[GRASS-SVN] r51483 - grass/trunk/raster/r.watershed/seg
svn_grass at osgeo.org
Sun Apr 22 13:12:18 EDT 2012
Author: mmetz
Date: 2012-04-22 10:12:18 -0700 (Sun, 22 Apr 2012)
New Revision: 51483
grass/trunk/raster/r.watershed/seg/Gwater.h
grass/trunk/raster/r.watershed/seg/bseg_close.c
grass/trunk/raster/r.watershed/seg/bseg_get.c
grass/trunk/raster/r.watershed/seg/bseg_open.c
grass/trunk/raster/r.watershed/seg/bseg_put.c
grass/trunk/raster/r.watershed/seg/bseg_read.c
grass/trunk/raster/r.watershed/seg/bseg_write.c
grass/trunk/raster/r.watershed/seg/close_maps.c
grass/trunk/raster/r.watershed/seg/close_maps2.c
grass/trunk/raster/r.watershed/seg/cseg.h
grass/trunk/raster/r.watershed/seg/cseg_close.c
grass/trunk/raster/r.watershed/seg/cseg_get.c
grass/trunk/raster/r.watershed/seg/cseg_open.c
grass/trunk/raster/r.watershed/seg/cseg_put.c
grass/trunk/raster/r.watershed/seg/cseg_read.c
grass/trunk/raster/r.watershed/seg/cseg_write.c
grass/trunk/raster/r.watershed/seg/def_basin.c
grass/trunk/raster/r.watershed/seg/do_astar.c
grass/trunk/raster/r.watershed/seg/do_astar.h
grass/trunk/raster/r.watershed/seg/do_cum.c
grass/trunk/raster/r.watershed/seg/dseg_close.c
grass/trunk/raster/r.watershed/seg/dseg_get.c
grass/trunk/raster/r.watershed/seg/dseg_open.c
grass/trunk/raster/r.watershed/seg/dseg_put.c
grass/trunk/raster/r.watershed/seg/dseg_read.c
grass/trunk/raster/r.watershed/seg/dseg_write.c
grass/trunk/raster/r.watershed/seg/find_pour.c
grass/trunk/raster/r.watershed/seg/init_vars.c
grass/trunk/raster/r.watershed/seg/main.c
grass/trunk/raster/r.watershed/seg/no_stream.c
grass/trunk/raster/r.watershed/seg/over_cells.c
grass/trunk/raster/r.watershed/seg/sg_factor.c
grass/trunk/raster/r.watershed/seg/slope_len.c
grass/trunk/raster/r.watershed/seg/split_str.c
grass/trunk/raster/r.watershed/seg/sseg_close.c
grass/trunk/raster/r.watershed/seg/sseg_get.c
grass/trunk/raster/r.watershed/seg/sseg_open.c
grass/trunk/raster/r.watershed/seg/sseg_put.c
r.watershed: support for more than 2 billion cells
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h 2012-04-22 17:12:18 UTC (rev 51483)
@@ -10,6 +10,9 @@
#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
+#define GW_LARGE_INT off_t
#include "cseg.h"
#include "flag.h"
@@ -49,7 +52,7 @@
#define HEAP_PNT struct heap_point
HEAP_PNT {
- int added;
+ GW_LARGE_INT added;
CELL ele;
POINT pnt;
@@ -60,6 +63,12 @@
DCELL wat;
+#define ASP_FLAG struct aspect_flag
+ASP_FLAG {
+ char asp;
+ char flag;
#define OC_STACK struct overland_cells_stack
OC_STACK {
int row, col;
@@ -69,18 +78,18 @@
extern int mfd, c_fac, abs_acc, ele_scale;
extern SSEG search_heap;
-extern int heap_size;
-extern int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+extern int nrows, ncols;
+extern GW_LARGE_INT heap_size;
+extern GW_LARGE_INT first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
extern CELL n_basins;
extern OC_STACK *ocs;
extern int ocs_alloced;
-extern int nrows, ncols;
extern double half_res, diag, max_length, dep_slope;
extern int bas_thres, tot_parts;
extern SSEG astar_pts;
-extern BSEG bitflags, s_b, asp;
+extern BSEG s_b;
extern CSEG dis, bas, haf, r_h, dep;
-extern SSEG watalt;
+extern SSEG watalt, aspflag;
extern DSEG slp, s_l, s_g, l_s, ril;
extern double segs_mb;
extern char zero, one;
Modified: grass/trunk/raster/r.watershed/seg/bseg_close.c
--- grass/trunk/raster/r.watershed/seg/bseg_close.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_close.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,6 +1,6 @@
#include <unistd.h>
-#include "cseg.h"
+#include "Gwater.h"
int bseg_close(BSEG * bseg)
Modified: grass/trunk/raster/r.watershed/seg/bseg_get.c
--- grass/trunk/raster/r.watershed/seg/bseg_get.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_get.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
#include <grass/segment.h>
-#include "cseg.h"
-int bseg_get(BSEG * bseg, char *value, int row, int col)
+int bseg_get(BSEG * bseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_get(&(bseg->seg), value, row, col) < 0) {
G_warning("cseg_get(): could not read segment file");
Modified: grass/trunk/raster/r.watershed/seg/bseg_open.c
--- grass/trunk/raster/r.watershed/seg/bseg_open.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_open.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -2,7 +2,7 @@
#include <unistd.h>
#include <fcntl.h>
-#include "cseg.h"
int bseg_open(BSEG * bseg, int srows, int scols, int nsegs_in_memory)
Modified: grass/trunk/raster/r.watershed/seg/bseg_put.c
--- grass/trunk/raster/r.watershed/seg/bseg_put.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_put.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int bseg_put(BSEG * bseg, char *value, int row, int col)
