[GRASS-SVN] r51484 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Mon Apr 23 01:50:33 EDT 2012
Author: lucadelu
Date: 2012-04-22 22:50:33 -0700 (Sun, 22 Apr 2012)
New Revision: 51484
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
Marco Curreli: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-04-22 17:12:18 UTC (rev 51483)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-04-23 05:50:33 UTC (rev 51484)
@@ -14,7 +14,7 @@
"Project-Id-Version: grassmods_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2012-04-05 21:30+0200\n"
+"PO-Revision-Date: 2012-04-22 10:55+0200\n"
"Last-Translator: \n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"Language: it\n"
@@ -38,7 +38,7 @@
#: ../visualization/nviz/src/nviz_init.c:60
msgid "Name of raster map(s) for Elevation"
-msgstr ""
+msgstr "Nome della mappa/e raster per Elevazione"
#: ../visualization/nviz/src/nviz_init.c:61
#: ../visualization/nviz/src/nviz_init.c:70
@@ -48,11 +48,11 @@
#: ../visualization/nviz/src/nviz_init.c:69
msgid "Name of raster map(s) for Color"
-msgstr ""
+msgstr "Nome della mappa/e raster per Colore"
#: ../visualization/nviz/src/nviz_init.c:78
msgid "Name of vector lines/areas overlay map(s)"
-msgstr ""
+msgstr "Nome della mappa/e vettoriale/i di linee/aree da sovrapporre"
#: ../visualization/nviz/src/nviz_init.c:79
#: ../visualization/nviz/src/nviz_init.c:88
@@ -61,7 +61,7 @@
#: ../visualization/nviz/src/nviz_init.c:87
msgid "Name of vector points overlay file(s)"
-msgstr ""
+msgstr "Nome del/dei file di punti vettoriali da sovrapporre"
#: ../visualization/nviz/src/nviz_init.c:96
msgid "Name of existing 3d raster map"
@@ -69,19 +69,19 @@
#: ../visualization/nviz/src/nviz_init.c:101
msgid "Quickstart - Do not load any data"
-msgstr ""
+msgstr "Avvio veloce - Non carica nessun dato"
#: ../visualization/nviz/src/nviz_init.c:106
msgid "Exit after completing script launched from the command line"
-msgstr ""
+msgstr "Uscire dopo il completamento dello script dalla riga di comando"
#: ../visualization/nviz/src/nviz_init.c:111
msgid "Start in Demo mode (skip the \"please wait\" message)"
-msgstr ""
+msgstr "Avvio in modalità dimostrazione (salta il messaggio \"attendere\")"
#: ../visualization/nviz/src/nviz_init.c:115
msgid "Verbose module output"
-msgstr ""
+msgstr "Output verboso del modulo"
#: ../visualization/nviz/src/nviz_init.c:121
msgid "Set alternative panel path"
@@ -89,11 +89,11 @@
#: ../visualization/nviz/src/nviz_init.c:127
msgid "Execute script file at startup"
-msgstr ""
+msgstr "Eseguire il file di script all'avvio"
#: ../visualization/nviz/src/nviz_init.c:133
msgid "Load previously saved state file"
-msgstr ""
+msgstr "Caricare il file dello stato precedentemente salvato"
#: ../visualization/nviz/src/nviz_init.c:157 ../raster/r.cost/main.c:226
#: ../raster/wildfire/r.spread/main.c:255 ../raster/wildfire/r.ros/main.c:314
@@ -105,7 +105,7 @@
#: ../visualization/nviz/src/nviz_init.c:287
msgid "Number of elevation files does not match number of colors files"
-msgstr ""
+msgstr "Il numero di file dell'elevazione non corrisponde al numero dei file del colori"
#: ../visualization/nviz/src/nviz_init.c:298
msgid "Loading data failed"
@@ -121,19 +121,19 @@
#: ../visualization/ximgview/main.c:82
msgid "Unable to get window attributes"
-msgstr ""
+msgstr "Non è possibile ottenere gli attributi della finestra"
#: ../visualization/ximgview/main.c:238
msgid "Unable to open image file"
-msgstr ""
+msgstr "Non è possibile aprire il file dell'immagine"
#: ../visualization/ximgview/main.c:241
msgid "Unable to read BMP header"
-msgstr ""
+msgstr "Non è possibile leggere l'intestazione BMP"
#: ../visualization/ximgview/main.c:244
msgid "Invalid BMP header"
-msgstr ""
+msgstr "Intestazione BMP non valida"
#: ../visualization/ximgview/main.c:250
msgid "Unable to map image file"
@@ -173,7 +173,7 @@
#: ../visualization/ximgview/color.c:256
#: ../visualization/xganim/Clr_table.c:260
msgid "Unable to get sufficient colors."
-msgstr ""
+msgstr "Non è possibile ottenere colori sufficienti."
#: ../visualization/ximgview/color.c:269
#: ../visualization/xganim/Clr_table.c:273
@@ -431,7 +431,7 @@
#: ../doc/raster/r.example/main.c:127
#, c-format
msgid "Unable to read file header of <%s>"
-msgstr ""
+msgstr "Non è possibile leggere l'intestazione del file di <%s>"
#: ../doc/raster/r.example/main.c:141 ../raster3d/r3.to.rast/main.c:183
#: ../raster/r.bilinear/main.c:104 ../raster/r.sun2/main.c:1164
@@ -714,7 +714,7 @@
#: ../raster3d/r3.in.v5d/main.c:191 ../raster3d/r3.in.ascii/main.c:240
msgid "raster3d, voxel, import"
-msgstr ""
+msgstr "raster3d, voxel, importazione"
#: ../raster3d/r3.in.v5d/main.c:193
msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
@@ -755,7 +755,7 @@
#: ../raster3d/r3.gwflow/main.c:94
msgid "Sources and sinks in [m^3/s]"
-msgstr ""
+msgstr "Sorgenti e pozzi in [m^3/s]"
#: ../raster3d/r3.gwflow/main.c:101
msgid "Specific yield in 1/m"
@@ -789,7 +789,7 @@
#: ../raster3d/base/r3.timestamp.main.c:43 ../raster3d/base/r3.mask.main.c:153
#: ../raster3d/r3.to.rast/main.c:215 ../raster3d/r3.cross.rast/main.c:270
msgid "raster3d, voxel"
-msgstr ""
+msgstr "raster3d, voxel"
#: ../raster3d/r3.gwflow/main.c:171
msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
@@ -858,7 +858,7 @@
#: ../raster3d/r3.mkdspf/main.c:127
#, fuzzy
msgid "Suppress progress report & min/max information"
-msgstr "Annulla le informazioni sull'andamento e sul minimo/massimo"
+msgstr "Omettere le informazioni sull'avanzamento e le informazioni sul minimo/massimo"
#: ../raster3d/r3.mkdspf/main.c:131
msgid "Use flat shading rather than gradient"
@@ -895,7 +895,7 @@
#: ../raster3d/r3.mkdspf/main.c:216
#, c-format
msgid "Writing %s from %s..."
-msgstr "Sto scrivendo %s da %s..."
+msgstr "Scrittura di %s da %s in corso..."
#: ../raster3d/r3.out.ascii/main.c:76
msgid "3D raster map to be converted to ASCII"
@@ -927,7 +927,7 @@
#: ../raster3d/r3.out.ascii/main.c:244 ../raster3d/r3.out.v5d/main.c:286
#: ../raster3d/r3.out.vtk/main.c:376
msgid "raster3d, voxel, export"
-msgstr ""
+msgstr "raster3d, voxel, esportazione"
#: ../raster3d/r3.out.ascii/main.c:246
msgid "Converts a 3D raster map layer into an ASCII text file."
@@ -967,11 +967,11 @@
#: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:266
#, c-format
msgid "%s: illegal value spec"
-msgstr "%s: valore illegale"
+msgstr "%s: specificazione di valore non consentita"
#: ../raster3d/base/r3.info.main.c:80
msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
+msgstr "Produce informazioni di base su un tematismo raster 3D definito dall'utente."
