list precip_abs0 -h
+t.rast.list precip_abs0 -h
t.register type=vect input=pnts_abs0 file="${n2}" start=file end=file
-tv.list pnts_abs0 -h
+t.vect.list pnts_abs0 -h
t.register type=vect input=pnts_abs1 file="${n3}" start=file end=file
-tv.list pnts_abs1 -h
+t.vect.list pnts_abs1 -h
# The @test
t.sample method=equal input=precip_abs0,precip_abs0,precip_abs0,precip_abs0 samtype=stvds sample=pnts_abs0 -cs
@@ -72,10 +72,13 @@
# Test with temporal point data
t.register type=rast input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
t.sample input=precip_abs0 samtype=stvds sample=pnts_abs0 -cs
t.sample input=precip_abs0 samtype=stvds sample=pnts_abs1 -cs
+t.unregister type=vect maps=pnts1,pnts2,pnts3,pnts4,pnts5,pnts6,pnts7,pnts8
t.remove type=strds input=precip_abs0
t.remove type=stvds input=pnts_abs0,pnts_abs1
+g.remove rast=prec_1,prec_2,prec_3,,prec_4,prec_5,prec_6
+g.remove vect=pnts1,pnts2,pnts3,pnts4,pnts5,pnts6,pnts7,pnts8
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.support/t.support.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -119,7 +119,7 @@
count += 1
# Execute the collected SQL statenents
- tgis.execute_transaction(statement, dbif)
+ dbif.execute_transaction(statement)
if map_update or update:
sp.update_from_registered_maps(dbif=dbif)
Added: grass/trunk/temporal/t.vect.extract/Makefile
--- grass/trunk/temporal/t.vect.extract/Makefile (rev 0)
+++ grass/trunk/temporal/t.vect.extract/Makefile 2012-04-13 11:13:35 UTC (rev 51407)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.vect.extract
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.vect.extract/t.vect.extract.html
Added: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.py (rev 0)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -0,0 +1,93 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.vect.extract
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Extract a subset of a space time vector dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Extract a subset of a space time raster dataset
+#% keywords: temporal
+#% keywords: extract
+#%end
+#%option G_OPT_STVDS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option G_OPT_DB_WHERE
+#% key: expression
+#%end
+#%option G_OPT_STVDS_OUTPUT
+#%end
+#%option G_OPT_V_FIELD
+#%end
+#%option G_OPT_V_TYPE
+#%end
+#%option
+#% key: base
+#% type: string
+#% description: Base name of the new created vector maps
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: The number of v.extract processes to run in parallel. Use only if you have a database backend which supports concurrent writing.
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register empty maps
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+from multiprocessing import Process
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ where = options["where"]
+ expression = options["expression"]
+ layer = options["layer"]
+ type = options["type"]
+ base = options["base"]
+ nprocs = int(options["nprocs"])
+ register_null = flags["n"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ tgis.extract_dataset(input, output, "vector", where, expression, base, nprocs, register_null, layer, type)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
Added: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh (rev 0)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -0,0 +1,47 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+v.random --o -z output=soil_1 n=100 zmin=0 zmax=100 column=height seed=1
+v.random --o -z output=soil_2 n=100 zmin=0 zmax=100 column=height seed=2
+v.random --o -z output=soil_3 n=100 zmin=0 zmax=100 column=height seed=3
+v.random --o -z output=soil_4 n=100 zmin=0 zmax=100 column=height seed=4
+v.random --o -z output=soil_5 n=100 zmin=0 zmax=100 column=height seed=5
+v.random --o -z output=soil_6 n=100 zmin=0 zmax=100 column=height seed=6
+v.random --o -z output=soil_7 n=100 zmin=0 zmax=100 column=height seed=7
+v.random --o -z output=soil_8 n=100 zmin=0 zmax=100 column=height seed=8
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+soil_1
+soil_2
+soil_3
+soil_4
+soil_5
+soil_6
+soil_7
+soil_8
+EOF
+t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
+t.register -i type=vect input=soil_abs1 file="${n1}" start='2001-01-01' increment="1 months"
+t.info type=stvds input=soil_abs1
+t.vect.list input=soil_abs1
+# The @test
+t.vect.extract --v input=soil_abs1 output=soil_abs2 where="start_time > '2001-03-01 00:00:01'"
+t.info type=stvds input=soil_abs2
+t.vect.list input=soil_abs2
+t.vect.extract --v --o input=soil_abs1 output=soil_abs3 where="start_time >= '2001-01-01'" \
+ base=new_vect expr=" height > 50" nprocs=1
+t.info type=stvds input=soil_abs3
+t.vect.list input=soil_abs3 columns=name,start_time,end_time,primitives
+# @postprocess
+t.unregister type=vect maps=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
+t.remove type=stvds input=soil_abs1,soil_abs2,soil_abs3
+g.remove vect=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
+g.remove vect=new_vect_1,new_vect_2,new_vect_3,new_vect_4,new_vect_5,new_vect_6
Property changes on: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-04-13 11:13:35 UTC (rev 51407)
@@ -29,7 +29,7 @@
#% description: Order the space time dataset by category.
#% required: no
#% multiple: yes
-#% options: id,name,layer,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east
+#% options: id,name,layer,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,points,lines,boundaries,centroids,faces,kernels,primitives,nodes,areas,islands,holes,volumes
#% answer: start_time
#%end
@@ -39,7 +39,7 @@
#% description: Select columns to be printed to stdout
#% required: no
#% multiple: yes
#% answer: id,name,layer,mapset,start_time,end_time
#%end
Modified: grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -103,3 +103,4 @@
t.unregister type=vect maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
t.remove type=stvds input=lidar_abs1,lidar_abs2,lidar_abs3,lidar_abs4,lidar_abs5
+g.remove vect=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2012-04-13 10:49:02 UTC (rev 51406)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2012-04-13 11:13:35 UTC (rev 51407)
@@ -45,12 +45,12 @@
t.create --o type=strds temporaltype=absolute output=sand_frac_abs_1 title="A test" descr="A test"
t.register -i type=rast input=sand_frac_abs_1 maps=sand_frac start="2001-01-01 00:00:00" increment="12 months"
-tr.list input=sand_frac_abs_1 columns=name,start_time,end_time
+t.rast.list input=sand_frac_abs_1 columns=name,start_time,end_time
t.create --o type=strds temporaltype=absolute output=sand_frac_abs_2 title="A test" descr="A test"
t.register -i type=rast input=sand_frac_abs_2 maps=sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6 \
start="2001-03-01 00:00:00" increment="1 months"
-tr.list input=sand_frac_abs_2 columns=name,start_time,end_time
+t.rast.list input=sand_frac_abs_2 columns=name,start_time,end_time
# Start the @test
t.vect.what.strds --v input=soil_abs strds=sand_frac_abs_1 sampling=overlap,during,contain column=sand_frac