+int bseg_put(BSEG * bseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_put(&(bseg->seg), value, row, col) < 0) {
G_warning("cseg_put(): could not write segment file");
@@ -11,7 +11,7 @@
return 0;
-int bseg_put_row(BSEG * bseg, char *value, int row)
+int bseg_put_row(BSEG * bseg, char *value, GW_LARGE_INT row)
if (segment_put_row(&(bseg->seg), value, row) < 0) {
Modified: grass/trunk/raster/r.watershed/seg/bseg_read.c
--- grass/trunk/raster/r.watershed/seg/bseg_read.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_read.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,7 +1,7 @@
#include <unistd.h>
-#include "cseg.h"
int bseg_read_cell(BSEG * bseg, char *map_name, char *mapset)
Modified: grass/trunk/raster/r.watershed/seg/bseg_write.c
--- grass/trunk/raster/r.watershed/seg/bseg_write.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/bseg_write.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,6 +1,6 @@
-#include "cseg.h"
int bseg_write_cellfile(BSEG * bseg, char *map_name)
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -7,15 +7,15 @@
struct Colors colors;
int r, c;
DCELL *dbuf = NULL;
+ CELL *cbuf = NULL;
int fd;
struct FPRange accRange;
DCELL min, max;
DCELL clr_min, clr_max;
DCELL sum, sum_sqr, stddev, lstddev, dvalue;
WAT_ALT *wabuf;
+ ASP_FLAG *afbuf;
- /* bseg_close(&swale); */
- bseg_close(&bitflags);
if (wat_flag) {
G_message(_("Closing accumulation map"));
sum = sum_sqr = stddev = 0.0;
@@ -126,12 +126,28 @@
seg_close(&watalt);
if (asp_flag) {
G_message(_("Closing flow direction map"));
- bseg_write_cellfile(&asp, asp_name);
+ cbuf = Rast_allocate_c_buf();
+ afbuf = G_malloc(ncols * sizeof(ASP_FLAG));
+ seg_flush(&aspflag);
+ fd = Rast_open_new(wat_name, DCELL_TYPE);
+ for (r = 0; r < nrows; r++) {
+ G_percent(r, nrows, 1);
+ Rast_set_c_null_value(cbuf, ncols); /* reset row to all NULL */
+ seg_get_row(&aspflag, (char *)afbuf, r);
+ for (c = 0; c < ncols; c++) {
+ if (!FLAG_GET(afbuf[c].flag, NULLFLAG)) {
+ cbuf[c] = afbuf[c].asp;
+ Rast_put_row(fd, cbuf, CELL_TYPE);
Rast_init_colors(&colors);
Rast_make_grey_scale_colors(&colors, 1, 8);
Rast_write_colors(asp_name, this_mapset, &colors);
- bseg_close(&asp);
+ seg_close(&aspflag);
if (ls_flag) {
G_message(_("Closing LS map"));
dseg_write_cellfile(&l_s, ls_name);
Modified: grass/trunk/raster/r.watershed/seg/close_maps2.c
--- grass/trunk/raster/r.watershed/seg/close_maps2.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/close_maps2.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -9,9 +9,8 @@
int incr, max, red, green, blue, rd, gr, bl, flag;
int c, r, map_fd;
CELL *cellrow;
- /* CELL value; */
- char cvalue;
CSEG *theseg;
+ ASP_FLAG af;
if (seg_flag || bas_flag || haf_flag) {
if (seg_flag)
@@ -93,8 +92,8 @@
/* bseg_get(&swale, &cvalue, r, c); */
/* if (cvalue) */
- bseg_get(&bitflags, &cvalue, r, c);
- if (FLAG_GET(cvalue, SWALEFLAG))
+ seg_get(&aspflag, (char *)&af, r, c);
+ if (FLAG_GET(af.flag, SWALEFLAG))
cseg_get(&bas, &(cellrow[c]), r, c);
Rast_put_row(map_fd, cellrow, CELL_TYPE);
Modified: grass/trunk/raster/r.watershed/seg/cseg.h
--- grass/trunk/raster/r.watershed/seg/cseg.h 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg.h 2012-04-22 17:12:18 UTC (rev 51483)
@@ -42,14 +42,14 @@
int bseg_close(BSEG *);
/* bseg_get.c */
-int bseg_get(BSEG *, char *, int, int);
+int bseg_get(BSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
/* bseg_open.c */
int bseg_open(BSEG *, int, int, int);
/* bseg_put.c */
-int bseg_put(BSEG *, char *, int, int);
-int bseg_put_row(BSEG *, char *, int);
+int bseg_put(BSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int bseg_put_row(BSEG *, char *, GW_LARGE_INT);
/* bseg_read.c */
int bseg_read_cell(BSEG *, char *, char *);
@@ -61,14 +61,14 @@
int cseg_close(CSEG *);
/* cseg_get.c */
-int cseg_get(CSEG *, CELL *, int, int);
+int cseg_get(CSEG *, CELL *, GW_LARGE_INT, GW_LARGE_INT);
/* cseg_open.c */
int cseg_open(CSEG *, int, int, int);
/* cseg_put.c */
-int cseg_put(CSEG *, CELL *, int, int);
-int cseg_put_row(CSEG *, CELL *, int);
+int cseg_put(CSEG *, CELL *, GW_LARGE_INT, GW_LARGE_INT);
+int cseg_put_row(CSEG *, CELL *, GW_LARGE_INT);
/* cseg_read.c */
int cseg_read_cell(CSEG *, char *, char *);
@@ -80,14 +80,14 @@
int dseg_close(DSEG *);
/* dseg_get.c */
-int dseg_get(DSEG *, double *, int, int);
+int dseg_get(DSEG *, double *, GW_LARGE_INT, GW_LARGE_INT);
/* dseg_open.c */
int dseg_open(DSEG *, int, int, int);
/* dseg_put.c */
-int dseg_put(DSEG *, double *, int, int);
-int dseg_put_row(DSEG *, double *, int);
+int dseg_put(DSEG *, double *, GW_LARGE_INT, GW_LARGE_INT);
+int dseg_put_row(DSEG *, double *, GW_LARGE_INT);
/* dseg_read.c */
int dseg_read_cell(DSEG *, char *, char *);
@@ -95,32 +95,20 @@
/* dseg_write.c */
int dseg_write_cellfile(DSEG *, char *);
