[GRASS-SVN] r51563 - grass/trunk/vector/v.buffer
Sat Apr 28 13:19:37 EDT 2012
Author: mmetz
Date: 2012-04-28 10:19:36 -0700 (Sat, 28 Apr 2012)
New Revision: 51563
Added:
   grass/trunk/vector/v.buffer/geos.c
   grass/trunk/vector/v.buffer/main.c
v.buffer: use GEOS
Added: grass/trunk/vector/v.buffer/geos.c
--- grass/trunk/vector/v.buffer/geos.c	                        (rev 0)
+++ grass/trunk/vector/v.buffer/geos.c	2012-04-28 17:19:36 UTC (rev 51563)
@@ -0,0 +1,128 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#ifdef HAVE_GEOS
+static int ring2pts(const GEOSGeometry *geom, struct line_pnts *Points)
+    int i, ncoords;
+    double x, y, z;
+    const GEOSCoordSequence *seq = NULL;
+    G_debug(3, "ring2pts()");
+    z = 0.0;
+    ncoords = GEOSGetNumCoordinates(geom);
+    if (!ncoords)
+	G_warning(_("No coordinates in GEOS geometry!"));
+    seq = GEOSGeom_getCoordSeq(geom);
+    for (i = 0; i < ncoords; i++) {
+	GEOSCoordSeq_getX(seq, i, &x);
+	GEOSCoordSeq_getY(seq, i, &y);
+	Vect_append_point(Points, x, y, z);
+    return 1;
+static int geom2ring(GEOSGeometry *geom, struct line_pnts **oPoints,
+		       struct line_pnts ***iPoints, int *inner_count)
+    int i, nrings, ngeoms, count;
+    const GEOSGeometry *geom2;
+    struct line_pnts *Points, **arrPoints = *iPoints;
+    if (GEOSGeomTypeId(geom) == GEOS_LINESTRING ||
+        GEOSGeomTypeId(geom) == GEOS_LINEARRING) {
+	Points = *oPoints;
+	if (Points->n_points == 0)
+	    ring2pts(geom, Points);
+	else {
+	    count = *inner_count + 1;
+	    arrPoints = G_realloc(arrPoints, count * sizeof(struct line_pnts *));
+	    arrPoints[*inner_count] = Vect_new_line_struct();
+	    ring2pts(geom, arrPoints[*inner_count]);
+	    *inner_count = count;
+	    *iPoints = arrPoints;
+    else if (GEOSGeomTypeId(geom) == GEOS_POLYGON) {
+	geom2 = GEOSGetExteriorRing(geom);
+	    ring2pts(geom2, Points);
+	else {
+	    ring2pts(geom2, arrPoints[*inner_count]);
+	nrings = GEOSGetNumInteriorRings(geom);
+	if (nrings > 0) {
+	    count = *inner_count + nrings;
+	    for (i = 0; i < nrings; i++) {
+		geom2 = GEOSGetInteriorRingN(geom, i);
+		arrPoints[*inner_count + i] = Vect_new_line_struct();
+		ring2pts(geom2, arrPoints[*inner_count + i]);
+    else if (GEOSGeomTypeId(geom) == GEOS_MULTILINESTRING ||
+             GEOSGeomTypeId(geom) == GEOS_MULTIPOLYGON ||
+	     GEOSGeomTypeId(geom) == GEOS_GEOMETRYCOLLECTION) {
+	ngeoms = GEOSGetNumGeometries(geom);
+	for (i = 0; i < ngeoms; i++) {
+	    geom2 = GEOSGetGeometryN(geom, i);
+	    geom2ring((GEOSGeometry *)geom2, oPoints, iPoints, inner_count);
+    else
+	G_fatal_error(_("Unknown GEOS geometry type"));
+    return 1;
+int geos_buffer(struct Map_info *In, int id, int type, double da,
+                GEOSBufferParams *buffer_params, struct line_pnts **oPoints,
+    GEOSGeometry *IGeom = NULL;
+    GEOSGeometry *OGeom = NULL;
+    *oPoints = Vect_new_line_struct();
+    *iPoints = NULL;
+    *inner_count = 0;
+    if (type == GV_AREA)
+	IGeom = Vect_read_area_geos(In, id);
+    else
+	IGeom = Vect_read_line_geos(In, id, &type);
+    OGeom = GEOSBufferWithParams(IGeom, buffer_params, da);
+    if (!OGeom)
+	G_warning(_("Buffering failed"));
+    geom2ring(OGeom, oPoints, iPoints, inner_count);
+    if (IGeom)
+	GEOSGeom_destroy(IGeom);
+    if (OGeom)
+	GEOSGeom_destroy(OGeom);
