[GRASS-SVN] r52499 - grass-addons/grass7/raster/r.houghtransform
svn_grass at osgeo.org
Thu Aug 2 03:35:51 PDT 2012
Author: wenzeslaus
Date: 2012-08-02 03:35:50 -0700 (Thu, 02 Aug 2012)
New Revision: 52499
Removed:
grass-addons/grass7/raster/r.houghtransform/matrix.cpp
grass-addons/grass7/raster/r.houghtransform/Makefile
grass-addons/grass7/raster/r.houghtransform/hough.cpp
grass-addons/grass7/raster/r.houghtransform/houghtransform.cpp
grass-addons/grass7/raster/r.houghtransform/houghtransform.h
grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.cpp
grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.h
grass-addons/grass7/raster/r.houghtransform/main.cpp
grass-addons/grass7/raster/r.houghtransform/matrix.h
grass-addons/grass7/raster/r.houghtransform/r.houghtransform.html
r.houghtransform: changing DCELL to CELL using templates and typedefs
Modified: grass-addons/grass7/raster/r.houghtransform/Makefile
--- grass-addons/grass7/raster/r.houghtransform/Makefile 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/Makefile 2012-08-02 10:35:50 UTC (rev 52499)
@@ -11,7 +11,7 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
-EXTRA_CFLAGS = $(VECT_CFLAGS) -Wno-sign-compare -Wall -Wextra -O0
+EXTRA_CFLAGS = $(VECT_CFLAGS) -Wno-sign-compare -Wall -Wextra -O0 -Wconversion
LINK = $(CXX)
Modified: grass-addons/grass7/raster/r.houghtransform/hough.cpp
--- grass-addons/grass7/raster/r.houghtransform/hough.cpp 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/hough.cpp 2012-08-02 10:35:50 UTC (rev 52499)
@@ -22,16 +22,16 @@
using grass::Vect_new_cats_struct;
using grass::Vect_new_line_struct;
-using grass::Rast_allocate_d_input_buf;
+using grass::Rast_allocate_c_input_buf;
using grass::Rast_open_old;
using grass::Rast_get_row;
using grass::Rast_close;
using grass::Rast_window_rows;
using grass::Rast_window_cols;
-using grass::Rast_allocate_d_buf;
+using grass::Rast_allocate_c_buf;
using grass::Rast_open_fp_new;
-using grass::Rast_put_d_row;
+using grass::Rast_put_c_row;
using grass::Rast_get_cellhd;
using grass::G_gettext;
@@ -40,13 +40,14 @@
using grass::G_free;
using grass::Colors;
-using grass::FPRange; // FIXME: DCELL/CELL
+using grass::Range;
using grass::G_mapset;
/** Loads map into memory.
\param[out] mat map in a matrix (row order), field have to be allocated
+template <typename Matrix>
void read_raster_map(const char *name, const char *mapset, int nrows,
int ncols, Matrix& mat)
@@ -55,11 +56,11 @@
int map_fd;
- DCELL *row_buffer;
+ CELL *row_buffer;
- DCELL cell_value;
+ CELL cell_value;
- row_buffer = Rast_allocate_d_input_buf();
+ row_buffer = Rast_allocate_c_buf();
/* load map */
map_fd = Rast_open_old(name, mapset);
@@ -74,11 +75,11 @@
// G_fatal_error(_("Error getting first raster map type"));
for (r = 0; r < nrows; r++) {
- Rast_get_row(map_fd, row_buffer, r, DCELL_TYPE);
+ Rast_get_row(map_fd, row_buffer, r, CELL_TYPE);
for (c = 0; c < ncols; c++) {
cell_value = row_buffer[c];
- if (!Rast_is_d_null_value(&cell_value))
+ if (!Rast_is_c_null_value(&cell_value))
mat(r, c) = cell_value;
else
mat(r, c) = 0.0;
@@ -92,22 +93,23 @@
void apply_hough_colors_to_map(const char *name)
struct Colors colors;
- struct FPRange range;
- DCELL min, max;
+ struct Range range;
+ CELL min, max;
- Rast_read_fp_range(name, G_mapset(), &range);