#: ../raster3d/base/r3.info.main.c:87
msgid "Name of input 3D raster map"
@@ -1401,7 +1401,7 @@
#: ../raster3d/r3.out.vtk/main.c:118
msgid "Specify top and bottom map"
-msgstr ""
+msgstr "Specificare la mappa superiore e inferiore"
#: ../raster3d/r3.out.vtk/main.c:125
#, c-format
@@ -1548,7 +1548,7 @@
#: ../misc/m.nviz.image/args.c:81
msgid "Name for output image file (without extension)"
-msgstr ""
+msgstr "Nome per il file immagine di output (senza estensione)"
#: ../misc/m.nviz.image/args.c:82 ../misc/m.nviz.image/args.c:96
#: ../misc/m.nviz.image/args.c:106
@@ -1562,7 +1562,7 @@
#: ../misc/m.nviz.image/args.c:104
msgid "Size (width, height) of output image"
-msgstr ""
+msgstr "Dimensione (larghezza, altezza) dell'immagine di output"
#: ../misc/m.nviz.image/args.c:121
msgid "Name of raster map(s) for elevation"
@@ -1610,7 +1610,7 @@
#: ../misc/m.nviz.image/args.c:220
msgid "Draw mode"
-msgstr ""
+msgstr "Modalità disegno"
#: ../misc/m.nviz.image/args.c:223 ../misc/m.nviz.image/args.c:234
#: ../misc/m.nviz.image/args.c:245 ../misc/m.nviz.image/args.c:257
@@ -1634,7 +1634,7 @@
#: ../misc/m.nviz.image/args.c:266
msgid "Shading"
-msgstr ""
+msgstr "Ombreggiatura"
#: ../misc/m.nviz.image/args.c:275
msgid "Wire color"
@@ -1643,11 +1643,11 @@
#: ../misc/m.nviz.image/args.c:287
#, fuzzy
msgid "Surface position"
-msgstr "Punto di riferimento"
+msgstr "Posizione sulla superficie"
#: ../misc/m.nviz.image/args.c:299
msgid "Name of line vector overlay map(s)"
-msgstr ""
+msgstr "Nome della mappa/e di linee vettoriali da sovrapporre"
#: ../misc/m.nviz.image/args.c:300 ../misc/m.nviz.image/args.c:311
#: ../misc/m.nviz.image/args.c:322 ../misc/m.nviz.image/args.c:334
@@ -1677,7 +1677,7 @@
#: ../misc/m.nviz.image/args.c:367
msgid "Name of point vector overlay map(s)"
-msgstr ""
+msgstr "Nome della mappa/e di punti vettoriali da sovrapporre"
#: ../misc/m.nviz.image/args.c:368 ../misc/m.nviz.image/args.c:379
#: ../misc/m.nviz.image/args.c:391 ../misc/m.nviz.image/args.c:402
@@ -1687,7 +1687,7 @@
#: ../misc/m.nviz.image/args.c:378
msgid "Icon size"
-msgstr " Grandezza icona"
+msgstr "Dimensione icona"
#: ../misc/m.nviz.image/args.c:390
msgid "Icon width"
@@ -1712,15 +1712,15 @@
#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:453
#: ../misc/m.nviz.image/args.c:463 ../misc/m.nviz.image/args.c:475
msgid "Viewpoint"
-msgstr ""
+msgstr "Punto di vista"
#: ../misc/m.nviz.image/args.c:452
msgid "Viewpoint height (in map units)"
-msgstr ""
+msgstr "Altezza del punto di vista (in unità di mappa)"
#: ../misc/m.nviz.image/args.c:462
msgid "Viewpoint field of view (in degrees)"
-msgstr ""
+msgstr "Campo visivo del punto di vista (in gradi)"
#: ../misc/m.nviz.image/args.c:474
msgid "Viewpoint twist angle (in degrees)"
@@ -1733,7 +1733,7 @@
#: ../misc/m.nviz.image/args.c:495 ../misc/m.nviz.image/args.c:530
#: ../misc/m.nviz.image/args.c:542 ../misc/m.nviz.image/args.c:552
msgid "Volumes"
-msgstr ""
+msgstr "Volumi"
#: ../misc/m.nviz.image/args.c:505
msgid "Volume draw mode"
@@ -1741,15 +1741,15 @@
#: ../misc/m.nviz.image/args.c:517
msgid "Volume shading"
-msgstr ""
+msgstr "Ombreggiatura del volume"
#: ../misc/m.nviz.image/args.c:529
msgid "Volume position"
-msgstr ""
+msgstr "Posizione del volume"
#: ../misc/m.nviz.image/args.c:540
msgid "Volume resolution"
-msgstr ""
+msgstr "Risoluzione del volume"
#: ../misc/m.nviz.image/args.c:551
msgid "Isosurface level"
@@ -1762,7 +1762,7 @@
#: ../misc/m.nviz.image/args.c:567 ../misc/m.nviz.image/args.c:573
#: ../misc/m.nviz.image/args.c:582 ../misc/m.nviz.image/args.c:592
msgid "Lighting"
-msgstr ""
+msgstr "Illuminazione"
#: ../misc/m.nviz.image/args.c:572
msgid "Light color"
@@ -1875,7 +1875,7 @@
#: ../misc/m.nviz.image/main.c:201
msgid "Unsupported output format"
-msgstr ""
+msgstr "Formato di output non supportato"
#: ../misc/m.nviz.image/main.c:203 ../imagery/i.cluster/main.c:346
#, c-format
@@ -1890,12 +1890,12 @@
#: ../misc/m.nviz.image/surface.c:130
#, c-format
msgid "Color attribute not defined, using default <%s>"
-msgstr ""
+msgstr "Attributo del colore non definito, verrà usato quello predefinito <%s>"
#: ../misc/m.nviz.image/surface.c:211
#, c-format
msgid "Surface id %d doesn't exist"
-msgstr ""
+msgstr "L'id dellal superficie %d non esiste"
#: ../misc/m.nviz.image/surface.c:251 ../misc/m.nviz.image/surface.c:258
#, c-format
@@ -1907,9 +1907,8 @@
msgstr ""
#: ../misc/m.cogo/main.c:225
-#, fuzzy
msgid "miscellaneous, distance"
-msgstr "N"
+msgstr "Miscellanea, distanza"
#: ../misc/m.cogo/main.c:226
msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
@@ -1921,11 +1920,11 @@
#: ../misc/m.cogo/main.c:232
msgid "Lines are labelled"
-msgstr ""
+msgstr "Le linee sono etichettate"
#: ../misc/m.cogo/main.c:236
msgid "Suppress warnings"
-msgstr ""
+msgstr "Non mostrare gli avvertimenti"
#: ../misc/m.cogo/main.c:241
msgid "Convert from coordinates to bearing and distance"
@@ -1961,12 +1960,12 @@
#: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:341
msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr ""
+msgstr "Non è possibile convertire le informazioni sulla proiezione della mappa raster nel formato di GRASS per la verifica"
#: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:357
#: ../vector/v.in.ogr/main.c:511
msgid "Over-riding projection check"
-msgstr ""
+msgstr "La verifica della proiezione verrà ignorata"
#: ../raster/r.external/main.c:107 ../raster/r.in.gdal/main.c:367
#: ../vector/v.in.ogr/main.c:520
@@ -2201,7 +2200,7 @@
#: ../raster/r.external/main.c:634
#, c-format
msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr ""
+msgstr "Il gruppo di immagini <%s> esite già e verrà sovrascritto."
#: ../raster/r.external/main.c:645 ../raster/r.in.gdal/main.c:472
#, c-format
@@ -2211,7 +2210,7 @@
#: ../raster/r.external/main.c:674
#, c-format
msgid "Imagery group <%s> created"
-msgstr ""
+msgstr "Gruppo di immagini <%s> creato"
#: ../raster/r.bilinear/main.c:42 ../raster/r.resamp.stats/main.c:259
#: ../raster/r.resamp.rst/main.c:156 ../raster/r.resample/main.c:54
@@ -2251,11 +2250,11 @@
#: ../raster/r.mode/main.c:58
msgid "Base map to be reclassified"
-msgstr ""
+msgstr "Mappa di base da riclassificare"
#: ../raster/r.mode/main.c:65
msgid "Coverage map"
-msgstr ""
+msgstr "Mappa di copertura"
#: ../raster/r.mode/main.c:72
msgid "Output map"
@@ -2274,7 +2273,7 @@
#: ../raster/r.mode/main.c:97
#, c-format
msgid "%s: base map and output map must be different"
-msgstr ""
+msgstr "%s: la mappa di base e la mappa di output devono essere differenti"
#: ../raster/r.mode/main.c:101
#, c-format
@@ -2405,7 +2404,7 @@
#: ../raster/r.profile/main.c:305
#, c-format
msgid "Approx. transect length [%f] m"
-msgstr ""
+msgstr "Lunghetta approssimativa del transetto [%f] m"
#: ../raster/r.profile/main.c:308
msgid "Endpoint coordinates are outside of current region settings"
@@ -2500,11 +2499,11 @@
#: ../raster/r.sun2/main.c:346
msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-msgstr ""
+msgstr "Nome della mappa raster di input dei coefficienti di radiazione diretta in condizioni di cielo reali [-]"
#: ../raster/r.sun2/main.c:355
msgid "Name of real-sky diffuse radiation coefficient input raster map [-]"
-msgstr ""
+msgstr "Nome della mappa raster di input dei coefficienti di radiazione diffusa in condizioni di cielo reali [-]"
#: ../raster/r.sun2/main.c:363
msgid "The horizon information input map prefix"
@@ -3127,17 +3126,20 @@
#: ../raster/r.watershed/shed/com_line.c:352
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
+msgstr "Premere <return> (invio) se non c'è una mappa del territorio antropizzato."
#: ../raster/r.watershed/shed/com_line.c:364
msgid ""
"\n"
"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
+"\n"
+"Immettere il valore indicante la percentuale di territorio antropizzato. Questo valore"
+# FINIRE
#: ../raster/r.watershed/shed/com_line.c:365
msgid "be used for every cell in the current region."
-msgstr "da utilizzare per ogni cella nella regione corrente."
+msgstr "verrà utilizzato per ogni cella nella regione corrente."
