[GRASS-SVN] r51562 - grass/trunk/vector
Fri Apr 27 11:24:25 EDT 2012
Author: neteler
Date: 2012-04-27 08:24:25 -0700 (Fri, 27 Apr 2012)
New Revision: 51562
   grass/trunk/vector/vectorintro.html
fixed patch mess
Modified: grass/trunk/vector/vectorintro.html
--- grass/trunk/vector/vectorintro.html	2012-04-27 15:16:02 UTC (rev 51561)
+++ grass/trunk/vector/vectorintro.html	2012-04-27 15:24:25 UTC (rev 51562)
@@ -178,9 +178,9 @@
 appear in that layer. In this fashion some vector objects may appear
 in some layers but not in others. Taking the example of the fields
 and paths, only some boundaries, but not all, might have a category
-value in layer 2. With <em>option=report</em>, <a href=
-    +"v.category.html">v.category</a> lists available categories in each
-layer.
+value in layer 2. With <em>option=report</em>,
+<a href="v.category.html">v.category</a> lists available categories
+in each layer.
 <br>
 Optionally, each layer can (but does not have
 to) be linked to an attribute table. The link is made by the
@@ -192,7 +192,6 @@
 In most modules, the first layer (<em>layer=1</em>) is active by
 default. Using <em>layer=-1</em> one can access all layers.
 </li>
-<br><br></li>
 <li><b>SQL support</b><br>
 The DBF driver provides only very limited SQL support (as DBF is not an