- Rast_get_fp_range_min_max(&range, &min, &max);
+ Rast_read_range(name, G_mapset(), &range);
+ Rast_get_range_min_max(&range, &min, &max);
Rast_make_grey_scale_colors(&colors, min, max);
Rast_write_colors(name, G_mapset(), &colors);
void create_raster_map(const char *name, struct Cell_head *window, const Matrix& mat)
struct Cell_head original_window;
- DCELL *cell_real;
+ CELL *cell_real;
int rows, cols; /* number of rows and columns */
long totsize; /* total number of data points */ // FIXME: make clear the size_t usage
- int realfd;
+ int mapfd;
/* get the rows and columns in the current window */
rows = mat.rows();
@@ -131,19 +133,19 @@
Rast_set_window(window);
/* allocate the space for one row of cell map data */
- cell_real = Rast_allocate_d_buf();
+ cell_real = Rast_allocate_c_buf();
/* open the output cell maps */
- realfd = Rast_open_fp_new(name);
+ mapfd = Rast_open_fp_new(name);
for (int i = 0; i < rows; i++) {
for (int j = 0; j < cols; j++) {
cell_real[j] = mat(i, j);
- Rast_put_d_row(realfd, cell_real);
+ Rast_put_c_row(mapfd, cell_real);
- Rast_close(realfd);
+ Rast_close(mapfd);
G_free(cell_real);
Rast_set_window(&original_window);
@@ -185,6 +187,7 @@
Vect_close(&Map);
void extract_line_segments(const Matrix &I,
const HoughTransform::Peaks& peaks,
const HoughTransform::TracebackMap& houghMap,
@@ -220,6 +223,7 @@
const char *anglesMapName,
const char *houghImageName, const char *result)
+ typedef matrix::Matrix<DCELL> Matrix;
Matrix I(nrows, ncols);
read_raster_map(name, mapset, nrows, ncols, I);
Modified: grass-addons/grass7/raster/r.houghtransform/houghtransform.cpp
--- grass-addons/grass7/raster/r.houghtransform/houghtransform.cpp 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/houghtransform.cpp 2012-08-02 10:35:50 UTC (rev 52499)
@@ -29,17 +29,17 @@
mNumR = mOriginalMatrix.rows();
mNumC = mOriginalMatrix.columns();
- mThetas = ColumnVector(matrix::Range(-M_PI/2.0, M_PI/2.0, M_PI/180.0).matrix_value ());
+ mThetas = ColumnVector(Range(-M_PI/2.0, M_PI/2.0, M_PI/180.0).matrix_value ());
const float diag_length = std::sqrt(mNumR*mNumR + mNumC*mNumC);
mNumBins = ceil(diag_length) - 1;
mHoughMatrix = Matrix(mNumBins, mThetas.length(), 0.0);
- c2 = ceil(mNumC/2.);
- r2 = ceil(mNumR/2.);
+ c_2 = ceil(mNumC/2.);
+ r_2 = ceil(mNumR/2.);
- bins0 = 1 - ceil(mNumBins/2.0);
+ first_bins = 1 - ceil(mNumBins/2.0);
/* functions */
@@ -64,10 +64,10 @@
for (size_t i = minIndex; i < maxIndex; i++)
const double theta = mThetas(i);
- const double cT = cos(theta);
- const double sT = sin(theta);
- const int rho = (int) floor(cT*(x - c2) + sT*(y - r2) + 0.5);
- const int bin = (int) (rho - bins0);
+ const double rho_d = std::cos(theta)*(x - c_2) + std::sin(theta)*(y - r_2);
+ const int rho = floor(rho_d + 0.5);
+ const int bin = rho - first_bins;
if ((bin > 0) && (bin < mNumBins))
mHoughMatrix(bin, i)++;
@@ -198,7 +198,7 @@
/** \param list[in, out] will be sorted by y cooridinate
if angle is in range (45, 135] or by x otherwise
-bool HoughTransform::findEndPoints(CoordinatesList& list, Coordinates &beginLine, Coordinates &endLine, const int angle)
+bool HoughTransform::findEndPoints(CoordinatesList& list, Coordinates &beginLine, Coordinates &endLine, const value_type angle)
if (angle > 45 && angle <= 135)
