[GRASS-SVN] r51473 - grass/trunk/vector/v.out.vtk
Wed Apr 18 13:05:00 EDT 2012
Author: mmetz
Date: 2012-04-18 10:05:00 -0700 (Wed, 18 Apr 2012)
New Revision: 51473
   grass/trunk/vector/v.out.vtk/local_proto.h
   grass/trunk/vector/v.out.vtk/main.c
   grass/trunk/vector/v.out.vtk/writeVTK.c
v.out.vtk: port -n flag to trunk
Modified: grass/trunk/vector/v.out.vtk/local_proto.h
--- grass/trunk/vector/v.out.vtk/local_proto.h	2012-04-18 15:52:45 UTC (rev 51472)
+++ grass/trunk/vector/v.out.vtk/local_proto.h	2012-04-18 17:05:00 UTC (rev 51473)
@@ -23,7 +23,7 @@
 /*Write the vtk output */
 int write_vtk(FILE * ascii, struct Map_info *, int layer, int *types,
-	      int typenum, int dp, double scale);
+	      int typenum, int dp, double scale, int numatts, int labels );
 /*Write the VTK header */
 int write_vtk_head(FILE * ascii, struct Map_info *Map);
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c	2012-04-18 15:52:45 UTC (rev 51472)
+++ grass/trunk/vector/v.out.vtk/main.c	2012-04-18 17:05:00 UTC (rev 51473)
@@ -32,12 +32,12 @@
     FILE *ascii;
     struct Option *input, *output, *type_opt, *dp_opt, *layer_opt, *scale;
-    struct Flag *coorcorr;
-    int *types = NULL, typenum = 0, dp, i;
+    struct Flag *coorcorr, *numatts, *labels;
+    int itype, *types = NULL, typenum = 0, dp, i;
     struct Map_info Map;
+    struct bound_box box;
     struct GModule *module;
-    int layer;
-    struct Cell_head region;
+    int layer, level;
     double zscale = 1.0, llscale = 1.0;
@@ -84,11 +84,23 @@
     layer_opt->answer = "1";
     layer_opt->description = _("Layer number");
-    coorcorr = G_define_flag();
-    coorcorr->key = 'c';
-    coorcorr->description =
-	_("Correct the coordinates to fit the VTK-OpenGL precision");
+    coorcorr = G_define_flag();
+    coorcorr->key = 'c';
+    coorcorr->description =
+    	_("Correct the coordinates to fit the VTK-OpenGL precision");
+    numatts = G_define_flag();
+    numatts->key = 'n';
+    numatts->description =
+    	_("Export numeric attribute table fields as VTK scalar variables");
+    labels = NULL; /* to avoid compiler warning about "unused variable"*/
+    /* not yet supported
+    labels = G_define_flag();
+    labels->key = 'l';
+    labels->description = _("Export text attribute table fields as VTK labels");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -130,47 +142,17 @@
 	i++;
+    itype = Vect_option_to_types(type_opt);
-    G_get_set_window(&region);
-    /*Correct the coordinates, so the precision of VTK is not hurt :( */
-    if (coorcorr->answer) {
-	/*Get the default region for coordiante correction */
-	G_get_default_window(&region);
-	/*Use the center of the current region as extent */
-	y_extent = (region.north + region.south) / 2;
-	x_extent = (region.west + region.east) / 2;
-    else {
-	x_extent = 0;
-	y_extent = 0;
     /* read and compute the scale factor */
     sscanf(scale->answer, "%lf", &zscale);
     /*if LL projection, convert the elevation values to degrees */
-    if (region.proj == PROJECTION_LL) {
+    if (G_projection() == PROJECTION_LL) {
 	llscale = M_PI / (180) * 6378137;
 	zscale /= llscale;
 	printf("Scale %g\n", zscale);
-    /*We need level 2 functions */
-    Vect_set_open_level(2);
-    Vect_open_old(&Map, input->answer, "");
-    if (output->answer) {
-	ascii = fopen(output->answer, "w");
-	if (ascii == NULL) {
-	    G_fatal_error(_("Unable to open file <%s>"), output->answer);
-    else {
-	ascii = stdout;
     /*The precision of the output */
     if (dp_opt->answer) {
 	if (sscanf(dp_opt->answer, "%d", &dp) != 1)
@@ -191,10 +173,77 @@
 	layer = 1;
+    if (output->answer) {
+	ascii = fopen(output->answer, "w");
+	if (ascii == NULL) {
+	    G_fatal_error(_("Unable to open file <%s>"), output->answer);
+    else {
+	ascii = stdout;
+    /* Open input vector */
+    level = Vect_open_old(&Map, input->answer, "");
+    if (level < 2 && (itype & GV_AREA))
+	G_fatal_error(_("Export of areas requires topology. "
+	                "Please adjust '%s' option or rebuild topology."),
+			type_opt->key);
+    if (level == 2)