#: ../raster/r.watershed/shed/com_line.c:368
#, c-format
@@ -3338,71 +3340,72 @@
#: ../raster/r.watershed/front/main.c:61
msgid "Input map: elevation on which entire analysis is based"
-msgstr ""
+msgstr "Mappa di input: il modello altimetrico su cui si basa l'intera analisi"
#: ../raster/r.watershed/front/main.c:66
msgid "Input map: locations of real depressions"
-msgstr ""
+msgstr "Mappa di input: ubicazione delle depressioni reali"
#: ../raster/r.watershed/front/main.c:72
msgid "Input map: amount of overland flow per cell"
-msgstr ""
+msgstr "Mappa di input: la quantità di deflusso superficiale per cella"
#: ../raster/r.watershed/front/main.c:79
msgid "Input map or value: percent of disturbed land, for USLE"
-msgstr ""
+msgstr "Mappa di input o valore: percentuale di territorio antropizzato, per USLE"
#: ../raster/r.watershed/front/main.c:88
msgid "Input map: terrain blocking overland surface flow, for USLE"
-msgstr ""
+msgstr "Mappa di input: terreno che ostacola lo scorrimento superficiale, per USLE"
#: ../raster/r.watershed/front/main.c:95
msgid "Output map: number of cells that drain through each cell"
-msgstr ""
+msgstr "Mappa di output: numero di celle che defluiscono attraverso ciascuna cella"
#: ../raster/r.watershed/front/main.c:101
msgid "Output map: drainage direction"
-msgstr ""
+msgstr "Mappa di output: direzione di drenaggio"
+# FINIRE
#: ../raster/r.watershed/front/main.c:108
msgid "Output map: unique label for each watershed basin"
-msgstr ""
+msgstr "Mappa di output: un'etichetta univoca per ogni bacino idrografico"
#: ../raster/r.watershed/front/main.c:114
msgid "Output map: stream segments"
-msgstr ""
+msgstr "Mappa di output: segmenti dei corsi d'acqua"
#: ../raster/r.watershed/front/main.c:121
msgid "Output map: each half-basin is given a unique value"
-msgstr ""
+msgstr "Mappa di output: a ogni semibacino è assegnato un valore univoco"
#: ../raster/r.watershed/front/main.c:128
msgid "Output map: useful for visual display of results"
-msgstr ""
+msgstr "Mappa di output: utile per la visualizzazione dei risultati"
#: ../raster/r.watershed/front/main.c:135
msgid "Output map: slope length and steepness (LS) factor for USLE"
-msgstr ""
+msgstr "Mappa di output: fattore lunghezza e inclinazione del pendio (LS) per USLE"
#: ../raster/r.watershed/front/main.c:141
msgid "Output map: slope steepness (S) factor for USLE"
-msgstr ""
+msgstr "Mappa di output: fattore pendenza (S) per USLE"
#: ../raster/r.watershed/front/main.c:148
msgid "Input value: minimum size of exterior watershed basin"
-msgstr ""
+msgstr "Valore in input: dimensione minima del bacino idrografico esterno"
#: ../raster/r.watershed/front/main.c:156
msgid "Input value: maximum length of surface flow, for USLE"
-msgstr ""
+msgstr "Valore in input: lunghezza massima dello scorrimento superficiale, per USLE"
#: ../raster/r.watershed/front/main.c:166
msgid "Convergence factor for MFD (1-10)"
-msgstr ""
+msgstr "Fattore d convergenza per MFD (1-10)"
#: ../raster/r.watershed/front/main.c:168
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
+msgstr "1 = flusso più divergente, 10 = flusso più convergente. Consigliato: 5"
#: ../raster/r.watershed/front/main.c:175
msgid "Maximum memory to be used with -m flag (in MB)"
@@ -3410,15 +3413,15 @@
#: ../raster/r.watershed/front/main.c:179
msgid "Enable MFD flow (default is SFD (D8))"
-msgstr ""
+msgstr "Abilitare flusso MDF (quello predefinito è SFD (D8))"
#: ../raster/r.watershed/front/main.c:181
msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
+msgstr "SFD: direzione di flusso singola, MFD: direzione di flusso multipla"
#: ../raster/r.watershed/front/main.c:186
msgid "Allow only horizontal and vertical flow of water"
-msgstr ""
+msgstr "Consentire solo deflussi idrici orizzontali e verticali"
#: ../raster/r.watershed/front/main.c:191
msgid "Enable disk swap memory option: Operation is slow"
@@ -3430,11 +3433,12 @@
#: ../raster/r.watershed/front/main.c:198
msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
+msgstr "Usare un'accumulazione di flusso positiva anche per le possibili sottostime"
+# FINIRE
#: ../raster/r.watershed/front/main.c:200
msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
+msgstr "Si veda il manuale per una descrizione dettagliata dell'output dell'accumulazione di flusso"
#: ../raster/r.watershed/front/main.c:217
msgid "Sorry, you must choose an output map."
@@ -3450,7 +3454,7 @@
#: ../raster/r.watershed/front/main.c:388
#, c-format
msgid "Subprocess failed with exit code %d"
-msgstr ""
+msgstr "Subprocesso non andato a buon fine con codice d'uscita %d"
#: ../raster/r.colors.out/main.c:63
msgid "raster, export, color table"
@@ -3795,9 +3799,9 @@
# row%s : singolare/plurale?
#: ../raster/r.support/modhead/modhead.c:271
-#, fuzzy, c-format
+#, c-format
msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-msgstr "L'intestazione indica %d righe%s nella mappa raster, ma il formato reale del file indica %d righe%s"
+msgstr "L'intestazione indica n. %d righe (row%s) nella mappa raster, ma il formato reale del file indica n. %d righe (row%s)"
#: ../raster/r.support/modhead/modhead.c:303
#, c-format
@@ -5028,9 +5032,8 @@
msgstr "Lettura di %s in corso ..."
#: ../raster/r.los/main.c:82
-#, fuzzy
msgid "raster, viewshed"
-msgstr "raster, serie"
+msgstr "raster, intervisibilità"
#: ../raster/r.los/main.c:83
msgid "Line-of-sight raster analysis program."
@@ -6996,9 +6999,8 @@
# vector: vettoriale
#: ../raster/r.le/r.le.setup/sample.c:1050
-#, fuzzy
msgid "Cannot read vector"
-msgstr "Impossibile leggere il vettore"
+msgstr "Impossibile leggere il vettoriale"
#: ../raster/r.le/r.le.pixel/main.c:47
msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
@@ -7012,7 +7014,7 @@
#: ../raster/r.digit/get_label.c:46
#, c-format
msgid "Enter a label for category %ld [%s] "
-msgstr ""
+msgstr "Inserisci un'etichetta per la categoria %ld [%s] "
#: ../raster/r.digit/get_label.c:68
msgid "Look ok? "
@@ -7024,7 +7026,7 @@
#: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:117
msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
+msgstr "Mostra i comandi da usare per lo sfondo (separati da ';')"
#: ../raster/r.digit/main.c:79
msgid "No graphics device selected!"
@@ -8192,9 +8194,8 @@
#: ../raster/wildfire/r.spread/main.c:151
#: ../raster/wildfire/r.spread/main.c:159
#: ../raster/wildfire/r.spread/main.c:167
-#, fuzzy
msgid "Input_maps"
-msgstr "Mappe di input"
+msgstr "Mappe in input"
#: ../raster/wildfire/r.spread/main.c:118
msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
@@ -8247,7 +8248,6 @@
#: ../raster/wildfire/r.spread/main.c:212
#: ../raster/wildfire/r.spread/main.c:220
#: ../raster/wildfire/r.spread/main.c:228
-#, fuzzy
msgid "Output_maps"
msgstr "Mappe in output"
@@ -8431,9 +8431,8 @@
msgstr "Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
#: ../raster/r.univar2/r3.univar_main.c:163
-#, fuzzy
msgid "Unable to load 3D raster range"
-msgstr "Impossibile leggere la riga del raster"
+msgstr "Non è possibile caricare il campo di variazione del raster 3D"
#: ../raster/r.grow.distance/main.c:132
msgid "Generates a raster map layer of distance to features in input layer."
@@ -9009,10 +9008,11 @@
msgid "Unable to read range for map <%s>"
msgstr "Non è possibile leggere l'intervallo per la mappa <%s>"
+# verificare
#: ../raster/r.stats/cell_stats.c:51
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read raster <map %d of %d> row %d"
-msgstr "Non è possibile leggere la mapp raster <map %d of %d> riga %d"
+msgstr "Non è possibile leggere la mappa raster <mappa %d di %d> riga %d"
#: ../raster/r.region/main.c:56
msgid "Sets the boundary definitions for a raster map."
@@ -10654,9 +10654,8 @@
# transetto?
#: ../raster/r.transect/main.c:54
-#, fuzzy
msgid "raster, transect"
-msgstr "raster, transect"
+msgstr "raster, transetto"
#: ../raster/r.transect/main.c:56
msgid "Outputs raster map layer values lying along user defined transect line(s)."
@@ -11239,9 +11238,10 @@
msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
msgstr "La rettifica polinomiale usata in i.rectify non lavora bene con dati NOAA/AVHRR. Prova usando gdalwarp con la rettifica spline piana. (-tps)"
+# flipped
#: ../raster/r.in.gdal/main.c:266
msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr "Il raster di input è ruotato - non può essere importato. Si può utilizzare 'gdalwarp' per trasformare la mappa col Nord in alto"
+msgstr "Il raster di input è capovolto o ruotato - non può essere importato. Si può utilizzare 'gdalwarp' per trasformare la mappa col Nord in alto."