@@ -221,7 +221,7 @@
size_t colIndex;
std::vector<size_t> colIndexes;
- std::vector<double> rowMax = matrix.row_max(colIndexes);
+ std::vector<value_type> rowMax = matrix.row_max(colIndexes);
int max = 0;
for (size_t i = 0; i < rowMax.size(); i++)
Modified: grass-addons/grass7/raster/r.houghtransform/houghtransform.h
--- grass-addons/grass7/raster/r.houghtransform/houghtransform.h 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/houghtransform.h 2012-08-02 10:35:50 UTC (rev 52499)
@@ -14,13 +14,14 @@
#include <stdio.h>
-using namespace matrix;
class HoughTransform
public:
/* types */
+ typedef double value_type;
+ typedef matrix::Matrix<value_type> Matrix;
+ typedef matrix::ColumnVector<double> ColumnVector;
+ typedef matrix::Range<double> Range;
/** This is class to provide compatible syntax with \c std::list. */
template <typename T>
@@ -52,7 +53,7 @@
struct Peak
- Peak(Coordinates coordinates, int value, Coordinates begin, Coordinates end)
+ Peak(Coordinates coordinates, value_type value, Coordinates begin, Coordinates end)
: coordinates(coordinates), value(value), beginLine(begin), endLine(end)
Coordinates coordinates;
@@ -94,7 +95,7 @@
// some of these functions can be changed to non-member
CoordinatesList neighbourhood(Coordinates &coordinates, const int sizeOfNeighbourhood);
void removePeakEffect(const CoordinatesList &neighbours, Coordinates &beginLine, Coordinates &endLine);
- bool findEndPoints(CoordinatesList& list, Coordinates &beginLine, Coordinates &endLine, const int angle);
+ bool findEndPoints(CoordinatesList& list, Coordinates &beginLine, Coordinates &endLine, const value_type angle);
int findMax(const Matrix& matrix, Coordinates &coordinates);
void computeHoughForXY(int x, int y, size_t minIndex, size_t maxIndex);
@@ -106,15 +107,16 @@
TracebackMap mHoughMap;
Peaks mPeaks;
+ HoughParametres mParams;
+ /* helper variables for computations */
int mNumR;
int mNumC;
ColumnVector mThetas;
int mNumBins;
- int c2;
- int r2;
- int bins0;
- HoughParametres mParams;
+ int c_2;
+ int r_2;
+ int first_bins;
Modified: grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.cpp
--- grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.cpp 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.cpp 2012-08-02 10:35:50 UTC (rev 52499)
@@ -32,6 +32,7 @@
return true;
+template<typename Matrix>
bool isData(const Matrix &I, const std::vector<int> &y, const std::vector<int> &x, const int cols, const int rows)
for (size_t k = 0; k < y.size(); k++)
@@ -125,7 +126,7 @@
/* member functions */
void LineSegmentsExtractor::extract(LineCoordinates lineCoordinates,
- float orient,
+ const double orient,
SegmentList& segments)
const int rows = mImage.rows();
Modified: grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.h
--- grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.h 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/linesegmentsextractor.h 2012-08-02 10:35:50 UTC (rev 52499)
@@ -16,11 +16,14 @@
class LineSegmentsExtractor
public:
\param image should exist during existence of LineSegmentsExtractor
\param lineCoordinates will be copied to internal variable
- LineSegmentsExtractor(const matrix::Matrix& image,
+ LineSegmentsExtractor(const Matrix& image,
const ExtractParametres& parametres)
: mImage(image),