-/* seg_close.c */
-int seg_close(SSEG *);
-/* seg_get.c */
-int seg_get(SSEG *, char *, int, int);
-/* seg_open.c */
-int seg_open(SSEG *, int, int, int, int, int, int);
-/* seg_put.c */
-int seg_put(SSEG *, char *, int, int);
-int seg_put_row(SSEG *, char *, int);
/* sseg_close.c */
/* sseg_get.c */
-int seg_get_row(SSEG *, char *, int);
+int seg_get(SSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int seg_get_row(SSEG *, char *, GW_LARGE_INT);
int seg_flush(SSEG *);
/* sseg_open.c */
+int seg_open(SSEG *, GW_LARGE_INT, GW_LARGE_INT, int, int, int, int);
/* sseg_put.c */
+int seg_put(SSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int seg_put_row(SSEG * sseg, char *value, GW_LARGE_INT);
#endif /* __CSEG_H__ */
Modified: grass/trunk/raster/r.watershed/seg/cseg_close.c
--- grass/trunk/raster/r.watershed/seg/cseg_close.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_close.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,7 +1,7 @@
#include <unistd.h>
-#include "cseg.h"
int cseg_close(CSEG * cseg)
Modified: grass/trunk/raster/r.watershed/seg/cseg_get.c
--- grass/trunk/raster/r.watershed/seg/cseg_get.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_get.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int cseg_get(CSEG * cseg, CELL * value, int row, int col)
+int cseg_get(CSEG * cseg, CELL * value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_get(&(cseg->seg), value, row, col) < 0) {
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,7 +1,7 @@
#include <unistd.h>
#include <fcntl.h>
-#include "cseg.h"
int cseg_open(CSEG * cseg, int srows, int scols, int nsegs_in_memory)
Modified: grass/trunk/raster/r.watershed/seg/cseg_put.c
--- grass/trunk/raster/r.watershed/seg/cseg_put.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_put.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int cseg_put(CSEG * cseg, CELL * value, int row, int col)
+int cseg_put(CSEG * cseg, CELL * value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_put(&(cseg->seg), value, row, col) < 0) {
@@ -11,7 +11,7 @@
return 0;
-int cseg_put_row(CSEG * cseg, CELL * value, int row)
+int cseg_put_row(CSEG * cseg, CELL * value, GW_LARGE_INT row)
if (segment_put_row(&(cseg->seg), value, row) < 0) {
Modified: grass/trunk/raster/r.watershed/seg/cseg_read.c
--- grass/trunk/raster/r.watershed/seg/cseg_read.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_read.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,13 +1,13 @@
-#include "cseg.h"
static char *me = "cseg_read_cell";
int cseg_read_cell(CSEG * cseg, char *map_name, char *mapset)
- int row, nrows;
+ GW_LARGE_INT row, nrows;
int map_fd;
CELL *buffer;
Modified: grass/trunk/raster/r.watershed/seg/cseg_write.c
--- grass/trunk/raster/r.watershed/seg/cseg_write.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/cseg_write.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,12 +1,12 @@
-#include "cseg.h"
int cseg_write_cellfile(CSEG * cseg, char *map_name)
int map_fd;
- int row, nrows;
CELL *buffer;
map_fd = Rast_open_c_new(map_name);
Modified: grass/trunk/raster/r.watershed/seg/def_basin.c
--- grass/trunk/raster/r.watershed/seg/def_basin.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/def_basin.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -6,8 +6,9 @@
int r, rr, c, cc, ct, new_r[9], new_c[9];
CELL value, new_elev;
- char downdir, direction, asp_value, cvalue;
+ char downdir, direction, asp_value;
int oldupdir, riteflag, leftflag, thisdir;
+ ASP_FLAG af;
for (;;) {
cseg_put(&bas, &basin_num, row, col);
@@ -17,12 +18,12 @@
if (r >= 0 && c >= 0 && r < nrows && c < ncols) {
if (r == row && c == col)
continue;
- bseg_get(&asp, &asp_value, r, c);
+ asp_value = af.asp;
if (asp_value < -1)
asp_value = -asp_value;
if (asp_value == drain[rr][cc]) {
- if (FLAG_GET(cvalue, SWALEFLAG)) {
+ if (FLAG_GET(af.flag, SWALEFLAG)) {
new_r[++ct] = r;
new_c[ct] = c;
@@ -40,7 +41,8 @@
return (basin_num);
oldupdir = drain[row - new_r[1] + 1][col - new_c[1] + 1];
- bseg_get(&asp, &downdir, row, col);
+ seg_get(&aspflag, (char *)&af, row, col);
+ downdir = af.asp;
if (downdir < 0)
downdir = -downdir;
riteflag = leftflag = 0;
@@ -49,7 +51,8 @@
continue;
- bseg_get(&asp, &direction, r, c);
+ direction = af.asp;
if (direction == drain[rr][cc]) {
thisdir = updrain[rr][cc];
switch (haf_basin_side
@@ -87,7 +90,8 @@
else { /* sides == 4 */
- bseg_get(&asp, &asp_value, row, col);
if (asp_value < 0)
if (asp_value == 2 || asp_value == 6) {
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -4,18 +4,18 @@
#include "do_astar.h"
HEAP_PNT drop_pt(void);
-int sift_up(int, HEAP_PNT);
+int sift_up(GW_LARGE_INT, HEAP_PNT);
int cmp_pnt(HEAP_PNT *a, HEAP_PNT *b);
double get_slope2(CELL, CELL, double);
int do_astar(void)
- int doer, count;
