[GRASS-SVN] r51431 - grass/trunk/lib/vector/neta
svn_grass at osgeo.org
Fri Apr 13 16:32:46 EDT 2012
Author: mmetz
Date: 2012-04-13 13:32:46 -0700 (Fri, 13 Apr 2012)
New Revision: 51431
Removed:
grass/trunk/lib/vector/neta/allpairs.c
neta lib:remove unused fn
Deleted: grass/trunk/lib/vector/neta/allpairs.c
--- grass/trunk/lib/vector/neta/allpairs.c 2012-04-13 18:52:38 UTC (rev 51430)
+++ grass/trunk/lib/vector/neta/allpairs.c 2012-04-13 20:32:46 UTC (rev 51431)
@@ -1,102 +0,0 @@
- \file vector/neta/allpairs.c
- \brief Network Analysis library - shortest path between all pairs
- Computes the length of the shortest path between all pairs of nodes
- in the network.
- (C) 2009-2010 by Daniel Bundala, and the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
- \author Daniel Bundala (Google Summer of Code 2009)
-#include <stdio.h>
-#include <stdlib.h>
-#include <grass/gis.h>
-#include <grass/vector.h>
-#include <grass/glocale.h>
-#include <grass/dgl/graph.h>
- \brief Stores the directed distance between every pair
- \todo Use only O(W*W) memory where W is the number of nodes present in the graph
- Upon the completion, dist stores the directed distance between every pair (i,j)
- or -1 if the nodes are unreachable. It must be an array of dimension [nodes+1]*[nodes+1]
- \param graph input graph
- \param[out] dist list of directed distance
- \return -1 on error
- \return 0 on success
-int NetA_allpairs(dglGraph_s * graph, dglInt32_t ** dist)
- int nnodes, i, j, k, indices;
- dglEdgesetTraverser_s et;
- dglNodeTraverser_s nt;
- dglInt32_t *node;
- nnodes = dglGet_NodeCount(graph);
- dglInt32_t *node_indices;
- node_indices = (dglInt32_t *) G_calloc(nnodes, sizeof(dglInt32_t));
- if (!node_indices) {
- G_fatal_error(_("Out of memory"));
- return -1;
- G_message(_("Computing all pairs shortest paths..."));
- G_percent_reset();
- for (i = 0; i <= nnodes; i++)
- for (j = 0; j <= nnodes; j++)
- dist[i][j] = -1;
- dglNode_T_Initialize(&nt, graph);
- indices = 0;
- for (node = dglNode_T_First(&nt); node; node = dglNode_T_Next(&nt)) {
- dglInt32_t node_id = dglNodeGet_Id(graph, node);
- node_indices[indices++] = node_id;
- dglInt32_t *edge;
- dglEdgeset_T_Initialize(&et, graph,
- dglNodeGet_OutEdgeset(graph, node));
- for (edge = dglEdgeset_T_First(&et); edge;
- edge = dglEdgeset_T_Next(&et))
- if (dglEdgeGet_Id(graph, edge) < 0) /*ignore backward edges */
- dist[node_id][dglNodeGet_Id
- (graph, dglEdgeGet_Tail(graph, edge))] =
- dglEdgeGet_Cost(graph, edge);
- dglEdgeset_T_Release(&et);
- dglNode_T_Release(&nt);
- for (k = 0; k < indices; k++) {
- dglInt32_t k_index = node_indices[k];
- G_percent(k + 1, indices, 1);
- for (i = 0; i < indices; i++) {
- dglInt32_t i_index = node_indices[i];
- if (dist[i_index][k_index] == -1)
- continue; /*no reason to proceed along infinite path */
- for (j = 0; j < indices; j++) {
- dglInt32_t j_index = node_indices[j];
- if (dist[k_index][j_index] != -1 &&
- (dist[i_index][k_index] + dist[k_index][j_index] <
- dist[i_index][j_index] ||
- dist[i_index][j_index] == -1)) {
- dist[i_index][k_index] + dist[k_index][j_index];
- G_free(node_indices);
- return 0;
