[GRASS-SVN] r52562 - in grass-addons/grass6/imagery: . i.despeckle
svn_grass at osgeo.org
Mon Aug 6 07:30:28 PDT 2012
Author: neteler
Date: 2012-08-06 07:30:28 -0700 (Mon, 06 Aug 2012)
New Revision: 52562
Added:
grass-addons/grass6/imagery/i.despeckle/
grass-addons/grass6/imagery/i.despeckle/Makefile
grass-addons/grass6/imagery/i.despeckle/description.html
grass-addons/grass6/imagery/i.despeckle/i.despeckle
grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_after.png
grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_before.png
new module for SAR despeckling
Added: grass-addons/grass6/imagery/i.despeckle/Makefile
--- grass-addons/grass6/imagery/i.despeckle/Makefile (rev 0)
+++ grass-addons/grass6/imagery/i.despeckle/Makefile 2012-08-06 14:30:28 UTC (rev 52562)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=i.despeckle
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/imagery/i.despeckle/description.html
--- grass-addons/grass6/imagery/i.despeckle/description.html (rev 0)
+++ grass-addons/grass6/imagery/i.despeckle/description.html 2012-08-06 14:30:28 UTC (rev 52562)
@@ -0,0 +1,45 @@
+<h2>DESCRIPTION</h2>
+<em>i.despeckle</em> despeckles a SAR image. Currently only the GAMMA filter is
+implemented.
+<h2>EXAMPLE</h2>
+Despeckling of a PALSAR image:
+<div class="code"><pre>
+g.region rast=PASL1500605241533341106080000_2006 -p
+i.despeckle PASL1500605241533341106080000_2006 \
+ out=PASL1500605241533341106080000_2006.gamma3
+</pre></div>
+Result:
+<p>
+<center>
+ <table border=1>
+ <tr>
+ <td align=center>
+ <img src="i_despeckle_gamma_before.png" alt="PALSAR image before despeckling">
+ <br>
+ <font size="-1">
+ <i>PALSAR image before despeckling</i>
+ </font>
+ </td>
+ <td align=center>
+ <img src="i_despeckle_gamma_after.png" alt="PALSAR image after despeckling">
+ <br>
+ <font size="-1">
+ <i>PALSAR image after despeckling</i>
+ </font>
+ </td>
+ </tr>
+ </table>
+</center>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/imagery/i.despeckle/description.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Added: grass-addons/grass6/imagery/i.despeckle/i.despeckle
--- grass-addons/grass6/imagery/i.despeckle/i.despeckle (rev 0)
+++ grass-addons/grass6/imagery/i.despeckle/i.despeckle 2012-08-06 14:30:28 UTC (rev 52562)
@@ -0,0 +1,136 @@
+#!/bin/sh
+# MODULE: i.despeckle
+# AUTHOR(S): Markus Neteler
+# PURPOSE: FGAMMA -- Gamma SAR Speckle Filter, based on
+# http://web.archive.org/web/20050826071553/http://www.pcigeomatics.com/cgi-bin/pcihlp/M_FGAMMA
+# COPYRIGHT: (C) 2012 GRASS Development Team/Markus Neteler
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%Module
+#% description: Applies GAMMA SAR Speckle Filter to map.
+#% keywords: imagery, filter, despeckle
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input raster map
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output raster map
+#% gisprompt: new,cell,raster
+#%End
+#%Option
+#% key: method
+#% type: string
+#% required: no
+#% multiple: no
+#% options: gamma
+#% description: Despeckle operation
+#% answer: gamma
+#%End
+#%Option
+#% key: size
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Neighborhood size
+#% answer: 3
+#%End
+#%Option
+#% key: looks
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Number of looks (1: single look)
+#% answer: 1
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+if [ $# -lt 1 -o "$1" = "help" -o "$1" = "-help" -o "$1" = "-h" ] ; then
+ echo "Usage: $0 sar_map"
+ exit 1
+fi
+MAP=$GIS_OPT_INPUT
+WIN=$GIS_OPT_SIZE
+NumberLooks=$GIS_OPT_LOOKS
+OUTPUT=$GIS_OPT_OUTPUT
+# S = standard deviation of intensity within window
+r.neighbors in=$MAP out=$MAP.stddev method=stddev size=$WIN
+# Im = mean value of intensity within window
+r.neighbors in=$MAP out=$MAP.mean method=average size=$WIN
+# Ci = S / Im
+r.mapcalc "$MAP.ci = $MAP.stddev / $MAP.mean"
+# Cu = SQRT(1/NumberLooks)
+Cu="`echo $NumberLooks | awk '{printf "%f", sqrt(1/$1)}'`"
+# Cmax = SQRT(2)*Cu
+Cmax="`echo $Cu | awk '{printf "%f", sqrt(2) * $1}'`"
+# A = (1+Cu^2)/(Ci^2-Cu^2)
+r.mapcalc "$MAP.A = (1 + $Cu^2)/($MAP.ci^2 - $Cu^2)"
+# B = A-NumberLooks-1
+r.mapcalc "$MAP.B = $MAP.A - $NumberLooks - 1"
+# D = Im*Im*B*B + 4*A*NumberLooks*Im*Ic
+# Ic = center pixel in filter window
+r.mapcalc "$MAP.D = $MAP.mean * $MAP.mean * $MAP.B * $MAP.B + 4 * $MAP.A * $NumberLooks * $MAP.mean * $MAP"
+# Rf = (B*Im + SQRT(D))/(2*A)
+r.mapcalc "$MAP.rf = ($MAP.B * $MAP.mean + sqrt($MAP.D)) / (2 * $MAP.A)"
+# R1 = Im for Ci <= Cu
+# R2 = Rf for Cu < Ci < Cmax
+# R3 = Ic for Ci >= Cmax
+r.mapcalc "$OUTPUT = eval(r1 = $MAP.mean, r2 = $MAP.rf, r3 = $MAP, \\
+ if($MAP.ci < $Cu, r1, \\
+ if($MAP.ci > $Cu && $MAP.ci < $Cmax, r2, \\
+ if($MAP.ci > $Cmax, r3, null() ) \\
+r.colors $OUTPUT col=grey -e
+g.remove --q rast=$MAP.mean,$MAP.stddev,$MAP.rf,$MAP.ci,$MAP.A,$MAP.B,$MAP.D
+echo "Written <$OUTPUT>"
Property changes on: grass-addons/grass6/imagery/i.despeckle/i.despeckle
Added: svn:executable
+ text/x-sh
+ native
Added: grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_after.png
(Binary files differ)
Property changes on: grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_after.png
+ image/png
Added: grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_before.png
Property changes on: grass-addons/grass6/imagery/i.despeckle/i_despeckle_gamma_before.png
+ image/png
