[GRASS-SVN] r52500 - grass-addons/grass7/raster/r.houghtransform
svn_grass at osgeo.org
Thu Aug 2 04:27:51 PDT 2012
Author: annakrat
Date: 2012-08-02 04:27:51 -0700 (Thu, 02 Aug 2012)
New Revision: 52500
grass-addons/grass7/raster/r.houghtransform/hough.cpp
r.houghtransform: fixed categories
Modified: grass-addons/grass7/raster/r.houghtransform/hough.cpp
--- grass-addons/grass7/raster/r.houghtransform/hough.cpp 2012-08-02 10:35:50 UTC (rev 52499)
+++ grass-addons/grass7/raster/r.houghtransform/hough.cpp 2012-08-02 11:27:51 UTC (rev 52500)
@@ -161,28 +161,33 @@
Vect_open_new(&Map, name, 0);
struct grass::line_cats *Cats;
+ struct grass::line_pnts *points;
Cats = Vect_new_cats_struct();
+ points = Vect_new_line_struct();
for (size_t i = 0; i < segments.size(); ++i)
const Segment& seg = segments[i];
- struct grass::line_pnts *points = Vect_new_line_struct(); // FIXME: some destroy
double y1 = Rast_row_to_northing(seg.first.first, cellhd);
double x1 = Rast_col_to_easting(seg.first.second, cellhd);
double y2 = Rast_row_to_northing(seg.second.first, cellhd);
double x2 = Rast_col_to_easting(seg.second.second, cellhd);
+ Vect_reset_cats(Cats);
Vect_cat_set(Cats, 1, i+1); // cat is segment number (counting from one)
+ Vect_reset_line(points);
Vect_append_point(points, x1, y1, 0);
Vect_append_point(points, x2, y2, 0);
Vect_write_line(&Map, GV_LINE, points, Cats);
+ Vect_destroy_cats_struct(Cats);
+ Vect_destroy_line_struct(points);
Vect_build(&Map);
Vect_close(&Map);
