[GRASS-SVN] r51430 - grass/trunk/vector/v.net.allpairs
Fri Apr 13 14:52:38 EDT 2012
Author: mmetz
Date: 2012-04-13 11:52:38 -0700 (Fri, 13 Apr 2012)
New Revision: 51430
   grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
update manual
Modified: grass/trunk/vector/v.net.allpairs/v.net.allpairs.html
--- grass/trunk/vector/v.net.allpairs/v.net.allpairs.html	2012-04-13 18:52:07 UTC (rev 51429)
+++ grass/trunk/vector/v.net.allpairs/v.net.allpairs.html	2012-04-13 18:52:38 UTC (rev 51430)
@@ -22,16 +22,35 @@
 If <b>abcolumn</b> is not given then then the same costs are used for
 forward and backward arcs.
-<h2>EXAMPLES</h2>
+<h2>EXAMPLE</h2>
-Find shortest path from each intersection with pedestrian crossing to
-every other point using <em>SHAPE_LEN</em> for the cost of traversing
-the arcs in both directions.
+Find shortest path along roads from selected archsites (Spearfish sample
+dataset):
 <div class="code"><pre>
-v.net.allpairs input=roads output=roads_pairs afcol=SHAPE_LEN where="crossing=1"
+# prepare network: connect archsites to roads with threshold 200
+v.net input=roads at PERMANENT points=archsites at PERMANENT \
+output=roads_net operation=connect thresh=200
+# verify result
+v.category input=roads_net option=report
+# only lines should have a category in layer 1
+# only points should have a category in layer 2
+# shortest path between all points with categories 1 - 5 in layer 2
+v.net.allpairs input=roads_net cats=1-5 out=roads_net_all
+v.db.select roads_net_all
 </pre></div>
-<p>
+Result in matrix form:
+<div class="code"><pre>
+from\to	1		3		4		5
+1	0		18820.386	17206.651	17373.274
+3	18820.386	0		1739.079	9040.575
+4	17206.651	1739.079	0		7426.84
+5	17373.274	9040.575	7426.84		0
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