+ GW_LARGE_INT doer, count;
int upr, upc, r = -1, c = -1, ct_dir;
CELL alt_val, alt_nbr[8];
WAT_ALT wa;
- char asp_val;
- char flag_value, is_in_list, is_worked;
+ ASP_FLAG af;
+ char is_in_list, is_worked;
HEAP_PNT heap_p;
/* sides
@@ -28,7 +28,6 @@
double dx, dy, dist_to_nbr[8], ew_res, ns_res;
double slope[8];
int skip_diag;
- int count_edge = 0, count_diag = 0, count_edge_sink = 0, count_diag_sink = 0;
G_message(_("SECTION 2: A* Search."));
@@ -50,7 +49,7 @@
if (heap_size == 0)
G_fatal_error(_("No seeds for A* Search"));
- G_debug(1, "heap size %d, points %d", heap_size, do_points);
+ G_debug(1, "heap size %"PRI_OFF_T", points %"PRI_OFF_T, heap_size, do_points);
count = 0;
@@ -64,7 +63,7 @@
r = heap_p.pnt.r;
c = heap_p.pnt.c;
- G_debug(3, "heap size %d, r %d, c %d", heap_size, r, c);
+ G_debug(3, "heap size %"PRI_OFF_T", r %d, c %d", heap_size, r, c);
alt_val = heap_p.ele;
@@ -76,9 +75,9 @@
slope[ct_dir] = alt_nbr[ct_dir] = 0;
/* check if upr, upc are within region */
if (upr >= 0 && upr < nrows && upc >= 0 && upc < ncols) {
- bseg_get(&bitflags, &flag_value, upr, upc);
- is_in_list = FLAG_GET(flag_value, INLISTFLAG);
- is_worked = FLAG_GET(flag_value, WORKEDFLAG);
+ seg_get(&aspflag, (char *)&af, upr, upc);
+ is_in_list = FLAG_GET(af.flag, INLISTFLAG);
+ is_worked = FLAG_GET(af.flag, WORKEDFLAG);
skip_diag = 0;
/* avoid diagonal flow direction bias */
if (!is_worked) {
@@ -110,34 +109,18 @@
/* add neighbour as new point if not in the list */
if (is_in_list == 0 && skip_diag == 0) {
/* set flow direction */
- asp_val = drain[upr - r + 1][upc - c + 1];
+ af.asp = drain[upr - r + 1][upc - c + 1];
add_pt(upr, upc, alt_nbr[ct_dir]);
- bseg_put(&asp, &asp_val, upr, upc);
- FLAG_SET(flag_value, INLISTFLAG);
- bseg_put(&bitflags, &flag_value, upr, upc);
- if (alt_nbr[ct_dir] < alt_val) {
- if (ct_dir < 4)
- count_edge_sink++;
- else
- count_diag_sink++;
- /* includes flat areas */
- else {
- if (ct_dir < 4)
- count_edge++;
- else
- count_diag++;
+ FLAG_SET(af.flag, INLISTFLAG);
+ seg_put(&aspflag, (char *)&af, upr, upc);
else if (is_in_list && is_worked == 0 &&
- FLAG_GET(flag_value, EDGEFLAG)) {
+ FLAG_GET(af.flag, EDGEFLAG)) {
/* neighbour is edge in list, not yet worked */
- bseg_get(&asp, &asp_val, upr, upc);
- if (asp_val < 0) {
+ if (af.asp < 0) {
/* adjust flow direction for edge cell */
seg_get(&watalt, (char *)&wa, r, c);
if (wa.wat > 0) {
wa.wat = -wa.wat;
@@ -145,9 +128,9 @@
/* neighbour is inside real depression, not yet worked */
- else if (asp_val == 0) {
+ else if (af.asp == 0) {
@@ -155,23 +138,18 @@
/* add astar points to sorted list for flow accumulation */
seg_put(&astar_pts, (char *)&heap_p.pnt, 0, doer);
doer--;
- bseg_get(&bitflags, &flag_value, r, c);
- FLAG_SET(flag_value, WORKEDFLAG);
- bseg_put(&bitflags, &flag_value, r, c);
+ FLAG_SET(af.flag, WORKEDFLAG);
+ seg_put(&aspflag, (char *)&af, r, c);
if (doer != -1)
- G_fatal_error(_("bug in A* Search: doer %d heap size %d count %d"),
+ G_fatal_error(_("bug in A* Search: doer %"PRI_OFF_T" heap size %"PRI_OFF_T" count %"PRI_OFF_T),
doer, heap_size, count);
seg_close(&search_heap);
G_percent(count, do_points, 1); /* finish it */
- G_debug(1, "edge direction: %d (%.2f%%)", count_edge, (double) 100. * count_edge / (count_edge + count_diag));
- G_debug(1, "diag direction: %d (%.2f%%)", count_diag, (double) 100. * count_diag / (count_edge + count_diag));
- G_debug(1, "edge out of depression: %d (%.2f%%)", count_edge_sink, (double) 100. * count_edge_sink / (count_edge_sink + count_diag_sink));
- G_debug(1, "diag out of depression: %d (%.2f%%)", count_diag_sink, (double) 100. * count_diag_sink / (count_edge_sink + count_diag_sink));
return 0;
@@ -258,9 +236,9 @@
/* standard sift-up routine for d-ary min heap */
-int sift_up(int start, HEAP_PNT child_p)
+int sift_up(GW_LARGE_INT start, HEAP_PNT child_p)
- int parent, child;
+ GW_LARGE_INT parent, child;
HEAP_PNT heap_p;
child = start;
Modified: grass/trunk/raster/r.watershed/seg/do_astar.h
--- grass/trunk/raster/r.watershed/seg/do_astar.h 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/do_astar.h 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
#ifndef __DO_ASTAR_H__
#define __DO_ASTAR_H__
-#define GET_PARENT(c) ((int) ((((c) - 2) >> 2) + 1))
-#define GET_CHILD(p) ((int) (((p) << 2) - 2))
+#define GET_PARENT(c) (((((GW_LARGE_INT) (c) - 2) >> 2) + 1))
+#define GET_CHILD(p) ((((GW_LARGE_INT) (p) << 2) - 2))
#define GET_PARENT(c) ((int) (((c) - 2) / 3 + 1))
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -8,14 +8,15 @@
int do_cum(void)
int r, c, dr, dc;
- char asp_val, asp_val_down;
- char is_swale, this_flag_value, flag_value;
+ char is_swale;
DCELL value, valued;
POINT point;
- int killer, threshold;
+ GW_LARGE_INT killer;
+ int threshold;