#: ../raster/r.in.gdal/main.c:308
msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
@@ -11298,22 +11298,21 @@
# target: ?
#: ../raster/r.in.gdal/main.c:668
-#, fuzzy
msgid "Unable to get projection info of target location"
-msgstr "Impossibile ottenere informazioni sulla proiezione della location definita dal parametro target"
+msgstr "Impossibile ottenere informazioni sulla proiezione della location target"
#: ../raster/r.in.gdal/main.c:670
msgid "Unable to get projection units of target location"
-msgstr "Impossibile ottene le unità della proiezione della location d'origine"
+msgstr "Impossibile ottene le unità della proiezione della location target"
#: ../raster/r.in.gdal/main.c:672
msgid "Unable to get projection key values of target location"
-msgstr ""
+msgstr "Impossibile ottene i valori chiave della proiezione della location target"
# target: destinazione ?
#: ../raster/r.in.gdal/main.c:675 ../imagery/i.rectify/target.c:32
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:31
-#, fuzzy, c-format
+#, c-format
msgid "Mapset <%s> in target location <%s> - "
msgstr "Mapset <%s> nella location target <%s> - "
@@ -11329,7 +11328,7 @@
#: ../raster/r.horizon/main.c:179
msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
+msgstr "Calcolo dell'angolo dell'orizzonte da un modello digitale di elevazione."
#: ../raster/r.horizon/main.c:181
msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
@@ -11802,36 +11801,38 @@
msgid "Unable to allocate buffer for reading raster map"
msgstr ""
+# FINIRE
#: ../raster/r.out.gdal/export_band.c:186
#, c-format
msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
+msgstr "La mappa raster di input contiene celle con valore NULL (nessun dato). Il valore %d verrà usato per rappresentare i valori delle celle senza dati nella mappa di input. È possibile specificare un valore per le celle senza dati con l'opzione %s."
#: ../raster/r.out.gdal/export_band.c:191
#, c-format
msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr ""
+msgstr "La mappa raster di input contiene celle con valore NULL (nessun dato). Il valore %f verrà usato per rappresentare i valori delle celle senza dati nella mappa di input. È possibile specificare un valore per le celle senza dati con l'opzione %s."
#: ../raster/r.out.gdal/export_band.c:201
#, c-format
msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
+msgstr "Il valore predefinito per 'nessun dato' è presente nella banda raster <%s> e potrebbe causare una perdita di dati. Specificare un altro valore col parametro %s."
#: ../raster/r.out.gdal/export_band.c:208
#, c-format
msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
+msgstr "Il valore %g definito dall'utente per 'nessun dato' è presente nella banda raster <%s> e potrebbe causare una perdita di dati. Specificare un altro valore col parametro %s."
#: ../raster/r.out.gdal/export_band.c:254
msgid "Unable to get raster band"
-msgstr ""
+msgstr "Non è possibile ottenere la banda raster"
#: ../raster/r.out.gdal/export_band.c:414
#: ../raster/r.out.gdal/export_band.c:447
#: ../raster/r.out.gdal/export_band.c:480
msgid "Unable to write GDAL raster file"
-msgstr ""
+msgstr "Non è possibile scrivere il file raster GDAL"
+# FINIRE
#: ../raster/r.out.gdal/export_band.c:498
#: ../raster/r.out.gdal/export_band.c:510
#: ../raster/r.out.gdal/export_band.c:523
@@ -11843,7 +11844,7 @@
#: ../raster/r.out.gdal/main.c:669 ../raster/r.out.gdal/main.c:681
#: ../raster/r.out.gdal/main.c:694
msgid "Selected GDAL datatype does not cover data range."
-msgstr ""
+msgstr "Il tipo di dati GDAL non copre il campo di variazione dei dati."
#: ../raster/r.out.gdal/export_band.c:499
#: ../raster/r.out.gdal/export_band.c:511
@@ -11853,7 +11854,7 @@
#: ../raster/r.out.gdal/main.c:670
#, c-format
msgid "GDAL datatype: %s, range: %d - %d"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, campo di variazione: %d - %d"
#: ../raster/r.out.gdal/export_band.c:502
#: ../raster/r.out.gdal/export_band.c:514
@@ -11869,13 +11870,13 @@
#: ../raster/r.out.gdal/export_band.c:549 ../raster/r.out.gdal/main.c:682
#, c-format
msgid "GDAL datatype: %s, range: %u - %u"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, campo di variazione: %u - %u"
#: ../raster/r.out.gdal/export_band.c:562
#: ../raster/r.out.gdal/export_band.c:576 ../raster/r.out.gdal/main.c:695
#, c-format
msgid "GDAL datatype: %s, range: %g - %g"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, campo di variazione: %g - %g"
#: ../raster/r.out.gdal/main.c:49
#, c-format
@@ -11911,10 +11912,11 @@
msgid "Name of raster map (or group) to export"
msgstr "Nome della mappa raster (o gruppo) da esportare"
+# FINIRE
#: ../raster/r.out.gdal/main.c:154
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr ""
+msgstr "Formato GIS da scrivere (sensibile alle maiuscole; vedi anche il flag -l)"
#: ../raster/r.out.gdal/main.c:175
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
@@ -11927,12 +11929,12 @@
#: ../raster/r.out.gdal/main.c:190
msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
+msgstr "Opzioni di creazione da passare al driver del formato di output"
#: ../raster/r.out.gdal/main.c:192
#: ../locale/scriptstrings/d.out.file_to_translate.c:21
msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma."
-msgstr ""
+msgstr "Nella forma \"NOME=VALORE\". Separare voci multiple con una virgola."
#: ../raster/r.out.gdal/main.c:199
msgid "Metadata key(s) and value(s) to include"
@@ -11940,11 +11942,12 @@
#: ../raster/r.out.gdal/main.c:201
msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
-msgstr ""
+msgstr "Nella forma \"META-TAG=VALORE\". Separare voci multiple con una virgola. Non supportato da tutti i driver di formato."
+# FINIRE
#: ../raster/r.out.gdal/main.c:210
msgid "Assign a specified nodata value to output bands"
-msgstr ""
+msgstr "Assegna un valore specifico per il valore 'nessun dato' alle bande di output."
#: ../raster/r.out.gdal/main.c:243
#, c-format
@@ -11959,16 +11962,17 @@
#: ../raster/r.out.gdal/main.c:261
#, c-format
msgid "Unable to get <%s> driver"
-msgstr ""
+msgstr "Non è possibile ottenere il driver <%s>"
+# FINIRE
#: ../raster/r.out.gdal/main.c:267
#, c-format
msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
+msgstr "Il driver <%s> non supporta la scrittura diretta. Si sta utilizzando il driver MEM per dataset intermedi"
#: ../raster/r.out.gdal/main.c:272
msgid "Unable to get in-memory raster driver"
-msgstr ""
+msgstr "Non è possibile ottenere il driver raster in-memory"
#: ../raster/r.out.gdal/main.c:276
#, c-format
@@ -11978,31 +11982,33 @@
#: ../raster/r.out.gdal/main.c:352
#, c-format
msgid "Could not read data range of raster <%s>"
-msgstr ""
+msgstr "Non è possibile leggere il campo di variazione dei dati del raster <%s>"
#: ../raster/r.out.gdal/main.c:409
#, c-format
msgid "Exporting to GDAL data type: %s"
-msgstr "Esporta al tipo di dato GDAL: %s"
+msgstr "Esportazione al tipo di dato GDAL: %s"
+# FINIRE
#: ../raster/r.out.gdal/main.c:424
msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
+msgstr "L'esportazione del raster potrebbe causare la perdita completa dei dati; l'operazione verrà interrotta."
#: ../raster/r.out.gdal/main.c:435
#, c-format
msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
-msgstr ""
+msgstr "Perdita di precisione: mappa raster <%s> di tipo %s da esportare come %s. Può essere evitata usando %s."
+# FINIRE
#: ../raster/r.out.gdal/main.c:446
#, c-format
msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
+msgstr "Perdita di precisione: il campo di variazione di <%s> non può essere preservato con accuratezza col tipo di dato GDAL Float32. Può essere evitata esportando in Int32 o Float64."
#: ../raster/r.out.gdal/main.c:454
#, c-format
msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
-msgstr ""
+msgstr "Perdita di precisione: Float32 non può preservare la precisione DCELL del raster <%s>. Può essere evitata usando Float64"
#: ../raster/r.out.gdal/main.c:482 ../raster/r.out.gdal/main.c:511
#: ../raster/r.out.gdal/main.c:515
@@ -12011,7 +12017,7 @@
#: ../raster/r.out.gdal/main.c:492
msgid "Checking GDAL data type and nodata value"
-msgstr ""
+msgstr "Controllo del tipo di dati GDAL e del valore 'nessun dato'"
#: ../raster/r.out.gdal/main.c:495
#, c-format
@@ -12045,7 +12051,7 @@
#: ../raster/r.out.gdal/main.c:580
msgid "Exporting to GDAL raster"
-msgstr ""
+msgstr "Esportazione nel raster GDAL"
#: ../raster/r.out.gdal/main.c:583
#, c-format
@@ -12067,40 +12073,41 @@
#: ../raster/r.out.gdal/main.c:685
#, c-format
msgid "Range to be exported: %f - %f"
-msgstr ""
+msgstr "Intervallo dati da esportare: %f - %f"
#: ../raster/r.out.gdal/main.c:698
#, c-format
msgid "Range to be exported: %g - %g"
-msgstr ""
+msgstr "Intervallo dati da esportare: %g - %g"
+# FINIRE
#: ../raster/r.out.gdal/main.c:722 ../raster/r.out.gdal/main.c:735
#: ../raster/r.out.gdal/main.c:749 ../raster/r.out.gdal/main.c:762
#: ../raster/r.out.gdal/main.c:777
#, c-format
msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
-msgstr ""
+msgstr "Discordanza fra il valore 'nessun dato' dei metadati e quello reale nel raster esportato: il valore 'nessun dato %f specificato viene convertito a %d dal tipo di dati GDAL selezionato."