+	Vect_get_map_box(&Map, &box);
+    else {
+	int i, type, first = TRUE;
+	struct line_pnts *Points = Vect_new_line_struct();
+	Vect_rewind(&Map);
+	while ((type = Vect_read_next_line(&Map, Points, NULL)) > 0) {
+	    if (first) {
+		box.E = box.W = Points->x[0];
+		box.N = box.S = Points->y[0];
+		box.B = box.T = Points->z[0];
+		first = FALSE;
+	    for (i = 1; i < Points->n_points; i++) {
+		if (Points->x[i] > box.E)
+		    box.E = Points->x[i];
+		else if (Points->x[i] < box.W)
+		    box.W = Points->x[i];
+		if (Points->y[i] > box.N)
+		    box.N = Points->y[i];
+		else if (Points->y[i] < box.S)
+		    box.S = Points->y[i];
+		if (Points->z[i] > box.T)
+		    box.T = Points->z[i];
+		else if (Points->z[i] < box.B)
+		    box.B = Points->z[i];
+	Vect_destroy_line_struct(Points);
+    /*Correct the coordinates, so the precision of VTK is not hurt :( */
+    if (coorcorr->answer) {
+	/*Use the center of the vector's bbox as extent */
+	y_extent = (box.N + box.S) / 2;
+	x_extent = (box.W + box.E) / 2;
+    else {
+	x_extent = 0;
+	y_extent = 0;
     /*Write the header */
     write_vtk_head(ascii, &Map);
     /*Write the geometry and data */
-    write_vtk(ascii, &Map, layer, types, typenum, dp, zscale);
+    write_vtk(ascii, &Map, layer, types, typenum, dp, zscale, numatts->answer, 0 );
+    /* change to this, when labels get supported:
+    write_vtk(ascii, &Map, layer, types, typenum, dp, zscale, numatts->answer, labels->answer );
     if (ascii != NULL)
 	fclose(ascii);
Modified: grass/trunk/vector/v.out.vtk/writeVTK.c
--- grass/trunk/vector/v.out.vtk/writeVTK.c	2012-04-18 15:52:45 UTC (rev 51472)
+++ grass/trunk/vector/v.out.vtk/writeVTK.c	2012-04-18 17:05:00 UTC (rev 51473)
@@ -16,6 +16,7 @@
 #include <stdlib.h>
 #include <grass/vector.h>
+#include <grass/dbmi.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
 #include "writeVTK.h"
@@ -44,7 +45,7 @@
     Points = Vect_new_line_struct();	/* init line_pnts struct */
     Cats = Vect_new_cats_struct();
-    G_message("Writing the coordinates");
+    G_message("Writing coordinates ...");
     /*For every available vector type */
     for (k = 0; k < typenum; k++) {
@@ -54,8 +55,19 @@
 	    /*Get the number of the points to generate */
 	    info->typeinfo[types[k]]->pointoffset = pointoffset;
-	    info->typeinfo[types[k]]->numpoints =
-		Vect_get_num_primitives(Map, types[k]);
+	    /*count the number of line_nodes and lines */
+	    Vect_rewind(Map);
+	    while (1) {
+		if (-1 == (type = Vect_read_next_line(Map, Points, Cats)))
+		    break;
+		if (type == -2)	/* EOF */
+		    break;
+		if (type == types[k]) {
+		    info->typeinfo[types[k]]->numpoints++;
 	    pointoffset += info->typeinfo[types[k]]->numpoints;
 	    info->typeinfo[types[k]]->numvertices =
@@ -102,7 +114,6 @@
 	     * info->typeinfo[types[k]]->lineoffset);
@@ -137,7 +148,6 @@
 	     * info->typeinfo[types[k]]->polygonoffset);
@@ -185,10 +195,8 @@
     if (info->maxnumpoints == 0)
 	G_fatal_error(_("No coordinates to generate the output! Maybe an empty vector type chosen?"));
     /*Write the coordinates into the vtk ascii file */
     fprintf(ascii, "POINTS %i float\n", info->maxnumpoints);
@@ -217,7 +225,6 @@
 		cur++;
@@ -238,7 +245,6 @@
 		cur++;
@@ -259,7 +265,6 @@
 		cur++;
@@ -275,7 +280,6 @@
 		Vect_get_area_points(Map, i, Points);
 		write_point_coordinates(Points, dp, scale, ascii);
@@ -298,7 +302,7 @@
     int linekeyword = 1;
     int polykeyword = 1;
-    G_message("Writing vtk cells");
+    G_message("Writing vtk cells ...");
@@ -306,7 +310,6 @@
 	/*POINT KERNEL CENTROID */
 	if (types[k] == GV_POINT || types[k] == GV_KERNEL ||
 	    types[k] == GV_CENTROID) {
@@ -465,7 +468,7 @@
-    G_message("Writing category cell data");
+    G_message("Writing category cell data ...");
     if (numcelldata > 0) {
 	/*Write the pointdata */
@@ -542,25 +545,329 @@
+	fprintf(ascii, "\n");
     return 1;
+   Reads the attribute field "name" for current cat and returns the value as a string
+   or NULL on error
+   Memory for the result string is allocated by this function and must be free'd by
+   the caller.