+    return 1;
+#endif /* HAVE_GEOS */
Property changes on: grass/trunk/vector/v.buffer/geos.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2012-04-27 15:24:25 UTC (rev 51562)
+++ grass/trunk/vector/v.buffer/main.c	2012-04-28 17:19:36 UTC (rev 51563)
@@ -34,6 +34,11 @@
 #define MAX(X,Y) ((X>Y)?X:Y)
 #endif
+#ifdef HAVE_GEOS
+int geos_buffer(struct Map_info *, int, int, double,
+                GEOSBufferParams *, struct line_pnts **,
+		struct line_pnts ***, int *);
+#endif
 /* returns 1 if unit_tolerance is adjusted, 0 otherwise */
 int adjust_tolerance(double *tolerance)
@@ -200,12 +205,16 @@
     /* Attributes if sizecol is used */
     int nrec, ctype;
-    struct field_info *Fi;
+    struct field_info *Fi = NULL;
     dbDriver *Driver;
     dbCatValArray cvarr;
     double size_val, scale;
+#ifdef HAVE_GEOS
+    GEOSBufferParams *buffer_params = NULL;
+#endif
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("geometry"));
@@ -323,7 +332,7 @@
     if (scale <= 0.0)
 	G_fatal_error("Illegal scale value");
-    da = db = dalpha = 0;
+    da = db = dalpha = unit_tolerance = 0;
     if (dista_opt->answer) {
 	da = atof(dista_opt->answer);
@@ -409,7 +418,7 @@
     /* Create buffers' boundaries */
     nlines = nareas = 0;
     if ((type & GV_POINTS) || (type & GV_LINES))
-	nlines += Vect_get_num_primitives(&In, type);
+	nlines = Vect_get_num_primitives(&In, type);
     if (type & GV_AREA)
 	nareas = Vect_get_num_areas(&In);
@@ -424,12 +433,20 @@
     Vect_spatial_index_init(&si, 0);
+#ifdef HAVE_GEOS
+    initGEOS(G_message, G_fatal_error);
+    buffer_params = GEOSBufferParams_create();
+    GEOSBufferParams_setEndCapStyle(buffer_params, GEOSBUF_CAP_ROUND);
+    GEOSBufferParams_setJoinStyle(buffer_params, GEOSBUF_JOIN_ROUND);
+#endif
     /* Lines (and Points) */
-    if ((type & GV_POINTS) || (type & GV_LINES)) {
+    if (nlines > 0) {
 	int ltype;
-	if (nlines > 0)
-	    G_message(_("Buffering lines..."));
+	G_message(_("Buffering lines..."));
+	nlines = Vect_get_num_lines(&In);
 	for (line = 1; line <= nlines; line++) {
 	    int cat;
@@ -492,12 +509,19 @@
 	    else {
+#ifdef HAVE_GEOS
+		GEOSBufferParams_setMitreLimit(buffer_params, unit_tolerance);
+		geos_buffer(&In, line, type, da, buffer_params, &(arr_bc_pts.oPoints),
+			    &(arr_bc_pts.iPoints), &(arr_bc_pts.inner_count));
+#else
 		Vect_line_buffer2(Points, da, db, dalpha,
 				  !(straight_flag->answer),
 				  !(nocaps_flag->answer), unit_tolerance,
+#endif
 		Vect_write_line(&Out, GV_BOUNDARY, arr_bc_pts.oPoints, BCats);
 		line_id = Vect_write_line(&Buf, GV_BOUNDARY, arr_bc_pts.oPoints, Cats);
@@ -527,11 +551,10 @@
     /* Areas */
-    if (type & GV_AREA) {
+    if (nareas > 0) {
 	int centroid;
-	if (nareas > 0)
-	    G_message(_("Buffering areas..."));
+	G_message(_("Buffering areas..."));
 	for (area = 1; area <= nareas; area++) {
 	    int cat;
@@ -575,12 +598,19 @@
 			unit_tolerance);
+#ifdef HAVE_GEOS
+	    GEOSBufferParams_setSingleSided(buffer_params, 1);
+	    geos_buffer(&In, area, GV_AREA, da, buffer_params, &(arr_bc_pts.oPoints),
+#else
 	    Vect_area_buffer2(&In, area, da, db, dalpha,
+#endif
@@ -608,6 +638,11 @@
+#ifdef HAVE_GEOS
+    GEOSBufferParams_destroy(buffer_params);
+    finishGEOS();
+#endif
     verbose = G_verbose();
     G_message(_("Cleaning buffers..."));