int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
WAT_ALT wa, wadown;
+ ASP_FLAG af, afdown;
G_message(_("SECTION 3: Accumulating Surface Flow with SFD."));
@@ -28,26 +29,25 @@
seg_get(&astar_pts, (char *)&point, 0, killer);
r = point.r;
c = point.c;
- bseg_get(&asp, &asp_val, r, c);
- if (asp_val) {
- dr = r + asp_r[ABS(asp_val)];
- dc = c + asp_c[ABS(asp_val)];
+ if (af.asp) {
+ dr = r + asp_r[ABS(af.asp)];
+ dc = c + asp_c[ABS(af.asp)];
/* skip user-defined depressions */
else
dr = dc = -1;
- bseg_get(&bitflags, &this_flag_value, r, c);
- FLAG_UNSET(this_flag_value, WORKEDFLAG);
+ FLAG_UNSET(af.flag, WORKEDFLAG);
if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) {
/* TODO: do not distribute flow along edges, this causes artifacts */
value = wa.wat;
- is_swale = FLAG_GET(this_flag_value, SWALEFLAG);
+ is_swale = FLAG_GET(af.flag, SWALEFLAG);
if (fabs(value) >= threshold && !is_swale) {
is_swale = 1;
- FLAG_SET(this_flag_value, SWALEFLAG);
+ FLAG_SET(af.flag, SWALEFLAG);
seg_get(&watalt, (char *)&wadown, dr, dc);
valued = wadown.wat;
@@ -67,17 +67,17 @@
seg_put(&watalt, (char *)&wadown, dr, dc);
/* update asp for depression */
if (is_swale || fabs(valued) >= threshold) {
- bseg_get(&bitflags, &flag_value, dr, dc);
- FLAG_SET(flag_value, SWALEFLAG);
- bseg_put(&bitflags, &flag_value, dr, dc);
+ seg_get(&aspflag, (char *)&afdown, dr, dc);
+ FLAG_SET(afdown.flag, SWALEFLAG);
+ seg_put(&aspflag, (char *)&afdown, dr, dc);
is_swale = 1;
else {
- if (er_flag && !is_swale && !FLAG_GET(this_flag_value, RUSLEBLOCKFLAG))
+ if (er_flag && !is_swale && !FLAG_GET(afdown.flag, RUSLEBLOCKFLAG))
slope_length(r, c, dr, dc);
- bseg_put(&bitflags, &this_flag_value, r, c);
G_percent(do_points, do_points, 1); /* finish it */
@@ -114,7 +114,9 @@
DCELL value, valued, *wat_nbr;
POINT point;
WAT_ALT wa;
+ int threshold;
/* MFD */
int mfd_cells, stream_cells, swale_cells, astar_not_set, is_null;
@@ -122,10 +124,9 @@
int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side, max_side;
double dx, dy;
CELL ele, *ele_nbr;
double prop, max_acc;
int workedon, edge, is_swale, flat;
- char *flag_nbr, this_flag_value, flag_value;
+ char *flag_nbr;
@@ -165,10 +166,10 @@
r = point.r;
c = point.c;
- if (asp_val) {
+ if (af.asp) {
else
@@ -176,8 +177,7 @@
/* WORKEDFLAG has been set during A* Search
* reversed meaning here: 0 = done, 1 = not yet done */
r_max = dr;
@@ -207,6 +207,7 @@
wat_nbr[ct_dir] = 0;
ele_nbr[ct_dir] = 0;
+ flag_nbr[ct_dir] = 0;
/* check if neighbour is within region */
if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
@@ -215,7 +216,8 @@
if (dr == r_nbr && dc == c_nbr)
np_side = ct_dir;
- bseg_get(&bitflags, &flag_nbr[ct_dir], r_nbr, c_nbr);
+ seg_get(&aspflag, (char *)&afdown, r_nbr, c_nbr);
+ flag_nbr[ct_dir] = afdown.flag;
seg_get(&watalt, (char *)&wa, r_nbr, c_nbr);
wat_nbr[ct_dir] = wa.wat;
ele_nbr[ct_dir] = wa.ele;
@@ -266,12 +268,11 @@
/* do not continue streams along edges, this causes artifacts */
if (edge) {
- if (is_swale && asp_val > 0) {
- asp_val = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
- bseg_put(&asp, &asp_val, r, c);
+ if (is_swale && af.asp > 0) {
+ af.asp = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
continue;
@@ -327,7 +328,7 @@
seg_put(&watalt, (char *)&wa, r_nbr, c_nbr);
/* get main drainage direction */
- if (ABS(wat_nbr[ct_dir]) >= max_acc) {
+ if (fabs(wat_nbr[ct_dir]) >= max_acc) {
max_acc = ABS(wat_nbr[ct_dir]);
r_max = r_nbr;
c_max = c_nbr;
@@ -348,7 +349,7 @@
c_max = dc;
- if (ABS(prop - 1.0) > 5E-6f) {
+ if (fabs(prop - 1.0) > 5E-6f) {
G_warning(_("MFD: cumulative proportion of flow distribution not 1.0 but %f"),
prop);
@@ -375,39 +376,36 @@
/* update asp */
if (dr != r_max || dc != c_max) {
- asp_val = -1 * drain[r - r_max + 1][c - c_max + 1];
+ if (af.asp < 0) {
+ af.asp = -1 * drain[r - r_max + 1][c - c_max + 1];
else
- asp_val = drain[r - r_max + 1][c - c_max + 1];
+ af.asp = drain[r - r_max + 1][c - c_max + 1];
/* start new stream */
- value = ABS(value) + 0.5;
- if (!is_swale && (int)value >= threshold && stream_cells < 1 &&
+ if (!is_swale && fabs(value) >= threshold && stream_cells < 1 &&
swale_cells < 1 && !flat) {
is_swale = 1;
/* continue stream */
if (is_swale) {
- flag_value = flag_nbr[max_side];
- bseg_put(&bitflags, &flag_value, r_max, c_max);
+ seg_get(&aspflag, (char *)&afdown, r_max, c_max);
+ seg_put(&aspflag, (char *)&afdown, r_max, c_max);
else {
+ if (er_flag && !is_swale && !FLAG_GET(af.flag, RUSLEBLOCKFLAG))
slope_length(r, c, r_max, c_max);
if (workedon)
- G_warning(_("MFD: A * path already processed when distributing flow: %d of %d cells"),
+ G_warning(_("MFD: A * path already processed when distributing flow: %d of %"PRI_OFF_T" cells"),
workedon, do_points);
seg_close(&astar_pts);