#: ../raster/r.out.gdal/main.c:725 ../raster/r.out.gdal/main.c:752
#: ../raster/r.out.gdal/main.c:780
#, c-format
msgid "GDAL datatype: %s, valid range: %d - %d"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, intervallo valido: %d - %d"
#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:765
#, c-format
msgid "GDAL datatype: %s, valid range: %u - %u"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, intervallo valido: %u - %u"
#: ../raster/r.out.gdal/main.c:791
#, c-format
msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
-msgstr ""
+msgstr "Discordanza fra il valore 'nessun dato' dei metadati e quello reale nel raster esportato: il valore 'nessun dato %g specificato viene convertito a %g dal tipo di dati GDAL selezionato."
#: ../raster/r.out.gdal/main.c:794
#, c-format
msgid "GDAL datatype: %s, valid range: %g - %g"
-msgstr ""
+msgstr "Tipo di dati GDAL: %s, intervallo valido: %g - %g"
#: ../raster/r.lake/main.c:79
#, c-format
@@ -12823,7 +12830,7 @@
#: ../imagery/i.points/main.c:96 ../imagery/i.vpoints/main.c:94
msgid "imagery, geometry"
-msgstr ""
+msgstr "immagine, geometria"
#: ../imagery/i.points/main.c:98
msgid "Mark ground control points on image to be rectified."
@@ -12831,7 +12838,7 @@
#: ../imagery/i.points/main.c:105 ../imagery/i.vpoints/main.c:104
msgid "Name of imagery group to be registered"
-msgstr ""
+msgstr "Nome del gruppo di immagini da registrare"
#: ../imagery/i.points/main.c:123 ../imagery/i.class/main.c:90
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:97
@@ -13040,7 +13047,7 @@
#: ../imagery/i.maxlik/main.c:63
msgid "imagery, classification, MLC"
-msgstr ""
+msgstr "immagini, classificazione, MLC"
#: ../imagery/i.maxlik/main.c:65
msgid "Classifies the cell spectral reflectances in imagery data."
@@ -13203,7 +13210,7 @@
#: ../imagery/i.class/main.c:72 ../imagery/i.cca/main.c:93
msgid "Name of input imagery subgroup"
-msgstr ""
+msgstr "Nome del sottogruppo di immagini di input"
#: ../imagery/i.class/main.c:77
msgid "File to contain result signatures"
@@ -13307,7 +13314,7 @@
#: ../imagery/i.group/main.c:52 ../imagery/i.target/main.c:45
msgid "imagery, map management"
-msgstr ""
+msgstr "immagini, gestione delle mappe"
#: ../imagery/i.group/main.c:54
msgid "Creates, edits, and lists groups and subgroups of imagery files."
@@ -13316,11 +13323,11 @@
#: ../imagery/i.group/main.c:58
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:62
msgid "Name of imagery group"
-msgstr ""
+msgstr "Nome del gruppo di immagini"
#: ../imagery/i.group/main.c:64
msgid "Name of imagery sub-group"
-msgstr ""
+msgstr "Nome del sottogruppo di immagini"
#: ../imagery/i.group/main.c:68
msgid "Name of raster map(s) to include in group"
@@ -13483,7 +13490,7 @@
#: ../imagery/i.his.rgb/h2rmain.c:45 ../imagery/i.rgb.his/r2hmain.c:45
msgid "imagery, color transformation, RGB, HIS"
-msgstr ""
+msgstr "immagini, trasformazione di colore, RGB, HIS"
#: ../imagery/i.his.rgb/h2rmain.c:47
msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
@@ -13555,7 +13562,7 @@
#: ../imagery/i.rectify/main.c:90
msgid "imagery, rectify"
-msgstr ""
+msgstr "immagini, rettificare"
#: ../imagery/i.rectify/main.c:92
msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
@@ -13746,34 +13753,35 @@
#: ../imagery/i.rectify/target.c:35
msgid "Please run i.target for group."
-msgstr ""
+msgstr "Eseguire i.target per il gruppo"
+# target
#: ../imagery/i.target/main.c:47
msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr ""
+msgstr "Destina un gruppo di immagini a una location e a un mapset di GRASS."
#: ../imagery/i.target/main.c:56
msgid "Name of imagery target location"
-msgstr ""
+msgstr "Nome della location di destinazione delle immagini"
#: ../imagery/i.target/main.c:62
msgid "Name of target mapset"
-msgstr "Nome del mapset d'origine"
+msgstr "Nome del mapset di destinazione"
#: ../imagery/i.target/main.c:67
msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
+msgstr "Imposta location e mapset correnti come destinazione del gruppo di immagini"
#: ../imagery/i.target/main.c:89 ../imagery/i.target/main.c:106
#: ../imagery/i.target/main.c:115
#, c-format
msgid "Group <%s> targeted for location [%s], mapset [%s]"
-msgstr ""
+msgstr "Il gruppo <%s> è stato assegnato alla location [%s], mapset [%s]"
#: ../imagery/i.target/main.c:92
#, c-format
msgid "Group <%s> has no target"
-msgstr ""
+msgstr "Il gruppo <%s> non ha destinazione"
#: ../imagery/i.target/main.c:100
msgid ""
@@ -13781,6 +13789,9 @@
" OR\n"
" manually enter the variables"
msgstr ""
+"Usare il flag \"mapset e location correnti\" (-c)\n"
+" OPPURE\n"
+" inserire manualmente le variabili"
#: ../imagery/i.vpoints/plot.c:61 ../imagery/i.vpoints/plot.c:143
#: ../display/d.graph/do_graph.c:415
@@ -13794,7 +13805,7 @@
#: ../imagery/i.topo.corr/correction.c:100
#, c-format
msgid "Minnaert constant = %lf"
-msgstr ""
+msgstr "Costante di Minnaert = %lf"
#: ../imagery/i.topo.corr/correction.c:105
#, c-format
@@ -13807,12 +13818,11 @@
#: ../imagery/i.topo.corr/main.c:86
msgid "imagery, terrain, topographic correction"
-msgstr ""
+msgstr "immagini, terreno, correzione topografica"
#: ../imagery/i.topo.corr/main.c:94
-#, fuzzy
msgid "Name of reflectance raster maps to be corrected topographically"
-msgstr "Nome dei raster da unire insieme"
+msgstr "Nome delle mappe raster di riflettanza da correggere topograficamente"
#: ../imagery/i.topo.corr/main.c:98
msgid "Name (flag -i) or prefix for output raster maps"
@@ -13824,45 +13834,45 @@
#: ../imagery/i.topo.corr/main.c:108
msgid "Solar zenith in degrees"
-msgstr ""
+msgstr "Zenit del sole in gradi"
#: ../imagery/i.topo.corr/main.c:114
msgid "Solar azimuth in degrees (only if flag -i)"
-msgstr ""
+msgstr "Azimut del sole in gradi (solo col flag -i)"
#: ../imagery/i.topo.corr/main.c:121
msgid "Topographic correction method"
-msgstr ""
+msgstr "Metodo di correzione topografica"
+# terrain model ?
#: ../imagery/i.topo.corr/main.c:126
-#, fuzzy
msgid "Output sun illumination terrain model"
-msgstr "Output sono gli errori dell'interpolazione "
+msgstr "Produce un modello di illuminazione del terreno"
#: ../imagery/i.topo.corr/main.c:132
msgid "Solar azimuth is necessary to calculate illumination terrain model"
-msgstr ""
+msgstr "L'azimut del sole è necessario per calcolre il modello di illuminazione del terreno"
#: ../imagery/i.topo.corr/main.c:135
msgid "Reflectance maps are necessary to make topographic correction"
-msgstr ""
+msgstr "Le mappe di riflettanza son necessarie per effettuare la correzione topografica"
#: ../imagery/i.topo.corr/main.c:167
msgid "Elevation raster map of unknown type"
-msgstr "Raster dell'elavazione di tipologia sconosciuta"
+msgstr "Raster dell'elevazione di tipologia sconosciuta"
#: ../imagery/i.topo.corr/main.c:201
msgid "Illumination model is of CELL type"
-msgstr ""
+msgstr "Il modello di illuminazione è di tipo CELL"
#: ../imagery/i.topo.corr/main.c:208
#, c-format
msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-msgstr "Raster della riflettanza <%s> non è DCELL - ignorato"
+msgstr "La riflettanza della mappa raster <%s> non è di tipo DCELL - ignorato"
#: ../imagery/i.ifft/ifftmain.c:68 ../imagery/i.fft/fftmain.c:74
msgid "imagery, FFT"
-msgstr ""
+msgstr "immagini, FFT"
#: ../imagery/i.ifft/ifftmain.c:70
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
@@ -14562,7 +14572,7 @@
#: ../imagery/i.pca/main.c:307
#, c-format
msgid "Computing row %d (of %d) of covariance matrix..."
-msgstr ""
+msgstr "Calcolo della riga %d (di %d) della matrice di covarianza in corso..."