+char *get_att(char *name, int cat, struct field_info *Fi, dbDriver * Driver,
+	      int ncol)
+    char buf[2000];
+    int more;
+    dbTable *Table;
+    static dbString dbstring;
+    dbColumn *Column;
+    dbCursor cursor;
+    char *retval;
+    static int first = 1;
+    if (first) {
+	db_init_string(&dbstring);
+	first = 0;
+    sprintf(buf, "SELECT %s FROM %s WHERE %s = %d", name, Fi->table, Fi->key, cat);
+    db_set_string(&dbstring, buf);
+    if (db_open_select_cursor(Driver, &dbstring, &cursor, DB_SEQUENTIAL) !=
+	DB_OK) {
+	G_fatal_error(_("Cannot select attributes for cat = %d"), cat);
+    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+	G_fatal_error(_("Unable to fetch data from table"));
+    Table = db_get_cursor_table(&cursor);
+    Column = db_get_table_column(Table, 0);
+    if (!strcmp(name, db_get_column_name(Column))) {
+	db_convert_column_value_to_string(Column, &dbstring);
+	retval =
+	    G_malloc(sizeof(char) *
+		     (strlen(db_get_string(&dbstring)) + 1));
+	retval = G_store(db_get_string(&dbstring));
+	db_close_cursor(&cursor);
+	return (retval);
+    return (NULL);
+/* This function writes numerical attribute table fields as VTK scalars **** */
 int write_vtk_db_data(FILE * ascii, struct Map_info *Map, VTKInfo * info,
 		      int layer, int *types, int typenum, int dp)
-    G_message("Writing database cell/point data");
+    int type, cat, i, k, centroid;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    /*The keywords may only be written once! */
+    int numcelldata =
+	info->maxnumvertices + info->maxnumlines + info->maxnumpolygons;
+    /* attribute table info */
+    int ncol = 0, colsqltype, colctype, num_atts, cur_att, progress;
+    struct field_info *Fi = NULL;
+    dbDriver *Driver = NULL;
+    dbHandle handle;
+    dbTable *Table;
+    dbString dbstring;
+    dbColumn *Column;
+    char *valbuf;
+    if (layer < 1) {
+	G_warning(_("Cannot export attribute table fields for layer < 1. Skipping export"));
+	return 1;
+    /* attempt to open attribute table for selected layer */
+    Fi = Vect_get_field(Map, layer);
+    if (Fi == NULL) {
+	G_fatal_error(_("No attribute table found"));
+    Driver = db_start_driver(Fi->driver);
+    if (Driver == NULL)
+	G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+    db_init_handle(&handle);
+    db_set_handle(&handle, Fi->database, NULL);
+    if (db_open_database(Driver, &handle) != DB_OK)
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Fi->database, Fi->driver);
+    db_set_string(&dbstring, Fi->table);
+    if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
+	G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+    /* analyse field structure */
+    ncol = db_get_table_number_of_columns(Table);
+    num_atts = 0;
+    for (i = 0; i < ncol; i++) {
+	Column = db_get_table_column(Table, i);
+	colsqltype = db_get_column_sqltype(Column);
+	colctype = db_sqltype_to_Ctype(colsqltype);
+	if ((colctype == DB_C_TYPE_INT) || (colctype == DB_C_TYPE_DOUBLE)) {
+	    /* we don't want to export the category field twice */
+	    if (strcmp(db_get_column_name(Column), "cat")) {
+		num_atts++;
+		/* fprintf ( stderr, "%i: %s\n", num_atts, db_get_column_name(Column) ); */
+    if (num_atts < 1) {
+	G_warning(_("No numerical attributes found. Skipping export"));
+	db_close_database(Driver);
+	db_shutdown_driver(Driver);
+	return 1;
+    Points = Vect_new_line_struct();	/* init line_pnts struct */
+    Cats = Vect_new_cats_struct();
+    G_message("Writing %i scalar variables as cell data ...", num_atts);
+    progress = 0;
+    for (cur_att = 0; cur_att < ncol; cur_att++) {
+	if (numcelldata > 0) {
+	    /*Write the pointdata */
+	    Column = db_get_table_column(Table, cur_att);