Modified: grass/trunk/raster/r.watershed/seg/dseg_close.c
--- grass/trunk/raster/r.watershed/seg/dseg_close.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_close.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,6 +1,6 @@
#include <unistd.h>
-#include "cseg.h"
int dseg_close(DSEG * dseg)
Modified: grass/trunk/raster/r.watershed/seg/dseg_get.c
--- grass/trunk/raster/r.watershed/seg/dseg_get.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_get.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int dseg_get(DSEG * dseg, double *value, int row, int col)
+int dseg_get(DSEG * dseg, double *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_get(&(dseg->seg), (DCELL *) value, row, col) < 0) {
G_warning("dseg_get(): could not read segment file");
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -2,7 +2,7 @@
#include <unistd.h>
#include <fcntl.h>
-#include "cseg.h"
int dseg_open(DSEG * dseg, int srows, int scols, int nsegs_in_memory)
Modified: grass/trunk/raster/r.watershed/seg/dseg_put.c
--- grass/trunk/raster/r.watershed/seg/dseg_put.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_put.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int dseg_put(DSEG * dseg, double *value, int row, int col)
+int dseg_put(DSEG * dseg, double *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_put(&(dseg->seg), (DCELL *) value, row, col) < 0) {
G_warning("dseg_put(): could not write segment file");
@@ -11,7 +11,7 @@
return 0;
-int dseg_put_row(DSEG * dseg, double *value, int row)
+int dseg_put_row(DSEG * dseg, double *value, GW_LARGE_INT row)
if (segment_put_row(&(dseg->seg), (DCELL *) value, row) < 0) {
Modified: grass/trunk/raster/r.watershed/seg/dseg_read.c
--- grass/trunk/raster/r.watershed/seg/dseg_read.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_read.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,13 +1,13 @@
-#include "cseg.h"
static char *me = "dseg_read_cell";
int dseg_read_cell(DSEG * dseg, char *map_name, char *mapset)
- int row, nrows, ncols;
+ GW_LARGE_INT row, nrows, ncols;
int map_fd;
double *dbuffer;
Modified: grass/trunk/raster/r.watershed/seg/dseg_write.c
--- grass/trunk/raster/r.watershed/seg/dseg_write.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/dseg_write.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,12 +1,12 @@
-#include "cseg.h"
int dseg_write_cellfile(DSEG * dseg, char *map_name)
int map_fd;
double *dbuffer;
map_fd = Rast_open_new(map_name, DCELL_TYPE);
Modified: grass/trunk/raster/r.watershed/seg/find_pour.c
--- grass/trunk/raster/r.watershed/seg/find_pour.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/find_pour.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -5,8 +5,8 @@
int row, col;
double easting, northing, stream_length;
CELL old_elev, basin_num, no_basin, curr_basin;
- char aspect;
WAT_ALT wa;
+ ASP_FLAG af;
char is_swale;
ocs_alloced = 2 * bas_thres;
@@ -19,16 +19,15 @@
G_percent(row, nrows, 1);
northing = window.north - (row + .5) * window.ns_res;
for (col = 0; col < ncols; col++) {
- bseg_get(&asp, &aspect, row, col);
- bseg_get(&bitflags, &is_swale, row, col);
cseg_get(&bas, &curr_basin, row, col);
if (curr_basin == 0)
cseg_put(&bas, &no_basin, row, col);
cseg_get(&haf, &curr_basin, row, col);
cseg_put(&haf, &no_basin, row, col);
- is_swale = FLAG_GET(is_swale, SWALEFLAG);
- if (aspect <= 0 && is_swale > 0) {
+ if (af.asp <= 0 && is_swale > 0) {
basin_num += 2;
if (arm_flag) {
easting = window.west + (col + .5) * window.ew_res;
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -10,18 +10,18 @@
int init_vars(int argc, char *argv[])
int r, c;
- int ele_fd, fd, wat_fd;
+ int ele_fd, wat_fd, fd = -1;
int seg_rows, seg_cols, num_cseg_total, num_open_segs, num_open_array_segs;
double memory_divisor, heap_mem, seg_factor, disk_space;
/* int page_block, num_cseg; */
int max_bytes;
CELL *buf, alt_value, *alt_value_buf, block_value;
- char asp_value, *asp_buf;
- char worked_value, flag_value, *flag_value_buf;
+ char asp_value;
DCELL wat_value;
DCELL dvalue;
WAT_ALT wa, *wabuf;
+ ASP_FLAG af, af_nbr, *afbuf;
char MASK_flag;
void *elebuf, *ptr, *watbuf, *watptr;
int ele_map_type, wat_map_type;
@@ -163,12 +163,9 @@
/* elevation + accumulation: * 2 */
memory_divisor = sizeof(WAT_ALT) * 2;
disk_space = sizeof(WAT_ALT);
- /* aspect: as is */
- memory_divisor += 1;
- disk_space += 1;
- /* flags: * 4 */
- memory_divisor += 4;
- disk_space += 1;
+ /* aspect and flags: * 4 */
+ memory_divisor += sizeof(ASP_FLAG) * 4;
+ disk_space += sizeof(ASP_FLAG);
/* astar_points: / 16 */
/* ideally only a few but large segments */
memory_divisor += sizeof(POINT) / 16.;
@@ -244,8 +241,7 @@
/* scattered access: alt, watalt, bitflags, asp */
seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2, sizeof(WAT_ALT));