#: ../imagery/i.pca/main.c:324
msgid "Unable to allocate memory for row buffer"
@@ -14575,7 +14585,7 @@
#: ../imagery/i.pca/main.c:395
#, c-format
msgid "Transforming <%s>..."
-msgstr "Sto trasformando <%s>..."
+msgstr "Trasformazione di <%s> in corso..."
#: ../imagery/i.pca/main.c:414
#, c-format
@@ -14637,7 +14647,7 @@
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:54
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:55
msgid "imagery, orthorectify"
-msgstr ""
+msgstr "immagini, ortorettificare"
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
@@ -14731,7 +14741,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:64
msgid "Interactively select or modify the target elevation model."
-msgstr ""
+msgstr "Seleziona o modifica interattivamente il modello di elevazione di destinazione."
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:68
#: ../imagery/i.ortho.photo/menu/menu.c:48
@@ -14740,15 +14750,16 @@
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:60
#: ../imagery/i.ortho.photo/i.photo.camera/main.c:61
msgid "Name of imagery group for ortho-rectification"
-msgstr ""
+msgstr "Nome del gruppo di immagini per l'ortorettificazione"
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:91
#, c-format
msgid "Target information for group [%s] missing\n"
-msgstr ""
+msgstr "Informazione mancante per il gruppo [%s]\n"
+# target?
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
-#, fuzzy, c-format
+#, c-format
msgid "Target location [%s] not found\n"
msgstr "Location di destinazione [%s] non trovata\n"
@@ -14767,7 +14778,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:131
msgid "Please select a target for group"
-msgstr ""
+msgstr "Selezionare una destinazione per il gruppo"
#: ../imagery/i.ortho.photo/menu/menu.c:44
msgid "Menu driver for the photo imagery programs."
@@ -14780,7 +14791,7 @@
#: ../imagery/i.ortho.photo/menu/menu.c:68
msgid "Enter imagery group for ortho-rectification"
-msgstr ""
+msgstr "Inserire il gruppo di immagini per l'ortorettificazione"
#: ../imagery/i.ortho.photo/menu/menu.c:74
#, c-format
@@ -14796,12 +14807,12 @@
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:50
#, c-format
msgid "Orthorectification cancelled"
-msgstr ""
+msgstr "Ortorettificazione annulata"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:49
#, c-format
msgid "No files in this group!"
-msgstr ""
+msgstr "Nessun file in questo gruppo!"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:61
msgid ""
@@ -14817,6 +14828,8 @@
"\n"
"Rectify image <%s>? "
msgstr ""
+"\n"
+"Rettificare l'immagine <%s>? "
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:84
#, c-format
@@ -14824,31 +14837,37 @@
"\n"
"No images selected, orthorectification cancelled."
msgstr ""
+"\n"
+"Nessuna immagine selezionata, ortorettificazione annullata."
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:99
msgid "Enter an extension to be appended to rectified maps:"
-msgstr ""
+msgstr "Inserire un'estensione da aggiungere alle mappe rettificate:"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:110
msgid ""
"\n"
"Choose another extension? "
msgstr ""
+"\n"
+"Scegliere un'altra estensione? "
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:122
msgid ""
"\n"
"Compute local camera angle? "
msgstr ""
+"\n"
+"Calcorare l'angolo di ripresa locale? "
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:132
msgid "Enter a name for the camera angle map:"
-msgstr ""
+msgstr "Inserire un nome per la mappa degli angoli di ripresa:"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:141
#, c-format
msgid "Map name <%s> is illegal"
-msgstr "Nome della mappa <%s> non è valido"
+msgstr "Il nome della mappa <%s> non è valido"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:142
msgid ""
@@ -14863,6 +14882,8 @@
"\n"
"Overwrite maps in target location/mapset? "
msgstr ""
+"\n"
+"Sovrascrivere le mappe in location/mapset di destinazione? "
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:224
#, c-format
@@ -14879,8 +14900,9 @@
msgid " 2. bilinear\n"
msgstr " 2. bilineare\n"
+# bicubica/bicubico?
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:227
-#, fuzzy, c-format
+#, c-format
msgid " 3. bicubic\n"
msgstr " 3. bicubica\n"
@@ -19696,7 +19718,7 @@
#: ../vector/v.random/main.c:136 ../vector/v.edit/args.c:216
#: ../vector/v.in.dxf/main.c:74
msgid "Do not build topology"
-msgstr "Non costruisce la topologia"
+msgstr "Non costruire la topologia"
#: ../vector/v.random/main.c:142
msgid "v.random can't create 3D vector and attribute table at same time"
@@ -21699,7 +21721,7 @@
# FINIRE
#: ../vector/v.out.ascii/b2a.c:150
-#, fuzzy, c-format
+#, c-format
msgid "got type %d"
msgstr "ottenuto il tipo %d"
@@ -21871,7 +21893,7 @@
#: ../vector/v.build/main.c:55
msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
-msgstr ""
+msgstr "build;costruisce la topologia;dump;scrive la topologia sullo stdout;sdump; scrive l'indice spaziale sullo stdout;cdump;scrive l'indice delle categorie sullo stdout"
#: ../vector/v.edit/args.c:38
msgid "Name of vector map to edit"
@@ -21879,7 +21901,7 @@
#: ../vector/v.edit/args.c:54
msgid "Tool"
-msgstr "Strumenti"
+msgstr "Strumento"
#: ../vector/v.edit/args.c:55
msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
@@ -21895,7 +21917,7 @@
#: ../vector/v.edit/args.c:112
msgid "Difference in x,y direction for moving feature or vertex"
-msgstr ""
+msgstr "Differenza nella direzione x, y per lo spostamento di un elemento o vertice"
#: ../vector/v.edit/args.c:119
msgid "Threshold distance (coords,snap,query)"
@@ -21911,11 +21933,11 @@
#: ../vector/v.edit/args.c:146
msgid "Bounding box for selecting features"
-msgstr ""
+msgstr "Limiti del riquadro per la selezione di elementi"
#: ../vector/v.edit/args.c:155
msgid "Polygon for selecting features"
-msgstr ""
+msgstr "Poligono per la selezione di elementi"
#: ../vector/v.edit/args.c:165
msgid "Query tool"
@@ -21939,15 +21961,17 @@
#: ../vector/v.edit/args.c:187
msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
-msgstr ""
+msgstr "no;Non applicare la cattura;node;Cattura solo i nodi;vertex;Abilita anche la cattura dei vertici"
+# FINIRE
#: ../vector/v.edit/args.c:195
+#, fuzzy
msgid "Starting value and step for z bulk-labeling"
-msgstr ""
+msgstr "Valore iniziale e passo per l'etichettatura di massa "
#: ../vector/v.edit/args.c:196
msgid "Pair: value,step (e.g. 1100,10)"
-msgstr ""
+msgstr "Coppia: valore, passo (p.es. 1100,10)"
#: ../vector/v.edit/args.c:201 ../vector/v.extract/main.c:106
#: ../vector/v.select/args.c:88
@@ -21956,15 +21980,15 @@
#: ../vector/v.edit/args.c:207
msgid "Close added boundaries (using threshold distance)"
-msgstr ""
+msgstr "Chiudere i confini aggiunti (usando la distanza di soglia)"
#: ../vector/v.edit/args.c:211
msgid "Do not expect header of input data"
-msgstr ""
+msgstr "Non attendere l'intestazione dei dati di input"
#: ../vector/v.edit/args.c:221
msgid "Modify only first found feature in bounding box"
-msgstr ""
+msgstr "Modificare solo il primo elemento trovato nel riquadro"
#: ../vector/v.edit/args.c:233
msgid "Polygon must have at least 3 coordinate pairs"
@@ -21985,7 +22009,7 @@
#: ../vector/v.edit/args.c:336
#, c-format
msgid "Tool %s requires option %s"
-msgstr ""
+msgstr "Lo strumento %s richiede l'opzione %s"
#: ../vector/v.edit/snap.c:111 ../vector/v.edit/a2b.c:328
#, c-format
@@ -21994,7 +22018,7 @@
#: ../vector/v.edit/main.c:55
msgid "vector, editing, geometry"
-msgstr ""
+msgstr "vettoriale, modifica, geometria"
#: ../vector/v.edit/main.c:56
msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
@@ -22012,7 +22036,7 @@
#: ../vector/v.edit/main.c:98
msgid "Creating new DB connection based on default mapset settings..."
-msgstr ""
+msgstr "Creazione di una nuova connessione al DB basata sulle impostazioni del mapset predefinito in corso..."
#: ../vector/v.edit/main.c:130 ../vector/v.kcv/main.c:137
#, c-format
@@ -22035,12 +22059,12 @@
#: ../vector/v.edit/main.c:220
msgid "No features selected, nothing to edit"
-msgstr ""
+msgstr "Nessun elemento selezionato, nulla da modificare"
#: ../vector/v.edit/main.c:228
#, c-format
msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
-msgstr ""
+msgstr "La mappa vettoriale <%s> non è 3D. Lo strumento '%s' richiede una mappa vettoriale 3D. Convertire la mappa vettoriale in 3D, p.es. usando %s."