gapSize(parametres.gapSize), maxNumOfGaps(parametres.maxNumOfGaps),
@@ -33,10 +36,10 @@
\param orient orientation of lines
\param[out] segments extracted segments will be added to this list
- void extract(LineCoordinates lineCoordinates, const float orient, SegmentList& segments);
+ void extract(LineCoordinates lineCoordinates, const double orient, SegmentList& segments);
private:
- const matrix::Matrix &mImage;
+ const Matrix &mImage;
int gapSize;
int maxNumOfGaps;
int lineGap;
Modified: grass-addons/grass7/raster/r.houghtransform/main.cpp
--- grass-addons/grass7/raster/r.houghtransform/main.cpp 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/main.cpp 2012-08-02 10:35:50 UTC (rev 52499)
@@ -5,7 +5,7 @@
* AUTHOR(S): Anna Kratochvilova - kratochanna gmail.com
* Vaclav Petras - wenzeslaus gmail.com
- * PURPOSE: Line extraction from edges in raster.
+ * PURPOSE: Line segment extraction using Hough transformation.
* COPYRIGHT: (C) 2012 by the GRASS Development Team
@@ -37,7 +37,7 @@
int main(int argc, char *argv[])
struct Cell_head cell_head; /* it stores region information,
- and header information of rasters */
+ and header information of rasters */
char *name; /* input raster name */
char *mapset; /* mapset name */
@@ -52,7 +52,7 @@
struct Option *input, *output, *anglesOption, *houghImageNameOption,
*angleWidthOption,
*minGapOption, *maxNumberOfGapsOption,
- *maxLinesOption, *maxGapOption, *minSegmentLengthOption,
+ *maxLinesOption, *maxGapOption, *minSegmentLengthOption,
*lineWidthOption;
/* initialize GIS environment */
@@ -62,10 +62,11 @@
module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("hought"));
- G_add_keyword(_(""));
+ G_add_keyword(_("ht"));
module->description =
- _("Canny edge detector. Region shall be set to input map. "
- "Can work only on small images since map is loaded into memory.");
+ _("Perform Hough transformation and extracts line segments from image."
+ " Region shall be set to input map."
+ " Can work only on small images since map is loaded into memory.");
/* Define the different options as defined in gis.h */
input = G_define_standard_option(G_OPT_R_INPUT);
@@ -147,30 +148,31 @@
/* options and flags parser */
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
/* stores options and flags to variables */
result = output->answer;
name = input->answer;
- ExtractParametres extractParametres;
HoughParametres houghParametres;
houghParametres.maxPeaksNum = atoi(maxLinesOption->answer);
- houghParametres.threshold = 10;
+ houghParametres.threshold = 10; // TODO: consider option
houghParametres.angleWidth = atoi(angleWidthOption->answer);
+ houghParametres.sizeOfNeighbourhood = 1; // TODO: consider option
+ ExtractParametres extractParametres;
extractParametres.gapSize = atoi(minGapOption->answer);
extractParametres.maxGap = atoi(maxGapOption->answer);
extractParametres.maxNumOfGaps = atoi(maxNumberOfGapsOption->answer);
extractParametres.lineLength = atoi(minSegmentLengthOption->answer);
extractParametres.lineWidth = atoi(lineWidthOption->answer);
- houghParametres.sizeOfNeighbourhood = 1;
/* returns NULL if the map was not found in any mapset,
* mapset name otherwise */
mapset = (char *)G_find_raster2(name, "");
if (mapset == NULL)
- G_fatal_error(_("Raster map <%s> not found"), name);