- bseg_open(&bitflags, seg_rows, seg_cols, num_open_segs * 4);
- bseg_open(&asp, seg_rows, seg_cols, num_open_segs);
+ seg_open(&aspflag, nrows, ncols, seg_rows, seg_cols, num_open_segs * 4, sizeof(ASP_FLAG));
/* open elevation input */
ele_fd = Rast_open_old(ele_name, "");
@@ -253,7 +249,7 @@
ele_map_type = Rast_get_map_type(ele_fd);
ele_size = Rast_cell_size(ele_map_type);
elebuf = Rast_allocate_buf(ele_map_type);
- asp_buf = G_malloc(ncols * sizeof(char));
if (ele_map_type == FCELL_TYPE || ele_map_type == DCELL_TYPE)
ele_scale = 1000; /* should be enough to do the trick */
@@ -271,13 +267,13 @@
wat_fd = wat_size = wat_map_type = -1;
wabuf = G_malloc(ncols * sizeof(WAT_ALT));
- flag_value_buf = G_malloc(ncols * sizeof(char));
alt_value_buf = Rast_allocate_buf(CELL_TYPE);
/* read elevation input and mark NULL/masked cells */
+ G_message("New version");
G_message("SECTION 1a: Mark masked and NULL cells");
MASK_flag = 0;
- do_points = nrows * ncols;
+ do_points = (GW_LARGE_INT) nrows * ncols;
Rast_get_row(ele_fd, elebuf, r, ele_map_type);
@@ -290,14 +286,14 @@
- flag_value_buf[c] = 0;
- asp_buf[c] = 0;
+ afbuf[c].flag = 0;
+ afbuf[c].asp = 0;
/* check for masked and NULL cells */
if (Rast_is_null_value(ptr, ele_map_type)) {
- FLAG_SET(flag_value_buf[c], NULLFLAG);
- FLAG_SET(flag_value_buf[c], INLISTFLAG);
- FLAG_SET(flag_value_buf[c], WORKEDFLAG);
+ FLAG_SET(afbuf[c].flag, NULLFLAG);
+ FLAG_SET(afbuf[c].flag, INLISTFLAG);
+ FLAG_SET(afbuf[c].flag, WORKEDFLAG);
Rast_set_c_null_value(&alt_value, 1);
/* flow accumulation */
Rast_set_d_null_value(&wat_value, 1);
@@ -338,7 +334,6 @@
else {
wat_value = 1;
wabuf[c].wat = wat_value;
wabuf[c].ele = alt_value;
@@ -349,8 +344,7 @@
seg_put_row(&watalt, (char *) wabuf, r);
- bseg_put_row(&bitflags, flag_value_buf, r);
- bseg_put_row(&asp, asp_buf, r);
+ seg_put_row(&aspflag, (char *)afbuf, r);
if (er_flag) {
cseg_put_row(&r_h, alt_value_buf, r);
@@ -359,8 +353,7 @@
G_percent(nrows, nrows, 1); /* finish it */
Rast_close(ele_fd);
G_free(wabuf);
- G_free(flag_value_buf);
- G_free(asp_buf);
+ G_free(afbuf);
if (run_flag) {
Rast_close(wat_fd);
@@ -380,9 +373,9 @@
block_value = buf[c];
if (!Rast_is_c_null_value(&block_value) && block_value) {
- FLAG_SET(flag_value, RUSLEBLOCKFLAG);
+ FLAG_SET(af.flag, RUSLEBLOCKFLAG);
@@ -462,11 +455,11 @@
if (pit_flag)
Rast_get_c_row(fd, buf, r);
- if (!FLAG_GET(flag_value, NULLFLAG)) {
+ if (!FLAG_GET(af.flag, NULLFLAG)) {
if (er_flag)
dseg_put(&s_l, &half_res, r, c);
if (r == 0 || c == 0 || r == nrows - 1 ||
c == ncols - 1) {
/* dseg_get(&wat, &wat_value, r, c); */
@@ -486,14 +479,13 @@
asp_value = -6;
else if (c == ncols - 1)
asp_value = -8;
- if (-1 == bseg_put(&asp, &asp_value, r, c))
- exit(EXIT_FAILURE);
/* cseg_get(&alt, &alt_value, r, c); */
alt_value = wa.ele;
add_pt(r, c, alt_value);
- FLAG_SET(flag_value, EDGEFLAG);
+ FLAG_SET(af.flag, EDGEFLAG);
+ af.asp = asp_value;
else {
@@ -502,14 +494,13 @@
r_nbr = r + nextdr[ct_dir];
c_nbr = c + nextdc[ct_dir];
- bseg_get(&bitflags, &worked_value, r_nbr, c_nbr);
- if (FLAG_GET(worked_value, NULLFLAG)) {
- asp_value = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
+ seg_get(&aspflag, (char *)&af_nbr, r_nbr, c_nbr);
+ if (FLAG_GET(af_nbr.flag, NULLFLAG)) {
add_pt(r, c, wa.ele);
- bseg_put(&asp, &asp_value, r, c);
wat_value = wa.wat;
if (wat_value > 0) {
wa.wat = -wat_value;
@@ -526,9 +517,9 @@
wat_value = wa.wat;
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/main.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -27,18 +27,18 @@
SSEG search_heap;
-int heap_size;
-int first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
+int nrows, ncols;
+GW_LARGE_INT heap_size;
+GW_LARGE_INT first_astar, first_cum, nxt_avail_pt, total_cells, do_points;
CELL n_basins;
OC_STACK *ocs;
int ocs_alloced;
-int nrows, ncols;
SSEG astar_pts;
-BSEG bitflags, s_b, asp;
+BSEG s_b;
CSEG dis, alt, bas, haf, r_h, dep;
-SSEG watalt;
+SSEG watalt, aspflag;
double segs_mb;
char zero, one;
Modified: grass/trunk/raster/r.watershed/seg/no_stream.c
--- grass/trunk/raster/r.watershed/seg/no_stream.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/no_stream.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -11,6 +11,7 @@
DCELL dvalue, max_drain; /* flow acc is now DCELL */
int updir, riteflag, leftflag, thisdir;
WAT_ALT wa;
+ ASP_FLAG af;
while (1) {
@@ -19,7 +20,8 @@
for (c = col - 1, cc = 0; c <= col + 1; c++, cc++) {
- bseg_get(&asp, &aspect, r, c);
+ aspect = af.asp;
if (aspect == drain[rr][cc]) {
dvalue = wa.wat;
@@ -36,7 +38,8 @@
if (max_drain > -1) {
updir = drain[row - uprow + 1][col - upcol + 1];
+ downdir = af.asp;
if (downdir < 0)
downdir = -downdir;
if (arm_flag) {
@@ -49,8 +52,8 @@
stream_length += window.ew_res;
- bseg_get(&asp, &asp_value, uprow, upcol);