+	    if ((strcmp("cat", db_get_column_name(Column))) &&
+		((colctype == DB_C_TYPE_INT) ||
+		 (colctype == DB_C_TYPE_DOUBLE))) {
+		if (colctype == DB_C_TYPE_INT) {
+		    /* G_message("  Writing integer scalar %s", db_get_column_name(Column) ); */
+		    fprintf(ascii, "SCALARS %s int 1\n",
+			    db_get_column_name(Column));
+		if (colctype == DB_C_TYPE_DOUBLE) {
+		    /* *G_message("  Writing double scalar %s", db_get_column_name(Column) ); */
+		    fprintf(ascii, "SCALARS %s double 1\n",
+		fprintf(ascii, "LOOKUP_TABLE default\n");
+		progress++;
+		/*For every available vector type */
+		for (k = 0; k < typenum; k++) {
+		    /*POINT KERNEL CENTROID */
+		    if (types[k] == GV_POINT || types[k] == GV_KERNEL ||
+			types[k] == GV_CENTROID) {
+			Vect_rewind(Map);
+			while (1) {
+			    if (-1 ==
+				(type =
+				 Vect_read_next_line(Map, NULL, Cats)))
+				break;
+				break;
+				Vect_cat_get(Cats, layer, &cat);
+				valbuf =
+				    get_att((char *)
+					    db_get_column_name(Column), cat,
+					    Fi, Driver, ncol);
+				if (valbuf == NULL) {
+				    G_fatal_error(_("Error reading value of attribute '%s'"),
+				/* DEBUG
+				   fprintf ( stderr, "%s (%i) = %s\n", db_get_column_name(Column), cat, valbuf );
+				fprintf(ascii, " %s", valbuf);
+				G_free(valbuf);
+		    /*LINE BOUNDARY */
+		    if (types[k] == GV_LINE || types[k] == GV_BOUNDARY) {
+			Vect_rewind(Map);
+			while (1) {
+			    if (-1 ==
+				(type =
+				break;
+				break;
+				valbuf =
+				    get_att((char *)
+				/* DEBUG
+				G_free(valbuf);
+		    /*FACE */
+		    if (types[k] == GV_FACE) {
+			Vect_rewind(Map);
+			while (1) {
+			    if (-1 ==
+				(type =
+				break;
+				break;
+				valbuf =
+				    get_att((char *)
+				/* DEBUG
+				G_free(valbuf);
+		    /*AREA */
+		    if (types[k] == GV_AREA) {
+			Vect_rewind(Map);
+			for (i = 1;
+			     i <= info->typeinfo[types[k]]->numpolygons;
+			     i++) {
+			    centroid = Vect_get_area_centroid(Map, i);
+			    if (centroid > 0) {
+				Vect_read_line(Map, NULL, Cats, centroid);
+			    valbuf =
+				get_att((char *)db_get_column_name(Column),
+					cat, Fi, Driver, ncol);
+			    /* DEBUG
+			    G_free(valbuf);
+	    }			/* END (do for all scalars != cat */
+    }				/* END (step through all numerical attributes) */
+    fprintf(stdout, "\n");
+    fflush(stdout);
     return 1;
+/* This function writes attribute table fields as VTK labels            **** */
+int write_vtk_db_labels(FILE * ascii, struct Map_info *Map, VTKInfo * info,
+			int layer, int *types, int typenum, int dp)
+    return 1;
 /* This function writes the point coordinates and the geometric feature **** */
 int write_vtk(FILE * ascii, struct Map_info *Map, int layer, int *types,
+	      int typenum, int dp, double scale, int numatts, int labels)
     VTKInfo *info;
     VTKTypeInfo **typeinfo;
@@ -569,7 +876,6 @@
 	GV_POINT + GV_KERNEL + GV_CENTROID + GV_LINE + GV_BOUNDARY + GV_FACE +
 	GV_AREA;
     /*Initiate the typeinfo structure for every supported type */
     typeinfo = (VTKTypeInfo **) calloc(infonum, sizeof(VTKTypeInfo *));
     for (i = 0; i < infonum; i++) {
@@ -604,9 +910,15 @@
     /*3. write the cat data */
     write_vtk_cat_data(ascii, Map, info, layer, types, typenum, dp);
-    /*4. write the DB data */
-    /* not yet implemented
-       write_vtk_db_data(ascii, Map, info, layer, types, typenum, dp);
+    /*4. write the DB data: numerical attributes */
+    if (numatts) {
+	write_vtk_db_data(ascii, Map, info, layer, types, typenum, dp);
+    /*5. Write labels (not yet supported)
+       if ( labels ) {
+       write_vtk_db_labels(ascii, Map, info, layer, types, typenum, dp);
     /*Release the memory */