+ G_fatal_error(_("Raster map <%s> not found"), name);
/* determine the inputmap type (CELL/FCELL/DCELL) */
//data_type = Rast_map_type(name, mapset);
Deleted: grass-addons/grass7/raster/r.houghtransform/matrix.cpp
Modified: grass-addons/grass7/raster/r.houghtransform/matrix.h
--- grass-addons/grass7/raster/r.houghtransform/matrix.h 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/matrix.h 2012-08-02 10:35:50 UTC (rev 52499)
@@ -10,21 +10,24 @@
namespace matrix {
+template <typename T>
class Matrix
public:
- Matrix(size_t r, size_t c, double val = 0)
+ typedef T value_type;
+ Matrix(size_t r, size_t c, value_type val = 0)
: mRows(r), mCols(c)
resize(r, c, val);
Matrix() : mRows(0), mCols(0) {}
- void resize(size_t r, size_t c, double val = 0)
+ void resize(size_t r, size_t c, value_type val = 0)
mRows = r;
mCols = c;
- std::vector<double> row;
+ std::vector<value_type> row;
row.resize(c, val);
mat.resize(r, row);
@@ -33,7 +36,7 @@
if (r > rows() || c > columns()) error;
- double& operator ()(size_t r, size_t c)
+ value_type& operator ()(size_t r, size_t c)
return mat[r][c];
@@ -41,22 +44,22 @@
- const double& operator ()(size_t r, size_t c) const
+ const value_type& operator ()(size_t r, size_t c) const
return mat[r][c];
size_t rows() const { return mRows; }
size_t columns() const { return mCols; }
- std::vector<double> row_max(std::vector<size_t>& colIndexes) const
+ std::vector<value_type> row_max(std::vector<size_t>& colIndexes) const
- std::vector<double> ret;
+ std::vector<value_type> ret;
ret.reserve(rows());
colIndexes.reserve(rows());
for (size_t i = 0; i < rows(); ++i)
- std::vector<double>::const_iterator maxe = std::max_element(mat[i].begin(), mat[i].end());
- double max = *maxe;
+ typename std::vector<value_type>::const_iterator maxe = std::max_element(mat[i].begin(), mat[i].end());
+ value_type max = *maxe;
size_t maxi = maxe - mat[i].begin();
ret.push_back(max);
@@ -66,15 +69,18 @@
private:
- std::vector< std::vector<double> > mat;
+ std::vector< std::vector<value_type> > mat;
size_t mRows;
size_t mCols;
class ColumnVector
public:
- ColumnVector(Matrix mat)
+ ColumnVector(Matrix<value_type> mat)
for (size_t i = 0; i < mat.columns(); ++i)
@@ -83,23 +89,26 @@
ColumnVector() {}
- double& operator ()(size_t i)
+ value_type& operator ()(size_t i)
return vec[i];
- const double& operator ()(size_t i) const
+ const value_type& operator ()(size_t i) const
return vec[i];
size_t length() { return vec.size(); }
private:
- std::vector<double> vec;
+ std::vector<value_type> vec;
class Range
public:
Range (double b, double l, double i)
: rng_base(b), rng_limit(l), rng_inc(i), rng_nelem(nelem_internal())
@@ -108,9 +117,9 @@
: rng_base(b), rng_limit(l), rng_inc(1),
rng_nelem(nelem_internal()) { }
- Matrix matrix_value() const
+ Matrix<value_type> matrix_value() const
- Matrix cache;
+ Matrix<value_type> cache;
//if (rng_nelem > 0 && cache.nelem () == 0)
cache.resize(1, rng_nelem);
Modified: grass-addons/grass7/raster/r.houghtransform/r.houghtransform.html
--- grass-addons/grass7/raster/r.houghtransform/r.houghtransform.html 2012-08-01 15:57:31 UTC (rev 52498)
+++ grass-addons/grass7/raster/r.houghtransform/r.houghtransform.html 2012-08-02 10:35:50 UTC (rev 52499)
@@ -16,3 +16,4 @@
Vaclav Petras
<p><i>Last changed: $Date$</i>
