[GRASS-SVN] r51474 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Wed Apr 18 13:35:58 EDT 2012
Author: mmetz
Date: 2012-04-18 10:35:58 -0700 (Wed, 18 Apr 2012)
New Revision: 51474
grass/trunk/vector/v.out.ogr/attrb.c
grass/trunk/vector/v.out.ogr/local_proto.h
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr speed-up, depends on export format
Modified: grass/trunk/vector/v.out.ogr/attrb.c
--- grass/trunk/vector/v.out.ogr/attrb.c 2012-04-18 17:05:00 UTC (rev 51473)
+++ grass/trunk/vector/v.out.ogr/attrb.c 2012-04-18 17:35:58 UTC (rev 51474)
@@ -3,21 +3,28 @@
#include "local_proto.h"
int mk_att(int cat, struct field_info *Fi, dbDriver *Driver, int ncol,
- int doatt, int nocat, OGRFeatureH Ogr_feature, int *noatt,
- int *fout)
+ int *colctype, const char **colname, int doatt, int nocat,
+ OGRFeatureH Ogr_feature, int *noatt, int *fout)
int j, ogrfieldnum;
- int colsqltype, colctype, more;
+ int more;
dbTable *Table;
- dbString dbstring;
+ static int first = 1;
+ static dbString dbstring;
dbColumn *Column;
dbValue *Value;
char buf[SQL_BUFFER_SIZE];
dbCursor cursor;
G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
- db_init_string(&dbstring);
+ /* init constants */
+ if (first) {
+ db_init_string(&dbstring);
+ first = 0;
/* Attributes */
/* Reset */
if (!doatt) {
@@ -68,37 +75,34 @@
G_debug(2, "col %d : val = %s", j,
db_get_string(&dbstring));
- colsqltype = db_get_column_sqltype(Column);
- colctype = db_sqltype_to_Ctype(colsqltype);
- G_debug(2, " colctype = %d", colctype);
+ G_debug(2, " colctype = %d", colctype[j]);
- if (nocat && strcmp(Fi->key, db_get_column_name(Column)) == 0)
+ if (nocat && strcmp(Fi->key, colname[j]) == 0)
continue;
ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
- db_get_column_name
- (Column));
+ colname[j]);
G_debug(2, " column = %s -> fieldnum = %d",
- db_get_column_name(Column), ogrfieldnum);
+ colname[j], ogrfieldnum);
if (ogrfieldnum < 0) {
G_debug(4, "Could not get OGR field number for column %s",
- db_get_column_name(Column));
+ colname[j]);
continue;
/* Reset */
- if ((nocat && strcmp(Fi->key, db_get_column_name(Column)) == 0) == 0) {
+ if ((nocat && strcmp(Fi->key, colname[j]) == 0) == 0) {
/* if this is 'cat', then execute the following only if the '-s' flag was NOT given*/
OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
/* prevent writing NULL values */
if (!db_test_value_isnull(Value)) {
- switch (colctype) {
+ switch (colctype[j]) {
case DB_C_TYPE_INT:
OGR_F_SetFieldInteger(Ogr_feature,
ogrfieldnum,
@@ -140,7 +144,9 @@
(*fout)++;
db_free_string(&dbstring);
return 1;
Modified: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h 2012-04-18 17:05:00 UTC (rev 51473)
+++ grass/trunk/vector/v.out.ogr/local_proto.h 2012-04-18 17:35:58 UTC (rev 51474)
@@ -25,7 +25,8 @@
/* attributes.c */
- int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature, int *, int *);
+ int ncol, int *colctype, const char **colname, int doatt, int nocat,
+ OGRFeatureH Ogr_feature, int *, int *);
/* list.c */
char *OGR_list_write_drivers();
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2012-04-18 17:05:00 UTC (rev 51473)
+++ grass/trunk/vector/v.out.ogr/main.c 2012-04-18 17:35:58 UTC (rev 51474)
@@ -50,8 +50,9 @@
int type, cat;
/* Attributes */
- int doatt = 0, ncol = 0, colsqltype, colctype, colwidth, keycol = -1;
- const char *colname;
+ int doatt = 0, ncol = 0, colsqltype, colwidth, keycol = -1;
+ int *colctype = NULL;
+ const char **colname = NULL;
struct field_info *Fi = NULL;
dbDriver *Driver = NULL;
dbTable *Table;
@@ -577,17 +578,19 @@
ncol = db_get_table_number_of_columns(Table);
G_debug(2, "ncol = %d", ncol);
+ colctype = G_malloc(ncol * sizeof(int));
+ colname = G_malloc(ncol * sizeof(char *));
keycol = -1;
for (i = 0; i < ncol; i++) {
Column = db_get_table_column(Table, i);
- colname = db_get_column_name(Column);
+ colname[i] = G_store(db_get_column_name(Column));
+ colctype[i] = db_sqltype_to_Ctype(colsqltype);
colwidth = db_get_column_length(Column);
G_debug(3, "col %d: %s sqltype=%d ctype=%d width=%d",
- i, colname, colsqltype, colctype, colwidth);
+ i, colname[i], colsqltype, colctype[i], colwidth);
+ switch (colctype[i]) {
case DB_C_TYPE_INT:
ogr_ftype = OFTInteger;
break;
@@ -605,29 +608,29 @@
strcpy(key1, Fi->key);
G_tolcase(key1);
- strcpy(key2, colname);
+ strcpy(key2, colname[i]);
G_tolcase(key2);
if (strcmp(key1, key2) == 0)
keycol = i;
G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
- colname, key1, key2, keycol);
+ colname[i], key1, key2, keycol);
if (flags.nocat->answer &&
- strcmp(Fi->key, colname) == 0)
+ strcmp(Fi->key, colname[i]) == 0)
/* skip export of 'cat' field */
continue;
if (flags.append->answer) {
Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
- if (OGR_FD_GetFieldIndex(Ogr_field, colname) > -1)
+ if (OGR_FD_GetFieldIndex(Ogr_field, colname[i]) > -1)
/* skip existing fields */
continue;
else
G_warning(_("New attribute column <%s> added to the table"),
- colname);
+ colname[i]);
- Ogr_field = OGR_Fld_Create(colname, ogr_ftype);
+ Ogr_field = OGR_Fld_Create(colname[i], ogr_ftype);
if (ogr_ftype == OFTString && colwidth > 0)
OGR_Fld_SetWidth(Ogr_field, colwidth);
OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
@@ -718,7 +721,7 @@
continue;
- mk_att(cat, Fi, Driver, ncol, doatt, flags.nocat->answer,
+ mk_att(cat, Fi, Driver, ncol, colctype, colname, doatt, flags.nocat->answer,
Ogr_feature, &noatt, &fout);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
@@ -793,7 +796,7 @@
continue;
@@ -853,7 +856,7 @@
continue;
@@ -908,7 +911,7 @@
continue;