+ seg_get(&aspflag, (char *)&af, uprow, upcol);
if (downdir == 2 || downdir == 6) {
stream_length += window.ns_res;
@@ -70,7 +73,8 @@
for (r = row - 1, rr = 0; rr < 3; r++, rr++) {
for (c = col - 1, cc = 0; cc < 3; c++, cc++) {
+ aspect = af.asp;
switch (haf_basin_side(updir,
Modified: grass/trunk/raster/r.watershed/seg/over_cells.c
--- grass/trunk/raster/r.watershed/seg/over_cells.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/over_cells.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -7,6 +7,7 @@
int r, rr, c, cc;
CELL new_ele, new_max_ele;
char aspect;
+ ASP_FLAG af;
cseg_put(&haf, &haf_num, row, col);
@@ -16,7 +17,8 @@
continue;
+ aspect = af.asp;
overland_cells(r, c, basin_num, haf_num, &new_ele);
@@ -44,6 +46,7 @@
int r, rr, c, cc, next_r, next_c;
char aspect;
int top = 0;
+ ASP_FLAG af;
/* put root on stack */
ocs[top].row = row;
@@ -64,7 +67,8 @@
continue;
+ aspect = af.asp;
if (top >= ocs_alloced) {
ocs_alloced += bas_thres;
Modified: grass/trunk/raster/r.watershed/seg/sg_factor.c
--- grass/trunk/raster/r.watershed/seg/sg_factor.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/sg_factor.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -8,15 +8,15 @@
int r, c;
CELL low_elev, hih_elev;
double height, length, S, sin_theta;
- char flag_value;
WAT_ALT wa;
+ ASP_FLAG af;
G_message(_("SECTION 5: RUSLE LS and/or S factor determination."));
for (r = nrows - 1; r >= 0; r--) {
G_percent(nrows - r, nrows, 3);
for (c = ncols - 1; c >= 0; c--) {
- if (FLAG_GET(flag_value, NULLFLAG))
+ if (FLAG_GET(af.flag, NULLFLAG))
continue;
seg_get(&watalt, (char *) &wa, r, c);
Modified: grass/trunk/raster/r.watershed/seg/slope_len.c
--- grass/trunk/raster/r.watershed/seg/slope_len.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/slope_len.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -6,6 +6,7 @@
char asp_value;
double res, top_ls, bot_ls;
WAT_ALT wa;
+ ASP_FLAG af;
if (sides == 8) {
if (r == dr)
@@ -17,7 +18,8 @@
- bseg_get(&asp, &asp_value, dr, dc);
+ seg_get(&aspflag, (char *)&af, dr, dc);
if (r == dr) {
res = window.ns_res;
Modified: grass/trunk/raster/r.watershed/seg/split_str.c
--- grass/trunk/raster/r.watershed/seg/split_str.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/split_str.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -7,6 +7,7 @@
CELL old_basin, new_elev;
char downdir, aspect;
WAT_ALT wa;
+ ASP_FLAG af;
double slope, easting, northing;
int doit, ctr, updir, splitdir[9];
int thisdir, leftflag, riteflag;
@@ -17,7 +18,8 @@
for (ctr = 1; ctr <= ct; ctr++)
splitdir[ctr] = drain[row - new_r[ctr] + 1][col - new_c[ctr] + 1];
updir = splitdir[1];
+ downdir = af.asp;
if (downdir < 0)
downdir = -downdir;
@@ -26,7 +28,8 @@
continue;
+ aspect = af.asp;
doit = 1;
Modified: grass/trunk/raster/r.watershed/seg/sseg_close.c
--- grass/trunk/raster/r.watershed/seg/sseg_close.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/sseg_close.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,7 +1,7 @@
#include <unistd.h>
-#include "cseg.h"
int seg_close(SSEG * sseg)
Modified: grass/trunk/raster/r.watershed/seg/sseg_get.c
--- grass/trunk/raster/r.watershed/seg/sseg_get.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/sseg_get.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int seg_get(SSEG * sseg, char *value, int row, int col)
+int seg_get(SSEG * sseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_get(&(sseg->seg), value, row, col) < 0) {
G_warning("seg_get(): could not read segment file");
@@ -11,7 +11,7 @@
return 0;
-int seg_get_row(SSEG * sseg, char *value, int row)
+int seg_get_row(SSEG * sseg, char *value, GW_LARGE_INT row)
if (segment_get_row(&(sseg->seg), value, row) < 0) {
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -2,10 +2,10 @@
#include <unistd.h>
#include <fcntl.h>
-#include "cseg.h"
int
-seg_open(SSEG * sseg, int nrows, int ncols, int row_in_seg, int col_in_seg,
+seg_open(SSEG * sseg, GW_LARGE_INT nrows, GW_LARGE_INT ncols, int row_in_seg, int col_in_seg,
int nsegs_in_memory, int size_struct)
char *filename;
Modified: grass/trunk/raster/r.watershed/seg/sseg_put.c
--- grass/trunk/raster/r.watershed/seg/sseg_put.c 2012-04-22 17:11:23 UTC (rev 51482)
+++ grass/trunk/raster/r.watershed/seg/sseg_put.c 2012-04-22 17:12:18 UTC (rev 51483)
@@ -1,8 +1,8 @@
-#include "cseg.h"
-int seg_put(SSEG * sseg, char *value, int row, int col)
+int seg_put(SSEG * sseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
if (segment_put(&(sseg->seg), value, row, col) < 0) {
G_warning("seg_put(): could not write segment file");
@@ -11,7 +11,7 @@
return 0;
-int seg_put_row(SSEG * sseg, char *value, int row)
+int seg_put_row(SSEG * sseg, char *value, GW_LARGE_INT row)
if (segment_put_row(&(sseg->seg), value, row) < 0) {