#: ../vector/v.edit/main.c:266
#, c-format
@@ -22052,7 +22076,7 @@
#: ../vector/v.edit/main.c:359
#, c-format
msgid "Threshold value for snapping is %.2f"
-msgstr ""
+msgstr "Il valore di soglia per la cattura è %.2f"
#: ../vector/v.edit/main.c:277
#, c-format
@@ -22117,7 +22141,7 @@
#: ../vector/v.edit/main.c:365
#, c-format
msgid "%d lines flipped"
-msgstr ""
+msgstr "%d linee invertite"
#: ../vector/v.edit/main.c:385
#, c-format
@@ -22154,7 +22178,7 @@
#: ../vector/v.edit/select.c:500
msgid "Layer must be > 0 for 'where'"
-msgstr ""
+msgstr "Layer dev'essere > 0 per 'where'"
#: ../vector/v.edit/a2b.c:85 ../vector/v.edit/a2b.c:123
#: ../vector/v.edit/a2b.c:147
@@ -22164,11 +22188,11 @@
#: ../vector/v.edit/a2b.c:136 ../vector/v.in.ascii/a2b.c:103
msgid "End of ASCII file reached before end of coordinates"
-msgstr ""
+msgstr "È stata raggiunta la fine del file ACII prima della fine delle coordinate"
#: ../vector/v.edit/a2b.c:178
msgid "End of ascii file reached before end of categories"
-msgstr ""
+msgstr "È stata raggiunta la fine del file ACII prima della fine delle categorie"
#: ../vector/v.edit/a2b.c:189
#, c-format
@@ -22178,12 +22202,12 @@
#: ../vector/v.edit/a2b.c:236
#, c-format
msgid "Unexpected data in vector head: '%s'"
-msgstr ""
+msgstr "Dati inattesi nell'intestazione del vettore: '%s' "
#: ../vector/v.edit/a2b.c:270
#, c-format
msgid "Unknown keyword '%s' in vector head"
-msgstr ""
+msgstr "Parola chiave '%s' sconosciuta nell'intestazione del vettoriale"
#: ../vector/v.in.dwg/main.c:66
msgid "Converts DWG/DXF to GRASS vector map"
@@ -22195,7 +22219,7 @@
#: ../vector/v.in.dwg/main.c:79 ../vector/v.in.dxf/main.c:107
msgid "List of layers to import"
-msgstr ""
+msgstr "Elenco dei tematismi da importare"
#: ../vector/v.in.dwg/main.c:84 ../vector/v.in.dxf/main.c:88
msgid "Invert selection by layers (don't import layers in list)"
@@ -22212,7 +22236,7 @@
#: ../vector/v.in.dwg/main.c:96 ../vector/v.in.dxf/main.c:82
#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
msgid "List available layers and exit"
-msgstr "Elenca i layer disponibili ed esce"
+msgstr "Elenca i tematismi disponibili ed esce"
#: ../vector/v.in.dwg/main.c:100
msgid "Use numeric type for attribute \"layer\""
@@ -22343,9 +22367,8 @@
msgstr "Impossibile aggiornare la tabella"
#: ../vector/v.digit/line.c:55
-#, fuzzy
msgid "Form"
-msgstr "Formato"
+msgstr ""
#: ../vector/v.digit/line.c:64
msgid "New record was created.<BR>"
@@ -22358,7 +22381,7 @@
#: ../vector/v.digit/line.c:138
#, c-format
msgid "Digitize new %s:"
-msgstr ""
+msgstr "Digitalizza nuovo %s:"
#: ../vector/v.digit/line.c:140 ../vector/v.digit/line.c:224
#: ../vector/v.digit/line.c:253
@@ -22379,17 +22402,16 @@
#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:302
#: ../vector/v.digit/attr.c:398 ../vector/v.digit/attr.c:403
#: ../vector/v.digit/attr.c:407 ../vector/v.digit/attr.c:463
-#, fuzzy
msgid "Quit tool"
-msgstr "Strumento interrogazione"
+msgstr "Strumento di uscita"
#: ../vector/v.digit/line.c:191
msgid "Out of memory! Point not added."
-msgstr ""
+msgstr "Memoria insufficiente! Punto non aggiunto."
#: ../vector/v.digit/line.c:246
msgid "Less than 2 points for line -> nothing written"
-msgstr ""
+msgstr "La linea ha meno di 2 punti --> nessun elemento disegnato"
msgid "Undo last point"
@@ -22397,9 +22419,8 @@
#: ../vector/v.digit/line.c:253 ../vector/v.digit/line.c:337
#: ../vector/v.digit/line.c:386
-#, fuzzy
msgid "Close line"
-msgstr "Chiusura non riuscita."
+msgstr "Concludi la linea"
#: ../vector/v.digit/line.c:337 ../vector/v.digit/line.c:386
#: ../vector/v.digit/line.c:407
@@ -22411,13 +22432,12 @@
msgstr "Annulla ultimo punto"
-#, fuzzy
msgid "Delete line and exit"
-msgstr "Mostra le tabelle ed esce"
+msgstr "Cancella la linea ed esci"
#: ../vector/v.digit/line.c:480
msgid "Delete point, line, boundary, or centroid:"
-msgstr ""
+msgstr "Cancella punto, linea, confine o centroide:"
#: ../vector/v.digit/line.c:481 ../vector/v.digit/line.c:566
#: ../vector/v.digit/line.c:620 ../vector/v.digit/line.c:705
@@ -22438,32 +22458,32 @@
#: ../vector/v.digit/line.c:564 ../vector/v.digit/vertex.c:130
#: ../vector/v.digit/vertex.c:303
msgid "Confirm and select next"
-msgstr ""
+msgstr "Conferma e seleziona il prossimo"
#: ../vector/v.digit/line.c:619
msgid "Move point, line, boundary, or centroid:"
-msgstr ""
+msgstr "Muovi punto, linea, confine o centroide:"
#: ../vector/v.digit/line.c:671 ../vector/v.digit/vertex.c:633
msgid "New location"
-msgstr "Nuova location"
+msgstr "Nuova posizione"
#: ../vector/v.digit/vertex.c:35
msgid "Split line:"
-msgstr ""
+msgstr "Spezza la linea:"
#: ../vector/v.digit/vertex.c:199
msgid "Remove vertex:"
-msgstr ""
+msgstr "Rimuovi vertice:"
#: ../vector/v.digit/vertex.c:200 ../vector/v.digit/vertex.c:220
#: ../vector/v.digit/vertex.c:325
msgid "Select vertex"
-msgstr ""
+msgstr "Seleziona vertice"
#: ../vector/v.digit/vertex.c:372
msgid "Add vertex:"
-msgstr ""
+msgstr "Aggiungi vertice:"
#: ../vector/v.digit/vertex.c:471
msgid "New vertex"
@@ -22471,7 +22491,7 @@
#: ../vector/v.digit/vertex.c:569
msgid "Move vertex:"
-msgstr ""
+msgstr "Muovi vertice:"
#: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
#, c-format
@@ -22509,12 +22529,11 @@
#: ../vector/v.digit/c_face.c:294 ../vector/v.db.connect/main.c:336
#, c-format
msgid "Cannot grant privileges on table %s"
-msgstr "Permessi non sufficienti per accedere alla tabella %s"
+msgstr "Non è possibile assegnare i permessi sulla tabella %s"
#: ../vector/v.digit/c_face.c:295
-#, fuzzy
msgid "Cannot grant privileges on table:\n"
+msgstr "Non è possibile assegnare i permessi sulla tabella:\n"
#: ../vector/v.digit/c_face.c:312
msgid "Cannot add database link to vector, link for given field probably already exists."
@@ -22548,12 +22567,11 @@
#: ../vector/v.digit/attr.c:302 ../vector/v.digit/attr.c:407
msgid "Select source object"
-msgstr ""
+msgstr "Seleziona oggetto origine"
#: ../vector/v.digit/attr.c:396 ../vector/v.digit/attr.c:402
-#, fuzzy
msgid "Select the target object"
-msgstr "Imposta il colore del testo"
+msgstr "Seleziona oggetto destinazione"
#: ../vector/v.digit/attr.c:397
msgid "Conform and select next"
@@ -22561,11 +22579,11 @@
msgid "Deselect Target"
-msgstr ""
+msgstr "Deseleziona Destinazione"
#: ../vector/v.digit/attr.c:403
msgid "Deselect Source"
-msgstr ""
+msgstr "Deselezione Origine"
#: ../vector/v.digit/attr.c:462
msgid "Display attributes:"
@@ -22597,7 +22615,7 @@
#: ../vector/v.digit/attr.c:668
#, c-format
msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
-msgstr ""
+msgstr "Non ci sono altri elementi con categoria %d (layer %d) nella mappa, ma c'è la riga nella tabella. Eliminare la riga?"
#: ../vector/v.digit/attr.c:680
#, c-format
@@ -22629,52 +22647,52 @@
#: ../vector/v.digit/generate.c:110
#, c-format
msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-msgstr ""
+msgstr "Non è possibile aprire il cursore selezionato:<BR>'%s'<BR>sul database '%s' col driver '%s'<BR>"
#: ../vector/v.digit/generate.c:121
#, fuzzy
msgid "Cannot fetch next record"
msgstr "Impossibile inserire il nuovo record: %s"
+# di database
#: ../vector/v.digit/generate.c:130
-#, fuzzy
msgid "No database record"
-msgstr "Driver del database:"
+msgstr "Nessun record nel database"
#: ../vector/v.digit/generate.c:223
#, c-format
msgid "<HR> Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
msgstr ""
+# editing ?
#: ../vector/v.digit/main.c:104
msgid "vector, editing, digitization"
-msgstr ""
+msgstr "vettoriale, editing, digitalizzazione"
#: ../vector/v.digit/main.c:106
msgid "Interactive editing and digitization of vector maps."
-msgstr ""
+msgstr "Modifica interattiva e digitalizzazione di mappe vettoriali."
#: ../vector/v.digit/main.c:121
msgid "Create new file if it does not exist."
-msgstr ""
+msgstr "Crea un nuovo file se non esiste."
#: ../vector/v.digit/main.c:150
msgid "New empty map created."
-msgstr ""
+msgstr "Creata una nuova mappa vuota."
#: ../vector/v.digit/main.c:157
#, c-format
msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-msgstr ""
+msgstr "La mappa <%s> non esiste nel mapset corrente. Aggiungere il flag -n per creare una nuova mappa."
#: ../vector/v.digit/centre.c:56
-#, fuzzy
msgid "Select tool"
-msgstr "Selezione"
+msgstr "Strumento di selezione"
#: ../vector/v.digit/centre.c:178
msgid "Region restored to original extent."
-msgstr ""
+msgstr "Regione ripristinata all'estensione originale."
#: ../vector/v.digit/var.c:80 ../vector/v.digit/var.c:101
#: ../vector/v.digit/var.c:122
@@ -22683,34 +22701,34 @@
msgstr "Impossibile impostare la variabile code = %d"
#: ../vector/v.digit/var.c:143
-#, fuzzy, c-format
+#, c-format
msgid "Cannot get type of variable %s"
-msgstr "Non riesco a mostrare i database:\n"
+msgstr "Non è possibile ottenere il tipo della variabile %s"
#: ../vector/v.digit/var.c:164
-#, fuzzy, c-format
+#, c-format
msgid "Cannot get code of variable %s"
+msgstr "Non è possibile ottenere il codice della variabile %s"
#: ../vector/v.digit/var.c:184
-#, fuzzy, c-format
+#, c-format
msgid "Cannot get name of variable %d"
+msgstr "Non è possibile ottenere il nome della variabile %d"
#: ../vector/v.digit/var.c:199 ../vector/v.digit/var.c:215
#: ../vector/v.digit/var.c:231
-#, fuzzy, c-format
+#, c-format
msgid "Cannot get value of variable code = %d"
+msgstr "Non è possibile ottenere il valore della variabile = %d"
#: ../vector/v.digit/zoom.c:26
msgid "Zoom by window"
-msgstr ""
+msgstr "Ingrandisci l'area con un riquadro"
#: ../vector/v.digit/zoom.c:27 ../vector/v.digit/zoom.c:44
#: ../vector/v.digit/zoom.c:75
msgid "1. corner"
-msgstr ""
+msgstr "1. angolo"
#: ../vector/v.digit/zoom.c:75 ../vector/v.digit/zoom.c:158
@@ -22719,20 +22737,20 @@
#: ../vector/v.digit/zoom.c:44
msgid "2. corner"
-msgstr ""
+msgstr "2. angolo"
#: ../vector/v.digit/zoom.c:157
msgid "Pan"
-msgstr ""
+msgstr "Sposta finestra"
#: ../vector/v.digit/zoom.c:158
msgid "New center"
msgstr "Nuovo centro"
#: ../vector/v.digit/zoom.c:247
-#, fuzzy, c-format
+#, c-format
msgid "Cannot find window '%s'"
-msgstr "Impossibile inserire una nuova regola: %s"
+msgstr "Non è possibile trovare la finestra '%s'"
#: ../vector/v.net.alloc/main.c:61
msgid "vector, network, allocation"
@@ -24041,33 +24059,28 @@
msgstr "Nome della mappa vettoriale di input contenente le linee"
#: ../vector/v.net.flow/main.c:77
-#, fuzzy
msgid "Name of arc forward/both direction(s) capacity column"
-msgstr "Colonna costo direzione avanti/entrambe per gli archi"
+msgstr "Nome della colonna capacità direzione avanti/entrambe per gli archi"
#: ../vector/v.net.flow/main.c:82
-#, fuzzy
msgid "Name of arc backward direction capacity column"
-msgstr "Colonna costo direzione indietro per gli archi"
+msgstr "Nome della colonna capacità direzione indietro per gli archi"
#: ../vector/v.net.flow/main.c:86
-#, fuzzy
msgid "Source layer number or name"
-msgstr "Numero del layer da interrogare (da cui leggere)"
+msgstr "Numero del layer delle sorgenti o nome"
#: ../vector/v.net.flow/main.c:91
-#, fuzzy
msgid "Source category values"
-msgstr "Problemi nel caricamento dei valori di categoria"
+msgstr "Valori di categoria delle sorgenti"
#: ../vector/v.net.flow/main.c:97
msgid "Source WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
#: ../vector/v.net.flow/main.c:102
-#, fuzzy
msgid "Sink layer number or name"
-msgstr "Numero del layer (da)"
+msgstr "Numero del layer dei pozzi o nome"
#: ../vector/v.net.flow/main.c:103 ../vector/v.net.flow/main.c:108
#: ../vector/v.net.flow/main.c:114
@@ -24075,9 +24088,8 @@
msgstr ""
#: ../vector/v.net.flow/main.c:107
-#, fuzzy
msgid "Sink category values"
+msgstr "Valori di categoria dei pozzi"
#: ../vector/v.net.flow/main.c:113
msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
@@ -24091,14 +24103,12 @@
msgstr ""
#: ../vector/v.net.flow/main.c:199
-#, fuzzy
msgid "No sources"
-msgstr "Origine"
+msgstr "Nessuna sorgente"
#: ../vector/v.net.flow/main.c:202
-#, fuzzy
msgid "No sinks"
-msgstr "Nessun punto di partenza"
+msgstr "Nessun pozzo"
#: ../vector/v.net.flow/main.c:224
msgid "Writing the output..."
@@ -24996,12 +25006,12 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:289
#, c-format
msgid "Mean = %.5lf"
-msgstr ""
+msgstr "Media = %.5lf"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:290
#, c-format
msgid "Root Means Square (RMS) = %.5lf"
-msgstr ""
+msgstr "Media quadratica (RMS) = %.5lf"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:306
msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
@@ -25023,7 +25033,7 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:319
#, c-format
msgid " %-10.5f| %-12.4f| %-12.4f|"
-msgstr ""
+msgstr " %-10.5f| %-12.4f| %-12.4f|"
#: ../vector/lidar/v.surf.bspline/crosscorr.c:327
msgid "No point lies into the current region"
@@ -25082,7 +25092,7 @@
#: ../vector/v.reclass/main.c:63
msgid "vector, reclass, attributes"
-msgstr ""
+msgstr "vettoriale, riclassificazione, attributi"
#: ../vector/v.reclass/main.c:65
msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
@@ -25178,7 +25188,7 @@
#: ../vector/v.neighbors/main.c:48
msgid "vector, raster, aggregation"
-msgstr ""
+msgstr "vettoriale, raster, aggregazione"
#: ../vector/v.net.timetable/main.c:218
#, c-format
@@ -26521,9 +26531,8 @@
msgstr ""
#: ../vector/v.net.components/main.c:87
-#, fuzzy
msgid "Type of components"
-msgstr "Tipo di tavola dei colori"
+msgstr "Tipo di componenti"
#: ../vector/v.to.3d/args.c:11
msgid "Reverse transformation; 3D vector features to 2D"
@@ -27845,14 +27854,12 @@
msgstr ""
#: ../vector/v.net.connectivity/main.c:66
-#, fuzzy
msgid "Name of node capacity column"
-msgstr "Nome della colonna"
+msgstr "Nome della colonna capacità per i nodi"
#: ../vector/v.net.connectivity/main.c:70
-#, fuzzy
msgid "Set1 layer number or name"
+msgstr "Numero del layer o nome di set1"
#: ../vector/v.net.connectivity/main.c:71
#: ../vector/v.net.connectivity/main.c:76
@@ -27861,18 +27868,16 @@
msgstr ""
#: ../vector/v.net.connectivity/main.c:75
-#, fuzzy
msgid "Set1 category values"
+msgstr "Valori di categoria di set1"
#: ../vector/v.net.connectivity/main.c:81
msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
#: ../vector/v.net.connectivity/main.c:86
-#, fuzzy
msgid "Set2 layer number or name"
+msgstr "Numero del layer o nome di set2"
#: ../vector/v.net.connectivity/main.c:87
#: ../vector/v.net.connectivity/main.c:92
@@ -27881,9 +27886,8 @@
msgstr ""
#: ../vector/v.net.connectivity/main.c:91
-#, fuzzy
msgid "Set2 category values"
+msgstr "Valori di categoria di set2"
#: ../vector/v.net.connectivity/main.c:97
msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
@@ -28302,10 +28306,10 @@
msgid "Unable to open database: "
msgstr "Impossibile aprire il database: "
+# FINIRE
#: ../db/drivers/sqlite/db.c:110
-#, fuzzy
msgid "SQLite database connection is still busy"
-msgstr "Connessione al database non definita"
+msgstr "La connessione al database SQLite è ancora impegnata"
#: ../db/drivers/sqlite/describe.c:160
#, c-format
@@ -30011,9 +30015,8 @@
msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:2
-#, fuzzy
msgid "miscellaneous, projection"
-msgstr "N"
+msgstr ""
#: ../locale/scriptstrings/m.proj_to_translate.c:3
msgid "Input coordinate file (omit to read from stdin)"
